WU 14553 & 14555
Altrix
WU 14553 & 14555
Post by Altrix »
both on different computers, getting reference kinetic energy nearly double what GPU was getting
20:07:03:WU00:FS02:0x22:Project: 14553 (Run 0, Clone 29, Gen 0)
20:07:03:WU00:FS02:0x22:Unit: 0x0000000180fccb025e725b1a3e83346f
20:07:03:WU00:FS02:0x22:Reading tar file core.xml
20:07:03:WU00:FS02:0x22:Reading tar file integrator.xml
20:07:03:WU00:FS02:0x22:Reading tar file state.xml
20:07:03:WU00:FS02:0x22:Reading tar file system.xml
20:07:03:WU00:FS02:0x22:Digital signatures verified
20:07:03:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
20:07:03:WU00:FS02:0x22:Version 0.0.2
20:07:15:WU00:FS02:0x22:ERROR:Kinetic energy error of 1692.71, threshold of 10
20:07:15:WU00:FS02:0x22:ERROR:Reference Kinetic Energy: 3557.73 | Given Kinetic Energy: 1865.02
20:07:15:WU00:FS02:0x22:Saving result file ..\logfile_01.txt
20:07:15:WU00:FS02:0x22:Saving result file science.log
20:07:15:WU00:FS02:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:07:15:WARNING:WU00:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:07:15:WU00:FS02:Sending unit results: id:00 state:SEND error:FAULTY project:14553 run:0 clone:29 gen:0 core:0x22 unit:0x0000000180fccb025e725b1a3e83346f
Vester
Hardware configuration: Gigabyte Aorus Z590 Pro AX, Intel i9-10850K, 32GB Crucial Ballistix DDR4-2600, Samsung NVMe EVO 980 Pro 256GB, CoolerMaster liquid cooler ML360, Nvidia Titan X (Pascal), Dell Nvidia RTX 3080 10GB 4Y12V, Pop!_OS.
Re: WU 14553 & 14555
Post by Vester »
I had a large number of bad work units in the last batch.
Windows 10 Pro
Radeon HD 7790, Driver 20.2.2, 28 Feb 2020
There were similar errors on Radeon HD 7990 GPUs running blockchain drivers.
20:05:33:WU02:FS01:Downloading 13.37MiB
20:05:35:WU02:FS01:Download complete
20:05:36:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14553 run:0 clone:14 gen:0 core:0x22 unit:0x0000000380fccb025e725b1b68ef74ea
20:05:36:WU02:FS01:Downloading core from http://cores.foldingathome.org/v7/win/6 ... ore_22.fah
20:05:36:WU02:FS01:Connecting to cores.foldingathome.org:80
20:05:36:WU02:FS01:FahCore 22: Downloading 4.04MiB
20:05:37:WU02:FS01:FahCore 22: Download complete
20:05:37:WU02:FS01:Valid core signature
20:05:37:WU02:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe
20:21:22:WU00:FS01:0x21:Completed 25000000 out of 25000000 steps (100%)
20:21:30:WU00:FS01:0x21:Saving result file logfile_01.txt
20:21:30:WU00:FS01:0x21:Saving result file checkpointState.xml
20:21:30:WU00:FS01:0x21:Saving result file checkpt.crc
20:21:30:WU00:FS01:0x21:Saving result file log.txt
20:21:30:WU00:FS01:0x21:Saving result file positions.xtc
20:21:30:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
20:21:34:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:21:34:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14310 run:142 clone:78 gen:5 core:0x21 unit:0x000000050002894c5e6cf76d1e3466bd
20:21:34:WU00:FS01:Uploading 8.58MiB to 155.247.166.220
20:21:34:WU02:FS01:Starting
20:21:34:WU00:FS01:Connecting to 155.247.166.220:8080
20:21:34:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\veste\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 8832 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:21:34:WU02:FS01:Started FahCore on PID 1888
20:21:34:WU02:FS01:Core PID:1996
20:21:34:WU02:FS01:FahCore 0x22 started
20:21:35:WU02:FS01:0x22:*********************** Log Started 2020-03-18T20:21:35Z ***********************
20:21:35:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:21:35:WU02:FS01:0x22: Type: 0x22
20:21:35:WU02:FS01:0x22: Core: Core22
20:21:35:WU02:FS01:0x22: Website: https://foldingathome.org/
20:21:35:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:21:35:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:21:35:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:21:35:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 705 -lifeline 1888 -checkpoint 30
20:21:35:WU02:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0
20:21:35:WU02:FS01:0x22: -gpu 0
20:21:35:WU02:FS01:0x22: Config: <none>
20:21:35:WU02:FS01:0x22:************************************ Build *************************************
20:21:35:WU02:FS01:0x22: Version: 0.0.2
20:21:35:WU02:FS01:0x22: Date: Dec 6 2019
20:21:35:WU02:FS01:0x22: Time: 21:30:31
20:21:35:WU02:FS01:0x22: Repository: Git
20:21:35:WU02:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:21:35:WU02:FS01:0x22: Branch: HEAD
20:21:35:WU02:FS01:0x22: Compiler: Visual C++ 2008
20:21:35:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:21:35:WU02:FS01:0x22: Platform: win32 10
20:21:35:WU02:FS01:0x22: Bits: 64
20:21:35:WU02:FS01:0x22: Mode: Release
20:21:35:WU02:FS01:0x22:************************************ System ************************************
20:21:35:WU02:FS01:0x22: CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
20:21:35:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
20:21:35:WU02:FS01:0x22: CPUs: 4
20:21:35:WU02:FS01:0x22: Memory: 8.00GiB
20:21:35:WU02:FS01:0x22:Free Memory: 5.09GiB
20:21:35:WU02:FS01:0x22: Threads: WINDOWS_THREADS
20:21:35:WU02:FS01:0x22: OS Version: 6.2
20:21:35:WU02:FS01:0x22:Has Battery: false
20:21:35:WU02:FS01:0x22: On Battery: false
20:21:35:WU02:FS01:0x22: UTC Offset: -4
20:21:35:WU02:FS01:0x22: PID: 1996
20:21:35:WU02:FS01:0x22: CWD: C:\Users\veste\AppData\Roaming\FAHClient\work
20:21:35:WU02:FS01:0x22: OS: Windows 10 Pro
20:21:35:WU02:FS01:0x22: OS Arch: AMD64
20:21:35:WU02:FS01:0x22:********************************************************************************
20:21:35:WU02:FS01:0x22:Project: 14553 (Run 0, Clone 14, Gen 0)
20:21:35:WU02:FS01:0x22:Unit: 0x0000000380fccb025e725b1b68ef74ea
20:21:35:WU02:FS01:0x22:Reading tar file core.xml
20:21:35:WU02:FS01:0x22:Reading tar file integrator.xml
20:21:35:WU02:FS01:0x22:Reading tar file state.xml
20:21:35:WU02:FS01:0x22:Reading tar file system.xml
20:21:35:WU02:FS01:0x22:Digital signatures verified
20:21:35:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:21:35:WU02:FS01:0x22:Version 0.0.2
20:22:18:WU00:FS01:Upload complete
20:22:18:WU00:FS01:Server responded WORK_ACK (400)
20:22:18:WU00:FS01:Final credit estimate, 84121.00 points
20:22:18:WU00:FS01:Cleaning up
20:22:21:WU02:FS01:0x22:ERROR:Kinetic energy error of 1692.71, threshold of 10
20:22:21:WU02:FS01:0x22:ERROR:Reference Kinetic Energy: 3557.73 | Given Kinetic Energy: 1865.02
20:22:21:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
20:22:21:WU02:FS01:0x22:Saving result file science.log
20:22:21:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:22:22:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:22:22:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14553 run:0 clone:14 gen:0 core:0x22 unit:0x0000000380fccb025e725b1b68ef74ea
20:22:22:WU02:FS01:Uploading 8.00KiB to 128.252.203.2
20:22:22:WU02:FS01:Connecting to 128.252.203.2:8080
20:22:22:WU02:FS01:Upload complete
20:22:22:WU02:FS01:Server responded WORK_ACK (400)
20:22:22:WU02:FS01:Cleaning up
20:22:22:WU00:FS01:Connecting to 65.254.110.245:8080
20:22:23:WU00:FS01:Assigned to work server 128.252.203.2
20:22:23:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Bonaire XT [Radeon HD 7790] from 128.252.203.2
20:22:23:WU00:FS01:Connecting to 128.252.203.2:8080
20:22:23:WU00:FS01:Downloading 13.07MiB
20:22:29:WU00:FS01:Download 64.55%
20:22:32:WU00:FS01:Download complete
20:22:32:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14555 run:0 clone:125 gen:0 core:0x22 unit:0x0000000380fccb025e726e3ecc94be98
20:22:32:WU00:FS01:Starting
20:22:32:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\veste\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 8832 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:22:32:WU00:FS01:Started FahCore on PID 9560
20:22:32:WU00:FS01:Core PID:3528
20:22:32:WU00:FS01:FahCore 0x22 started
20:22:33:WU00:FS01:0x22:*********************** Log Started 2020-03-18T20:22:33Z ***********************
20:22:33:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:22:33:WU00:FS01:0x22: Type: 0x22
20:22:33:WU00:FS01:0x22: Core: Core22
20:22:33:WU00:FS01:0x22: Website: https://foldingathome.org/
20:22:33:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:22:33:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:22:33:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:22:33:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 9560 -checkpoint 30
20:22:33:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0
20:22:33:WU00:FS01:0x22: -gpu 0
20:22:33:WU00:FS01:0x22: Config: <none>
20:22:33:WU00:FS01:0x22:************************************ Build *************************************
20:22:33:WU00:FS01:0x22: Version: 0.0.2
20:22:33:WU00:FS01:0x22: Date: Dec 6 2019
20:22:33:WU00:FS01:0x22: Time: 21:30:31
20:22:33:WU00:FS01:0x22: Repository: Git
20:22:33:WU00:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:22:33:WU00:FS01:0x22: Branch: HEAD
20:22:33:WU00:FS01:0x22: Compiler: Visual C++ 2008
20:22:33:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:22:33:WU00:FS01:0x22: Platform: win32 10
20:22:33:WU00:FS01:0x22: Bits: 64
20:22:33:WU00:FS01:0x22: Mode: Release
20:22:33:WU00:FS01:0x22:************************************ System ************************************
20:22:33:WU00:FS01:0x22: CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
20:22:33:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
20:22:33:WU00:FS01:0x22: CPUs: 4
20:22:33:WU00:FS01:0x22: Memory: 8.00GiB
20:22:33:WU00:FS01:0x22:Free Memory: 5.29GiB
20:22:33:WU00:FS01:0x22: Threads: WINDOWS_THREADS
20:22:33:WU00:FS01:0x22: OS Version: 6.2
20:22:33:WU00:FS01:0x22:Has Battery: false
20:22:33:WU00:FS01:0x22: On Battery: false
20:22:33:WU00:FS01:0x22: UTC Offset: -4
20:22:33:WU00:FS01:0x22: PID: 3528
20:22:33:WU00:FS01:0x22: CWD: C:\Users\veste\AppData\Roaming\FAHClient\work
20:22:33:WU00:FS01:0x22: OS: Windows 10 Pro
20:22:33:WU00:FS01:0x22: OS Arch: AMD64
20:22:33:WU00:FS01:0x22:********************************************************************************
20:22:33:WU00:FS01:0x22:Project: 14555 (Run 0, Clone 125, Gen 0)
20:22:33:WU00:FS01:0x22:Unit: 0x0000000380fccb025e726e3ecc94be98
20:22:33:WU00:FS01:0x22:Reading tar file core.xml
20:22:33:WU00:FS01:0x22:Reading tar file integrator.xml
20:22:33:WU00:FS01:0x22:Reading tar file state.xml
20:22:33:WU00:FS01:0x22:Reading tar file system.xml
20:22:33:WU00:FS01:0x22:Digital signatures verified
20:22:33:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:22:33:WU00:FS01:0x22:Version 0.0.2
20:22:57:WU00:FS01:0x22:ERROR:Kinetic energy error of 1638.2, threshold of 10
20:22:57:WU00:FS01:0x22:ERROR:Reference Kinetic Energy: 3436.57 | Given Kinetic Energy: 1798.37
20:22:57:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
20:22:57:WU00:FS01:0x22:Saving result file science.log
20:22:57:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:22:58:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:22:58:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14555 run:0 clone:125 gen:0 core:0x22 unit:0x0000000380fccb025e726e3ecc94be98
20:22:58:WU00:FS01:Uploading 8.00KiB to 128.252.203.2
20:22:58:WU00:FS01:Connecting to 128.252.203.2:8080
20:22:58:WU00:FS01:Upload complete
20:22:58:WU00:FS01:Server responded WORK_ACK (400)
20:22:58:WU00:FS01:Cleaning up
20:22:58:WU02:FS01:Connecting to 65.254.110.245:8080
20:22:58:WU02:FS01:Assigned to work server 128.252.203.2
20:22:58:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Bonaire XT [Radeon HD 7790] from 128.252.203.2
20:22:58:WU02:FS01:Connecting to 128.252.203.2:8080
20:23:00:WU02:FS01:Downloading 13.07MiB
20:23:03:WU02:FS01:Download complete
20:23:03:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14555 run:0 clone:133 gen:0 core:0x22 unit:0x0000000180fccb025e726e41fd1be060
20:23:03:WU02:FS01:Starting
20:23:03:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\veste\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 8832 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:23:03:WU02:FS01:Started FahCore on PID 6812
20:23:03:WU02:FS01:Core PID:2060
20:23:03:WU02:FS01:FahCore 0x22 started
20:23:04:WU02:FS01:0x22:*********************** Log Started 2020-03-18T20:23:03Z ***********************
20:23:04:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:23:04:WU02:FS01:0x22: Type: 0x22
20:23:04:WU02:FS01:0x22: Core: Core22
20:23:04:WU02:FS01:0x22: Website: https://foldingathome.org/
20:23:04:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:23:04:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:23:04:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:23:04:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 705 -lifeline 6812 -checkpoint 30
20:23:04:WU02:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0
20:23:04:WU02:FS01:0x22: -gpu 0
20:23:04:WU02:FS01:0x22: Config: <none>
20:23:04:WU02:FS01:0x22:************************************ Build *************************************
20:23:04:WU02:FS01:0x22: Version: 0.0.2
20:23:04:WU02:FS01:0x22: Date: Dec 6 2019
20:23:04:WU02:FS01:0x22: Time: 21:30:31
20:23:04:WU02:FS01:0x22: Repository: Git
20:23:04:WU02:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:23:04:WU02:FS01:0x22: Branch: HEAD
20:23:04:WU02:FS01:0x22: Compiler: Visual C++ 2008
20:23:04:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:23:04:WU02:FS01:0x22: Platform: win32 10
20:23:04:WU02:FS01:0x22: Bits: 64
20:23:04:WU02:FS01:0x22: Mode: Release
20:23:04:WU02:FS01:0x22:************************************ System ************************************
20:23:04:WU02:FS01:0x22: CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
20:23:04:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
20:23:04:WU02:FS01:0x22: CPUs: 4
20:23:04:WU02:FS01:0x22: Memory: 8.00GiB
20:23:04:WU02:FS01:0x22:Free Memory: 5.35GiB
20:23:04:WU02:FS01:0x22: Threads: WINDOWS_THREADS
20:23:04:WU02:FS01:0x22: OS Version: 6.2
20:23:04:WU02:FS01:0x22:Has Battery: false
20:23:04:WU02:FS01:0x22: On Battery: false
20:23:04:WU02:FS01:0x22: UTC Offset: -4
20:23:04:WU02:FS01:0x22: PID: 2060
20:23:04:WU02:FS01:0x22: CWD: C:\Users\veste\AppData\Roaming\FAHClient\work
20:23:04:WU02:FS01:0x22: OS: Windows 10 Pro
20:23:04:WU02:FS01:0x22: OS Arch: AMD64
20:23:04:WU02:FS01:0x22:********************************************************************************
20:23:04:WU02:FS01:0x22:Project: 14555 (Run 0, Clone 133, Gen 0)
20:23:04:WU02:FS01:0x22:Unit: 0x0000000180fccb025e726e41fd1be060
20:23:04:WU02:FS01:0x22:Reading tar file core.xml
20:23:04:WU02:FS01:0x22:Reading tar file integrator.xml
20:23:04:WU02:FS01:0x22:Reading tar file state.xml
20:23:04:WU02:FS01:0x22:Reading tar file system.xml
20:23:04:WU02:FS01:0x22:Digital signatures verified
20:23:04:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:23:04:WU02:FS01:0x22:Version 0.0.2
20:23:28:WU02:FS01:0x22:ERROR:Kinetic energy error of 1638.2, threshold of 10
20:23:28:WU02:FS01:0x22:ERROR:Reference Kinetic Energy: 3436.57 | Given Kinetic Energy: 1798.37
20:23:28:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
20:23:28:WU02:FS01:0x22:Saving result file science.log
20:23:28:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:23:29:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:23:29:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14555 run:0 clone:133 gen:0 core:0x22 unit:0x0000000180fccb025e726e41fd1be060
20:23:29:WU02:FS01:Uploading 8.00KiB to 128.252.203.2
20:23:29:WU02:FS01:Connecting to 128.252.203.2:8080
20:23:29:WU00:FS01:Connecting to 65.254.110.245:8080
20:23:29:WU02:FS01:Upload complete
20:23:29:WU02:FS01:Server responded WORK_ACK (400)
20:23:29:WU02:FS01:Cleaning up
20:23:30:WU00:FS01:Assigned to work server 140.163.4.231
20:23:30:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Bonaire XT [Radeon HD 7790] from 140.163.4.231
20:23:30:WU00:FS01:Connecting to 140.163.4.231:8080
20:24:31:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:24:31:WU00:FS01:Connecting to 65.254.110.245:8080
20:24:31:WU00:FS01:Assigned to work server 128.252.203.2
20:24:31:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Bonaire XT [Radeon HD 7790] from 128.252.203.2
20:24:31:WU00:FS01:Connecting to 128.252.203.2:8080
20:24:33:WU00:FS01:Downloading 13.37MiB
20:24:35:WU00:FS01:Download complete
20:24:35:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14553 run:0 clone:78 gen:0 core:0x22 unit:0x0000000380fccb025e725b1aeadd1009
20:24:35:WU00:FS01:Starting
20:24:35:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\veste\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 8832 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:24:35:WU00:FS01:Started FahCore on PID 6612
20:24:35:WU00:FS01:Core PID:9116
20:24:35:WU00:FS01:FahCore 0x22 started
20:24:36:WU00:FS01:0x22:*********************** Log Started 2020-03-18T20:24:35Z ***********************
20:24:36:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:24:36:WU00:FS01:0x22: Type: 0x22
20:24:36:WU00:FS01:0x22: Core: Core22
20:24:36:WU00:FS01:0x22: Website: https://foldingathome.org/
20:24:36:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:24:36:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:24:36:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:24:36:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 6612 -checkpoint 30
20:24:36:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0
20:24:36:WU00:FS01:0x22: -gpu 0
20:24:36:WU00:FS01:0x22: Config: <none>
20:24:36:WU00:FS01:0x22:************************************ Build *************************************
20:24:36:WU00:FS01:0x22: Version: 0.0.2
20:24:36:WU00:FS01:0x22: Date: Dec 6 2019
20:24:36:WU00:FS01:0x22: Time: 21:30:31
20:24:36:WU00:FS01:0x22: Repository: Git
20:24:36:WU00:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:24:36:WU00:FS01:0x22: Branch: HEAD
20:24:36:WU00:FS01:0x22: Compiler: Visual C++ 2008
20:24:36:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:24:36:WU00:FS01:0x22: Platform: win32 10
20:24:36:WU00:FS01:0x22: Bits: 64
20:24:36:WU00:FS01:0x22: Mode: Release
20:24:36:WU00:FS01:0x22:************************************ System ************************************
20:24:36:WU00:FS01:0x22: CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
20:24:36:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
20:24:36:WU00:FS01:0x22: CPUs: 4
20:24:36:WU00:FS01:0x22: Memory: 8.00GiB
20:24:36:WU00:FS01:0x22:Free Memory: 5.38GiB
20:24:36:WU00:FS01:0x22: Threads: WINDOWS_THREADS
20:24:36:WU00:FS01:0x22: OS Version: 6.2
20:24:36:WU00:FS01:0x22:Has Battery: false
20:24:36:WU00:FS01:0x22: On Battery: false
20:24:36:WU00:FS01:0x22: UTC Offset: -4
20:24:36:WU00:FS01:0x22: PID: 9116
20:24:36:WU00:FS01:0x22: CWD: C:\Users\veste\AppData\Roaming\FAHClient\work
20:24:36:WU00:FS01:0x22: OS: Windows 10 Pro
20:24:36:WU00:FS01:0x22: OS Arch: AMD64
20:24:36:WU00:FS01:0x22:********************************************************************************
20:24:36:WU00:FS01:0x22:Project: 14553 (Run 0, Clone 78, Gen 0)
20:24:36:WU00:FS01:0x22:Unit: 0x0000000380fccb025e725b1aeadd1009
20:24:36:WU00:FS01:0x22:Reading tar file core.xml
20:24:36:WU00:FS01:0x22:Reading tar file integrator.xml
20:24:36:WU00:FS01:0x22:Reading tar file state.xml
20:24:36:WU00:FS01:0x22:Reading tar file system.xml
20:24:36:WU00:FS01:0x22:Digital signatures verified
20:24:36:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:24:36:WU00:FS01:0x22:Version 0.0.2
20:25:00:WU00:FS01:0x22:ERROR:Kinetic energy error of 1692.71, threshold of 10
20:25:00:WU00:FS01:0x22:ERROR:Reference Kinetic Energy: 3557.73 | Given Kinetic Energy: 1865.02
20:25:00:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
20:25:00:WU00:FS01:0x22:Saving result file science.log
20:25:00:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:25:01:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:25:01:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14553 run:0 clone:78 gen:0 core:0x22 unit:0x0000000380fccb025e725b1aeadd1009
20:25:01:WU00:FS01:Uploading 8.00KiB to 128.252.203.2
20:25:01:WU00:FS01:Connecting to 128.252.203.2:8080
20:25:01:WU02:FS01:Connecting to 65.254.110.245:8080
20:25:01:WU02:FS01:Assigned to work server 128.252.203.2
20:25:01:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Bonaire XT [Radeon HD 7790] from 128.252.203.2
20:25:01:WU02:FS01:Connecting to 128.252.203.2:8080
20:25:02:WU02:FS01:Downloading 13.07MiB
20:25:02:WU00:FS01:Upload complete
20:25:02:WU00:FS01:Server responded WORK_ACK (400)
20:25:02:WU00:FS01:Cleaning up
20:25:06:WU02:FS01:Download complete
20:25:06:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14555 run:0 clone:136 gen:0 core:0x22 unit:0x0000000480fccb025e726e421abe6cad
20:25:06:WU02:FS01:Starting
20:25:06:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\veste\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 8832 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:25:06:WU02:FS01:Started FahCore on PID 9628
20:25:06:WU02:FS01:Core PID:3796
20:25:06:WU02:FS01:FahCore 0x22 started
20:25:07:WU02:FS01:0x22:*********************** Log Started 2020-03-18T20:25:06Z ***********************
20:25:07:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:25:07:WU02:FS01:0x22: Type: 0x22
20:25:07:WU02:FS01:0x22: Core: Core22
20:25:07:WU02:FS01:0x22: Website: https://foldingathome.org/
20:25:07:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:25:07:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:25:07:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:25:07:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 705 -lifeline 9628 -checkpoint 30
20:25:07:WU02:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0
20:25:07:WU02:FS01:0x22: -gpu 0
20:25:07:WU02:FS01:0x22: Config: <none>
20:25:07:WU02:FS01:0x22:************************************ Build *************************************
20:25:07:WU02:FS01:0x22: Version: 0.0.2
20:25:07:WU02:FS01:0x22: Date: Dec 6 2019
20:25:07:WU02:FS01:0x22: Time: 21:30:31
20:25:07:WU02:FS01:0x22: Repository: Git
20:25:07:WU02:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:25:07:WU02:FS01:0x22: Branch: HEAD
20:25:07:WU02:FS01:0x22: Compiler: Visual C++ 2008
20:25:07:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:25:07:WU02:FS01:0x22: Platform: win32 10
20:25:07:WU02:FS01:0x22: Bits: 64
20:25:07:WU02:FS01:0x22: Mode: Release
20:25:07:WU02:FS01:0x22:************************************ System ************************************
20:25:07:WU02:FS01:0x22: CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
20:25:07:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
20:25:07:WU02:FS01:0x22: CPUs: 4
20:25:07:WU02:FS01:0x22: Memory: 8.00GiB
20:25:07:WU02:FS01:0x22:Free Memory: 5.36GiB
20:25:07:WU02:FS01:0x22: Threads: WINDOWS_THREADS
20:25:07:WU02:FS01:0x22: OS Version: 6.2
20:25:07:WU02:FS01:0x22:Has Battery: false
20:25:07:WU02:FS01:0x22: On Battery: false
20:25:07:WU02:FS01:0x22: UTC Offset: -4
20:25:07:WU02:FS01:0x22: PID: 3796
20:25:07:WU02:FS01:0x22: CWD: C:\Users\veste\AppData\Roaming\FAHClient\work
20:25:07:WU02:FS01:0x22: OS: Windows 10 Pro
20:25:07:WU02:FS01:0x22: OS Arch: AMD64
20:25:07:WU02:FS01:0x22:********************************************************************************
20:25:07:WU02:FS01:0x22:Project: 14555 (Run 0, Clone 136, Gen 0)
20:25:07:WU02:FS01:0x22:Unit: 0x0000000480fccb025e726e421abe6cad
20:25:07:WU02:FS01:0x22:Reading tar file core.xml
20:25:07:WU02:FS01:0x22:Reading tar file integrator.xml
20:25:07:WU02:FS01:0x22:Reading tar file state.xml
20:25:07:WU02:FS01:0x22:Reading tar file system.xml
20:25:07:WU02:FS01:0x22:Digital signatures verified
20:25:07:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:25:07:WU02:FS01:0x22:Version 0.0.2
20:25:31:WU02:FS01:0x22:ERROR:Kinetic energy error of 1638.2, threshold of 10
20:25:31:WU02:FS01:0x22:ERROR:Reference Kinetic Energy: 3436.57 | Given Kinetic Energy: 1798.37
20:25:31:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
20:25:31:WU02:FS01:0x22:Saving result file science.log
20:25:31:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:25:31:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:25:31:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14555 run:0 clone:136 gen:0 core:0x22 unit:0x0000000480fccb025e726e421abe6cad
20:25:31:WU02:FS01:Uploading 8.00KiB to 128.252.203.2
20:25:31:WU02:FS01:Connecting to 128.252.203.2:8080
20:25:32:WU00:FS01:Connecting to 65.254.110.245:8080
20:25:32:WU02:FS01:Upload complete
20:25:32:WU02:FS01:Server responded WORK_ACK (400)
20:25:32:WU02:FS01:Cleaning up
20:25:32:WU00:FS01:Assigned to work server 128.252.203.2
20:25:32:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Bonaire XT [Radeon HD 7790] from 128.252.203.2
20:25:32:WU00:FS01:Connecting to 128.252.203.2:8080
20:25:32:WU00:FS01:Downloading 13.37MiB
20:25:35:WU00:FS01:Download complete
20:25:35:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14553 run:0 clone:150 gen:0 core:0x22 unit:0x0000000180fccb025e725b1a07b83f43
20:25:35:WU00:FS01:Starting
20:25:35:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\veste\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 8832 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:25:35:WU00:FS01:Started FahCore on PID 5680
20:25:35:WU00:FS01:Core PID:9368
20:25:35:WU00:FS01:FahCore 0x22 started
20:25:35:WU00:FS01:0x22:*********************** Log Started 2020-03-18T20:25:35Z ***********************
20:25:35:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:25:35:WU00:FS01:0x22: Type: 0x22
20:25:35:WU00:FS01:0x22: Core: Core22
20:25:35:WU00:FS01:0x22: Website: https://foldingathome.org/
20:25:35:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:25:35:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:25:35:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:25:35:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 5680 -checkpoint 30
20:25:35:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0
20:25:35:WU00:FS01:0x22: -gpu 0
20:25:35:WU00:FS01:0x22: Config: <none>
20:25:35:WU00:FS01:0x22:************************************ Build *************************************
20:25:35:WU00:FS01:0x22: Version: 0.0.2
20:25:35:WU00:FS01:0x22: Date: Dec 6 2019
20:25:35:WU00:FS01:0x22: Time: 21:30:31
20:25:35:WU00:FS01:0x22: Repository: Git
20:25:35:WU00:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:25:35:WU00:FS01:0x22: Branch: HEAD
20:25:35:WU00:FS01:0x22: Compiler: Visual C++ 2008
20:25:35:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:25:35:WU00:FS01:0x22: Platform: win32 10
20:25:35:WU00:FS01:0x22: Bits: 64
20:25:35:WU00:FS01:0x22: Mode: Release
20:25:35:WU00:FS01:0x22:************************************ System ************************************
20:25:35:WU00:FS01:0x22: CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
20:25:35:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
20:25:35:WU00:FS01:0x22: CPUs: 4
20:25:35:WU00:FS01:0x22: Memory: 8.00GiB
20:25:35:WU00:FS01:0x22:Free Memory: 5.36GiB
20:25:35:WU00:FS01:0x22: Threads: WINDOWS_THREADS
20:25:35:WU00:FS01:0x22: OS Version: 6.2
20:25:35:WU00:FS01:0x22:Has Battery: false
20:25:35:WU00:FS01:0x22: On Battery: false
20:25:35:WU00:FS01:0x22: UTC Offset: -4
20:25:35:WU00:FS01:0x22: PID: 9368
20:25:35:WU00:FS01:0x22: CWD: C:\Users\veste\AppData\Roaming\FAHClient\work
20:25:35:WU00:FS01:0x22: OS: Windows 10 Pro
20:25:35:WU00:FS01:0x22: OS Arch: AMD64
20:25:35:WU00:FS01:0x22:********************************************************************************
20:25:35:WU00:FS01:0x22:Project: 14553 (Run 0, Clone 150, Gen 0)
20:25:35:WU00:FS01:0x22:Unit: 0x0000000180fccb025e725b1a07b83f43
20:25:35:WU00:FS01:0x22:Reading tar file core.xml
20:25:35:WU00:FS01:0x22:Reading tar file integrator.xml
20:25:35:WU00:FS01:0x22:Reading tar file state.xml
20:25:35:WU00:FS01:0x22:Reading tar file system.xml
20:25:36:WU00:FS01:0x22:Digital signatures verified
20:25:36:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:25:36:WU00:FS01:0x22:Version 0.0.2
20:26:00:WU00:FS01:0x22:ERROR:Kinetic energy error of 1692.71, threshold of 10
20:26:00:WU00:FS01:0x22:ERROR:Reference Kinetic Energy: 3557.73 | Given Kinetic Energy: 1865.02
20:26:00:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
20:26:00:WU00:FS01:0x22:Saving result file science.log
20:26:00:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:26:00:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:26:00:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14553 run:0 clone:150 gen:0 core:0x22 unit:0x0000000180fccb025e725b1a07b83f43
20:26:00:WU00:FS01:Uploading 8.00KiB to 128.252.203.2
20:26:00:WU00:FS01:Connecting to 128.252.203.2:8080
20:26:00:WU00:FS01:Upload complete
20:26:00:WU00:FS01:Server responded WORK_ACK (400)
20:26:00:WU00:FS01:Cleaning up
20:26:00:WU02:FS01:Connecting to 65.254.110.245:8080
20:26:01:WU02:FS01:Assigned to work server 140.163.4.231
20:26:01:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Bonaire XT [Radeon HD 7790] from 140.163.4.231
20:26:01:WU02:FS01:Connecting to 140.163.4.231:8080
20:27:16:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:27:16:WU02:FS01:Connecting to 65.254.110.245:8080
20:27:17:WU02:FS01:Assigned to work server 128.252.203.2
20:27:17:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Bonaire XT [Radeon HD 7790] from 128.252.203.2
20:27:17:WU02:FS01:Connecting to 128.252.203.2:8080
20:27:17:WU02:FS01:Downloading 13.07MiB
20:27:19:WU02:FS01:Download complete
20:27:19:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14555 run:0 clone:3 gen:0 core:0x22 unit:0x0000000280fccb025e726de5c3a1f440
20:27:19:WU02:FS01:Starting
20:27:19:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\veste\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 8832 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:27:19:WU02:FS01:Started FahCore on PID 1788
20:27:19:WU02:FS01:Core PID:3504
20:27:19:WU02:FS01:FahCore 0x22 started
20:27:20:WU02:FS01:0x22:*********************** Log Started 2020-03-18T20:27:19Z ***********************
20:27:20:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:27:20:WU02:FS01:0x22: Type: 0x22
20:27:20:WU02:FS01:0x22: Core: Core22
20:27:20:WU02:FS01:0x22: Website: https://foldingathome.org/
20:27:20:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:27:20:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:27:20:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:27:20:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 705 -lifeline 1788 -checkpoint 30
20:27:20:WU02:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0
20:27:20:WU02:FS01:0x22: -gpu 0
20:27:20:WU02:FS01:0x22: Config: <none>
20:27:20:WU02:FS01:0x22:************************************ Build *************************************
20:27:20:WU02:FS01:0x22: Version: 0.0.2
20:27:20:WU02:FS01:0x22: Date: Dec 6 2019
20:27:20:WU02:FS01:0x22: Time: 21:30:31
20:27:20:WU02:FS01:0x22: Repository: Git
20:27:20:WU02:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:27:20:WU02:FS01:0x22: Branch: HEAD
20:27:20:WU02:FS01:0x22: Compiler: Visual C++ 2008
20:27:20:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:27:20:WU02:FS01:0x22: Platform: win32 10
20:27:20:WU02:FS01:0x22: Bits: 64
20:27:20:WU02:FS01:0x22: Mode: Release
20:27:20:WU02:FS01:0x22:************************************ System ************************************
20:27:20:WU02:FS01:0x22: CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
20:27:20:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
20:27:20:WU02:FS01:0x22: CPUs: 4
20:27:20:WU02:FS01:0x22: Memory: 8.00GiB
20:27:20:WU02:FS01:0x22:Free Memory: 5.36GiB
20:27:20:WU02:FS01:0x22: Threads: WINDOWS_THREADS
20:27:20:WU02:FS01:0x22: OS Version: 6.2
20:27:20:WU02:FS01:0x22:Has Battery: false
20:27:20:WU02:FS01:0x22: On Battery: false
20:27:20:WU02:FS01:0x22: UTC Offset: -4
20:27:20:WU02:FS01:0x22: PID: 3504
20:27:20:WU02:FS01:0x22: CWD: C:\Users\veste\AppData\Roaming\FAHClient\work
20:27:20:WU02:FS01:0x22: OS: Windows 10 Pro
20:27:20:WU02:FS01:0x22: OS Arch: AMD64
20:27:20:WU02:FS01:0x22:********************************************************************************
20:27:20:WU02:FS01:0x22:Project: 14555 (Run 0, Clone 3, Gen 0)
20:27:20:WU02:FS01:0x22:Unit: 0x0000000280fccb025e726de5c3a1f440
20:27:20:WU02:FS01:0x22:Reading tar file core.xml
20:27:20:WU02:FS01:0x22:Reading tar file integrator.xml
20:27:20:WU02:FS01:0x22:Reading tar file state.xml
20:27:20:WU02:FS01:0x22:Reading tar file system.xml
20:27:20:WU02:FS01:0x22:Digital signatures verified
20:27:20:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:27:20:WU02:FS01:0x22:Version 0.0.2
20:27:44:WU02:FS01:0x22:ERROR:Kinetic energy error of 1638.2, threshold of 10
20:27:44:WU02:FS01:0x22:ERROR:Reference Kinetic Energy: 3436.57 | Given Kinetic Energy: 1798.37
20:27:44:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
20:27:44:WU02:FS01:0x22:Saving result file science.log
20:27:44:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:27:44:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:27:44:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14555 run:0 clone:3 gen:0 core:0x22 unit:0x0000000280fccb025e726de5c3a1f440
20:27:44:WU02:FS01:Uploading 8.00KiB to 128.252.203.2
20:27:44:WU02:FS01:Connecting to 128.252.203.2:8080
20:27:45:WU00:FS01:Connecting to 65.254.110.245:8080
20:27:45:WU02:FS01:Upload complete
20:27:45:WU02:FS01:Server responded WORK_ACK (400)
20:27:45:WU02:FS01:Cleaning up
20:27:45:WU00:FS01:Assigned to work server 128.252.203.2
20:27:45:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Bonaire XT [Radeon HD 7790] from 128.252.203.2
20:27:45:WU00:FS01:Connecting to 128.252.203.2:8080
20:27:45:WU00:FS01:Downloading 13.37MiB
20:27:47:WU00:FS01:Download complete
20:27:47:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14553 run:0 clone:148 gen:0 core:0x22 unit:0x0000000480fccb025e725b1a94e5e4fd
20:27:47:WU00:FS01:Starting
20:27:47:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\veste\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 8832 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:27:47:WU00:FS01:Started FahCore on PID 4980
20:27:47:WU00:FS01:Core PID:7648
20:27:47:WU00:FS01:FahCore 0x22 started
20:27:48:WU00:FS01:0x22:*********************** Log Started 2020-03-18T20:27:48Z ***********************
20:27:48:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:27:48:WU00:FS01:0x22: Type: 0x22
20:27:48:WU00:FS01:0x22: Core: Core22
20:27:48:WU00:FS01:0x22: Website: https://foldingathome.org/
20:27:48:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:27:48:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:27:48:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:27:48:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 4980 -checkpoint 30
20:27:48:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0
20:27:48:WU00:FS01:0x22: -gpu 0
20:27:48:WU00:FS01:0x22: Config: <none>
20:27:48:WU00:FS01:0x22:************************************ Build *************************************
20:27:48:WU00:FS01:0x22: Version: 0.0.2
20:27:48:WU00:FS01:0x22: Date: Dec 6 2019
20:27:48:WU00:FS01:0x22: Time: 21:30:31
20:27:48:WU00:FS01:0x22: Repository: Git
20:27:48:WU00:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:27:48:WU00:FS01:0x22: Branch: HEAD
20:27:48:WU00:FS01:0x22: Compiler: Visual C++ 2008
20:27:48:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:27:48:WU00:FS01:0x22: Platform: win32 10
20:27:48:WU00:FS01:0x22: Bits: 64
20:27:48:WU00:FS01:0x22: Mode: Release
20:27:48:WU00:FS01:0x22:************************************ System ************************************
20:27:48:WU00:FS01:0x22: CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
20:27:48:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
20:27:48:WU00:FS01:0x22: CPUs: 4
20:27:48:WU00:FS01:0x22: Memory: 8.00GiB
20:27:48:WU00:FS01:0x22:Free Memory: 5.37GiB
20:27:48:WU00:FS01:0x22: Threads: WINDOWS_THREADS
20:27:48:WU00:FS01:0x22: OS Version: 6.2
20:27:48:WU00:FS01:0x22:Has Battery: false
20:27:48:WU00:FS01:0x22: On Battery: false
20:27:48:WU00:FS01:0x22: UTC Offset: -4
20:27:48:WU00:FS01:0x22: PID: 7648
20:27:48:WU00:FS01:0x22: CWD: C:\Users\veste\AppData\Roaming\FAHClient\work
20:27:48:WU00:FS01:0x22: OS: Windows 10 Pro
20:27:48:WU00:FS01:0x22: OS Arch: AMD64
20:27:48:WU00:FS01:0x22:********************************************************************************
20:27:48:WU00:FS01:0x22:Project: 14553 (Run 0, Clone 148, Gen 0)
20:27:48:WU00:FS01:0x22:Unit: 0x0000000480fccb025e725b1a94e5e4fd
20:27:48:WU00:FS01:0x22:Reading tar file core.xml
20:27:48:WU00:FS01:0x22:Reading tar file integrator.xml
20:27:48:WU00:FS01:0x22:Reading tar file state.xml
20:27:48:WU00:FS01:0x22:Reading tar file system.xml
20:27:48:WU00:FS01:0x22:Digital signatures verified
20:27:48:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:27:48:WU00:FS01:0x22:Version 0.0.2
20:28:12:WU00:FS01:0x22:ERROR:Kinetic energy error of 1692.71, threshold of 10
20:28:12:WU00:FS01:0x22:ERROR:Reference Kinetic Energy: 3557.73 | Given Kinetic Energy: 1865.02
20:28:12:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
20:28:12:WU00:FS01:0x22:Saving result file science.log
20:28:12:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:28:13:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:28:13:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14553 run:0 clone:148 gen:0 core:0x22 unit:0x0000000480fccb025e725b1a94e5e4fd
20:28:13:WU00:FS01:Uploading 8.00KiB to 128.252.203.2
20:28:13:WU00:FS01:Connecting to 128.252.203.2:8080
20:28:13:WU02:FS01:Connecting to 65.254.110.245:8080
20:28:13:WU00:FS01:Upload complete
20:28:13:WU00:FS01:Server responded WORK_ACK (400)
20:28:13:WU00:FS01:Cleaning up
20:28:14:WU02:FS01:Assigned to work server 128.252.203.2
20:28:14:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Bonaire XT [Radeon HD 7790] from 128.252.203.2
20:28:14:WU02:FS01:Connecting to 128.252.203.2:8080
20:28:14:WU02:FS01:Downloading 13.07MiB
20:28:16:WU02:FS01:Download complete
20:28:16:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14555 run:0 clone:114 gen:0 core:0x22 unit:0x0000000480fccb025e726e399a86a6d2
20:28:16:WU02:FS01:Starting
20:28:16:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\veste\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 8832 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:28:16:WU02:FS01:Started FahCore on PID 8572
20:28:17:WU02:FS01:Core PID:7776
20:28:17:WU02:FS01:FahCore 0x22 started
20:28:17:WU02:FS01:0x22:*********************** Log Started 2020-03-18T20:28:17Z ***********************
20:28:17:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:28:17:WU02:FS01:0x22: Type: 0x22
20:28:17:WU02:FS01:0x22: Core: Core22
20:28:17:WU02:FS01:0x22: Website: https://foldingathome.org/
20:28:17:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:28:17:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:28:17:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:28:17:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 705 -lifeline 8572 -checkpoint 30
20:28:17:WU02:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0
20:28:17:WU02:FS01:0x22: -gpu 0
20:28:17:WU02:FS01:0x22: Config: <none>
20:28:17:WU02:FS01:0x22:************************************ Build *************************************
20:28:17:WU02:FS01:0x22: Version: 0.0.2
20:28:17:WU02:FS01:0x22: Date: Dec 6 2019
20:28:17:WU02:FS01:0x22: Time: 21:30:31
20:28:17:WU02:FS01:0x22: Repository: Git
20:28:17:WU02:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:28:17:WU02:FS01:0x22: Branch: HEAD
20:28:17:WU02:FS01:0x22: Compiler: Visual C++ 2008
20:28:17:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:28:17:WU02:FS01:0x22: Platform: win32 10
20:28:17:WU02:FS01:0x22: Bits: 64
20:28:17:WU02:FS01:0x22: Mode: Release
20:28:17:WU02:FS01:0x22:************************************ System ************************************
20:28:17:WU02:FS01:0x22: CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
20:28:17:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
20:28:17:WU02:FS01:0x22: CPUs: 4
20:28:17:WU02:FS01:0x22: Memory: 8.00GiB
20:28:17:WU02:FS01:0x22:Free Memory: 5.37GiB
20:28:17:WU02:FS01:0x22: Threads: WINDOWS_THREADS
20:28:17:WU02:FS01:0x22: OS Version: 6.2
20:28:17:WU02:FS01:0x22:Has Battery: false
20:28:17:WU02:FS01:0x22: On Battery: false
20:28:17:WU02:FS01:0x22: UTC Offset: -4
20:28:17:WU02:FS01:0x22: PID: 7776
20:28:17:WU02:FS01:0x22: CWD: C:\Users\veste\AppData\Roaming\FAHClient\work
20:28:17:WU02:FS01:0x22: OS: Windows 10 Pro
20:28:17:WU02:FS01:0x22: OS Arch: AMD64
20:28:17:WU02:FS01:0x22:********************************************************************************
20:28:17:WU02:FS01:0x22:Project: 14555 (Run 0, Clone 114, Gen 0)
20:28:17:WU02:FS01:0x22:Unit: 0x0000000480fccb025e726e399a86a6d2
20:28:17:WU02:FS01:0x22:Reading tar file core.xml
20:28:17:WU02:FS01:0x22:Reading tar file integrator.xml
20:28:17:WU02:FS01:0x22:Reading tar file state.xml
20:28:17:WU02:FS01:0x22:Reading tar file system.xml
20:28:17:WU02:FS01:0x22:Digital signatures verified
20:28:17:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:28:18:WU02:FS01:0x22:Version 0.0.2
20:28:41:WU02:FS01:0x22:ERROR:Kinetic energy error of 1638.2, threshold of 10
20:28:41:WU02:FS01:0x22:ERROR:Reference Kinetic Energy: 3436.57 | Given Kinetic Energy: 1798.37
20:28:41:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
20:28:41:WU02:FS01:0x22:Saving result file science.log
20:28:41:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:28:42:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:28:42:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14555 run:0 clone:114 gen:0 core:0x22 unit:0x0000000480fccb025e726e399a86a6d2
20:28:42:WU02:FS01:Uploading 8.00KiB to 128.252.203.2
20:28:42:WU02:FS01:Connecting to 128.252.203.2:8080
20:28:42:WU00:FS01:Connecting to 65.254.110.245:8080
20:28:42:WU00:FS01:Assigned to work server 128.252.203.2
20:28:42:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Bonaire XT [Radeon HD 7790] from 128.252.203.2
20:28:42:WU00:FS01:Connecting to 128.252.203.2:8080
20:28:43:WU00:FS01:Downloading 13.37MiB
20:28:43:WU02:FS01:Upload complete
20:28:43:WU02:FS01:Server responded WORK_ACK (400)
20:28:43:WU02:FS01:Cleaning up
20:28:45:WU00:FS01:Download complete
20:28:45:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14553 run:0 clone:153 gen:0 core:0x22 unit:0x0000000480fccb025e725b1a6b8117e2
20:28:45:WU00:FS01:Starting
20:28:45:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\veste\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 8832 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:28:45:WU00:FS01:Started FahCore on PID 8284
20:28:45:WU00:FS01:Core PID:1660
20:28:45:WU00:FS01:FahCore 0x22 started
20:28:46:WU00:FS01:0x22:*********************** Log Started 2020-03-18T20:28:45Z ***********************
20:28:46:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:28:46:WU00:FS01:0x22: Type: 0x22
20:28:46:WU00:FS01:0x22: Core: Core22
20:28:46:WU00:FS01:0x22: Website: https://foldingathome.org/
20:28:46:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:28:46:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:28:46:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:28:46:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 8284 -checkpoint 30
20:28:46:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -cuda-device 0
20:28:46:WU00:FS01:0x22: -gpu 0
20:28:46:WU00:FS01:0x22: Config: <none>
20:28:46:WU00:FS01:0x22:************************************ Build *************************************
20:28:46:WU00:FS01:0x22: Version: 0.0.2
20:28:46:WU00:FS01:0x22: Date: Dec 6 2019
20:28:46:WU00:FS01:0x22: Time: 21:30:31
20:28:46:WU00:FS01:0x22: Repository: Git
20:28:46:WU00:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:28:46:WU00:FS01:0x22: Branch: HEAD
20:28:46:WU00:FS01:0x22: Compiler: Visual C++ 2008
20:28:46:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:28:46:WU00:FS01:0x22: Platform: win32 10
20:28:46:WU00:FS01:0x22: Bits: 64
20:28:46:WU00:FS01:0x22: Mode: Release
20:28:46:WU00:FS01:0x22:************************************ System ************************************
20:28:46:WU00:FS01:0x22: CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
20:28:46:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
20:28:46:WU00:FS01:0x22: CPUs: 4
20:28:46:WU00:FS01:0x22: Memory: 8.00GiB
20:28:46:WU00:FS01:0x22:Free Memory: 5.39GiB
20:28:46:WU00:FS01:0x22: Threads: WINDOWS_THREADS
20:28:46:WU00:FS01:0x22: OS Version: 6.2
20:28:46:WU00:FS01:0x22:Has Battery: false
20:28:46:WU00:FS01:0x22: On Battery: false
20:28:46:WU00:FS01:0x22: UTC Offset: -4
20:28:46:WU00:FS01:0x22: PID: 1660
20:28:46:WU00:FS01:0x22: CWD: C:\Users\veste\AppData\Roaming\FAHClient\work
20:28:46:WU00:FS01:0x22: OS: Windows 10 Pro
20:28:46:WU00:FS01:0x22: OS Arch: AMD64
20:28:46:WU00:FS01:0x22:********************************************************************************
20:28:46:WU00:FS01:0x22:Project: 14553 (Run 0, Clone 153, Gen 0)
20:28:46:WU00:FS01:0x22:Unit: 0x0000000480fccb025e725b1a6b8117e2
20:28:46:WU00:FS01:0x22:Reading tar file core.xml
20:28:46:WU00:FS01:0x22:Reading tar file integrator.xml
20:28:46:WU00:FS01:0x22:Reading tar file state.xml
20:28:46:WU00:FS01:0x22:Reading tar file system.xml
20:28:46:WU00:FS01:0x22:Digital signatures verified
20:28:46:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:28:46:WU00:FS01:0x22:Version 0.0.2
20:29:10:WU00:FS01:0x22:ERROR:Kinetic energy error of 1692.71, threshold of 10
20:29:10:WU00:FS01:0x22:ERROR:Reference Kinetic Energy: 3557.73 | Given Kinetic Energy: 1865.02
20:29:10:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
20:29:11:WU00:FS01:0x22:Saving result file science.log
20:29:11:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:29:11:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:29:11:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14553 run:0 clone:153 gen:0 core:0x22 unit:0x0000000480fccb025e725b1a6b8117e2
20:29:11:WU00:FS01:Uploading 8.00KiB to 128.252.203.2
20:29:11:WU00:FS01:Connecting to 128.252.203.2:8080
20:29:11:WU00:FS01:Upload complete
20:29:13:WU00:FS01:Server responded WORK_ACK (400)
20:29:13:WU00:FS01:Cleaning up
I notice you are using the Beta setting. WU's from those project may not be stable yet, that is why they are in beta. Advanced gets you WU's that may still be less stable that normal, but have some beta testing to find the problems.
Vester
Post by Vester »
Excuse me for not taking more time to read it and report it in the correct forum. I removed the beta flag on two installations because I don't spend as much time on the computer as I did years ago when I became a beta tester.
