GPU2 ATI projects : unexplained EUE
I don't know want happened here :( :
[10:15:31] Completed 31%
[10:16:41] Completed 32%
[10:16:41] mdrun_gpu returned -1
[10:16:41] Going to send back what have done.
[10:16:42] logfile size: 31788 info=31788 bed=25 hdr=1
[10:16:42] - Writing 32326 bytes of core data to disk...
[10:16:42] Done: 31814 -> 5661 (compressed to 17.7 percent)
[10:16:42]   ... Done.
[10:16:42]
[10:16:42] Folding@home Core Shutdown: EARLY_UNIT_END
[10:16:45] CoreStatus = 72 (114)
This one came with a VPU recover windows :
[22:27:30] Project: 4731 (Run 1, Clone 23, Gen 13)
[23:48:49] Completed 69%
[23:49:58] Completed 70%
[23:49:58] mdrun_gpu returned -1
[23:49:58] Going to send back what have done.
[23:49:59] logfile size: 53344 info=53344 bed=25 hdr=1
[23:49:59] - Writing 53882 bytes of core data to disk...
[23:49:59] Done: 53370 -> 6577 (compressed to 12.3 percent)
[23:49:59]   ... Done.
[23:49:59]
[23:49:59] Folding@home Core Shutdown: EARLY_UNIT_END
[23:50:03] CoreStatus = 72 (114)
Re: Project: 4731 (Run 3, Clone 110, Gen 5) + another one
My GPU is on strike today :roll: :
[10:21:18] Project: 4726 (Run 1, Clone 13, Gen 11)
[11:02:10] Completed 37%
[11:03:20] Completed 38%
[11:03:20] mdrun_gpu returned -1
[11:03:20] Going to send back what have done.
[11:03:21] logfile size: 35375 info=35375 bed=25 hdr=1
[11:03:21] - Writing 35913 bytes of core data to disk...
[11:03:21] Done: 35401 -> 5869 (compressed to 16.5 percent)
[11:03:21]   ... Done.
[11:03:21]
[11:03:21] Folding@home Core Shutdown: EARLY_UNIT_END
[11:03:25] CoreStatus = 72 (114)
I won't report more EUE ... I need to check GPU stability, so I turned it off for a while ...
mhouston
Scientist
Post by mhouston »
Hrmm. Are you still running your GPU at high clocks?
mhouston wrote:Hrmm. Are you still running your GPU at high clocks?
This one used to be stable (3870 @ 860 MHz) ... that's why I posted, to get confirmation that some else was able to complete the WU, and that my overclocking is to blame :mrgreen:
edit : I've lost another one (and completed 2 in the meantime) ... I'm removing some MHz ... :
[15:01:17] Project: 4731 (Run 2, Clone 32, Gen 19)
[18:03:53] Completed 71%
[18:05:02] Completed 72%
[18:05:02] mdrun_gpu returned -1
[18:05:02] Going to send back what have done.
[18:05:03] Timer requesting checkpoint
[18:05:03] logfile size: 54471 info=54471 bed=25 hdr=1
[18:05:03] - Writing 55009 bytes of core data to disk...
[18:05:03] Done: 54497 -> 6624 (compressed to 12.1 percent)
[18:05:03]   ... Done.
[18:05:03]
[18:05:03] Folding@home Core Shutdown: EARLY_UNIT_END
[18:05:07] CoreStatus = 72 (114)
Lost another one @ 850 MHz (a p4727) ... but the next one folded well (p4731) :
[18:05:21] Project: 4727 (Run 3, Clone 159, Gen 7)
[19:26:20] Completed 68%
[19:27:31] Completed 69%
[19:27:31] mdrun_gpu returned -1
[19:27:31] Going to send back what have done.
[19:27:32] logfile size: 52779 info=52779 bed=25 hdr=1
[19:27:32] - Writing 53317 bytes of core data to disk...
[19:27:32] Done: 52805 -> 6533 (compressed to 12.3 percent)
[19:27:32]   ... Done.
[19:27:32]
[19:27:32] Folding@home Core Shutdown: EARLY_UNIT_END
[19:27:35] CoreStatus = 72 (114)
Reducing clock to 800 MHz :?
Re: Project: 4731 (Run 3, Clone 110, Gen 5) and some more ...
I hope the problem is not poping again after 24H of continuous operation :
--- Opening Log file [June 23 23:52:01]
[22:55:01] Project: 4727 (Run 0, Clone 23, Gen 59)
[22:55:01]
[22:55:01] Assembly optimizations on if available.
[22:55:01] Entering M.D.
[22:55:07] Working on 544 p4709_fip35_ww_domain
[22:55:08] Client config found, loading data.
[22:55:08] Starting GUI Server
[22:56:28] Completed 1%
[22:57:40] Completed 2%
[22:58:52] Completed 3%
[23:00:06] Completed 4%
[23:01:19] Completed 5%
[23:02:29] Completed 6%
[23:03:40] Completed 7%
[23:04:51] Completed 8%
[23:04:51] mdrun_gpu returned -1
[23:04:51] Going to send back what have done.
[23:04:52] logfile size: 18287 info=18287 bed=25 hdr=1
[23:04:52] - Writing 18825 bytes of core data to disk...
[23:04:52] Done: 18313 -> 5005 (compressed to 27.3 percent)
[23:04:52]   ... Done.
[23:04:52]
[23:04:52] Folding@home Core Shutdown: EARLY_UNIT_END
[23:04:55] CoreStatus = 72 (114)
edit : two more at night :
[03:09:47] Project: 4727 (Run 0, Clone 15, Gen 50)
[03:30:00] Completed 17%
[03:31:10] Completed 18%
[03:31:10] mdrun_gpu returned -1
[03:31:10] Going to send back what have done.
[03:31:11] logfile size: 23966 info=23966 bed=25 hdr=1
[03:31:11] - Writing 24504 bytes of core data to disk...
[03:31:11] Done: 23992 -> 5324 (compressed to 22.1 percent)
[03:31:11]   ... Done.
[03:31:11]
[03:31:11] Folding@home Core Shutdown: EARLY_UNIT_END
[03:31:13] CoreStatus = 72 (114)
[03:31:28] Project: 4731 (Run 2, Clone 34, Gen 26)
[05:11:31] Completed 85%
[05:12:42] Completed 86%
[05:12:42] mdrun_gpu returned -1
[05:12:42] Going to send back what have done.
[05:12:43] logfile size: 62491 info=62491 bed=25 hdr=1
[05:12:43] - Writing 63029 bytes of core data to disk...
[05:12:43] Done: 62517 -> 6939 (compressed to 11.0 percent)
[05:12:43]   ... Done.
[05:12:43]
[05:12:43] Folding@home Core Shutdown: EARLY_UNIT_END
[05:12:46] CoreStatus = 72 (114)
This one happened after I played Racedriver GRID (FAH was paused while I was playing) :
[14:42:06] Project: 4727 (Run 2, Clone 96, Gen 41)
[14:53:19] Completed 9%
[14:54:32] Completed 10%
[14:55:38] + Paused
[16:33:58] + Working ...
[16:33:58] Suspending work thread...
[16:33:58] Resuming work thread...
[16:34:05] Completed 11%
[16:34:05] mdrun_gpu returned -1
[16:34:05] Going to send back what have done.
[16:34:06] logfile size: 19944 info=19944 bed=25 hdr=1
[16:34:06] - Writing 20482 bytes of core data to disk...
[16:34:06] Done: 19970 -> 5091 (compressed to 25.4 percent)
[16:34:06]   ... Done.
[16:34:06]
[16:34:06] Folding@home Core Shutdown: EARLY_UNIT_END
[16:34:10] CoreStatus = 72 (114)
