Does not stat on Idle
gideonDK
Post by gideonDK »
Hi,
I'm back on folding after a loooooong break. And on a new PC.
The problem; it does not start on idle! What to do, how to fix?
Regards
Gideon
PS Good to be back!
davidcoton
Re: Does not stat on Idle
Post by davidcoton »
Look in Advanced Control. What is the log saying?
gideonDK
Post by gideonDK »
Maybe it is running... I just dont hear my fan starting. When folding while I work, the fan goes balistic!
LOG:
13:55:32:WU01:FS00:Starting
13:55:32:WARNING:WU01:FS00:Changed SMP threads from 3 to 1 this can cause some work units to fail
13:55:32:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ag.DAKOFA.000\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 16012 -checkpoint 5 -np 1
13:55:32:WU01:FS00:Started FahCore on PID 9128
13:55:32:WU01:FS00:Core PID:11144
13:55:32:WU01:FS00:FahCore 0xa7 started
13:55:32:WU01:FS00:0xa7:*********************** Log Started 2020-03-20T13:55:32Z ***********************
13:55:32:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:55:32:WU01:FS00:0xa7: Type: 0xa7
13:55:32:WU01:FS00:0xa7: Core: Gromacs
13:55:32:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 9128 -checkpoint 5 -np 1
13:55:32:WU01:FS00:0xa7:************************************ CBang *************************************
13:55:32:WU01:FS00:0xa7: Date: Oct 26 2019
13:55:32:WU01:FS00:0xa7: Time: 01:38:25
13:55:32:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
13:55:32:WU01:FS00:0xa7: Branch: master
13:55:32:WU01:FS00:0xa7: Compiler: Visual C++ 2008
13:55:32:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:55:32:WU01:FS00:0xa7: Platform: win32 10
13:55:32:WU01:FS00:0xa7: Bits: 64
13:55:32:WU01:FS00:0xa7: Mode: Release
13:55:32:WU01:FS00:0xa7:************************************ System ************************************
13:55:32:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
13:55:32:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
13:55:32:WU01:FS00:0xa7: CPUs: 4
13:55:32:WU01:FS00:0xa7: Memory: 7.85GiB
13:55:32:WU01:FS00:0xa7:Free Memory: 2.40GiB
13:55:32:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
13:55:32:WU01:FS00:0xa7: OS Version: 6.2
13:55:32:WU01:FS00:0xa7:Has Battery: true
13:55:32:WU01:FS00:0xa7: On Battery: false
13:55:32:WU01:FS00:0xa7: UTC Offset: 1
13:55:32:WU01:FS00:0xa7: PID: 11144
13:55:32:WU01:FS00:0xa7: CWD: C:\Users\ag.DAKOFA.000\AppData\Roaming\FAHClient\work
13:55:32:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
13:55:32:WU01:FS00:0xa7: Version: 0.0.18
13:55:32:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:55:32:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
13:55:32:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
13:55:32:WU01:FS00:0xa7: Time: 01:52:30
13:55:32:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
13:55:32:WU01:FS00:0xa7:************************************ Build *************************************
13:55:32:WU01:FS00:0xa7: SIMD: avx_256
13:55:32:WU01:FS00:0xa7:********************************************************************************
13:55:32:WU01:FS00:0xa7:Project: 13826 (Run 571, Clone 2, Gen 100)
13:55:32:WU01:FS00:0xa7:Unit: 0x0000007480fccb095c979ac3e7d03825
13:55:32:WU01:FS00:0xa7:Digital signatures verified
13:55:32:WU01:FS00:0xa7:Calling: mdrun -s frame100.tpr -o frame100.trr -x frame100.xtc -cpi state.cpt -cpt 5 -nt 1
13:55:33:WU01:FS00:0xa7:Steps: first=12500000 total=125000
13:55:35:WU01:FS00:0xa7:Completed 76212 out of 125000 steps (60%)
13:55:52:WU01:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
13:55:56:Removing old file 'configs/config-20200314-135313.xml'
13:55:56:Saving configuration to config.xml
13:55:56:<config>
13:55:56: <!-- Folding Core -->
13:55:56: <checkpoint v='5'/>
13:55:56: <core-priority v='low'/>
13:55:56:
13:55:56: <!-- Network -->
13:55:56: <proxy v=':8080'/>
13:55:56:
13:55:56: <!-- Slot Control -->
13:55:56: <power v='LIGHT'/>
13:55:56:
13:55:56: <!-- User Information -->
13:55:56: <team v='40051'/>
13:55:56: <user v='GideonDK'/>
13:55:56:
13:55:56: <!-- Folding Slots -->
13:55:56: <slot id='0' type='CPU'/>
13:55:56:</config>
13:57:07:FS00:Shutting core down
13:57:08:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 11144
13:57:08:WU01:FS00:0xa7:Exiting, please wait. . .
13:57:08:FS00:Shutting core down
13:57:13:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
13:57:13:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:57:58:Removing old file 'configs/config-20200314-140630.xml'
13:57:58:Saving configuration to config.xml
13:57:58:<config>
13:57:58: <!-- Folding Core -->
13:57:58: <checkpoint v='5'/>
13:57:58: <core-priority v='low'/>
13:57:58:
13:57:58: <!-- Network -->
13:57:58: <proxy v=':8080'/>
13:57:58:
13:57:58: <!-- Slot Control -->
13:57:58: <power v='full'/>
13:57:58:
13:57:58: <!-- User Information -->
13:57:58: <team v='40051'/>
13:57:58: <user v='GideonDK'/>
13:57:58:
13:57:58: <!-- Folding Slots -->
13:57:58: <slot id='0' type='CPU'>
13:57:58: <idle v='true'/>
13:57:58: </slot>
13:57:58:</config>
13:58:49:WU01:FS00:Starting
13:58:49:WARNING:WU01:FS00:Changed SMP threads from 1 to 4 this can cause some work units to fail
13:58:49:WARNING:WU01:FS00:AS lowered CPUs from 4 to 1
13:58:49:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ag.DAKOFA.000\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 16012 -checkpoint 5 -np 1
13:58:49:WU01:FS00:Started FahCore on PID 8916
13:58:49:WU01:FS00:Core PID:5688
13:58:49:WU01:FS00:FahCore 0xa7 started
13:58:50:WU01:FS00:0xa7:*********************** Log Started 2020-03-20T13:58:49Z ***********************
13:58:50:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:58:50:WU01:FS00:0xa7: Type: 0xa7
13:58:50:WU01:FS00:0xa7: Core: Gromacs
13:58:50:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 8916 -checkpoint 5 -np 1
13:58:50:WU01:FS00:0xa7:************************************ CBang *************************************
13:58:50:WU01:FS00:0xa7: Date: Oct 26 2019
13:58:50:WU01:FS00:0xa7: Time: 01:38:25
13:58:50:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
13:58:50:WU01:FS00:0xa7: Branch: master
13:58:50:WU01:FS00:0xa7: Compiler: Visual C++ 2008
13:58:50:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:58:50:WU01:FS00:0xa7: Platform: win32 10
13:58:50:WU01:FS00:0xa7: Bits: 64
13:58:50:WU01:FS00:0xa7: Mode: Release
13:58:50:WU01:FS00:0xa7:************************************ System ************************************
13:58:50:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
13:58:50:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
13:58:50:WU01:FS00:0xa7: CPUs: 4
13:58:50:WU01:FS00:0xa7: Memory: 7.85GiB
13:58:50:WU01:FS00:0xa7:Free Memory: 2.15GiB
13:58:50:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
13:58:50:WU01:FS00:0xa7: OS Version: 6.2
13:58:50:WU01:FS00:0xa7:Has Battery: true
13:58:50:WU01:FS00:0xa7: On Battery: false
13:58:50:WU01:FS00:0xa7: UTC Offset: 1
13:58:50:WU01:FS00:0xa7: PID: 5688
13:58:50:WU01:FS00:0xa7: CWD: C:\Users\ag.DAKOFA.000\AppData\Roaming\FAHClient\work
13:58:50:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
13:58:50:WU01:FS00:0xa7: Version: 0.0.18
13:58:50:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:58:50:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
13:58:50:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
13:58:50:WU01:FS00:0xa7: Time: 01:52:30
13:58:50:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
13:58:50:WU01:FS00:0xa7:************************************ Build *************************************
13:58:50:WU01:FS00:0xa7: SIMD: avx_256
13:58:50:WU01:FS00:0xa7:********************************************************************************
13:58:50:WU01:FS00:0xa7:Project: 13826 (Run 571, Clone 2, Gen 100)
13:58:50:WU01:FS00:0xa7:Unit: 0x0000007480fccb095c979ac3e7d03825
13:58:50:WU01:FS00:0xa7:Digital signatures verified
13:58:50:WU01:FS00:0xa7:Calling: mdrun -s frame100.tpr -o frame100.trr -x frame100.xtc -cpi state.cpt -cpt 5 -nt 1
13:58:50:WU01:FS00:0xa7:Steps: first=12500000 total=125000
13:58:53:WU01:FS00:0xa7:Completed 76422 out of 125000 steps (61%)
14:00:11:FS00:Shutting core down
14:00:11:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 5688
14:00:11:WU01:FS00:0xa7:Exiting, please wait. . .
14:00:30:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
14:00:31:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
There is a begin the installer that sometimes sets the request for the very first WU to be for just one CPU thread. Once downloaded that WU will never use more threads. So what is showing is that WU processing on a single core of your CPU, hence the lack of fan noise. It was up to 61%, once it completes and downloads another WU, the next one will use as many threads as are set at the time of the download.
Set on Full that will be 4, Medium 3, and 2 on Light. You can run a WU at fewer threads than are set at download time, but not higher.
