FAH Viewer not showing stats
MobileGamesMotion
Hardware configuration: Windows 7, Intel i7-6600U CPU on a laptop
Post by MobileGamesMotion »
The FAH viewer shows the 3d structure but shows no stats in the bars. In status, it says "Demo" How can I fix it?
#StayAtHome #AlertNotAnxious #FoldForCOVID :) :idea: :egeek:
Basic help stuff:viewtopic.php?f=61&t=26036 | Find Your Stats:https://stats.foldingathome.org/donors
https://folding.extremeoverclocking.com/
Re: FAH Viewer not showing stats
If you are running Windows, not easily. A bug crept into the Windows version of the code between the prior version and the current 7.5.1 client software. Some have posted details on how to install the 7.4.4 FAHViewer and a DLL not in the current version, but it is a bit tricky and can leave you with a non-functioning F@h client.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
Related threads about this bug: viewtopic.php?f=106&t=32628#p314026
