New user. Many errors
Cliff1983
Post by Cliff1983 »
Hey everyone,
Just downloaded the client today. I was getting a lot of the normal errors about the WU's that everyone else seems to be posting about. Now i'm also getting "ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine." over and over again. Is this also due to the server load or.....??
*********************** Log Started 2020-03-18T13:04:17Z ***********************
13:04:17:************************* Folding@home Client *************************
13:04:17:        Website: https://foldingathome.org/
13:04:17:      Copyright: (c) 2009-2018 foldingathome.org
13:04:17:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:04:17:           Args: --open-web-control
13:04:17:         Config: <none>
13:04:17:******************************** Build ********************************
13:04:17:        Version: 7.5.1
13:04:17:           Date: May 11 2018
13:04:17:           Time: 13:06:32
13:04:17:     Repository: Git
13:04:17:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
13:04:17:         Branch: master
13:04:17:       Compiler: Visual C++ 2008
13:04:17:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:04:17:       Platform: win32 10
13:04:17:           Bits: 32
13:04:17:           Mode: Release
13:04:17:******************************* System ********************************
13:04:17:            CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
13:04:17:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
13:04:17:           CPUs: 8
13:04:17:         Memory: 15.91GiB
13:04:17:    Free Memory: 11.41GiB
13:04:17:        Threads: WINDOWS_THREADS
13:04:17:     OS Version: 6.2
13:04:17:    Has Battery: false
13:04:17:     On Battery: false
13:04:17:     UTC Offset: -4
13:04:17:            PID: 18504
13:04:17:            CWD: C:\Users\cliff\AppData\Roaming\FAHClient
13:04:17:             OS: Windows 10 Home
13:04:17:        OS Arch: AMD64
13:04:17:           GPUs: 0
13:04:17:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
13:04:17:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.50
13:04:17:  Win32 Service: false
13:04:17:***********************************************************************
13:04:17:<config>
13:04:17:  <!-- Folding Slots -->
13:04:17:</config>
13:04:17:Connecting to assign1.foldingathome.org:8080
13:04:17:Updated GPUs.txt
13:04:17:Read GPUs.txt
13:04:17:Trying to access database...
13:04:17:Successfully acquired database lock
13:04:17:Enabled folding slot 00: PAUSED cpu:6 (not configured)
13:04:17:Enabled folding slot 01: PAUSED gpu:0:TU106 [GeForce RTX 2060 Super] (not configured)
13:04:20:10:127.0.0.1:New Web connection
13:05:18:Saving configuration to config.xml
13:05:18:<config>
13:05:18:  <!-- Folding Slots -->
13:05:18:  <slot id='0' type='CPU'/>
13:05:18:  <slot id='1' type='GPU'/>
13:05:18:</config>
13:05:18:Set client configured
13:05:18:WU00:FS00:Connecting to 65.254.110.245:8080
13:05:18:WU01:FS01:Connecting to 65.254.110.245:8080
13:05:19:WU00:FS00:Connecting to 65.254.110.245:8080
13:05:19:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:05:19:WU01:FS01:Connecting to 18.218.241.186:80
13:05:19:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:05:19:WU00:FS00:Connecting to 18.218.241.186:80
13:05:19:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:05:19:ERROR:WU01:FS01:Exception: Could not get an assignment
13:05:19:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:05:19:ERROR:WU00:FS00:Exception: Could not get an assignment
13:05:19:WU01:FS01:Connecting to 65.254.110.245:8080
13:05:20:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:05:20:ERROR:WU01:FS01:Exception: Could not get an assignment
13:05:20:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:05:20:ERROR:WU00:FS00:Exception: Could not get an assignment
13:06:19:WU00:FS00:Connecting to 65.254.110.245:8080
13:06:20:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:06:20:WU00:FS00:Connecting to 18.218.241.186:80
13:06:20:WU01:FS01:Connecting to 65.254.110.245:8080
13:06:20:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:06:20:ERROR:WU00:FS00:Exception: Could not get an assignment
13:06:20:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:06:20:WU01:FS01:Connecting to 18.218.241.186:80
13:06:20:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:06:20:ERROR:WU01:FS01:Exception: Could not get an assignment
13:07:57:WU00:FS00:Connecting to 65.254.110.245:8080
13:07:57:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:07:57:WU00:FS00:Connecting to 18.218.241.186:80
13:07:57:WU01:FS01:Connecting to 65.254.110.245:8080
13:07:57:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:07:57:ERROR:WU00:FS00:Exception: Could not get an assignment
13:07:57:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:07:57:WU01:FS01:Connecting to 18.218.241.186:80
13:07:57:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:07:57:ERROR:WU01:FS01:Exception: Could not get an assignment
13:10:06:WU00:FS00:Connecting to 65.254.110.245:8080
13:10:07:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:10:07:WU00:FS00:Connecting to 18.218.241.186:80
13:10:07:WU01:FS01:Connecting to 65.254.110.245:8080
13:10:07:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:10:07:ERROR:WU00:FS00:Exception: Could not get an assignment
13:10:07:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:10:07:WU01:FS01:Connecting to 18.218.241.186:80
13:10:07:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:10:07:ERROR:WU01:FS01:Exception: Could not get an assignment
13:10:23:Saving configuration to config.xml
13:10:23:<config>
13:10:23:  <!-- Slot Control -->
13:10:23:  <power v='FULL'/>
13:10:23:
13:10:23:  <!-- User Information -->
13:10:23:  <passkey v='********************************'/>
13:10:23:  <user v='Cliff'/>
13:10:23:
13:10:23:  <!-- Folding Slots -->
13:10:23:  <slot id='0' type='CPU'>
13:10:23:    <idle v='true'/>
13:10:23:  </slot>
13:10:23:  <slot id='1' type='GPU'>
13:10:23:  </slot>
13:10:23:</config>
13:11:07:WU00:FS00:Connecting to 65.254.110.245:8080
13:11:07:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:11:07:WU00:FS00:Connecting to 18.218.241.186:80
13:11:07:WU01:FS01:Connecting to 65.254.110.245:8080
13:11:07:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:11:07:ERROR:WU00:FS00:Exception: Could not get an assignment
13:11:07:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:11:07:WU01:FS01:Connecting to 18.218.241.186:80
13:11:07:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:11:07:ERROR:WU01:FS01:Exception: Could not get an assignment
13:11:24:Saving configuration to config.xml
13:11:24:<config>
13:11:24:  <!-- Slot Control -->
13:11:24:  <power v='FULL'/>
13:11:24:
13:11:24:  <!-- User Information -->
13:11:24:  <passkey v='********************************'/>
13:11:24:  <user v='Cliff'/>
13:11:24:
13:11:24:  <!-- Folding Slots -->
13:11:24:  <slot id='0' type='CPU'/>
13:11:24:  <slot id='1' type='GPU'/>
13:11:24:</config>
13:12:44:WU00:FS00:Connecting to 65.254.110.245:8080
13:12:44:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:12:44:WU00:FS00:Connecting to 18.218.241.186:80
13:12:44:WU01:FS01:Connecting to 65.254.110.245:8080
13:12:44:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:12:44:ERROR:WU00:FS00:Exception: Could not get an assignment
13:12:44:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:12:44:WU01:FS01:Connecting to 18.218.241.186:80
13:12:44:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:12:44:ERROR:WU01:FS01:Exception: Could not get an assignment
13:15:21:WU00:FS00:Connecting to 65.254.110.245:8080
13:15:21:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:15:21:WU00:FS00:Connecting to 18.218.241.186:80
13:15:21:WU01:FS01:Connecting to 65.254.110.245:8080
13:15:21:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:15:21:ERROR:WU00:FS00:Exception: Could not get an assignment
13:15:21:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:15:21:WU01:FS01:Connecting to 18.218.241.186:80
13:15:22:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:15:22:ERROR:WU01:FS01:Exception: Could not get an assignment
13:19:35:WU00:FS00:Connecting to 65.254.110.245:8080
13:19:35:WU00:FS00:Assigned to work server 128.252.203.9
13:19:35:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 128.252.203.9
13:19:35:WU00:FS00:Connecting to 128.252.203.9:8080
13:19:35:WU01:FS01:Connecting to 65.254.110.245:8080
13:19:36:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:19:36:WU01:FS01:Connecting to 18.218.241.186:80
13:19:36:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:19:36:ERROR:WU01:FS01:Exception: Could not get an assignment
13:19:39:ERROR:WU00:FS00:Exception: Server did not assign work unit
13:26:27:WU00:FS00:Connecting to 65.254.110.245:8080
13:26:27:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:26:27:WU00:FS00:Connecting to 18.218.241.186:80
13:26:27:WU01:FS01:Connecting to 65.254.110.245:8080
13:26:27:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:26:27:ERROR:WU00:FS00:Exception: Could not get an assignment
13:26:27:WU01:FS01:Assigned to work server 155.247.166.220
13:26:27:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU106 [GeForce RTX 2060 Super] from 155.247.166.220
13:26:27:WU01:FS01:Connecting to 155.247.166.220:8080
13:26:28:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
13:37:32:WU00:FS00:Connecting to 65.254.110.245:8080
13:37:32:WU01:FS01:Connecting to 65.254.110.245:8080
13:37:33:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:37:33:WU00:FS00:Connecting to 18.218.241.186:80
13:37:33:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:37:33:ERROR:WU00:FS00:Exception: Could not get an assignment
13:37:33:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:37:33:WU01:FS01:Connecting to 18.218.241.186:80
13:37:34:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:37:34:ERROR:WU01:FS01:Exception: Could not get an assignment
13:55:29:WU00:FS00:Connecting to 65.254.110.245:8080
13:55:29:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:55:29:WU00:FS00:Connecting to 18.218.241.186:80
13:55:29:WU01:FS01:Connecting to 65.254.110.245:8080
13:55:29:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:55:29:ERROR:WU00:FS00:Exception: Could not get an assignment
13:55:29:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:55:29:WU01:FS01:Connecting to 18.218.241.186:80
13:55:30:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:55:30:ERROR:WU01:FS01:Exception: Could not get an assignment
14:24:31:WU00:FS00:Connecting to 65.254.110.245:8080
14:24:31:WU01:FS01:Connecting to 65.254.110.245:8080
14:24:32:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:24:32:WU00:FS00:Connecting to 18.218.241.186:80
14:24:32:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:24:32:WU01:FS01:Connecting to 18.218.241.186:80
14:24:32:WU00:FS00:Assigned to work server 155.247.164.214
14:24:32:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.164.214
14:24:32:WU00:FS00:Connecting to 155.247.164.214:8080
14:24:32:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:24:32:ERROR:WU01:FS01:Exception: Could not get an assignment
14:24:35:WU00:FS00:Downloading 1.53MiB
14:24:35:WU00:FS00:Download complete
14:24:35:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14328 run:8 clone:110 gen:3 core:0xa7 unit:0x000000059bf7a4d65e6d0cbb3f1876bf
14:24:35:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
14:24:35:WU00:FS00:Connecting to cores.foldingathome.org:80
14:24:36:WU00:FS00:FahCore a7: Downloading 6.71MiB
14:24:36:WU00:FS00:FahCore a7: Download complete
14:24:36:WU00:FS00:Valid core signature
14:24:36:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
14:24:36:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
14:24:36:WU00:FS00:Starting
14:24:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cliff\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 18504 -checkpoint 15 -np 7
14:24:37:WU00:FS00:Started FahCore on PID 19268
14:24:37:WU00:FS00:Core PID:17296
14:24:37:WU00:FS00:FahCore 0xa7 started
14:24:37:WU00:FS00:0xa7:*********************** Log Started 2020-03-18T14:24:37Z ***********************
14:24:37:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:24:37:WU00:FS00:0xa7:       Type: 0xa7
14:24:37:WU00:FS00:0xa7:       Core: Gromacs
14:24:37:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 19268 -checkpoint 15 -np
14:24:37:WU00:FS00:0xa7:             7
14:24:37:WU00:FS00:0xa7:************************************ CBang *************************************
14:24:37:WU00:FS00:0xa7:       Date: Oct 26 2019
14:24:37:WU00:FS00:0xa7:       Time: 01:38:25
14:24:37:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:24:37:WU00:FS00:0xa7:     Branch: master
14:24:37:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
14:24:37:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:24:37:WU00:FS00:0xa7:   Platform: win32 10
14:24:37:WU00:FS00:0xa7:       Bits: 64
14:24:37:WU00:FS00:0xa7:       Mode: Release
14:24:37:WU00:FS00:0xa7:************************************ System ************************************
14:24:37:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
14:24:37:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
14:24:37:WU00:FS00:0xa7:       CPUs: 8
14:24:37:WU00:FS00:0xa7:     Memory: 15.91GiB
14:24:37:WU00:FS00:0xa7:Free Memory: 11.58GiB
14:24:37:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
14:24:37:WU00:FS00:0xa7: OS Version: 6.2
14:24:37:WU00:FS00:0xa7:Has Battery: false
14:24:37:WU00:FS00:0xa7: On Battery: false
14:24:37:WU00:FS00:0xa7: UTC Offset: -4
14:24:37:WU00:FS00:0xa7:        PID: 17296
14:24:37:WU00:FS00:0xa7:        CWD: C:\Users\cliff\AppData\Roaming\FAHClient\work
14:24:37:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:24:37:WU00:FS00:0xa7:    Version: 0.0.18
14:24:37:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:24:37:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:24:37:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
14:24:37:WU00:FS00:0xa7:       Time: 01:52:30
14:24:37:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:24:38:WU00:FS00:0xa7:   Platform: win32 10
14:24:38:WU00:FS00:0xa7:       Bits: 64
14:24:38:WU00:FS00:0xa7:       Mode: Release
14:24:38:WU00:FS00:0xa7:************************************ Build *************************************
14:24:38:WU00:FS00:0xa7:       SIMD: avx_256
14:24:38:WU00:FS00:0xa7:********************************************************************************
14:24:38:WU00:FS00:0xa7:Project: 14328 (Run 8, Clone 110, Gen 3)
14:24:38:WU00:FS00:0xa7:Unit: 0x000000059bf7a4d65e6d0cbb3f1876bf
14:24:38:WU00:FS00:0xa7:Reading tar file core.xml
14:24:38:WU00:FS00:0xa7:Reading tar file frame3.tpr
14:24:38:WU00:FS00:0xa7:Digital signatures verified
14:24:38:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
14:24:38:WU00:FS00:0xa7:Calling: mdrun -s frame3.tpr -o frame3.trr -cpt 15 -nt 6
14:24:38:WU00:FS00:0xa7:Steps: first=750000 total=250000
14:24:38:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
14:25:08:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
14:25:39:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
14:26:09:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
14:26:38:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
14:27:08:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
14:27:38:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
14:28:08:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
14:28:38:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
14:29:07:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
14:29:37:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
14:30:07:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
14:30:37:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
14:31:06:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
14:31:36:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
14:32:06:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
14:32:36:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
14:33:05:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
14:33:35:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
14:34:05:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
14:34:35:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
14:35:05:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
14:35:34:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
14:36:04:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
14:36:34:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
14:37:03:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
14:37:33:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
14:38:03:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
14:38:33:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
14:39:02:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
14:39:32:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
14:40:02:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
14:40:32:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
14:41:02:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
14:41:31:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
14:42:01:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
14:42:31:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
14:43:00:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
14:43:30:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
14:44:00:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
14:44:30:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
14:45:00:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
14:45:29:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
14:45:59:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
14:46:29:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
14:46:59:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
14:47:29:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
14:47:58:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
14:48:28:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
14:48:58:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
14:49:27:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
14:49:57:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
14:50:27:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
14:50:57:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
14:51:27:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
14:51:57:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
14:52:26:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
14:52:56:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
14:53:26:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
14:53:56:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
14:54:26:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
14:54:56:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
14:55:25:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
14:55:55:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
14:56:25:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
14:56:55:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
14:57:25:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
14:57:54:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
14:58:24:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
14:58:54:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
14:59:24:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
14:59:54:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
15:00:23:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
15:00:53:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
15:01:23:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
15:01:53:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
15:02:22:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
15:02:52:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
15:03:22:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
15:03:52:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
15:04:22:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
15:04:51:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
15:05:21:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
15:05:51:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
15:06:21:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
15:06:51:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
15:07:20:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
15:07:50:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
15:08:20:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
15:08:50:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
15:09:20:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
15:09:50:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
15:10:20:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
15:10:49:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
15:11:19:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
15:11:30:WU01:FS01:Connecting to 65.254.110.245:8080
15:11:31:WU01:FS01:Assigned to work server 140.163.4.231
15:11:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU106 [GeForce RTX 2060 Super] from 140.163.4.231
15:11:31:WU01:FS01:Connecting to 140.163.4.231:8080
15:11:49:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
15:11:52:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
15:11:52:WU01:FS01:Connecting to 140.163.4.231:80
15:12:19:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
15:12:49:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
15:13:16:WU01:FS01:Downloading 4.53MiB
15:13:19:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
15:13:22:WU01:FS01:Download 41.41%
15:13:29:WU01:FS01:Download 95.25%
15:13:30:WU01:FS01:Download complete
15:13:30:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11748 run:0 clone:4023 gen:3 core:0x22 unit:0x000000068ca304e75e6a7ff5e9fc27f0
15:13:30:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
15:13:30:WU01:FS01:Connecting to cores.foldingathome.org:80
15:13:31:WU01:FS01:FahCore 22: Downloading 4.04MiB
15:13:31:WU01:FS01:FahCore 22: Download complete
15:13:32:WU01:FS01:Valid core signature
15:13:32:WU01:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
15:13:32:WU01:FS01:Starting
15:13:32:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cliff\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 18504 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:13:32:WU01:FS01:Started FahCore on PID 7224
15:13:32:WU01:FS01:Core PID:13472
15:13:32:WU01:FS01:FahCore 0x22 started
15:13:32:WU01:FS01:0x22:*********************** Log Started 2020-03-18T15:13:32Z ***********************
15:13:32:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:13:32:WU01:FS01:0x22:       Type: 0x22
15:13:32:WU01:FS01:0x22:       Core: Core22
15:13:32:WU01:FS01:0x22:    Website: https://foldingathome.org/
15:13:32:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
15:13:32:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:13:32:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
15:13:32:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 7224 -checkpoint 15
15:13:32:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
15:13:32:WU01:FS01:0x22:             0 -gpu 0
15:13:32:WU01:FS01:0x22:     Config: <none>
15:13:32:WU01:FS01:0x22:************************************ Build *************************************
15:13:32:WU01:FS01:0x22:    Version: 0.0.2
15:13:32:WU01:FS01:0x22:       Date: Dec 6 2019
15:13:32:WU01:FS01:0x22:       Time: 21:30:31
15:13:32:WU01:FS01:0x22: Repository: Git
15:13:32:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
15:13:32:WU01:FS01:0x22:     Branch: HEAD
15:13:32:WU01:FS01:0x22:   Compiler: Visual C++ 2008
15:13:32:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:13:32:WU01:FS01:0x22:   Platform: win32 10
15:13:32:WU01:FS01:0x22:       Bits: 64
15:13:32:WU01:FS01:0x22:       Mode: Release
15:13:32:WU01:FS01:0x22:************************************ System ************************************
15:13:32:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
15:13:32:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
15:13:32:WU01:FS01:0x22:       CPUs: 8
15:13:32:WU01:FS01:0x22:     Memory: 15.91GiB
15:13:32:WU01:FS01:0x22:Free Memory: 11.49GiB
15:13:32:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
15:13:32:WU01:FS01:0x22: OS Version: 6.2
15:13:32:WU01:FS01:0x22:Has Battery: false
15:13:32:WU01:FS01:0x22: On Battery: false
15:13:32:WU01:FS01:0x22: UTC Offset: -4
15:13:32:WU01:FS01:0x22:        PID: 13472
15:13:32:WU01:FS01:0x22:        CWD: C:\Users\cliff\AppData\Roaming\FAHClient\work
15:13:32:WU01:FS01:0x22:         OS: Windows 10 Home
15:13:32:WU01:FS01:0x22:    OS Arch: AMD64
15:13:32:WU01:FS01:0x22:********************************************************************************
15:13:32:WU01:FS01:0x22:Project: 11748 (Run 0, Clone 4023, Gen 3)
15:13:32:WU01:FS01:0x22:Unit: 0x000000068ca304e75e6a7ff5e9fc27f0
15:13:32:WU01:FS01:0x22:Reading tar file core.xml
15:13:32:WU01:FS01:0x22:Reading tar file integrator.xml
15:13:32:WU01:FS01:0x22:Reading tar file state.xml
15:13:33:WU01:FS01:0x22:Reading tar file system.xml
15:13:33:WU01:FS01:0x22:Digital signatures verified
15:13:33:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:13:33:WU01:FS01:0x22:Version 0.0.2
15:13:49:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
15:13:49:WU02:FS00:Connecting to 65.254.110.245:8080
15:13:49:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:13:49:WU02:FS00:Connecting to 18.218.241.186:80
15:13:49:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:13:49:ERROR:WU02:FS00:Exception: Could not get an assignment
15:13:50:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:13:50:WU02:FS00:Connecting to 18.218.241.186:80
15:13:50:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:13:50:ERROR:WU02:FS00:Exception: Could not get an assignment
15:13:53:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
15:13:53:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:14:20:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
15:14:20:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
15:14:20:WU00:FS00:0xa7:Saving result file frame3.trr
15:14:21:WU00:FS00:0xa7:Saving result file md.log
15:14:21:WU00:FS00:0xa7:Saving result file science.log
15:14:21:WU00:FS00:0xa7:Saving result file traj_comp.xtc
15:14:21:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
15:14:22:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:14:22:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14328 run:8 clone:110 gen:3 core:0xa7 unit:0x000000059bf7a4d65e6d0cbb3f1876bf
15:14:22:WU00:FS00:Uploading 4.95MiB to 155.247.164.214
15:14:22:WU00:FS00:Connecting to 155.247.164.214:8080
15:14:29:WU00:FS00:Upload complete
15:14:29:WU00:FS00:Server responded WORK_ACK (400)
15:14:29:WU00:FS00:Final credit estimate, 3148.00 points
15:14:29:WU00:FS00:Cleaning up
15:14:50:WU02:FS00:Connecting to 65.254.110.245:8080
15:14:50:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:14:50:WU02:FS00:Connecting to 18.218.241.186:80
15:14:50:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:14:50:ERROR:WU02:FS00:Exception: Could not get an assignment
15:14:51:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
15:15:48:WU01:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
15:16:27:WU02:FS00:Connecting to 65.254.110.245:8080
15:16:27:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:16:27:WU02:FS00:Connecting to 18.218.241.186:80
15:16:27:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:16:27:ERROR:WU02:FS00:Exception: Could not get an assignment
15:16:48:WU01:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
15:17:47:WU01:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
15:18:45:WU01:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
15:19:04:WU02:FS00:Connecting to 65.254.110.245:8080
15:19:04:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:19:04:WU02:FS00:Connecting to 18.218.241.186:80
15:19:04:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:19:04:ERROR:WU02:FS00:Exception: Could not get an assignment
15:19:46:WU01:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
15:20:44:WU01:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
15:21:45:WU01:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
15:22:43:WU01:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
15:23:18:WU02:FS00:Connecting to 65.254.110.245:8080
15:23:18:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:23:18:WU02:FS00:Connecting to 18.218.241.186:80
15:23:19:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:23:19:ERROR:WU02:FS00:Exception: Could not get an assignment
15:23:42:WU01:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
15:24:42:WU01:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
15:25:41:WU01:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
15:26:42:WU01:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
15:27:41:WU01:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
15:28:39:WU01:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
15:29:40:WU01:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
15:30:10:WU02:FS00:Connecting to 65.254.110.245:8080
15:30:10:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:30:10:WU02:FS00:Connecting to 18.218.241.186:80
15:30:10:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:30:10:ERROR:WU02:FS00:Exception: Could not get an assignment
15:30:39:WU01:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
15:31:40:WU01:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
15:32:38:WU01:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
15:33:37:WU01:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
15:34:38:WU01:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
15:35:36:WU01:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
15:36:37:WU01:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
15:37:36:WU01:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
15:38:34:WU01:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
15:39:35:WU01:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
15:40:34:WU01:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
15:41:15:WU02:FS00:Connecting to 65.254.110.245:8080
15:41:15:WU02:FS00:Assigned to work server 155.247.164.213
15:41:15:WU02:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.164.213
15:41:15:WU02:FS00:Connecting to 155.247.164.213:8080
15:41:16:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
15:41:34:WU01:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
15:42:33:WU01:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
15:43:32:WU01:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
15:44:33:WU01:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
15:45:32:WU01:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
15:46:33:WU01:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
15:47:31:WU01:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
15:48:30:WU01:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
15:49:31:WU01:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
15:50:29:WU01:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
15:51:30:WU01:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
15:52:29:WU01:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
15:53:28:WU01:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
15:54:28:WU01:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
15:55:27:WU01:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
15:56:28:WU01:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
15:57:27:WU01:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
15:58:25:WU01:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
15:59:12:WU02:FS00:Connecting to 65.254.110.245:8080
15:59:12:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:59:12:WU02:FS00:Connecting to 18.218.241.186:80
15:59:13:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:59:13:ERROR:WU02:FS00:Exception: Could not get an assignment
15:59:26:WU01:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
16:00:25:WU01:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
16:01:25:WU01:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
16:02:24:WU01:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
16:03:23:WU01:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
16:04:23:WU01:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
16:05:22:WU01:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
16:06:23:WU01:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
16:07:21:WU01:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
16:08:20:WU01:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
16:09:21:WU01:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
16:10:19:WU01:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
16:11:20:WU01:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
16:12:19:WU01:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
16:13:17:WU01:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
16:14:18:WU01:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
16:15:17:WU01:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
16:16:18:WU01:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
16:17:16:WU01:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
16:18:15:WU01:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
16:19:15:WU01:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
16:20:14:WU01:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
16:21:15:WU01:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
16:22:13:WU01:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
16:23:12:WU01:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
16:24:13:WU01:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
16:25:11:WU01:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
16:26:12:WU01:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
16:27:11:WU01:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
16:28:09:WU01:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
16:28:14:WU02:FS00:Connecting to 65.254.110.245:8080
16:28:14:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:28:14:WU02:FS00:Connecting to 18.218.241.186:80
16:28:15:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:28:15:ERROR:WU02:FS00:Exception: Could not get an assignment
16:29:10:WU01:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
16:30:09:WU01:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
16:31:10:WU01:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
16:32:08:WU01:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
16:33:07:WU01:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
16:34:07:WU01:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
16:35:06:WU01:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
16:36:07:WU01:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
16:37:05:WU01:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
16:38:04:WU01:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
16:39:05:WU01:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
16:40:03:WU01:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
16:41:04:WU01:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
16:42:03:WU01:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
16:43:01:WU01:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
16:44:02:WU01:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
16:45:01:WU01:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
16:46:02:WU01:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
16:47:00:WU01:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
16:47:59:WU01:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
16:49:00:WU01:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
16:49:58:WU01:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
16:50:59:WU01:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
16:51:58:WU01:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
16:51:58:WU00:FS01:Connecting to 65.254.110.245:8080
16:51:58:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:51:58:WU00:FS01:Connecting to 18.218.241.186:80
16:51:58:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:51:58:ERROR:WU00:FS01:Exception: Could not get an assignment
16:51:59:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:51:59:WU00:FS01:Connecting to 18.218.241.186:80
16:51:59:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:51:59:ERROR:WU00:FS01:Exception: Could not get an assignment
16:52:56:WU01:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
16:52:59:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
16:52:59:WU01:FS01:0x22:Saving result file checkpointState.xml
16:52:59:WU00:FS01:Connecting to 65.254.110.245:8080
16:52:59:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:52:59:WU00:FS01:Connecting to 18.218.241.186:80
16:52:59:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:52:59:ERROR:WU00:FS01:Exception: Could not get an assignment
16:53:00:WU01:FS01:0x22:Saving result file checkpt.crc
16:53:00:WU01:FS01:0x22:Saving result file positions.xtc
16:53:01:WU01:FS01:0x22:Saving result file science.log
16:53:01:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
16:53:01:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:53:01:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11748 run:0 clone:4023 gen:3 core:0x22 unit:0x000000068ca304e75e6a7ff5e9fc27f0
16:53:01:WU01:FS01:Uploading 12.58MiB to 140.163.4.231
16:53:01:WU01:FS01:Connecting to 140.163.4.231:8080
16:53:07:WU01:FS01:Upload 41.25%
16:53:14:WU01:FS01:Upload complete
16:53:15:WU01:FS01:Server responded WORK_ACK (400)
16:53:15:WU01:FS01:Final credit estimate, 87749.00 points
16:53:15:WU01:FS01:Cleaning up
16:54:36:WU00:FS01:Connecting to 65.254.110.245:8080
16:54:36:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:54:36:WU00:FS01:Connecting to 18.218.241.186:80
16:54:36:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:54:36:ERROR:WU00:FS01:Exception: Could not get an assignment
16:57:13:WU00:FS01:Connecting to 65.254.110.245:8080
16:57:13:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:57:13:WU00:FS01:Connecting to 18.218.241.186:80
16:57:13:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:57:13:ERROR:WU00:FS01:Exception: Could not get an assignment
17:01:27:WU00:FS01:Connecting to 65.254.110.245:8080
17:01:28:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:01:28:WU00:FS01:Connecting to 18.218.241.186:80
17:01:28:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:01:28:ERROR:WU00:FS01:Exception: Could not get an assignment
17:08:19:WU00:FS01:Connecting to 65.254.110.245:8080
17:08:19:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:08:19:WU00:FS01:Connecting to 18.218.241.186:80
17:08:19:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:08:19:ERROR:WU00:FS01:Exception: Could not get an assignment
17:15:13:WU02:FS00:Connecting to 65.254.110.245:8080
17:15:13:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:15:13:WU02:FS00:Connecting to 18.218.241.186:80
17:15:13:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:15:13:ERROR:WU02:FS00:Exception: Could not get an assignment
17:19:24:WU00:FS01:Connecting to 65.254.110.245:8080
17:19:24:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:19:24:WU00:FS01:Connecting to 18.218.241.186:80
17:19:25:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:19:25:ERROR:WU00:FS01:Exception: Could not get an assignment
17:37:21:WU00:FS01:Connecting to 65.254.110.245:8080
17:37:21:WU00:FS01:Assigned to work server 128.252.203.2
17:37:21:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU106 [GeForce RTX 2060 Super] from 128.252.203.2
17:37:21:WU00:FS01:Connecting to 128.252.203.2:8080
17:37:42:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:37:42:WU00:FS01:Connecting to 128.252.203.2:80
17:38:04:ERROR:WU00:FS01:Exception: Failed to connect to 128.252.203.2:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:06:23:WU00:FS01:Connecting to 65.254.110.245:8080
18:06:24:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:06:24:WU00:FS01:Connecting to 18.218.241.186:80
18:06:24:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:06:24:ERROR:WU00:FS01:Exception: Could not get an assignment
18:31:14:WU02:FS00:Connecting to 65.254.110.245:8080
18:31:14:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:31:14:WU02:FS00:Connecting to 18.218.241.186:80
18:31:15:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:31:15:ERROR:WU02:FS00:Exception: Could not get an assignment
18:43:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:44:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:53:22:WU00:FS01:Connecting to 65.254.110.245:8080
18:53:22:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:53:22:WU00:FS01:Connecting to 18.218.241.186:80
18:53:23:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:53:23:ERROR:WU00:FS01:Exception: Could not get an assignment
******************************* Date: 2020-03-18 *******************************
20:09:23:WU00:FS01:Connecting to 65.254.110.245:8080
20:09:24:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:09:24:WU00:FS01:Connecting to 18.218.241.186:80
20:09:24:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:09:24:ERROR:WU00:FS01:Exception: Could not get an assignment
20:28:49:Saving configuration to config.xml
20:28:49:<config>
20:28:49:  <!-- Logging -->
20:28:49:  <verbosity v='4'/>
20:28:49:
20:28:49:  <!-- Network -->
20:28:49:  <proxy v=':8080'/>
20:28:49:
20:28:49:  <!-- Slot Control -->
20:28:49:  <power v='FULL'/>
20:28:49:
20:28:49:  <!-- User Information -->
20:28:49:  <passkey v='********************************'/>
20:28:49:  <user v='Cliff'/>
20:28:49:
20:28:49:  <!-- Folding Slots -->
20:28:49:  <slot id='0' type='CPU'/>
20:28:49:  <slot id='1' type='GPU'/>
20:28:49:</config>
20:29:35:Saving configuration to config.xml
20:29:35:<config>
20:29:35:  <!-- Logging -->
20:29:35:  <verbosity v='4'/>
20:29:35:
20:29:35:  <!-- Network -->
20:29:35:  <proxy v=':8080'/>
20:29:35:
20:29:35:  <!-- Slot Control -->
20:29:35:  <power v='FULL'/>
20:29:35:
20:29:35:  <!-- User Information -->
20:29:35:  <passkey v='********************************'/>
20:29:35:  <user v='Cliff'/>
20:29:35:
20:29:35:  <!-- Folding Slots -->
20:29:35:  <slot id='0' type='CPU'/>
20:29:35:  <slot id='1' type='GPU'/>
20:29:35:</config>
20:34:14:WU02:FS00:Connecting to 65.254.110.245:8080
20:34:14:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:34:14:WU02:FS00:Connecting to 18.218.241.186:80
20:34:14:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:34:14:ERROR:WU02:FS00:Exception: Could not get an assignment
20:51:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:51:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:51:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:52:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:52:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:52:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:52:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:53:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
Re: New user. Many errors
That 10053 error you can ignore. It comes from the Web Control and possibly other components of the client not closing their connection properly. On the fix list for the next version of the client.
The failed assignment messages are the ones everyone else is posting about, and "normal" for the current situation with the server loads.
