Uninstall Mojave Help- FahCore_a7 process going crazy
redrumute
Post by redrumute »
The FahCore_a7 process is consuming 300% of CPU. Need to uninstall the app. The instructions on the webpage are incomplete. Only references a non-existant third party uninstaller at the bottom of the page. Please help.
Re: Uninstall Mojave Help- FahCore_a7 process going crazy
That just means it is running on 3 CPU cores of the ones you have, that is the way Activity Monitor displays CPU usage. If your had 8 cores, all of them in use would show as 800%. You can reduce the number of cores in use by moving the slider to Light or use FAHControl to set the number to any number from 1 to the maximum number of CPU cores your Mac has. I can provide directions for that if you want.
If you still want to uninstall the app, look inside the Folding@home folder that was installed in Applications. There you will find the Uninstaller.
As for the web page, that is a very old version of the directions. The Uninstaller has been part of the installed software since version 7.4 of the client. I think it reverted to an older edit during the site move from Stanford to the current foldingathome.org website. It is on a long list of fixes to the site that are needed.
TomJohnson
Hardware configuration: F@H Info – V8.5.5 – 9 Machines – 119 CPUs - 1,500K+ PPD
iMac M-4 16,3, 10 CPUs
Mac Pro 14,8, 24 CPUs
Mac Pro 5,1, 24 CPUs
Mac Studio 13,1, 10 CPUs
iMac Pro 1,1, 16 CPUs
Mac Book Pro 17,1, 8 CPUs
Mac Book Pro 13,3, 8 CPUs
HP Pavilion, 12 CPUs
SONY VAIO, 8 CPUs
Folding 24/7 since 1/1/2004
Rank - 2219 / Points - 2,785,861,627 as of 5/13/2026
Post by TomJohnson »
redrumute wrote:The FahCore_a7 process is consuming 300% of CPU. Need to uninstall the app. The instructions on the webpage are incomplete. Only references a non-existant third party uninstaller at the bottom of the page. Please help.
FYI - Activity Monitor app CPU usage shows my Mac Pro ID 5,1 with 24 cores using 2,200% of available 2,400% for FahCore_a7 processing.
I use Macs Fan Control V1.4.12 to adjust my multiple fans RPM to maintain 150 degree F temp while running Folding Power at Full.
Mac Pro M-2 14,8, 24 CPUs
iMac Pro 1,1, 15 CPUs
HP Pavilion 12 CPUs
Sony VAIO 8 CPUs
redrumute
Post by redrumute »
@Joe_H thank you. I found the uninstall file in the folder as you said. Thanks so much. I have found that the fans start to run quite loud with the 3 cores running at 300%. I may try and reduce the number of cores in use. I will let you know if i have any further questions.
