Running Folding@home and get popup msg: The procedure entry point fatBinaryCtl could not be located in the dynamic link library C:\WINDOWS\System32\nvopencl.dll
I updated my NVIDIA driver for my GeForce GTX 950 video card; nvopencl.dll exists in that directory, dated today, 24.0 MB.
Reinstalled FAH, get same popup
NVIDIA driver info
Operating System: Windows 10 Pro, 64-bit
DirectX version: 12.0
GPU processor: GeForce GTX 950
Driver version: 441.87
Driver Type: Standard
Direct3D API version: 12
Direct3D feature level: 12_1
CUDA Cores: 768
Core clock: 1025 MHz
Memory data rate: 6.61 Gbps
Memory interface: 128-bit
Memory bandwidth: 105.76 GB/s
Total available graphics memory: 18391 MB
Dedicated video memory: 2048 MB GDDR5
System video memory: 0 MB
Shared system memory: 16343 MB
Video BIOS version: 84.06.5E.00.7E
IRQ: Not used
Bus: PCI Express x16 Gen2
Device Id: 10DE 1402 85861043
Part Number: G301 0006
[Components]
nvui.dll 8.17.14.4187 NVIDIA User Experience Driver Component
nvxdplcy.dll 8.17.14.4187 NVIDIA User Experience Driver Component
nvxdbat.dll 8.17.14.4187 NVIDIA User Experience Driver Component
nvxdapix.dll 8.17.14.4187 NVIDIA User Experience Driver Component
nvCplUIR.dll 8.1.940.0 NVIDIA Control Panel
nvCplUI.exe 8.1.940.0 NVIDIA Control Panel
nvWSSR.dll 26.21.14.4187 NVIDIA Workstation Server
nvWSS.dll 26.21.14.4187 NVIDIA Workstation Server
nvViTvSR.dll 26.21.14.4187 NVIDIA Video Server
nvViTvS.dll 26.21.14.4187 NVIDIA Video Server
nvLicensingS.dll 6.14.14.4187 NVIDIA Licensing Server
nvDispSR.dll 26.21.14.4187 NVIDIA Display Server
NVMCTRAY.DLL 26.21.14.4187 NVIDIA Media Center Library
nvDispS.dll 26.21.14.4187 NVIDIA Display Server
nvDevToolS.dll 26.21.14.4187 NVIDIA 3D Settings Server
PhysX 09.19.0218 NVIDIA PhysX
NVCUDA.DLL 26.21.14.4187 NVIDIA CUDA 10.2.115 driver
nvGameSR.dll 26.21.14.4187 NVIDIA 3D Settings Server
nvGameS.dll 26.21.14.4187 NVIDIA 3D Settings Server
Start fails,Missing fatBinaryCtl entry point in nvopencl.dll
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Re: Start fails,Missing fatBinaryCtl entry point in nvopencl
Use Disp[lay Driver Uninstaller or similar to get rid of the Nvidia driver.
Run CCleaner and scan/fix everything, including the registry (make a backup of what you are erasing).
Reboot.
Reinstall the Nvidia Driver.
Does that fix it? If not.
Check your firewall software isnt sandboxing or virtualising FAH. Also make sure it can connect to the internet.
Try an older version of the Nvidia Driver.
Reboot.
