I'm new to F@H and after some troubles, I got it running on my GPU, theoretically.
It's not just that I get no WUs, it seems, I'm not even been blessed with an ID to get WUs.
I already have set up a client on my small home server running Ubuntu, this one gets WUs, from time to time. So I don't think, it's a general network problem on my side.
*********************** Log Started 2020-03-20T21:18:10Z ***********************
21:18:10:************************* Folding@home Client *************************
21:18:10: Website: https://foldingathome.org/
21:18:10: Copyright: (c) 2009-2018 foldingathome.org
21:18:10: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:18:10: Args: --open-web-control
21:18:10: Config: D:\FatHData\config.xml
21:18:10:******************************** Build ********************************
21:18:10: Version: 7.5.1
21:18:10: Date: May 11 2018
21:18:10: Time: 13:06:32
21:18:10: Repository: Git
21:18:10: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
21:18:10: Branch: master
21:18:10: Compiler: Visual C++ 2008
21:18:10: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:18:10: Platform: win32 10
21:18:10: Bits: 32
21:18:10: Mode: Release
21:18:10:******************************* System ********************************
21:18:10: CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
21:18:10: CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
21:18:10: CPUs: 12
21:18:10: Memory: 15.94GiB
21:18:10: Free Memory: 11.65GiB
21:18:10: Threads: WINDOWS_THREADS
21:18:10: OS Version: 6.2
21:18:10: Has Battery: false
21:18:10: On Battery: false
21:18:10: UTC Offset: 1
21:18:10: PID: 1964
21:18:10: CWD: D:\FatHData
21:18:10: OS: Windows 10 Enterprise
21:18:10: OS Arch: AMD64
21:18:10: GPUs: 1
21:18:10: GPU 0: Bus:5 Slot:0 Func:0 AMD:5 Vega 10 XL/XT [Radeon RX Vega 56/64]
21:18:10: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
21:18:10: angegebene Modul wurde nicht gefunden.
21:18:10:
21:18:10:OpenCL Device 0: Platform:0 Device:0 Bus:5 Slot:0 Compute:1.2 Driver:3004.8
21:18:10: Win32 Service: false
21:18:10:***********************************************************************
21:18:10:<config>
21:18:10: <!-- Folding Core -->
21:18:10: <core-priority v='low'/>
21:18:10:
21:18:10: <!-- Network -->
21:18:10: <proxy v=':8080'/>
21:18:10:
21:18:10: <!-- User Information -->
21:18:10: <passkey v='********************************'/>
21:18:10: <team v='239216'/>
21:18:10: <user v='DHAmoKK'/>
21:18:10:
21:18:10: <!-- Folding Slots -->
21:18:10: <slot id='0' type='CPU'/>
21:18:10:</config>
21:18:10:Trying to access database...
21:18:10:Successfully acquired database lock
21:18:10:Enabled folding slot 00: READY cpu:11
21:18:10:WU00:FS00:Connecting to 65.254.110.245:8080
21:18:11:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
21:18:11:WU00:FS00:Connecting to 18.218.241.186:80
21:18:12:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
21:18:12:ERROR:WU00:FS00:Exception: Could not get an assignment ID
21:18:12:WU00:FS00:Connecting to 65.254.110.245:8080
21:18:12:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
21:18:12:WU00:FS00:Connecting to 18.218.241.186:80
21:18:13:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
21:18:13:ERROR:WU00:FS00:Exception: Could not get an assignment ID
21:18:25:Adding folding slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64]
21:18:25:Removing old file 'configs/config-20200320-104512.xml'
21:18:25:Saving configuration to config.xml
21:18:25:<config>
21:18:25: <!-- Folding Core -->
21:18:25: <core-priority v='low'/>
21:18:25:
21:18:25: <!-- Network -->
21:18:25: <proxy v=':8080'/>
21:18:25:
21:18:25: <!-- User Information -->
21:18:25: <passkey v='********************************'/>
21:18:25: <team v='239216'/>
21:18:25: <user v='DHAmoKK'/>
21:18:25:
21:18:25: <!-- Folding Slots -->
21:18:25: <slot id='0' type='CPU'/>
21:18:25: <slot id='1' type='GPU'/>
21:18:25:</config>
21:18:26:WU01:FS01:Connecting to 65.254.110.245:8080
21:18:26:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
21:18:26:WU01:FS01:Connecting to 18.218.241.186:80
21:18:26:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
21:18:26:ERROR:WU01:FS01:Exception: Could not get an assignment ID
21:18:27:WU01:FS01:Connecting to 18.218.241.186:80
21:18:27:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
21:18:27:ERROR:WU01:FS01:Exception: Could not get an assignment ID
21:18:40:Removing old file 'configs/config-20200320-104553.xml'
21:18:40:Saving configuration to config.xml
21:18:40:<config>
21:18:40: <!-- Folding Core -->
21:18:40: <core-priority v='low'/>
21:18:40:
21:18:40: <!-- Network -->
21:18:40: <proxy v=':8080'/>
21:18:40:
21:18:40: <!-- User Information -->
21:18:40: <passkey v='********************************'/>
21:18:40: <team v='239216'/>
21:18:40: <user v='DHAmoKK'/>
21:18:40:
21:18:40: <!-- Folding Slots -->
21:18:40: <slot id='1' type='GPU'/>
21:18:40:</config>
21:18:40:WU00:FS00:Slot ID 0 no longer exists and not yet downloaded, dumping
21:18:40:WU00:FS00:Cleaning up
21:19:11:Removing old file 'configs/config-20200320-104725.xml'
21:19:11:Saving configuration to config.xml
21:19:11:<config>
21:19:11: <!-- Folding Core -->
21:19:11: <core-priority v='low'/>
21:19:11:
21:19:11: <!-- Network -->
21:19:11: <proxy v=':8080'/>
21:19:11:
21:19:11: <!-- User Information -->
21:19:11: <passkey v='********************************'/>
21:19:11: <team v='239216'/>
21:19:11: <user v='DHAmoKK'/>
21:19:11:
21:19:11: <!-- Folding Slots -->
21:19:11: <slot id='1' type='GPU'/>
21:19:11:</config>
21:19:26:WU01:FS01:Connecting to 65.254.110.245:8080
21:19:26:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
21:19:26:WU01:FS01:Connecting to 18.218.241.186:80
21:19:27:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
21:19:27:ERROR:WU01:FS01:Exception: Could not get an assignment ID
21:21:03:WU01:FS01:Connecting to 65.254.110.245:8080
21:21:03:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
21:21:03:WU01:FS01:Connecting to 18.218.241.186:80
21:21:04:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
21:21:04:ERROR:WU01:FS01:Exception: Could not get an assignment ID
21:23:41:WU01:FS01:Connecting to 65.254.110.245:8080
21:23:41:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
21:23:41:WU01:FS01:Connecting to 18.218.241.186:80
21:23:41:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
21:23:41:ERROR:WU01:FS01:Exception: Could not get an assignment ID
21:24:51:ERROR:Receive error: 10053: Eine bestehende Verbindung wurde softwaregesteuert
21:24:51:ERROR:durch den Hostcomputer abgebrochen.
21:27:55:WU01:FS01:Connecting to 65.254.110.245:8080
21:27:55:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
21:27:55:WU01:FS01:Connecting to 18.218.241.186:80
21:27:55:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
21:27:56:ERROR:WU01:FS01:Exception: Could not get an assignment ID
21:32:51:Removing old file 'configs/config-20200320-104755.xml'
21:32:51:Saving configuration to config.xml
21:32:51:<config>
21:32:51: <!-- Folding Core -->
21:32:51: <core-priority v='low'/>
21:32:51:
21:32:51: <!-- Network -->
21:32:51: <proxy v=':8080'/>
21:32:51:
21:32:51: <!-- User Information -->
21:32:51: <passkey v='********************************'/>
21:32:51: <team v='239216'/>
21:32:51: <user v='DHAmoKK'/>
21:32:51:
21:32:51: <!-- Folding Slots -->
21:32:51: <slot id='1' type='GPU'/>
21:32:51:</config>
21:34:47:WU01:FS01:Connecting to 65.254.110.245:8080
21:34:47:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
21:34:47:WU01:FS01:Connecting to 18.218.241.186:80
21:34:47:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
21:34:47:ERROR:WU01:FS01:Exception: Could not get an assignment ID
21:45:52:WU01:FS01:Connecting to 65.254.110.245:8080
21:45:52:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
21:45:52:WU01:FS01:Connecting to 18.218.241.186:80
21:45:53:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
21:45:53:ERROR:WU01:FS01:Exception: Could not get an assignment ID
22:03:49:WU01:FS01:Connecting to 65.254.110.245:8080
22:03:49:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
22:03:49:WU01:FS01:Connecting to 18.218.241.186:80
22:03:49:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
22:03:49:ERROR:WU01:FS01:Exception: Could not get an assignment ID
22:14:15:FS01:Paused
22:14:19:FS01:Unpaused
22:14:19:WU01:FS01:Connecting to 65.254.110.245:8080
22:14:19:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
22:14:19:WU01:FS01:Connecting to 18.218.241.186:80
22:14:20:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
22:14:20:ERROR:WU01:FS01:Exception: Could not get an assignment ID
22:15:56:WU01:FS01:Connecting to 65.254.110.245:8080
22:15:56:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
22:15:56:WU01:FS01:Connecting to 18.218.241.186:80
22:15:57:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
22:15:57:ERROR:WU01:FS01:Exception: Could not get an assignment ID
22:18:34:WU01:FS01:Connecting to 65.254.110.245:8080
22:18:34:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
22:18:34:WU01:FS01:Connecting to 18.218.241.186:80
22:18:34:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
22:18:34:ERROR:WU01:FS01:Exception: Could not get an assignment ID
22:22:48:WU01:FS01:Connecting to 65.254.110.245:8080
22:22:48:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
22:22:48:WU01:FS01:Connecting to 18.218.241.186:80
22:22:48:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
22:22:48:ERROR:WU01:FS01:Exception: Could not get an assignment ID
22:29:04:10:127.0.0.1:New Web connection
22:29:39:WU01:FS01:Connecting to 65.254.110.245:8080
22:29:40:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
22:29:40:WU01:FS01:Connecting to 18.218.241.186:80
22:29:40:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
22:29:40:ERROR:WU01:FS01:Exception: Could not get an assignment ID
22:33:15:Clean exit
--lspci
0x8086:0x3cc2:255:10:2:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 2 - 3CC2
0x8086:0x3c83:255:8:3:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 0 - 3C83
0x8086:0x244e:0:30:0:Intel Corporation:PCI-zu-PCI-Br³cke
0x8086:0x3c04:0:2:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 2a - 3C04
0x8086:0x3cc1:255:10:1:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 1 - 3CC1
0x8086:0x3ce6:255:19:4:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QuickPath Interconnect Agent Ring Registers - 3CE6
0x8086:0x3cb8:255:17:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 DDRIO - 3CB8
0x8086:0x3c2a:0:5:2:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Control Status and Global Errors - 3C2A
0x8086:0x3cc0:255:10:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 0 - 3CC0
0x8086:0x3cb7:255:16:7:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 3 - 3CB7
0x8086:0x1d3a:0:22:0:Intel Corporation:Intel(R) 6 Series/C200 Series Management Engine Interface - 1D3A
0x8086:0x3ce4:255:19:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 R2PCIe - 3CE4
0x8086:0x3cb6:255:16:6:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 2 - 3CB6
0x8086:0x3c80:255:8:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link 0 - 3C80
0x8086:0x3ce3:255:11:3:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Semaphore and Scratchpad Configuration Registers - 3CE3
0x8086:0x3cb5:255:16:5:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 3 - 3CB5
0x1022:0x1470:3:0:0:Advanced Micro Devices, Inc. [AMD]:PCI-zu-PCI-Br³cke
0x1022:0x1471:4:0:0:Advanced Micro Devices, Inc. [AMD]:PCI-zu-PCI-Br³cke
0x8086:0x1d10:0:28:0:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 1 - 1D10
0x8086:0x3cb4:255:16:4:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 2 - 3CB4
0x8086:0x1d18:0:28:4:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 5 - 1D18
0x8086:0x1d22:0:31:3:Intel Corporation:Intel(R) C600/X79 series chipset SMBus Host Controller - 1D22
0x1002:0x687f:5:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:Radeon RX Vega
0x8086:0x3c06:0:2:2:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 2c - 3C06
0x8086:0x3cb3:255:16:3:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 1 - 3CB3
0x8086:0x3c2c:0:5:4:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 I/O APIC - 3C2C
0x1002:0xaaf8:5:0:1:Advanced Micro Devices, Inc. [AMD/ATI]:High Definition Audio-Controller
0x8086:0x3c46:255:14:1:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Processor Home Agent Performance Monitoring - 3C46
0x8086:0x3ce0:255:11:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Interrupt Control Registers - 3CE0
0x8086:0x3cb2:255:16:2:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 0 - 3CB2
0x8086:0x3c28:0:5:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Address Map, VTd_Misc, System Management - 3C28
0x8086:0x3c45:255:19:6:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Ring to QuickPath Interconnect Link 1 Performance Monitor - 3C45
0x1b21:0x1042:12:0:0:ASMedia Technology Inc.:USB-xHCI-kompatibler Hostcontroller
0x8086:0x3c03:0:1:1:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 1b - 3C03
0x8086:0x3cb1:255:16:1:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 1 - 3CB1
0x8086:0x3ca8:255:15:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Registers - 3CA8
0x8086:0x3c44:255:19:5:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Ring to QuickPath Interconnect Link 0 Performance Monitor - 3C44
0x8086:0x1d02:0:31:2:Intel Corporation:Intel(R) C600 series chipset SATA AHCI Controller
0x8086:0x3cb0:255:16:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 0 - 3CB0
0x8086:0x1d41:0:31:0:Intel Corporation:Intel(R) C600/X79 series chipset LPC Controller - 1D41
0x8086:0x3c71:255:15:1:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller RAS Registers - 3C71
0x8086:0x3c43:255:19:1:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Ring to PCI Express Performance Monitor - 3C43
0x8086:0x3c00:0:0:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 DMI2 - 3C00
0x1b4b:0x9130:10:0:0:Marvell Technology Group Ltd.:Standardmõ¯iger SATA AHCI- Controller
0x8086:0x3c08:0:3:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 3a in PCI Express Mode - 3C08
0x8086:0x3c94:255:9:4:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 1 - 3C94
0x8086:0x1d2d:0:26:0:Intel Corporation:Intel(R) C600/X79 Series Chipset USB2 Enhanced Host Controller 2 - 1D2D
0x8086:0x3c93:255:9:3:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 1 - 3C93
0x8086:0x1d3e:0:17:0:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Virtual Root Port - 1D3E
0x8086:0x3cf6:255:12:7:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 System Address Decoder - 3CF6
0x1102:0x000b:2:0:0:Creative Labs:Auzentech X-Fi Home Theatr HD
0x1b21:0x1042:11:0:0:ASMedia Technology Inc.:USB-xHCI-kompatibler Hostcontroller
0x8086:0x3cd0:255:10:3:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 3 - 3CD0
0x8086:0x3cf5:255:13:6:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller System Address Decoder 1 - 3CF5
0x8086:0x3cae:255:15:6:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 4 - 3CAE
0x8086:0x1d14:0:28:2:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 3 - 1D14
0x8086:0x3c02:0:1:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 1a - 3C02
0x8086:0x3cf4:255:12:6:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller System Address Decoder 0 - 3CF4
0x8086:0x3c90:255:9:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link 1 - 3C90
0x8086:0x3cad:255:15:5:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 3 - 3CAD
0x8086:0x1d26:0:29:0:Intel Corporation:Intel(R) C600/X79 Series Chipset USB2 Enhanced Host Controller 1 - 1D26
0x8086:0x3ca0:255:14:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Processor Home Agent - 3CA0
0x8086:0x3cac:255:15:4:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 2 - 3CAC
0x1ade:0x3038:6:0:0:Spin Master Ltd.:DVBSky S950 V3 - DVBS/S2 PCIe
0x8086:0x3cab:255:15:3:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 1 - 3CAB
0x8086:0x3ce8:255:12:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Unicast Register 0 - 3CE8
0x8086:0x3ce8:255:12:1:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Unicast Register 0 - 3CE8
0x8086:0x3ce8:255:12:2:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Unicast Register 0 - 3CE8
0x8086:0x3ce8:255:13:0:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Unicast Register 0 - 3CE8
0x8086:0x3ce8:255:13:1:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Unicast Register 0 - 3CE8
0x8086:0x3ce8:255:13:2:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Unicast Register 0 - 3CE8
0x8086:0x1d1a:0:28:5:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 6 - 1D1A
0x8086:0x1503:0:25:0:Intel Corporation:Intel(R) 82579V Gigabit Network Connection
0x8086:0x3caa:255:15:2:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 0 - 3CAA
0x8086:0x3c84:255:8:4:Intel Corporation:Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 0 - 3C84
>clinfo
Number of platforms: 1
Platform Profile: FULL_PROFILE
Platform Version: OpenCL 2.1 AMD-APP (3004.8)
Platform Name: AMD Accelerated Parallel Processing
Platform Vendor: Advanced Micro Devices, Inc.
Platform Extensions: cl_khr_icd cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_amd_event_callback cl_amd_offline_devices
Number of devices: 1
Device Type: CL_DEVICE_TYPE_GPU
Vendor ID: 1002h
Board name: Radeon RX Vega
Device Topology: PCI[ B#5, D#0, F#0 ]
Max compute units: 64
Max work items dimensions: 3
Max work items[0]: 1024
Max work items[1]: 1024
Max work items[2]: 1024
Max work group size: 256
Preferred vector width char: 4
Preferred vector width short: 2
Preferred vector width int: 1
Preferred vector width long: 1
Preferred vector width float: 1
Preferred vector width double: 1
Native vector width char: 4
Native vector width short: 2
Native vector width int: 1
Native vector width long: 1
Native vector width float: 1
Native vector width double: 1
Max clock frequency: 1630Mhz
Address bits: 64
Max memory allocation: 4244635648
Image support: Yes
Max number of images read arguments: 128
Max number of images write arguments: 64
Max image 2D width: 16384
Max image 2D height: 16384
Max image 3D width: 2048
Max image 3D height: 2048
Max image 3D depth: 2048
Max samplers within kernel: 16
Max size of kernel argument: 1024
Alignment (bits) of base address: 2048
Minimum alignment (bytes) for any datatype: 128
Single precision floating point capability
Denorms: No
Quiet NaNs: Yes
Round to nearest even: Yes
Round to zero: Yes
Round to +ve and infinity: Yes
IEEE754-2008 fused multiply-add: Yes
Cache type: Read/Write
Cache line size: 64
Cache size: 16384
Global memory size: 8573157376
Constant buffer size: 4244635648
Max number of constant args: 8
Local memory type: Scratchpad
Local memory size: 32768
Max pipe arguments: 16
Max pipe active reservations: 16
Max pipe packet size: 4244635648
Max global variable size: 3820172032
Max global variable preferred total size: 8573157376
Max read/write image args: 64
Max on device events: 1024
Queue on device max size: 8388608
Max on device queues: 1
Queue on device preferred size: 262144
SVM capabilities:
Coarse grain buffer: Yes
Fine grain buffer: Yes
Fine grain system: No
Atomics: No
Preferred platform atomic alignment: 0
Preferred global atomic alignment: 0
Preferred local atomic alignment: 0
Kernel Preferred work group size multiple: 64
Error correction support: 0
Unified memory for Host and Device: 0
Profiling timer resolution: 1
Device endianess: Little
Available: Yes
Compiler available: Yes
Execution capabilities:
Execute OpenCL kernels: Yes
Execute native function: No
Queue on Host properties:
Out-of-Order: No
Profiling : Yes
Queue on Device properties:
Out-of-Order: Yes
Profiling : Yes
Platform ID: 00007FFE9194BFD0
Device OpenCL C version: OpenCL C 2.0
Driver version: 3004.8 (PAL,HSAIL)
Version: OpenCL 2.0 AMD-APP (3004.8)
Extensions: cl_khr_fp64 cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_khr_gl_depth_images cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_media_ops2 cl_amd_popcnt cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_khr_image2d_from_buffer cl_khr_subgroups cl_khr_gl_event cl_khr_depth_images cl_khr_mipmap_image cl_khr_mipmap_image_writes cl_amd_liquid_flash cl_amd_copy_buffer_p2p cl_amd_planar_yuv
