Low GPU Usage
Xostas
Low GPU Usage
Post by Xostas »
Hi, I am folding on CPU and GPU but my GPU usage only goes up to 2% never higher! Why can't I use 100% of my GPU?
CPU stays around 80/90% as expected.
I have chosen full folding power on advanced mode
Thanks for your help.
Xostas
jonault
Re: RX 580 Low GPU Usage
Post by jonault »
I assume you're folding on Windows & using the Activity Monitor to check your GPU usage. Activity Monitor doesn't accurately show the work that F@H is doing on the video card. Supposedly there is a way to fix that, but I'm unfamiliar with the details. You can also use a third party GPU monitor like MSI Afterburner or GPU-Z to get a better picture of what's going on with your GPU (this is what I do).
Xostas
Re: Low GPU Usage
Post by Xostas »
Thanks, I am following my GPU usage via MSI Afterburner that shows always 1-2% never higher, also got GPU temps that are very mild do not correlate to a very high GPU activity. The FAH is folding using the GPU that is for sure because the percentage moves changes but looks very slow.
Re: Low GPU Usage
Welcome to Folding@Home!
If you post the first 200 lines of your Log, we can see whet your PC thinks is configured and happening.
viewtopic.php?f=24&t=26036
The double vision of your opinion and the PCs opinion helps us help.
Xostas
Re: Low GPU Usage
Post by Xostas »
Thanks for your answer, below the log.
*********************** Log Started 2020-03-19T23:08:18Z ***********************
23:08:18:************************* Folding@home Client *************************
23:08:18: Website: https://foldingathome.org/
23:08:18: Copyright: (c) 2009-2018 foldingathome.org
23:08:18: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:08:18: Args: --open-web-control
23:08:18: Config: C:\Users\Xostas\AppData\Roaming\FAHClient\config.xml
23:08:18:******************************** Build ********************************
23:08:18: Version: 7.5.1
23:08:18: Date: May 11 2018
23:08:18: Time: 13:06:32
23:08:18: Repository: Git
23:08:18: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
23:08:18: Branch: master
23:08:18: Compiler: Visual C++ 2008
23:08:18: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:08:18: Platform: win32 10
23:08:18: Bits: 32
23:08:18: Mode: Release
23:08:18:******************************* System ********************************
23:08:18: CPU: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
23:08:18: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:08:18: CPUs: 8
23:08:18: Memory: 15.94GiB
23:08:18: Free Memory: 11.47GiB
23:08:18: Threads: WINDOWS_THREADS
23:08:18: OS Version: 6.2
23:08:18: Has Battery: false
23:08:18: On Battery: false
23:08:18: UTC Offset: -4
23:08:18: PID: 14544
23:08:18: CWD: C:\Users\Xostas\AppData\Roaming\FAHClient
23:08:18: OS: Windows 10 Enterprise
23:08:18: OS Arch: AMD64
23:08:18: GPUs: 1
23:08:18: GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:08:18: 470/480/570/580]
23:08:18: CUDA: Not detected: cuInit() returned 999
23:08:18:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
23:08:18: Win32 Service: false
23:08:18:***********************************************************************
23:08:18:<config>
23:08:18: <!-- Folding Core -->
23:08:18: <core-priority v='low'/>
23:08:18:
23:08:18: <!-- Network -->
23:08:18: <proxy v=':8080'/>
23:08:18:
23:08:18: <!-- Slot Control -->
23:08:18: <power v='full'/>
23:08:18:
23:08:18: <!-- User Information -->
23:08:18: <passkey v='********************************'/>
23:08:18: <user v='Xostas'/>
23:08:18:
23:08:18: <!-- Folding Slots -->
23:08:18: <slot id='0' type='CPU'/>
23:08:18: <slot id='1' type='GPU'/>
23:08:18:</config>
23:08:18:Trying to access database...
23:08:18:Successfully acquired database lock
23:08:18:Enabled folding slot 00: READY cpu:7
23:08:18:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580]
23:08:18:WU00:FS01:Starting
23:08:18:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Xostas\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 14544 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
23:08:19:WU00:FS01:Started FahCore on PID 19044
23:08:19:WU00:FS01:Core PID:20216
23:08:19:WU00:FS01:FahCore 0x22 started
23:08:19:WU00:FS01:0x22:*********************** Log Started 2020-03-19T23:08:19Z ***********************
23:08:19:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
23:08:19:WU00:FS01:0x22: Type: 0x22
23:08:19:WU00:FS01:0x22: Core: Core22
23:08:19:WU00:FS01:0x22: Website: https://foldingathome.org/
23:08:19:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
23:08:19:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
23:08:19:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
23:08:19:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 19044 -checkpoint 15
23:08:19:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
23:08:19:WU00:FS01:0x22: Config: <none>
23:08:19:WU00:FS01:0x22:************************************ Build *************************************
23:08:19:WU00:FS01:0x22: Version: 0.0.2
23:08:19:WU00:FS01:0x22: Date: Dec 6 2019
23:08:19:WU00:FS01:0x22: Time: 21:30:31
23:08:19:WU00:FS01:0x22: Repository: Git
23:08:19:WU00:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
23:08:19:WU00:FS01:0x22: Branch: HEAD
23:08:19:WU00:FS01:0x22: Compiler: Visual C++ 2008
23:08:19:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:08:19:WU00:FS01:0x22: Platform: win32 10
23:08:19:WU00:FS01:0x22: Bits: 64
23:08:19:WU00:FS01:0x22: Mode: Release
23:08:19:WU00:FS01:0x22:************************************ System ************************************
23:08:19:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
23:08:19:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:08:19:WU00:FS01:0x22: CPUs: 8
23:08:19:WU00:FS01:0x22: Memory: 15.94GiB
23:08:19:WU00:FS01:0x22:Free Memory: 11.38GiB
23:08:19:WU00:FS01:0x22: Threads: WINDOWS_THREADS
23:08:19:WU00:FS01:0x22: OS Version: 6.2
23:08:19:WU00:FS01:0x22:Has Battery: false
23:08:19:WU00:FS01:0x22: On Battery: false
23:08:19:WU00:FS01:0x22: UTC Offset: -4
23:08:19:WU00:FS01:0x22: PID: 20216
23:08:19:WU00:FS01:0x22: CWD: C:\Users\Xostas\AppData\Roaming\FAHClient\work
23:08:19:WU00:FS01:0x22: OS: Windows 10 Pro
23:08:19:WU00:FS01:0x22: OS Arch: AMD64
23:08:19:WU00:FS01:0x22:********************************************************************************
23:08:19:WU00:FS01:0x22:Project: 11779 (Run 0, Clone 777, Gen 0)
23:08:19:WU00:FS01:0x22:Unit: 0x000000020d5a98395e73c5d83bd97085
23:08:19:WU00:FS01:0x22:Digital signatures verified
23:08:19:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
23:08:19:WU00:FS01:0x22:Version 0.0.2
23:08:19:WU00:FS01:0x22: Found a checkpoint file
23:08:21:WU02:FS00:Starting
23:08:21:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Xostas\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 14544 -checkpoint 15 -np 7
23:08:21:WU02:FS00:Started FahCore on PID 3440
23:08:21:WU02:FS00:Core PID:3508
23:08:21:WU02:FS00:FahCore 0xa7 started
23:08:21:WU02:FS00:0xa7:*********************** Log Started 2020-03-19T23:08:21Z ***********************
23:08:21:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:08:21:WU02:FS00:0xa7: Type: 0xa7
23:08:21:WU02:FS00:0xa7: Core: Gromacs
23:08:21:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 3440 -checkpoint 15 -np 7
23:08:21:WU02:FS00:0xa7:************************************ CBang *************************************
23:08:21:WU02:FS00:0xa7: Date: Oct 26 2019
23:08:21:WU02:FS00:0xa7: Time: 01:38:25
23:08:21:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:08:21:WU02:FS00:0xa7: Branch: master
23:08:21:WU02:FS00:0xa7: Compiler: Visual C++ 2008
23:08:21:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:08:21:WU02:FS00:0xa7: Platform: win32 10
23:08:21:WU02:FS00:0xa7: Bits: 64
23:08:21:WU02:FS00:0xa7: Mode: Release
23:08:21:WU02:FS00:0xa7:************************************ System ************************************
23:08:21:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
23:08:21:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:08:21:WU02:FS00:0xa7: CPUs: 8
23:08:21:WU02:FS00:0xa7: Memory: 15.94GiB
23:08:21:WU02:FS00:0xa7:Free Memory: 10.90GiB
23:08:21:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
23:08:21:WU02:FS00:0xa7: OS Version: 6.2
23:08:21:WU02:FS00:0xa7:Has Battery: false
23:08:21:WU02:FS00:0xa7: On Battery: false
23:08:21:WU02:FS00:0xa7: UTC Offset: -4
23:08:21:WU02:FS00:0xa7: PID: 3508
23:08:21:WU02:FS00:0xa7: CWD: C:\Users\Xostas\AppData\Roaming\FAHClient\work
23:08:21:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
23:08:21:WU02:FS00:0xa7: Version: 0.0.18
23:08:21:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:08:21:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
23:08:21:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
23:08:21:WU02:FS00:0xa7: Time: 01:52:30
23:08:21:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:08:21:WU02:FS00:0xa7:************************************ Build *************************************
23:08:21:WU02:FS00:0xa7: SIMD: avx_256
23:08:21:WU02:FS00:0xa7:********************************************************************************
23:08:21:WU02:FS00:0xa7:Project: 13826 (Run 417, Clone 5, Gen 0)
23:08:21:WU02:FS00:0xa7:Unit: 0x0000000080fccb095e73b7c3433f212e
23:08:21:WU02:FS00:0xa7:Digital signatures verified
23:08:21:WU02:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
23:08:21:WU02:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -cpi state.cpt -cpt 15 -nt 6
23:08:22:WU02:FS00:0xa7:Steps: first=0 total=125000
23:08:25:WU02:FS00:0xa7:Completed 63122 out of 125000 steps (50%)
23:08:44:WU00:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
23:08:44:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:09:32:WU02:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
23:10:31:WU00:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
23:11:42:WU02:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
23:12:28:WU00:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
jonault
Re: Low GPU Usage
Post by jonault »
Well, you're definitely folding on your GPU. I've had one P11779 WU, and I was getting about 30 seconds/frame on a RTX2080Ti, where you're getting closer to 2 minutes per frame. Does that seem like a reasonable performance ratio for your card? You're only using 6 of your 8 CPU threads for CPU folding, so you have 1 left over for the GPU so that's not an issue. I can't tell whether your AMD drivers are up to date, that would be something to check.
One other perhaps stupid idea - are you sure MSI Afterburner is looking at your GPU? If you have the MB graphics enabled in the BIOS, MSI Afterburner will monitor that also, but if you're not actually using it for anything it would be idle.
That's all I can come up with.
