Client doesn't connect
Crissa
Post by Crissa »
This has been weirdly hard to diagnose, and I'm not sure where I should go from here.
I can now get the screensaver up and I've seen the control panel but don't see anything helpful. Other articles posted the log file, so I found that and it seems nothing is connecting externally, but I don't know why.
CPU Intel i9-9900K 3.6Ghz 8-core 16 logical
Physical RAM 16GB
NVIDIA GeForce RTX 2080 Ti
Windows 10 Pro 10.0.17763 Build 17763
Stock speeds and stability; a few power saving things are turned off (doesn't sleep)
Folding@home Client 7.5.1
*********************** Log Started 2020-03-20T17:00:41Z ***********************
17:00:41:************************* Folding@home Client *************************
17:00:41:        Website: https://foldingathome.org/
17:00:41:      Copyright: (c) 2009-2018 foldingathome.org
17:00:41:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:00:41:           Args: --open-web-control
17:00:41:         Config: <none>
17:00:41:******************************** Build ********************************
17:00:41:        Version: 7.5.1
17:00:41:           Date: May 11 2018
17:00:41:           Time: 13:06:32
17:00:41:     Repository: Git
17:00:41:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
17:00:41:         Branch: master
17:00:41:       Compiler: Visual C++ 2008
17:00:41:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:00:41:       Platform: win32 10
17:00:41:           Bits: 32
17:00:41:           Mode: Release
17:00:41:******************************* System ********************************
17:00:41:            CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
17:00:41:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
17:00:41:           CPUs: 16
17:00:41:         Memory: 15.92GiB
17:00:41:    Free Memory: 12.56GiB
17:00:41:        Threads: WINDOWS_THREADS
17:00:41:     OS Version: 6.2
17:00:41:    Has Battery: false
17:00:41:     On Battery: false
17:00:41:     UTC Offset: -7
17:00:41:            PID: 8140
17:00:41:            CWD: C:\Users\Crissa\AppData\Roaming\FAHClient
17:00:41:             OS: Windows 10 Enterprise
17:00:41:        OS Arch: AMD64
17:00:41:           GPUs: 0
17:00:41:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.1
17:00:41:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:432.0
17:00:41:  Win32 Service: false
17:00:41:***********************************************************************
17:00:41:<config>
17:00:41:  <!-- Folding Slots -->
17:00:41:</config>
17:00:41:Connecting to assign1.foldingathome.org:8080
17:00:41:Updated GPUs.txt
17:00:41:Read GPUs.txt
17:00:41:Trying to access database...
17:00:41:Successfully acquired database lock
17:00:41:Enabled folding slot 00: PAUSED cpu:14 (not configured)
17:00:41:Enabled folding slot 01: PAUSED gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 (not configured)
17:00:43:8:127.0.0.1:New Web connection
17:01:42:Saving configuration to config.xml
17:01:42:<config>
17:01:42:  <!-- Folding Slots -->
17:01:42:  <slot id='0' type='CPU'/>
17:01:42:  <slot id='1' type='GPU'/>
17:01:42:</config>
17:01:42:Set client configured
17:01:42:WU00:FS00:Connecting to 65.254.110.245:8080
17:01:42:WU01:FS01:Connecting to 65.254.110.245:8080
17:01:42:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:01:42:WU00:FS00:Connecting to 18.218.241.186:80
17:01:42:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:01:42:WU01:FS01:Connecting to 18.218.241.186:80
17:01:43:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:01:43:ERROR:WU00:FS00:Exception: Could not get an assignment
17:01:43:WU01:FS01:Assigned to work server 128.252.203.2
17:01:43:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 128.252.203.2
17:01:43:WU01:FS01:Connecting to 128.252.203.2:8080
17:01:43:WU00:FS00:Connecting to 65.254.110.245:8080
17:01:43:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:01:43:WU00:FS00:Connecting to 18.218.241.186:80
17:02:04:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:02:04:WU01:FS01:Connecting to 128.252.203.2:80
17:02:24:ERROR:WU01:FS01:Exception: Server did not assign work unit
17:02:43:Saving configuration to config.xml
17:02:43:<config>
17:02:43:  <!-- Slot Control -->
17:02:43:  <power v='FULL'/>
17:02:43:
17:02:43:  <!-- User Information -->
17:02:43:  <user v='CrissaKentavr'/>
17:02:43:
17:02:43:  <!-- Folding Slots -->
17:02:43:  <slot id='0' type='CPU'>
17:02:43:    <idle v='true'/>
17:02:43:  </slot>
17:02:43:  <slot id='1' type='GPU'>
17:02:43:  </slot>
17:02:43:</config>
17:09:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:10:15:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
17:47:53:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:48:09:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:01:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:01:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:01:17:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:01:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:02:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:02:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:03:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:03:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:03:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:03:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:04:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:04:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
Re: Client doesn't connect
The 10053 error messages you can ignore, they come from parts of the client such as Web Control not closing a connection properly.
The errors in getting an assignment are common right now, the great turnout of persons donating time on their computers has increased the number of requests on the servers more than 10 times what it was a week ago. They are working on getting more servers up and running, currently there can be a wait before getting an assignment.
Crissa
Post by Crissa »
Okay. Too bad it doesn't say that.
I figured with everyone home, there'd be less available as offices had their power deactivated. Thanks.
-Crissa
Crissa
Post by Crissa »
Is there any reason I'm not getting GPU assignments? Are they still out? I don't have a rare/weird GPU.
*********************** Log Started 2020-03-25T06:45:44Z ***********************
06:45:44:************************* Folding@home Client *************************
06:45:44:        Website: https://foldingathome.org/
06:45:44:      Copyright: (c) 2009-2018 foldingathome.org
06:45:44:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:45:44:           Args:
06:45:44:         Config: C:\Users\Crissa\AppData\Roaming\FAHClient\config.xml
06:45:44:******************************** Build ********************************
06:45:44:        Version: 7.5.1
06:45:44:           Date: May 11 2018
06:45:44:           Time: 13:06:32
06:45:44:     Repository: Git
06:45:44:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
06:45:44:         Branch: master
06:45:44:       Compiler: Visual C++ 2008
06:45:44:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:45:44:       Platform: win32 10
06:45:44:           Bits: 32
06:45:44:           Mode: Release
06:45:44:******************************* System ********************************
06:45:44:            CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
06:45:44:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
06:45:44:           CPUs: 16
06:45:44:         Memory: 15.92GiB
06:45:44:    Free Memory: 13.59GiB
06:45:44:        Threads: WINDOWS_THREADS
06:45:44:     OS Version: 6.2
06:45:44:    Has Battery: false
06:45:44:     On Battery: false
06:45:44:     UTC Offset: -7
06:45:44:            PID: 10328
06:45:44:            CWD: C:\Users\Crissa\AppData\Roaming\FAHClient
06:45:44:             OS: Windows 10 Enterprise
06:45:44:        OS Arch: AMD64
06:45:44:           GPUs: 1
06:45:44:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 TU102 [GeForce RTX 2080 Ti Rev. A]
06:45:44:                 M 13448
06:45:44:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.1
06:45:44:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:432.0
06:45:44:  Win32 Service: false
06:45:44:***********************************************************************
06:45:44:<config>
06:45:44:  <!-- Slot Control -->
06:45:44:  <power v='FULL'/>
06:45:44:
06:45:44:  <!-- User Information -->
06:45:44:  <user v='CrissaKentavr'/>
06:45:44:
06:45:44:  <!-- Folding Slots -->
06:45:44:  <slot id='0' type='CPU'>
06:45:44:    <idle v='true'/>
06:45:44:  </slot>
06:45:44:  <slot id='1' type='GPU'>
06:45:44:  </slot>
06:45:44:</config>
06:45:44:Trying to access database...
06:45:44:Successfully acquired database lock
06:45:44:Enabled folding slot 00: PAUSED cpu:15 (waiting for idle)
06:45:44:Enabled folding slot 01: PAUSED gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 (waiting for idle)
08:20:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:21:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:21:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:21:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:21:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:22:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:22:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:22:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:22:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:23:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:23:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:23:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:24:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:24:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:24:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:24:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:25:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:25:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:25:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:25:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:26:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:26:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:26:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:26:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:27:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:27:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:27:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:28:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:28:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:28:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:28:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:29:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:29:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:29:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:29:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:30:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:30:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:30:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:30:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:31:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:31:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:31:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:32:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:32:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:32:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:32:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:33:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:33:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:33:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:33:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:34:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:34:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:34:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:34:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:35:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:35:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:35:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:36:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:36:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:36:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:36:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:37:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:37:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:37:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:37:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:38:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:38:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:38:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:38:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:39:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:39:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:39:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:40:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:40:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:40:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:40:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:41:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:41:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:41:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:41:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:42:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:42:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:42:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:42:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:43:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:43:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:43:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:44:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:44:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:44:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:44:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:45:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:45:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:45:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:45:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:46:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:46:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:46:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:46:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:47:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:47:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:47:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:48:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:48:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:48:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:48:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:49:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:49:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:49:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:49:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:50:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:50:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:50:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:50:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:51:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:51:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
For the log section you posted, both folding slots show as paused, waiting for idle. Does the system ever detect it is idle and try to request WUs?
As for WUs, there are available ones, just more connection requests than the servers can handle. Eventually your system should get some assigned, it is a bit of luck whether your system connects and there is a server that can take another connection and has work of the type requested.
When requesting work, the client will wait an increasing amount of time between requests to avoid having everyone request at once after a server outage from something like a power outage affecting many servers. As such it is not ideally configured for this situation, but is what is there. If the time between requests gets too long, several hours or so, you can pause the client or slot for a minute, and then set it to start again.
