No donor information
EZ8000
Post by EZ8000 »
I’ve been folding for a little bit but I recently found out about the pass key and I wanted to use one. I decided I wanted to change my username and use this new username with the pass key instead of the old one. Since doing this I am unable to see my new username in my team and whenever I view the donor info for the new username it says that it’s not found.
Any help with this would be greatly appreciated.
Thanks in advance.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: No donor information
Post by Jesse_V »
You have to upload a workunit with the new name and passkey. Then it will also take a little bit of time to show up, I think one day for the system to update.
EZ8000
Post by EZ8000 »
Ah ok, ive uploaded a fair few workloads already. guess it hasn't updated yet mby.
With the new username, or just under the old. Once turned in the username and team attached to the record does not change.
If you have turned in with the new name, there is a backlog of stats entries, they should show up eventually.
EZ8000
Post by EZ8000 »
ok cheers so i should just wait and itll show up eventually?
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
EZ8000 wrote:ok cheers so i should just wait and itll show up eventually?
Yes, I think so.
