GPU task appears then suddenly disappears
Nope.avi
Post by Nope.avi »
When I try to run a GPU work unit, I temporarily get a task, and then a few seconds later it disappears with the following code.
The drivers are directly from Nvidia's website. Everything is running at stock clocks and I've been using this machine to fold for FAH for years. Is this an issue on my side?
*********************** Log Started 2020-03-21T03:39:42Z ***********************
03:39:42:************************* Folding@home Client *************************
03:39:42:        Website: https://foldingathome.org/
03:39:42:      Copyright: (c) 2009-2018 foldingathome.org
03:39:42:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:39:42:           Args:
03:39:42:         Config: C:\Users\Gemini\AppData\Roaming\FAHClient\config.xml
03:39:42:******************************** Build ********************************
03:39:42:        Version: 7.5.1
03:39:42:           Date: May 11 2018
03:39:42:           Time: 13:06:32
03:39:42:     Repository: Git
03:39:42:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
03:39:42:         Branch: master
03:39:42:       Compiler: Visual C++ 2008
03:39:42:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:39:42:       Platform: win32 10
03:39:42:           Bits: 32
03:39:42:           Mode: Release
03:39:42:******************************* System ********************************
03:39:42:            CPU: Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
03:39:42:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
03:39:42:           CPUs: 8
03:39:42:         Memory: 7.73GiB
03:39:42:    Free Memory: 5.78GiB
03:39:42:        Threads: WINDOWS_THREADS
03:39:42:     OS Version: 6.2
03:39:42:    Has Battery: true
03:39:42:     On Battery: false
03:39:42:     UTC Offset: -6
03:39:42:            PID: 3616
03:39:42:            CWD: C:\Users\Gemini\AppData\Roaming\FAHClient
03:39:42:             OS: Windows 10 Enterprise
03:39:42:        OS Arch: AMD64
03:39:42:           GPUs: 1
03:39:42:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:3 GK107 [GeForce GT 750M]
03:39:42:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:10.1
03:39:42:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:425.31
03:39:42:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
03:39:42:  Win32 Service: false
03:39:42:***********************************************************************
03:39:42:<config>
03:39:42:  <!-- Network -->
03:39:42:  <proxy v=':8080'/>
03:39:42:
03:39:42:  <!-- Slot Control -->
03:39:42:  <power v='full'/>
03:39:42:
03:39:42:  <!-- User Information -->
03:39:42:  <team v='225187'/>
03:39:42:  <user v='Nope.avi'/>
03:39:42:
03:39:42:  <!-- Folding Slots -->
03:39:42:  <slot id='0' type='GPU'>
03:39:42:    <paused v='true'/>
03:39:42:  </slot>
03:39:42:</config>
03:39:42:Trying to access database...
03:39:42:Successfully acquired database lock
03:39:42:Enabled folding slot 00: PAUSED gpu:0:GK107 [GeForce GT 750M] (by user)
03:40:26:FS00:Unpaused
03:40:27:WU00:FS00:Connecting to 65.254.110.245:8080
03:40:27:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:40:27:WU00:FS00:Connecting to 18.218.241.186:80
03:40:28:WU00:FS00:Assigned to work server 40.114.52.201
03:40:28:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GK107 [GeForce GT 750M] from 40.114.52.201
03:40:28:WU00:FS00:Connecting to 40.114.52.201:8080
03:40:43:Removing old file 'configs/config-20200319-023635.xml'
03:40:43:Saving configuration to config.xml
03:40:43:<config>
03:40:43:  <!-- Network -->
03:40:43:  <proxy v=':8080'/>
03:40:43:
03:40:43:  <!-- Slot Control -->
03:40:43:  <power v='full'/>
03:40:43:
03:40:43:  <!-- User Information -->
03:40:43:  <team v='225187'/>
03:40:43:  <user v='Nope.avi'/>
03:40:43:
03:40:43:  <!-- Folding Slots -->
03:40:43:  <slot id='0' type='GPU'/>
03:40:43:</config>
03:41:06:WU00:FS00:Downloading 29.75MiB
03:41:12:WU00:FS00:Download 30.67%
03:41:18:WU00:FS00:Download 45.37%
03:41:24:WU00:FS00:Download 61.76%
03:41:28:WU00:FS00:Download complete
03:41:28:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11777 run:0 clone:5108 gen:0 core:0x22 unit:0x00000001287234c95e743311b7448834
03:41:28:WU00:FS00:Starting
03:41:28:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Gemini\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 3616 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
03:41:28:WU00:FS00:Started FahCore on PID 5260
03:41:28:WU00:FS00:Core PID:9032
03:41:28:WU00:FS00:FahCore 0x22 started
03:41:29:WU00:FS00:0x22:*********************** Log Started 2020-03-21T03:41:28Z ***********************
03:41:29:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
03:41:29:WU00:FS00:0x22:       Type: 0x22
03:41:29:WU00:FS00:0x22:       Core: Core22
03:41:29:WU00:FS00:0x22:    Website: https://foldingathome.org/
03:41:29:WU00:FS00:0x22:  Copyright: (c) 2009-2018 foldingathome.org
03:41:29:WU00:FS00:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:41:29:WU00:FS00:0x22:             <rafal.wiewiora@choderalab.org>
03:41:29:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 5260 -checkpoint 15
03:41:29:WU00:FS00:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
03:41:29:WU00:FS00:0x22:             0 -gpu 0
03:41:29:WU00:FS00:0x22:     Config: <none>
03:41:29:WU00:FS00:0x22:************************************ Build *************************************
03:41:29:WU00:FS00:0x22:    Version: 0.0.2
03:41:29:WU00:FS00:0x22:       Date: Dec 6 2019
03:41:29:WU00:FS00:0x22:       Time: 21:30:31
03:41:29:WU00:FS00:0x22: Repository: Git
03:41:29:WU00:FS00:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
03:41:29:WU00:FS00:0x22:     Branch: HEAD
03:41:29:WU00:FS00:0x22:   Compiler: Visual C++ 2008
03:41:29:WU00:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:41:29:WU00:FS00:0x22:   Platform: win32 10
03:41:29:WU00:FS00:0x22:       Bits: 64
03:41:29:WU00:FS00:0x22:       Mode: Release
03:41:29:WU00:FS00:0x22:************************************ System ************************************
03:41:29:WU00:FS00:0x22:        CPU: Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
03:41:29:WU00:FS00:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
03:41:29:WU00:FS00:0x22:       CPUs: 8
03:41:29:WU00:FS00:0x22:     Memory: 7.73GiB
03:41:29:WU00:FS00:0x22:Free Memory: 5.37GiB
03:41:29:WU00:FS00:0x22:    Threads: WINDOWS_THREADS
03:41:29:WU00:FS00:0x22: OS Version: 6.2
03:41:29:WU00:FS00:0x22:Has Battery: true
03:41:29:WU00:FS00:0x22: On Battery: false
03:41:29:WU00:FS00:0x22: UTC Offset: -6
03:41:29:WU00:FS00:0x22:        PID: 9032
03:41:29:WU00:FS00:0x22:        CWD: C:\Users\Gemini\AppData\Roaming\FAHClient\work
03:41:29:WU00:FS00:0x22:         OS: Windows 10 Pro
03:41:29:WU00:FS00:0x22:    OS Arch: AMD64
03:41:29:WU00:FS00:0x22:********************************************************************************
03:41:29:WU00:FS00:0x22:Project: 11777 (Run 0, Clone 5108, Gen 0)
03:41:29:WU00:FS00:0x22:Unit: 0x00000001287234c95e743311b7448834
03:41:29:WU00:FS00:0x22:Reading tar file core.xml
03:41:29:WU00:FS00:0x22:Reading tar file integrator.xml
03:41:29:WU00:FS00:0x22:Reading tar file state.xml
03:41:29:WU00:FS00:0x22:Reading tar file system.xml
03:41:29:WU00:FS00:0x22:Digital signatures verified
03:41:29:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
03:41:29:WU00:FS00:0x22:Version 0.0.2
03:41:33:WU00:FS00:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
03:41:33:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
03:41:33:WU00:FS00:0x22:Saving result file science.log
03:41:33:WU00:FS00:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
03:41:34:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:41:34:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:11777 run:0 clone:5108 gen:0 core:0x22 unit:0x00000001287234c95e743311b7448834
03:41:34:WU00:FS00:Uploading 8.50KiB to 40.114.52.201
03:41:34:WU00:FS00:Connecting to 40.114.52.201:8080
03:41:34:WU01:FS00:Connecting to 65.254.110.245:8080
03:41:35:WU01:FS00:Assigned to work server 140.163.4.231
03:41:35:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GK107 [GeForce GT 750M] from 140.163.4.231
03:41:35:WU01:FS00:Connecting to 140.163.4.231:8080
03:42:00:WU00:FS00:Upload complete
03:42:00:WU00:FS00:Server responded WORK_ACK (400)
03:42:01:WU00:FS00:Cleaning up
03:43:17:WU01:FS00:Downloading 13.15MiB
03:43:23:WU01:FS00:Download 8.08%
03:43:36:WU01:FS00:Download 25.19%
03:43:42:WU01:FS00:Download 36.12%
03:43:54:WU01:FS00:Download 44.19%
03:44:09:WU01:FS00:Download 66.53%
03:44:17:WU01:FS00:Download 84.11%
03:44:23:WU01:FS00:Download 97.89%
03:44:24:WU01:FS00:Download complete
03:44:24:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11752 run:0 clone:2281 gen:7 core:0x22 unit:0x0000000f8ca304e75e6a8067f0267163
03:44:24:WU01:FS00:Starting
03:44:24:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Gemini\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 3616 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
03:44:24:WU01:FS00:Started FahCore on PID 3908
03:44:24:WU01:FS00:Core PID:5232
03:44:24:WU01:FS00:FahCore 0x22 started
03:44:25:WU01:FS00:0x22:*********************** Log Started 2020-03-21T03:44:24Z ***********************
03:44:25:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
03:44:25:WU01:FS00:0x22:       Type: 0x22
03:44:25:WU01:FS00:0x22:       Core: Core22
03:44:25:WU01:FS00:0x22:    Website: https://foldingathome.org/
03:44:25:WU01:FS00:0x22:  Copyright: (c) 2009-2018 foldingathome.org
03:44:25:WU01:FS00:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:44:25:WU01:FS00:0x22:             <rafal.wiewiora@choderalab.org>
03:44:25:WU01:FS00:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 3908 -checkpoint 15
03:44:25:WU01:FS00:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
03:44:25:WU01:FS00:0x22:             0 -gpu 0
03:44:25:WU01:FS00:0x22:     Config: <none>
03:44:25:WU01:FS00:0x22:************************************ Build *************************************
03:44:25:WU01:FS00:0x22:    Version: 0.0.2
03:44:25:WU01:FS00:0x22:       Date: Dec 6 2019
03:44:25:WU01:FS00:0x22:       Time: 21:30:31
03:44:25:WU01:FS00:0x22: Repository: Git
03:44:25:WU01:FS00:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
03:44:25:WU01:FS00:0x22:     Branch: HEAD
03:44:25:WU01:FS00:0x22:   Compiler: Visual C++ 2008
03:44:25:WU01:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:44:25:WU01:FS00:0x22:   Platform: win32 10
03:44:25:WU01:FS00:0x22:       Bits: 64
03:44:25:WU01:FS00:0x22:       Mode: Release
03:44:25:WU01:FS00:0x22:************************************ System ************************************
03:44:25:WU01:FS00:0x22:        CPU: Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
03:44:25:WU01:FS00:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
03:44:25:WU01:FS00:0x22:       CPUs: 8
03:44:25:WU01:FS00:0x22:     Memory: 7.73GiB
03:44:25:WU01:FS00:0x22:Free Memory: 5.45GiB
03:44:25:WU01:FS00:0x22:    Threads: WINDOWS_THREADS
03:44:25:WU01:FS00:0x22: OS Version: 6.2
03:44:25:WU01:FS00:0x22:Has Battery: true
03:44:25:WU01:FS00:0x22: On Battery: false
03:44:25:WU01:FS00:0x22: UTC Offset: -6
03:44:25:WU01:FS00:0x22:        PID: 5232
03:44:25:WU01:FS00:0x22:        CWD: C:\Users\Gemini\AppData\Roaming\FAHClient\work
03:44:25:WU01:FS00:0x22:         OS: Windows 10 Pro
03:44:25:WU01:FS00:0x22:    OS Arch: AMD64
03:44:25:WU01:FS00:0x22:********************************************************************************
03:44:25:WU01:FS00:0x22:Project: 11752 (Run 0, Clone 2281, Gen 7)
03:44:25:WU01:FS00:0x22:Unit: 0x0000000f8ca304e75e6a8067f0267163
03:44:25:WU01:FS00:0x22:Reading tar file core.xml
03:44:25:WU01:FS00:0x22:Reading tar file integrator.xml
03:44:25:WU01:FS00:0x22:Reading tar file state.xml
03:44:27:WU01:FS00:0x22:Reading tar file system.xml
03:44:28:WU01:FS00:0x22:Digital signatures verified
03:44:28:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
03:44:28:WU01:FS00:0x22:Version 0.0.2
03:44:39:WU01:FS00:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
03:44:39:WU01:FS00:0x22:Saving result file ..\logfile_01.txt
03:44:39:WU01:FS00:0x22:Saving result file science.log
03:44:39:WU01:FS00:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
03:44:40:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:44:40:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:11752 run:0 clone:2281 gen:7 core:0x22 unit:0x0000000f8ca304e75e6a8067f0267163
03:44:40:WU01:FS00:Uploading 2.63KiB to 140.163.4.231
03:44:40:WU01:FS00:Connecting to 140.163.4.231:8080
03:44:40:WU00:FS00:Connecting to 65.254.110.245:8080
03:44:41:WU00:FS00:Assigned to work server 40.114.52.201
03:44:41:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GK107 [GeForce GT 750M] from 40.114.52.201
03:44:41:WU00:FS00:Connecting to 40.114.52.201:8080
03:44:55:WU01:FS00:Upload 100.00%
03:44:56:FS00:Finishing
03:45:17:WU00:FS00:Downloading 79.27MiB
03:45:23:WU00:FS00:Download 11.27%
03:45:29:WU00:FS00:Download 33.27%
03:45:35:WU00:FS00:Download 47.54%
03:45:41:WU00:FS00:Download 54.40%
03:45:47:WU00:FS00:Download 70.80%
03:45:53:WU00:FS00:Download 78.37%
03:45:59:WU00:FS00:Download 87.04%
03:46:02:WU00:FS00:Download complete
03:46:02:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11776 run:0 clone:9213 gen:0 core:0x22 unit:0x00000000287234c95e7433694b94b9a8
03:46:02:WU00:FS00:Starting
03:46:02:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Gemini\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 3616 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
03:46:02:WU00:FS00:Started FahCore on PID 1576
03:46:02:WU00:FS00:Core PID:9352
03:46:02:WU00:FS00:FahCore 0x22 started
03:46:03:WU00:FS00:0x22:*********************** Log Started 2020-03-21T03:46:02Z ***********************
03:46:03:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
03:46:03:WU00:FS00:0x22:       Type: 0x22
03:46:03:WU00:FS00:0x22:       Core: Core22
03:46:03:WU00:FS00:0x22:    Website: https://foldingathome.org/
03:46:03:WU00:FS00:0x22:  Copyright: (c) 2009-2018 foldingathome.org
03:46:03:WU00:FS00:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:46:03:WU00:FS00:0x22:             <rafal.wiewiora@choderalab.org>
03:46:03:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 1576 -checkpoint 15
03:46:03:WU00:FS00:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
03:46:03:WU00:FS00:0x22:             0 -gpu 0
03:46:03:WU00:FS00:0x22:     Config: <none>
03:46:03:WU00:FS00:0x22:************************************ Build *************************************
03:46:03:WU00:FS00:0x22:    Version: 0.0.2
03:46:03:WU00:FS00:0x22:       Date: Dec 6 2019
03:46:03:WU00:FS00:0x22:       Time: 21:30:31
03:46:03:WU00:FS00:0x22: Repository: Git
03:46:03:WU00:FS00:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
03:46:03:WU00:FS00:0x22:     Branch: HEAD
03:46:03:WU00:FS00:0x22:   Compiler: Visual C++ 2008
03:46:03:WU00:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:46:03:WU00:FS00:0x22:   Platform: win32 10
03:46:03:WU00:FS00:0x22:       Bits: 64
03:46:03:WU00:FS00:0x22:       Mode: Release
03:46:03:WU00:FS00:0x22:************************************ System ************************************
03:46:03:WU00:FS00:0x22:        CPU: Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
03:46:03:WU00:FS00:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
03:46:03:WU00:FS00:0x22:       CPUs: 8
03:46:03:WU00:FS00:0x22:     Memory: 7.73GiB
03:46:03:WU00:FS00:0x22:Free Memory: 5.48GiB
03:46:03:WU00:FS00:0x22:    Threads: WINDOWS_THREADS
03:46:03:WU00:FS00:0x22: OS Version: 6.2
03:46:03:WU00:FS00:0x22:Has Battery: true
03:46:03:WU00:FS00:0x22: On Battery: false
03:46:03:WU00:FS00:0x22: UTC Offset: -6
03:46:03:WU00:FS00:0x22:        PID: 9352
03:46:03:WU00:FS00:0x22:        CWD: C:\Users\Gemini\AppData\Roaming\FAHClient\work
03:46:03:WU00:FS00:0x22:         OS: Windows 10 Pro
03:46:03:WU00:FS00:0x22:    OS Arch: AMD64
03:46:03:WU00:FS00:0x22:********************************************************************************
03:46:03:WU00:FS00:0x22:Project: 11776 (Run 0, Clone 9213, Gen 0)
03:46:03:WU00:FS00:0x22:Unit: 0x00000000287234c95e7433694b94b9a8
03:46:03:WU00:FS00:0x22:Reading tar file core.xml
03:46:03:WU00:FS00:0x22:Reading tar file integrator.xml
03:46:03:WU00:FS00:0x22:Reading tar file state.xml
03:46:03:WU00:FS00:0x22:Reading tar file system.xml
03:46:04:WU00:FS00:0x22:Digital signatures verified
03:46:04:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
03:46:04:WU00:FS00:0x22:Version 0.0.2
03:46:07:WU01:FS00:Upload complete
03:46:07:WU01:FS00:Server responded WORK_ACK (400)
03:46:07:WU01:FS00:Cleaning up
03:46:15:WU00:FS00:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
03:46:15:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
03:46:15:WU00:FS00:0x22:Saving result file science.log
03:46:15:WU00:FS00:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
03:46:15:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:46:15:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:11776 run:0 clone:9213 gen:0 core:0x22 unit:0x00000000287234c95e7433694b94b9a8
03:46:15:WU00:FS00:Uploading 8.50KiB to 40.114.52.201
03:46:15:WU00:FS00:Connecting to 40.114.52.201:8080
03:46:53:WU00:FS00:Upload complete
03:46:53:WU00:FS00:Server responded WORK_ACK (400)
03:46:54:WU00:FS00:Cleaning up
03:47:28:WU00:FS00:Connecting to 65.254.110.245:8080
03:47:28:WU00:FS00:Assigned to work server 128.252.203.2
03:47:28:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GK107 [GeForce GT 750M] from 128.252.203.2
03:47:28:WU00:FS00:Connecting to 128.252.203.2:8080
03:47:31:FS00:Finishing
03:47:50:Removing old file 'configs/config-20200319-023648.xml'
03:47:50:Saving configuration to config.xml
03:47:50:<config>
03:47:50:  <!-- Network -->
03:47:50:  <proxy v=':8080'/>
03:47:50:
03:47:50:  <!-- Slot Control -->
03:47:50:  <power v='medium'/>
03:47:50:
03:47:50:  <!-- User Information -->
03:47:50:  <team v='225187'/>
03:47:50:  <user v='Nope.avi'/>
03:47:50:
03:47:50:  <!-- Folding Slots -->
03:47:50:  <slot id='0' type='GPU'/>
03:47:50:</config>
03:48:28:WU00:FS00:Downloading 79.12MiB
03:48:34:WU00:FS00:Download 18.88%
03:48:40:WU00:FS00:Download 44.87%
03:48:46:WU00:FS00:Download 61.77%
03:48:52:WU00:FS00:Download 93.45%
03:48:53:WU00:FS00:Download complete
03:48:53:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14533 run:0 clone:6640 gen:1 core:0x22 unit:0x0000000480fccb025e72f25756786d81
03:48:53:WU00:FS00:Starting
03:48:53:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Gemini\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 3616 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
03:48:53:WU00:FS00:Started FahCore on PID 6820
03:48:53:WU00:FS00:Core PID:2992
03:48:53:WU00:FS00:FahCore 0x22 started
03:48:53:WU00:FS00:0x22:*********************** Log Started 2020-03-21T03:48:53Z ***********************
03:48:53:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
03:48:53:WU00:FS00:0x22:       Type: 0x22
03:48:53:WU00:FS00:0x22:       Core: Core22
03:48:53:WU00:FS00:0x22:    Website: https://foldingathome.org/
03:48:53:WU00:FS00:0x22:  Copyright: (c) 2009-2018 foldingathome.org
03:48:53:WU00:FS00:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:48:53:WU00:FS00:0x22:             <rafal.wiewiora@choderalab.org>
03:48:53:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 6820 -checkpoint 15
03:48:53:WU00:FS00:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
03:48:53:WU00:FS00:0x22:             0 -gpu 0
03:48:53:WU00:FS00:0x22:     Config: <none>
03:48:53:WU00:FS00:0x22:************************************ Build *************************************
03:48:53:WU00:FS00:0x22:    Version: 0.0.2
03:48:53:WU00:FS00:0x22:       Date: Dec 6 2019
03:48:53:WU00:FS00:0x22:       Time: 21:30:31
03:48:53:WU00:FS00:0x22: Repository: Git
03:48:53:WU00:FS00:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
03:48:53:WU00:FS00:0x22:     Branch: HEAD
03:48:53:WU00:FS00:0x22:   Compiler: Visual C++ 2008
03:48:53:WU00:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:48:53:WU00:FS00:0x22:   Platform: win32 10
03:48:53:WU00:FS00:0x22:       Bits: 64
03:48:53:WU00:FS00:0x22:       Mode: Release
03:48:53:WU00:FS00:0x22:************************************ System ************************************
03:48:53:WU00:FS00:0x22:        CPU: Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
03:48:53:WU00:FS00:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
03:48:53:WU00:FS00:0x22:       CPUs: 8
03:48:53:WU00:FS00:0x22:     Memory: 7.73GiB
03:48:53:WU00:FS00:0x22:Free Memory: 5.47GiB
03:48:53:WU00:FS00:0x22:    Threads: WINDOWS_THREADS
03:48:53:WU00:FS00:0x22: OS Version: 6.2
03:48:53:WU00:FS00:0x22:Has Battery: true
03:48:53:WU00:FS00:0x22: On Battery: false
03:48:53:WU00:FS00:0x22: UTC Offset: -6
03:48:53:WU00:FS00:0x22:        PID: 2992
03:48:53:WU00:FS00:0x22:        CWD: C:\Users\Gemini\AppData\Roaming\FAHClient\work
03:48:53:WU00:FS00:0x22:         OS: Windows 10 Pro
03:48:53:WU00:FS00:0x22:    OS Arch: AMD64
03:48:53:WU00:FS00:0x22:********************************************************************************
03:48:53:WU00:FS00:0x22:Project: 14533 (Run 0, Clone 6640, Gen 1)
03:48:53:WU00:FS00:0x22:Unit: 0x0000000480fccb025e72f25756786d81
03:48:53:WU00:FS00:0x22:Reading tar file core.xml
03:48:53:WU00:FS00:0x22:Reading tar file integrator.xml
03:48:53:WU00:FS00:0x22:Reading tar file state.xml
03:48:54:WU00:FS00:0x22:Reading tar file system.xml
03:48:55:WU00:FS00:0x22:Digital signatures verified
03:48:55:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
03:48:55:WU00:FS00:0x22:Version 0.0.2
03:49:05:WU00:FS00:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
03:49:05:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
03:49:05:WU00:FS00:0x22:Saving result file science.log
03:49:05:WU00:FS00:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
03:49:06:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:49:06:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:14533 run:0 clone:6640 gen:1 core:0x22 unit:0x0000000480fccb025e72f25756786d81
03:49:06:WU00:FS00:Uploading 8.50KiB to 128.252.203.2
03:49:06:WU00:FS00:Connecting to 128.252.203.2:8080
03:49:18:FS00:Paused
03:49:21:WU00:FS00:Upload 100.00%
03:49:52:Removing old file 'configs/config-20200319-023651.xml'
03:49:52:Saving configuration to config.xml
03:49:52:<config>
03:49:52:  <!-- Network -->
03:49:52:  <proxy v=':8080'/>
03:49:52:
03:49:52:  <!-- Slot Control -->
03:49:52:  <power v='medium'/>
03:49:52:
03:49:52:  <!-- User Information -->
03:49:52:  <team v='225187'/>
03:49:52:  <user v='Nope.avi'/>
03:49:52:
03:49:52:  <!-- Folding Slots -->
03:49:52:  <slot id='0' type='GPU'>
03:49:52:    <paused v='true'/>
03:49:52:  </slot>
03:49:52:</config>
03:50:23:WU00:FS00:Upload complete
03:50:23:WU00:FS00:Server responded WORK_ACK (400)
03:50:23:WU00:FS00:Cleaning up
anandhanju
Re: GPU task appears then suddenly disappears
Post by anandhanju »
Have you updated the drivers recently? The work units you're getting are different each time and for different projects so its unlikely that its a bad WU.
Also FYI, once you get past this error, consider using a passkey. You will not receive bonus points if you do not use a passkey.
Nope.avi
Post by Nope.avi »
anandhanju wrote:Have you updated the drivers recently? The work units you're getting are different each time and for different projects so its unlikely that its a bad WU.
I re installed the latest drivers directly from Nvidia. However the latest drivers available are from April of last year.
Rel25917
Post by Rel25917 »
Did you do a full install of the drivers? Its acting like OpenCL is not installed. ( installed with/part of the cuda drivers I think. Been a while since I installed nvidia drivers)
Nope.avi
Post by Nope.avi »
bruce wrote:According to the information I have, the GT 7xxM series lacks double precision support so the FAHCore required cannot support that hardware.
I suspect that the project is also configured on the server. You should not be receiving assignments that your hardware cannot support.
Even if the OpenCL version supports double precision, it needs to pass the instructions to the GPU and the GPU needs to be able to process them. I'm not aware of any way a GT 750M can be supported. Unfortunately that means you need to upgrade your hardware or you're stuck.
But I was able to work on a work unit for five hours the other day. And it has successfully worked on GPU work units before.
Nope.avi
Post by Nope.avi »
Rel25917 wrote:Did you do a full install of the drivers? Its acting like OpenCL is not installed. ( installed with/part of the cuda drivers I think. Been a while since I installed nvidia drivers)
Yes I did a full install. Besides, opencl support is already built in to modern Nvidia drivers.
But quickly removed by MS Windows Update if it decides to update a driver on you, even when you have that checked off to not happen.
Nope.avi
Post by Nope.avi »
Joe_H wrote:But quickly removed by MS Windows Update if it decides to update a driver on you, even when you have that checked off to not happen.
I checked on Passmark and OpenCL is working perfectly fine on both the Nvidia Graphics card and the Intel integrated graphics. What else can I try?
The Intel Integrated Graphics is not supported by FAH. There's an ongoing testing program that's considering adding support but there's no information available regarding it's progress.
The GeForce GT 750M is, in fact, listed as supported.
We've had some previous reports of trouble when two versions of OpenCL are installed. I suggest you remove the Intel driver, reinstall the nV driver and see what happens.
