Entry point of procedure clReleaseDevice not found
VirusCorona
Post by VirusCorona »
Hello,
I'm often getting notifications that Entry point of procedure clReleaseDevice wasn't found in the library. It happens after I had to restart my laptop on Thursday evening, because it didn't respond (it sometimes happens when it's on for some time and I'm not using it). But I don't know if it haven't happened before that. After that I had 370 points, now I have 380. How can I fix it? Or, if this error doesn't matter (computations are still useful), how can I disable that notification? Here's my log (cut because of characters limit):
08:29:57:***********************************************************************
08:46:34:WU00:FS01:Connecting to 65.254.110.245:8080
08:46:34:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:46:34:WU00:FS01:Connecting to 18.218.241.186:80
08:46:35:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:46:35:ERROR:WU00:FS01:Exception: Could not get an assignment
08:51:20:WU01:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
08:57:39:WU00:FS01:Connecting to 65.254.110.245:8080
08:57:40:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:57:40:WU00:FS01:Connecting to 18.218.241.186:80
08:57:40:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:57:40:ERROR:WU00:FS01:Exception: Could not get an assignment
09:15:36:WU00:FS01:Connecting to 65.254.110.245:8080
09:15:36:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:15:36:WU00:FS01:Connecting to 18.218.241.186:80
09:15:37:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:15:37:ERROR:WU00:FS01:Exception: Could not get an assignment
09:19:49:WU01:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
09:44:38:WU00:FS01:Connecting to 65.254.110.245:8080
09:44:38:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:44:38:WU00:FS01:Connecting to 18.218.241.186:80
09:44:39:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:44:39:ERROR:WU00:FS01:Exception: Could not get an assignment
09:48:45:WU01:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
10:11:44:60:127.0.0.1:New Web connection
10:12:07:FS00:Shutting core down
10:12:07:WU00:FS01:Connecting to 65.254.110.245:8080
10:12:07:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 6168
10:12:07:WU01:FS00:0xa7:Exiting, please wait. . .
10:12:08:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:12:08:WU00:FS01:Connecting to 18.218.241.186:80
10:12:08:WU00:FS01:Assigned to work server 128.252.203.10
10:12:08:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [GeForce 610M] from 128.252.203.10
10:12:08:WU00:FS01:Connecting to 128.252.203.10:8080
10:12:22:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
10:12:22:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:12:22:WU01:FS00:Starting
10:12:22:WARNING:WU01:FS00:Changed SMP threads from 3 to 2 this can cause some work units to fail
10:12:22:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -np 2
10:12:22:WU01:FS00:Started FahCore on PID 3256
10:12:23:WU01:FS00:Core PID:5556
10:12:23:WU01:FS00:FahCore 0xa7 started
10:12:23:WU01:FS00:0xa7:*********************** Log Started 2020-03-20T10:12:23Z ***********************
10:12:23:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:12:23:WU01:FS00:0xa7:       Type: 0xa7
10:12:23:WU01:FS00:0xa7:       Core: Gromacs
10:12:23:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 3256 -checkpoint 15 -np 2
10:12:23:WU01:FS00:0xa7:************************************ CBang *************************************
10:12:23:WU01:FS00:0xa7:       Date: Oct 26 2019
10:12:23:WU01:FS00:0xa7:       Time: 01:38:25
10:12:23:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:12:23:WU01:FS00:0xa7:     Branch: master
10:12:23:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
10:12:23:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:12:23:WU01:FS00:0xa7:   Platform: win32 10
10:12:23:WU01:FS00:0xa7:       Bits: 64
10:12:23:WU01:FS00:0xa7:       Mode: Release
10:12:23:WU01:FS00:0xa7:************************************ System ************************************
10:12:23:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-2328M CPU @ 2.20GHz
10:12:23:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
10:12:23:WU01:FS00:0xa7:       CPUs: 4
10:12:23:WU01:FS00:0xa7:     Memory: 7.45GiB
10:12:23:WU01:FS00:0xa7:Free Memory: 2.82GiB
10:12:23:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
10:12:23:WU01:FS00:0xa7: OS Version: 6.2
10:12:23:WU01:FS00:0xa7:Has Battery: true
10:12:23:WU01:FS00:0xa7: On Battery: false
10:12:23:WU01:FS00:0xa7: UTC Offset: 1
10:12:23:WU01:FS00:0xa7:        PID: 5556
10:12:23:WU01:FS00:0xa7:        CWD: C:\Users\my_username\AppData\Roaming\FAHClient\work
10:12:23:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
10:12:23:WU01:FS00:0xa7:    Version: 0.0.18
10:12:23:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:12:23:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:12:23:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
10:12:23:WU01:FS00:0xa7:       Time: 01:52:30
10:12:23:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:12:23:WU01:FS00:0xa7:************************************ Build *************************************
10:12:23:WU01:FS00:0xa7:       SIMD: avx_256
10:12:23:WU01:FS00:0xa7:********************************************************************************
10:12:23:WU01:FS00:0xa7:Project: 14328 (Run 5, Clone 3411, Gen 10)
10:12:23:WU01:FS00:0xa7:Unit: 0x0000000c9bf7a4d65e6d0f362d34abe0
10:12:23:WU01:FS00:0xa7:Digital signatures verified
10:12:23:WU01:FS00:0xa7:Calling: mdrun -s frame10.tpr -o frame10.trr -cpi state.cpt -cpt 15 -nt 2
10:12:29:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
10:12:29:WU00:FS01:Connecting to 128.252.203.10:80
10:12:38:Saving configuration to config.xml
10:12:38:<config>
10:12:38:  <!-- Slot Control -->
10:12:38:  <power v='MEDIUM'/>
10:12:38:
10:12:38:  <!-- User Information -->
10:12:38:  <team v='44851'/>
10:12:38:
10:12:38:  <!-- Folding Slots -->
10:12:38:  <slot id='0' type='CPU'/>
10:12:38:  <slot id='1' type='GPU'/>
10:12:38:</config>
10:12:38:WU01:FS00:0xa7:Steps: first=2500000 total=250000
10:12:43:WU01:FS00:0xa7:Completed 139722 out of 250000 steps (55%)
10:12:50:ERROR:WU00:FS01:Exception: Failed to connect to 128.252.203.10:80: Próba połączenia nie powiodła się, ponieważ połączona strona nie odpowiedziała poprawnie po ustalonym okresie czasu lub utworzone połączenie nie powiodło się, ponieważ połączony host nie odpowiedział.
10:13:44:WU00:FS01:Connecting to 65.254.110.245:8080
10:13:45:WU00:FS01:Assigned to work server 155.247.164.213
10:13:45:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [GeForce 610M] from 155.247.164.213
10:13:45:WU00:FS01:Connecting to 155.247.164.213:8080
10:13:48:WU00:FS01:Downloading 4.52MiB
10:13:53:WU00:FS01:Download complete
10:13:53:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11755 run:0 clone:147 gen:9 core:0x22 unit:0x0000000d9bf7a4d55e6d76dff4d21c31
10:13:53:WU00:FS01:Starting
10:13:53:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:13:53:WU00:FS01:Started FahCore on PID 4524
10:13:53:WU00:FS01:Core PID:6196
10:13:53:WU00:FS01:FahCore 0x22 started
10:13:55:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:13:55:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
10:13:55:WU00:FS01:Starting
10:13:55:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:13:55:WU00:FS01:Started FahCore on PID 5572
10:13:55:WU00:FS01:Core PID:1044
10:13:55:WU00:FS01:FahCore 0x22 started
10:13:57:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:13:57:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
10:14:55:WU00:FS01:Starting
10:14:55:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:14:55:WU00:FS01:Started FahCore on PID 5944
10:14:55:WU00:FS01:Core PID:2136
10:14:55:WU00:FS01:FahCore 0x22 started
10:14:57:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:14:57:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
10:15:08:WU01:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
10:15:55:WU00:FS01:Starting
10:15:55:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:15:55:WU00:FS01:Started FahCore on PID 5472
10:15:55:WU00:FS01:Core PID:6164
10:15:55:WU00:FS01:FahCore 0x22 started
10:15:57:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:15:57:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
10:16:55:WU00:FS01:Starting
10:16:55:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:16:55:WU00:FS01:Started FahCore on PID 6968
10:16:55:WU00:FS01:Core PID:4024
10:16:56:WU00:FS01:FahCore 0x22 started
10:16:57:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:16:57:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
10:16:57:WARNING:WU00:FS01:Too many errors, failing
10:16:57:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:11755 run:0 clone:147 gen:9 core:0x22 unit:0x0000000d9bf7a4d55e6d76dff4d21c31
10:16:57:WU00:FS01:Connecting to 155.247.164.213:8080
10:16:57:WU02:FS01:Connecting to 65.254.110.245:8080
10:16:57:WU00:FS01:Server responded WORK_ACK (400)
10:16:58:WU00:FS01:Cleaning up
10:16:58:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:16:58:WU02:FS01:Connecting to 18.218.241.186:80
10:16:59:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:16:59:ERROR:WU02:FS01:Exception: Could not get an assignment
10:17:00:WU02:FS01:Connecting to 65.254.110.245:8080
10:17:00:WU02:FS01:Assigned to work server 13.90.152.57
10:17:00:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [GeForce 610M] from 13.90.152.57
10:17:00:WU02:FS01:Connecting to 13.90.152.57:8080
10:17:22:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:17:22:WU02:FS01:Connecting to 13.90.152.57:80
10:17:43:ERROR:WU02:FS01:Exception: Failed to connect to 13.90.152.57:80: Próba połączenia nie powiodła się, ponieważ połączona strona nie odpowiedziała poprawnie po ustalonym okresie czasu lub utworzone połączenie nie powiodło się, ponieważ połączony host nie odpowiedział.
10:18:00:WU02:FS01:Connecting to 65.254.110.245:8080
10:18:00:WU02:FS01:Assigned to work server 40.114.52.201
10:18:00:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [GeForce 610M] from 40.114.52.201
10:18:00:WU02:FS01:Connecting to 40.114.52.201:8080
10:18:21:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:18:21:WU02:FS01:Connecting to 40.114.52.201:80
10:18:43:ERROR:WU02:FS01:Exception: Failed to connect to 40.114.52.201:80: Próba połączenia nie powiodła się, ponieważ połączona strona nie odpowiedziała poprawnie po ustalonym okresie czasu lub utworzone połączenie nie powiodło się, ponieważ połączony host nie odpowiedział.
10:19:33:FS00:Shutting core down
10:19:33:WU02:FS01:Connecting to 65.254.110.245:8080
10:19:34:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 5556
10:19:34:WU01:FS00:0xa7:Exiting, please wait. . .
10:19:34:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:19:34:WU02:FS01:Connecting to 18.218.241.186:80
10:19:34:WU02:FS01:Assigned to work server 128.252.203.2
10:19:34:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [GeForce 610M] from 128.252.203.2
10:19:34:WU02:FS01:Connecting to 128.252.203.2:8080
10:19:38:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:19:39:WU01:FS00:Starting
10:19:39:WARNING:WU01:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
10:19:39:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -np 3
10:19:39:WU01:FS00:Started FahCore on PID 5920
10:19:39:WU01:FS00:Core PID:6056
10:19:39:WU01:FS00:FahCore 0xa7 started
10:19:39:WU01:FS00:0xa7:*********************** Log Started 2020-03-20T10:19:39Z ***********************
10:19:39:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:19:39:WU01:FS00:0xa7:       Type: 0xa7
10:19:39:WU01:FS00:0xa7:       Core: Gromacs
10:19:39:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 5920 -checkpoint 15 -np 3
10:19:39:WU01:FS00:0xa7:************************************ CBang *************************************
10:19:39:WU01:FS00:0xa7:       Date: Oct 26 2019
10:19:39:WU01:FS00:0xa7:       Time: 01:38:25
10:19:39:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:19:39:WU01:FS00:0xa7:     Branch: master
10:19:39:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
10:19:39:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:19:39:WU01:FS00:0xa7:   Platform: win32 10
10:19:39:WU01:FS00:0xa7:       Bits: 64
10:19:39:WU01:FS00:0xa7:       Mode: Release
10:19:39:WU01:FS00:0xa7:************************************ System ************************************
10:19:39:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-2328M CPU @ 2.20GHz
10:19:39:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
10:19:39:WU01:FS00:0xa7:       CPUs: 4
10:19:39:WU01:FS00:0xa7:     Memory: 7.45GiB
10:19:39:WU01:FS00:0xa7:Free Memory: 3.04GiB
10:19:39:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
10:19:39:WU01:FS00:0xa7: OS Version: 6.2
10:19:39:WU01:FS00:0xa7:Has Battery: true
10:19:39:WU01:FS00:0xa7: On Battery: false
10:19:39:WU01:FS00:0xa7: UTC Offset: 1
10:19:39:WU01:FS00:0xa7:        PID: 6056
10:19:39:WU01:FS00:0xa7:        CWD: C:\Users\my_username\AppData\Roaming\FAHClient\work
10:19:39:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
10:19:39:WU01:FS00:0xa7:    Version: 0.0.18
10:19:39:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:19:39:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:19:39:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
10:19:39:WU01:FS00:0xa7:       Time: 01:52:30
10:19:39:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:19:39:WU01:FS00:0xa7:************************************ Build *************************************
10:19:39:WU01:FS00:0xa7:       SIMD: avx_256
10:19:39:WU01:FS00:0xa7:********************************************************************************
10:19:39:WU01:FS00:0xa7:Project: 14328 (Run 5, Clone 3411, Gen 10)
10:19:39:WU01:FS00:0xa7:Unit: 0x0000000c9bf7a4d65e6d0f362d34abe0
10:19:39:WU01:FS00:0xa7:Digital signatures verified
10:19:39:WU01:FS00:0xa7:Calling: mdrun -s frame10.tpr -o frame10.trr -cpi state.cpt -cpt 15 -nt 3
10:19:45:Saving configuration to config.xml
10:19:45:<config>
10:19:45:  <!-- Slot Control -->
10:19:45:  <power v='FULL'/>
10:19:45:
10:19:45:  <!-- User Information -->
10:19:45:  <team v='44851'/>
10:19:45:
10:19:45:  <!-- Folding Slots -->
10:19:45:  <slot id='0' type='CPU'/>
10:19:45:  <slot id='1' type='GPU'/>
10:19:45:</config>
10:19:45:WU02:FS01:Downloading 79.12MiB
10:19:51:WU02:FS01:Download 5.29%
10:19:53:WU01:FS00:0xa7:Steps: first=2500000 total=250000
10:19:57:WU02:FS01:Download 11.38%
10:19:59:WU01:FS00:0xa7:Completed 140512 out of 250000 steps (56%)
10:20:03:WU02:FS01:Download 17.85%
10:20:09:WU02:FS01:Download 25.51%
10:20:15:WU02:FS01:Download 31.04%
10:20:21:WU02:FS01:Download 35.55%
10:20:27:WU02:FS01:Download 41.23%
10:20:33:WU02:FS01:Download 45.90%
10:20:39:WU02:FS01:Download 49.92%
10:20:45:WU02:FS01:Download 54.27%
10:20:51:WU02:FS01:Download 58.69%
10:20:57:WU02:FS01:Download 63.98%
10:21:03:WU02:FS01:Download 69.28%
10:21:09:WU02:FS01:Download 75.68%
10:21:15:WU02:FS01:Download 82.31%
10:21:21:WU02:FS01:Download 90.37%
10:21:27:WU02:FS01:Download 98.98%
10:21:27:WU02:FS01:Download complete
10:21:27:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14533 run:0 clone:7803 gen:5 core:0x22 unit:0x0000000880fccb025e72f26ff0b89441
10:21:27:WU02:FS01:Starting
10:21:27:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:21:27:WU02:FS01:Started FahCore on PID 4476
10:21:27:WU02:FS01:Core PID:5616
10:21:27:WU02:FS01:FahCore 0x22 started
10:37:24:WU01:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
10:59:38:WU01:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
11:22:38:WU01:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
11:45:29:WU01:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
12:08:55:WU01:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
12:32:38:WU01:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
12:57:03:WU01:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
13:22:02:WU01:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
13:48:07:WU01:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
14:14:57:WU01:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
******************************* Date: 2020-03-20 *******************************
14:42:13:WU01:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
15:07:18:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
15:07:18:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
15:07:19:WU02:FS01:Starting
15:07:19:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:07:19:WU02:FS01:Started FahCore on PID 5628
15:07:19:WU02:FS01:Core PID:4524
15:07:19:WU02:FS01:FahCore 0x22 started
15:10:52:WU01:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
15:21:17:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
15:21:17:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
15:21:18:WU02:FS01:Starting
15:21:18:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:21:18:WU02:FS01:Started FahCore on PID 6312
15:21:18:WU02:FS01:Core PID:5328
15:21:18:WU02:FS01:FahCore 0x22 started
15:24:01:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
15:24:01:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
15:24:02:WU02:FS01:Starting
15:24:02:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:24:02:WU02:FS01:Started FahCore on PID 3824
15:24:02:WU02:FS01:Core PID:1188
15:24:02:WU02:FS01:FahCore 0x22 started
15:24:03:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
15:24:03:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
15:24:24:93:127.0.0.1:New Web connection
15:25:02:WU02:FS01:Starting
15:25:02:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:25:02:WU02:FS01:Started FahCore on PID 3104
15:25:02:WU02:FS01:Core PID:200
15:25:02:WU02:FS01:FahCore 0x22 started
15:25:13:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
15:25:13:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
15:25:13:WARNING:WU02:FS01:Too many errors, failing
15:25:13:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:14533 run:0 clone:7803 gen:5 core:0x22 unit:0x0000000880fccb025e72f26ff0b89441
15:25:13:WU02:FS01:Connecting to 128.252.203.2:8080
15:25:13:WU00:FS01:Connecting to 65.254.110.245:8080
15:25:13:WU02:FS01:Server responded WORK_ACK (400)
15:25:13:WU02:FS01:Cleaning up
15:25:14:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:25:14:WU00:FS01:Connecting to 18.218.241.186:80
15:25:15:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:25:15:ERROR:WU00:FS01:Exception: Could not get an assignment
15:25:15:WU00:FS01:Connecting to 65.254.110.245:8080
15:25:15:WU00:FS01:Assigned to work server 13.90.152.57
15:25:15:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [GeForce 610M] from 13.90.152.57
15:25:15:WU00:FS01:Connecting to 13.90.152.57:8080
15:25:37:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
15:25:37:WU00:FS01:Connecting to 13.90.152.57:80
15:27:13:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:27:13:WU00:FS01:Connecting to 65.254.110.245:8080
15:27:14:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:27:14:WU00:FS01:Connecting to 18.218.241.186:80
15:27:14:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:27:14:ERROR:WU00:FS01:Exception: Could not get an assignment
15:28:51:WU00:FS01:Connecting to 65.254.110.245:8080
15:28:51:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:28:51:WU00:FS01:Connecting to 18.218.241.186:80
15:28:52:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:28:52:ERROR:WU00:FS01:Exception: Could not get an assignment
15:31:28:WU00:FS01:Connecting to 65.254.110.245:8080
15:31:28:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:31:28:WU00:FS01:Connecting to 18.218.241.186:80
15:31:29:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:31:29:ERROR:WU00:FS01:Exception: Could not get an assignment
15:35:42:WU00:FS01:Connecting to 65.254.110.245:8080
15:35:43:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:35:43:WU00:FS01:Connecting to 18.218.241.186:80
15:35:43:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:35:43:ERROR:WU00:FS01:Exception: Could not get an assignment
15:37:46:WU01:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
15:42:34:WU00:FS01:Connecting to 65.254.110.245:8080
15:42:34:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:42:34:WU00:FS01:Connecting to 18.218.241.186:80
15:42:34:WU00:FS01:Assigned to work server 155.247.166.220
15:42:34:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [GeForce 610M] from 155.247.166.220
15:42:34:WU00:FS01:Connecting to 155.247.166.220:8080
15:42:35:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
15:53:39:WU00:FS01:Connecting to 65.254.110.245:8080
15:53:40:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:53:40:WU00:FS01:Connecting to 18.218.241.186:80
15:53:40:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:53:40:ERROR:WU00:FS01:Exception: Could not get an assignment
16:01:26:WU01:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
16:11:36:WU00:FS01:Connecting to 65.254.110.245:8080
16:11:36:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:11:36:WU00:FS01:Connecting to 18.218.241.186:80
16:11:37:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:11:37:ERROR:WU00:FS01:Exception: Could not get an assignment
16:22:16:WU01:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
16:40:38:WU00:FS01:Connecting to 65.254.110.245:8080
16:40:39:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:40:39:WU00:FS01:Connecting to 18.218.241.186:80
16:40:39:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:40:39:ERROR:WU00:FS01:Exception: Could not get an assignment
16:45:23:WU01:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
17:04:12:WU01:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
17:21:19:WU01:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
17:27:37:WU00:FS01:Connecting to 65.254.110.245:8080
17:27:37:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:27:37:WU00:FS01:Connecting to 18.218.241.186:80
17:27:38:WU00:FS01:Assigned to work server 155.247.166.220
17:27:38:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [GeForce 610M] from 155.247.166.220
17:27:38:WU00:FS01:Connecting to 155.247.166.220:8080
17:27:38:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:37:45:WU01:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
17:54:30:WU01:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
18:09:50:WU01:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
18:25:09:WU01:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
18:41:32:WU01:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
18:43:38:WU00:FS01:Connecting to 65.254.110.245:8080
18:43:39:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:43:39:WU00:FS01:Connecting to 18.218.241.186:80
18:43:39:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:43:39:ERROR:WU00:FS01:Exception: Could not get an assignment
18:56:51:WU01:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
19:13:09:WU01:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
19:15:13:143:127.0.0.1:New Web connection
19:28:51:WU01:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
19:44:01:WU01:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
19:59:17:WU01:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
20:14:19:WU01:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
20:29:24:WU01:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
20:44:32:WU01:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
20:46:38:WU00:FS01:Connecting to 65.254.110.245:8080
20:46:38:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:46:38:WU00:FS01:Connecting to 18.218.241.186:80
20:46:39:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:46:39:ERROR:WU00:FS01:Exception: Could not get an assignment
20:59:44:WU01:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
21:14:48:WU01:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
21:29:50:WU01:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
21:44:54:WU01:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
22:00:00:WU01:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
22:15:14:WU01:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
22:30:24:WU01:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
22:45:41:WU01:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
23:02:11:WU01:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
23:17:19:WU01:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
23:32:42:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
23:47:55:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
23:47:56:WU02:FS00:Connecting to 65.254.110.245:8080
23:47:57:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:47:57:WU02:FS00:Connecting to 18.218.241.186:80
23:47:57:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:47:57:ERROR:WU02:FS00:Exception: Could not get an assignment
23:47:57:WU02:FS00:Connecting to 65.254.110.245:8080
23:47:58:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:47:58:WU02:FS00:Connecting to 18.218.241.186:80
23:47:58:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:47:58:ERROR:WU02:FS00:Exception: Could not get an assignment
23:48:58:WU02:FS00:Connecting to 65.254.110.245:8080
23:48:58:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:48:58:WU02:FS00:Connecting to 18.218.241.186:80
23:48:58:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:48:58:ERROR:WU02:FS00:Exception: Could not get an assignment
23:50:35:WU02:FS00:Connecting to 65.254.110.245:8080
23:50:35:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:50:35:WU02:FS00:Connecting to 18.218.241.186:80
23:50:36:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:50:36:ERROR:WU02:FS00:Exception: Could not get an assignment
23:53:12:WU02:FS00:Connecting to 65.254.110.245:8080
23:53:12:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:53:12:WU02:FS00:Connecting to 18.218.241.186:80
23:53:13:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:53:13:ERROR:WU02:FS00:Exception: Could not get an assignment
23:57:26:WU02:FS00:Connecting to 65.254.110.245:8080
23:57:27:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:57:27:WU02:FS00:Connecting to 18.218.241.186:80
23:57:27:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:57:27:ERROR:WU02:FS00:Exception: Could not get an assignment
00:03:16:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
00:03:22:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
00:03:22:WU01:FS00:0xa7:Saving result file frame10.trr
00:03:24:WU01:FS00:0xa7:Saving result file md.log
00:03:25:WU01:FS00:0xa7:Saving result file science.log
00:03:25:WU01:FS00:0xa7:Saving result file traj_comp.xtc
00:03:26:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
00:03:27:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:03:27:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14328 run:5 clone:3411 gen:10 core:0xa7 unit:0x0000000c9bf7a4d65e6d0f362d34abe0
00:03:27:WU01:FS00:Uploading 4.97MiB to 155.247.164.214
00:03:27:WU01:FS00:Connecting to 155.247.164.214:8080
00:03:33:WU01:FS00:Upload 7.55%
00:03:39:WU01:FS00:Upload 27.68%
00:03:45:WU01:FS00:Upload 44.04%
00:03:51:WU01:FS00:Upload 55.36%
00:03:57:WU01:FS00:Upload 67.95%
00:04:03:WU01:FS00:Upload 75.50%
00:04:09:WU01:FS00:Upload 81.79%
00:04:15:WU01:FS00:Upload 89.34%
00:04:17:WU02:FS00:Connecting to 65.254.110.245:8080
00:04:18:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
00:04:18:WU02:FS00:Connecting to 18.218.241.186:80
00:04:18:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:04:18:ERROR:WU02:FS00:Exception: Could not get an assignment
00:04:22:WU01:FS00:Upload 95.63%
00:04:26:WU01:FS00:Upload complete
00:04:26:WU01:FS00:Server responded WORK_ACK (400)
00:04:26:WU01:FS00:Final credit estimate, 559.00 points
00:04:26:WU01:FS00:Cleaning up
00:05:38:WU00:FS01:Connecting to 65.254.110.245:8080
00:05:38:WU00:FS01:Assigned to work server 40.114.52.201
00:05:38:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [GeForce 610M] from 40.114.52.201
00:05:38:WU00:FS01:Connecting to 40.114.52.201:8080
00:05:59:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
00:05:59:WU00:FS01:Connecting to 40.114.52.201:80
00:06:21:ERROR:WU00:FS01:Exception: Failed to connect to 40.114.52.201:80: Próba połączenia nie powiodła się, ponieważ połączona strona nie odpowiedziała poprawnie po ustalonym okresie czasu lub utworzone połączenie nie powiodło się, ponieważ połączony host nie odpowiedział.
00:15:23:WU02:FS00:Connecting to 65.254.110.245:8080
00:15:23:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
00:15:23:WU02:FS00:Connecting to 18.218.241.186:80
00:15:24:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:15:24:ERROR:WU02:FS00:Exception: Could not get an assignment
00:33:20:WU02:FS00:Connecting to 65.254.110.245:8080
00:33:20:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
00:33:20:WU02:FS00:Connecting to 18.218.241.186:80
00:33:21:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:33:21:ERROR:WU02:FS00:Exception: Could not get an assignment
01:02:22:WU02:FS00:Connecting to 65.254.110.245:8080
01:02:22:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
01:02:22:WU02:FS00:Connecting to 18.218.241.186:80
01:02:23:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:02:23:ERROR:WU02:FS00:Exception: Could not get an assignment
01:49:21:WU02:FS00:Connecting to 65.254.110.245:8080
01:49:21:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
01:49:21:WU02:FS00:Connecting to 18.218.241.186:80
01:49:22:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:49:22:ERROR:WU02:FS00:Exception: Could not get an assignment
******************************* Date: 2020-03-21 *******************************
03:05:22:WU02:FS00:Connecting to 65.254.110.245:8080
03:05:22:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:05:22:WU02:FS00:Connecting to 18.218.241.186:80
03:05:23:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:05:23:ERROR:WU02:FS00:Exception: Could not get an assignment
05:08:21:WU02:FS00:Connecting to 65.254.110.245:8080
05:08:22:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:08:22:WU02:FS00:Connecting to 18.218.241.186:80
05:08:23:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:08:23:ERROR:WU02:FS00:Exception: Could not get an assignment
05:27:38:WU00:FS01:Connecting to 65.254.110.245:8080
05:27:38:WU00:FS01:Assigned to work server 40.114.52.201
05:27:38:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [GeForce 610M] from 40.114.52.201
05:27:38:WU00:FS01:Connecting to 40.114.52.201:8080
05:27:59:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:27:59:WU00:FS01:Connecting to 40.114.52.201:80
05:28:36:WU00:FS01:Downloading 29.59MiB
05:28:42:WU00:FS01:Download 10.77%
05:28:48:WU00:FS01:Download 27.67%
05:28:54:WU00:FS01:Download 43.72%
05:29:00:WU00:FS01:Download 57.45%
05:29:06:WU00:FS01:Download 72.45%
05:29:12:WU00:FS01:Download 85.96%
05:29:18:WU00:FS01:Download 98.85%
05:29:18:WU00:FS01:Download complete
05:29:18:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11778 run:0 clone:4673 gen:1 core:0x22 unit:0x00000007287234c95e73c401a9777a22
05:29:18:WU00:FS01:Starting
05:29:18:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
05:29:18:WU00:FS01:Started FahCore on PID 8136
05:29:19:WU00:FS01:Core PID:4464
05:29:19:WU00:FS01:FahCore 0x22 started
08:27:22:WU02:FS00:Connecting to 65.254.110.245:8080
08:27:22:WU02:FS00:Assigned to work server 128.252.203.9
08:27:22:WU02:FS00:Requesting new work unit for slot 00: READY cpu:3 from 128.252.203.9
08:27:22:WU02:FS00:Connecting to 128.252.203.9:8080
08:27:26:WU02:FS00:Downloading 2.16MiB
08:27:28:WU02:FS00:Download complete
08:27:28:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13833 run:0 clone:3738 gen:2 core:0xa7 unit:0x0000000380fccb095e6e55b5edf26d4f
08:27:28:WU02:FS00:Starting
08:27:28:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -np 3
08:27:28:WU02:FS00:Started FahCore on PID 7304
08:27:28:WU02:FS00:Core PID:7732
08:27:28:WU02:FS00:FahCore 0xa7 started
08:27:29:WU02:FS00:0xa7:*********************** Log Started 2020-03-21T08:27:29Z ***********************
08:27:29:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:27:29:WU02:FS00:0xa7:       Type: 0xa7
08:27:29:WU02:FS00:0xa7:       Core: Gromacs
08:27:29:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 7304 -checkpoint 15 -np 3
08:27:29:WU02:FS00:0xa7:************************************ CBang *************************************
08:27:29:WU02:FS00:0xa7:       Date: Oct 26 2019
08:27:29:WU02:FS00:0xa7:       Time: 01:38:25
08:27:29:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:27:29:WU02:FS00:0xa7:     Branch: master
08:27:29:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
08:27:29:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:27:29:WU02:FS00:0xa7:   Platform: win32 10
08:27:29:WU02:FS00:0xa7:       Bits: 64
08:27:29:WU02:FS00:0xa7:       Mode: Release
08:27:29:WU02:FS00:0xa7:************************************ System ************************************
08:27:29:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-2328M CPU @ 2.20GHz
08:27:29:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
08:27:29:WU02:FS00:0xa7:       CPUs: 4
08:27:29:WU02:FS00:0xa7:     Memory: 7.45GiB
08:27:29:WU02:FS00:0xa7:Free Memory: 2.52GiB
08:27:29:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
08:27:29:WU02:FS00:0xa7: OS Version: 6.2
08:27:29:WU02:FS00:0xa7:Has Battery: true
08:27:29:WU02:FS00:0xa7: On Battery: false
08:27:29:WU02:FS00:0xa7: UTC Offset: 1
08:27:29:WU02:FS00:0xa7:        PID: 7732
08:27:29:WU02:FS00:0xa7:        CWD: C:\Users\my_username\AppData\Roaming\FAHClient\work
08:27:29:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
08:27:29:WU02:FS00:0xa7:    Version: 0.0.18
08:27:29:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:27:29:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:27:29:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
08:27:29:WU02:FS00:0xa7:       Time: 01:52:30
08:27:29:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:27:29:WU02:FS00:0xa7:************************************ Build *************************************
08:27:29:WU02:FS00:0xa7:       SIMD: avx_256
08:27:29:WU02:FS00:0xa7:********************************************************************************
08:27:29:WU02:FS00:0xa7:Project: 13833 (Run 0, Clone 3738, Gen 2)
08:27:29:WU02:FS00:0xa7:Unit: 0x0000000380fccb095e6e55b5edf26d4f
08:27:29:WU02:FS00:0xa7:Reading tar file core.xml
08:27:29:WU02:FS00:0xa7:Reading tar file frame2.tpr
08:27:29:WU02:FS00:0xa7:Digital signatures verified
08:27:29:WU02:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -x frame2.xtc -cpt 15 -nt 3
08:27:37:WU02:FS00:0xa7:Steps: first=500000 total=250000
08:27:45:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
08:43:19:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
08:43:19:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
08:43:20:WU00:FS01:Starting
08:43:20:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
08:43:20:WU00:FS01:Started FahCore on PID 8072
08:43:20:WU00:FS01:Core PID:5804
08:43:20:WU00:FS01:FahCore 0x22 started
08:43:22:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
08:43:22:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
08:43:36:176:127.0.0.1:New Web connection
08:44:20:WU00:FS01:Starting
08:44:20:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
08:44:20:WU00:FS01:Started FahCore on PID 7776
08:44:20:WU00:FS01:Core PID:7552
08:44:20:WU00:FS01:FahCore 0x22 started
08:44:23:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
08:44:23:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
08:45:20:WU00:FS01:Starting
08:45:20:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
08:45:20:WU00:FS01:Started FahCore on PID 7276
08:45:20:WU00:FS01:Core PID:2104
08:45:20:WU00:FS01:FahCore 0x22 started
08:47:02:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
09:07:24:WU02:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
09:27:30:WU02:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
09:47:40:WU02:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
10:07:49:WU02:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
10:27:55:WU02:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
10:48:03:WU02:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
10:48:28:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:48:28:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
10:48:28:WU00:FS01:Starting
10:48:28:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:48:28:WU00:FS01:Started FahCore on PID 4240
10:48:28:WU00:FS01:Core PID:8132
10:48:28:WU00:FS01:FahCore 0x22 started
10:48:32:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:48:32:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
10:48:32:WARNING:WU00:FS01:Too many errors, failing
10:48:32:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:11778 run:0 clone:4673 gen:1 core:0x22 unit:0x00000007287234c95e73c401a9777a22
10:48:32:WU00:FS01:Connecting to 40.114.52.201:8080
10:48:32:WU01:FS01:Connecting to 65.254.110.245:8080
10:48:33:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:48:33:WU01:FS01:Connecting to 18.218.241.186:80
10:48:33:WU01:FS01:Assigned to work server 140.163.4.231
10:48:33:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [GeForce 610M] from 140.163.4.231
10:48:33:WU01:FS01:Connecting to 140.163.4.231:8080
10:48:53:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
10:48:53:WU00:FS01:Connecting to 40.114.52.201:80
10:49:14:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Próba połączenia nie powiodła się, ponieważ połączona strona nie odpowiedziała poprawnie po ustalonym okresie czasu lub utworzone połączenie nie powiodło się, ponieważ połączony host nie odpowiedział.
10:49:14:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:11778 run:0 clone:4673 gen:1 core:0x22 unit:0x00000007287234c95e73c401a9777a22
10:49:14:WU00:FS01:Connecting to 40.114.52.201:8080
10:49:22:WU01:FS01:Downloading 4.53MiB
10:49:28:WU01:FS01:Download 52.45%
10:49:38:WU01:FS01:Download 93.86%
10:49:38:WU01:FS01:Download complete
10:49:38:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11748 run:0 clone:1132 gen:5 core:0x22 unit:0x0000000d8ca304e75e6a7fe522ccfb8f
10:49:38:WU01:FS01:Starting
10:49:38:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:49:38:WU01:FS01:Started FahCore on PID 1740
10:49:38:WU01:FS01:Core PID:7288
10:49:38:WU01:FS01:FahCore 0x22 started
10:49:40:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:49:40:WARNING:WU01:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
10:49:40:WU01:FS01:Starting
10:49:40:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:49:40:WU01:FS01:Started FahCore on PID 7336
10:49:41:WU01:FS01:Core PID:7488
10:49:41:WU01:FS01:FahCore 0x22 started
10:49:42:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:49:42:WARNING:WU01:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
10:49:47:209:127.0.0.1:New Web connection
10:50:27:WARNING:WU00:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
10:50:27:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:11778 run:0 clone:4673 gen:1 core:0x22 unit:0x00000007287234c95e73c401a9777a22
10:50:27:WU00:FS01:Connecting to 40.114.52.201:8080
10:50:31:ERROR:Receive error: 10053: Nawiązane połączenie zostało przerwane przez oprogramowanie zainstalowane w komputerze-hoście.
10:50:41:WU01:FS01:Starting
10:50:41:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:50:41:WU01:FS01:Started FahCore on PID 7196
10:50:41:WU01:FS01:Core PID:7672
10:50:41:WU01:FS01:FahCore 0x22 started
10:50:42:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:50:42:WARNING:WU01:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
10:50:47:ERROR:Receive error: 10053: Nawiązane połączenie zostało przerwane przez oprogramowanie zainstalowane w komputerze-hoście.
10:50:48:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
10:50:48:WU00:FS01:Connecting to 40.114.52.201:80
10:51:03:ERROR:Receive error: 10053: Nawiązane połączenie zostało przerwane przez oprogramowanie zainstalowane w komputerze-hoście.
10:51:09:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Próba połączenia nie powiodła się, ponieważ połączona strona nie odpowiedziała poprawnie po ustalonym okresie czasu lub utworzone połączenie nie powiodło się, ponieważ połączony host nie odpowiedział.
10:51:41:WU01:FS01:Starting
10:51:41:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:51:41:WU01:FS01:Started FahCore on PID 7736
10:51:41:WU01:FS01:Core PID:8000
10:51:41:WU01:FS01:FahCore 0x22 started
10:51:45:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:51:45:WARNING:WU01:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
10:52:04:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:11778 run:0 clone:4673 gen:1 core:0x22 unit:0x00000007287234c95e73c401a9777a22
10:52:04:WU00:FS01:Connecting to 40.114.52.201:8080
10:52:25:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
10:52:25:WU00:FS01:Connecting to 40.114.52.201:80
10:52:41:WU01:FS01:Starting
10:52:41:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:52:41:WU01:FS01:Started FahCore on PID 5772
10:52:41:WU01:FS01:Core PID:7640
10:52:41:WU01:FS01:FahCore 0x22 started
10:52:42:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:52:42:WARNING:WU01:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
10:52:42:WARNING:WU01:FS01:Too many errors, failing
10:52:42:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:11748 run:0 clone:1132 gen:5 core:0x22 unit:0x0000000d8ca304e75e6a7fe522ccfb8f
10:52:42:WU01:FS01:Connecting to 140.163.4.231:8080
10:52:43:WU03:FS01:Connecting to 65.254.110.245:8080
10:52:43:WU03:FS01:Assigned to work server 128.252.203.2
10:52:43:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [GeForce 610M] from 128.252.203.2
10:52:43:WU03:FS01:Connecting to 128.252.203.2:8080
10:52:44:ERROR:WU03:FS01:Exception: Server did not assign work unit
10:52:44:WU03:FS01:Connecting to 65.254.110.245:8080
10:52:44:WARNING:WU03:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:52:44:WU03:FS01:Connecting to 18.218.241.186:80
10:52:45:WU03:FS01:Assigned to work server 155.247.164.213
10:52:45:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [GeForce 610M] from 155.247.164.213
10:52:45:WU03:FS01:Connecting to 155.247.164.213:8080
10:52:46:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Próba połączenia nie powiodła się, ponieważ połączona strona nie odpowiedziała poprawnie po ustalonym okresie czasu lub utworzone połączenie nie powiodło się, ponieważ połączony host nie odpowiedział.
10:52:49:WU03:FS01:Downloading 4.53MiB
10:52:52:WU01:FS01:Server responded WORK_ACK (400)
10:52:52:WU01:FS01:Cleaning up
10:52:54:WU03:FS01:Download complete
10:52:54:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11754 run:0 clone:2552 gen:9 core:0x22 unit:0x0000000d9bf7a4d55e6d76d79d191200
10:54:17:ERROR:Receive error: 10053: Nawiązane połączenie zostało przerwane przez oprogramowanie zainstalowane w komputerze-hoście.
10:54:19:WU03:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
10:54:19:WU03:FS01:Connecting to cores.foldingathome.org:80
10:54:20:WU03:FS01:FahCore 22: Downloading 4.04MiB
10:54:25:WU03:FS01:FahCore 22: Download complete
10:54:25:WU03:FS01:Valid core signature
10:54:25:WU03:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
10:54:26:WU03:FS01:Starting
10:54:26:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:54:26:WU03:FS01:Started FahCore on PID 7196
10:54:28:WU03:FS01:Core PID:7676
10:54:28:WU03:FS01:FahCore 0x22 started
10:54:30:WARNING:WU03:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:54:30:WARNING:WU03:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
10:54:31:WU03:FS01:Starting
10:54:31:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\my_username\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 705 -lifeline 6024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:54:31:WU03:FS01:Started FahCore on PID 7580
10:54:31:WU03:FS01:Core PID:4164
10:54:31:WU03:FS01:FahCore 0x22 started
10:54:32:WARNING:WU03:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:54:32:WARNING:WU03:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
Re: Entry point of procedure clReleaseDevice not found
This is a hint there was a Windows error F@H does not know about. Windows Event Viewer may have more details.
Now for some random Guesses!
This appears to hint you have a laptop, perhaps the GPU is overheating in there. You may not be able to fold with the GPU in a Laptop.
Many Laptops with Nvidia graphics use a technology called Optimus, where it uses Intel graphics until there is high load then switches to Nvidia. Sadly F2H can't use Intel graphics and crashes before switching. Some people use the Nvidia Control Panel, and go to 3D settings and set it to always use Nvidia. This may well make your laptop louder and hotter.
https://www.geforce.com/hardware/techno ... technology
You may just not have a current driver for the 610M Nvidia is no longer supporting the 610M, but here is the latest.
https://www.geforce.com/drivers/results/132841
If a newer driver does not solve the crashes and the Windows Event Viewer does not give hints. You may not be able to fold on that card.
v00d00
Hardware configuration: FX8320e (6 cores enabled) @ stock,
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Ran Seti@Home prior to that.
Post by v00d00 »
If it is overheating, a laptop cooling pad would negate a lot of the problem. Also open it up and vac any dust out of it, if its over a year old. Electronics attract dust and laptops always get clogged over time. Youtube should be able to help with opening it.
VirusCorona
I already cleaned my laptop and it didn't help. After Friday it didn't happen again (it didn't require restart). But now I have another problem: F@H seems to not work and I can't open it. Web control shows now 0% use and 0 points. There's no F@H icon in hidden icons on the task bar, where it used to be (windows, near the clock). When I'm trying to start the program with it's desktop shortcut, nothing happens. But fan is blowing hot air all the time.
v00d00
- 16GB DDR3,
Debian 9.
Post by v00d00 »
Open Task manager and see if FAH is still running in the background?
Move to Web Client for start/stop if the FAHClient is still running in the background.
If FAHControl has crashed, terminate it from Task Manager.
If the Core is running but no FAHClient, then terminate and restart the client.
The GeForce 610M is not supported because it lacks Double Precision hardware. We are looking into that problem.
It may also be an issue for OpenCL 1.1
VirusCorona
I found FAH in background processes in task manager and closed it. After reopening from shortcut it works again (there's icon in hidden icons on task bar and after clicking it displays menu).
