Client seems unable to use more than 32 Threads while a total of 56 are available, is there a way to force the client beyond 32 or an alternative build/Beta build available?
Computer Specs:
-CPU(s):
(2) Xeon E5 2690 V4, 28 cores / 56 Threads (total)
-RAM:
128 GB
-GPU(s):
NVIDIA 2080 TI
NVIDIA 1080 TI
-OS
Windows 10 Pro
-Network Connection
Verizon Fios
-Overclocked:
No
-Stable
Yes
-Client:
FAH 7.5.1
CPU Folding able to use more than 32 cores?
Thirdstorm
Re: CPU Folding able to use more than 32 cores?
Yes, the client can use more than 32 cores, but not on Windows.
Thirdstorm
D'oh, well locked into Windows on this machine, thanks!Joe_H wrote:Yes, the client can use more than 32 cores, but not on Windows.
I meant to say on one WU, but forgot to write that. Some with larger servers running Windows will set up two slots that use more of the cores together. If you do, you need to set them up with specific settings for CPU thread usage instead of leaving it at the default which leaves usage up to the software.
Usable thread counts will be multiples of 2, 3 and sometimes 5. Multiples of prime numbers 7 and greater are not good.
Thirdstorm
So if I'm reading this correctly, if I changed the "0" Folding slot (CPU) to lets say 20 cores and add a second CPU Folding slot of 32 cores that should come close to maxing out the available CPU resources (x2 CPU's, 14 cores per CPU, 28 Threads).Joe_H wrote:I meant to say on one WU, but forgot to write that. Some with larger servers running Windows will set up two slots that use more of the cores together. If you do, you need to set them up with specific settings for CPU thread usage instead of leaving it at the default which leaves usage up to the software....
Thanks BTW, and seems all of the new "Folders" like me are resulting in little work left to be done, keep waiting for more assignments.
