Basically there are a few people with the username I use on folding. I don't want to change that username because I've accumulated a load of points. I was hoping to create my own team so I can more easily track my points without getting lost in the names, but I'm worried, will the points carry across. Baring in mind I haven't joined a team before?
Thanks in advance!
Do points migrate when first joining a team?
DeeGee
- Hardware configuration: Asus Crosshair Hero VIII, AMD Ryzen 3950x, 2x8GB 3600MHz DDR4, Radeon VII, Win10
Asus Crosshair Hero VII, Amd Ryzen 3900x, 2x16GB 3200MHz DDR4, GeForce 980 TI, Kubuntu 19.10 - Location: Finland
Re: Do points migrate when first joining a team?
Any points you get only account for the team you made them in. For example my stats (if they load, the servers are really struggling at the moment).
https://stats.foldingathome.org/donor/49630
You do have a passkey, So at least something differentiates you from the other users with the same name?
https://foldingathome.org/support/faq/points/passkey/
