program dont working
bmwbmw2
Post by bmwbmw2 »
i have problem . computer sending gpu proces . and nothig. but i have off cpu processes. and now hes working on my gpu on cpu procceses IN 0 %.... check jpg , still send error
*********************** Log Started 2020-03-18T16:40:24Z ***********************
16:40:24:************************* Folding@home Client *************************
16:40:24:        Website: https://foldingathome.org/
16:40:24:      Copyright: (c) 2009-2018 foldingathome.org
16:40:24:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:40:24:           Args: --open-web-control
16:40:24:         Config: C:\Users\DESKTOP\AppData\Roaming\FAHClient\config.xml
16:40:24:******************************** Build ********************************
16:40:24:        Version: 7.5.1
16:40:24:           Date: May 11 2018
16:40:24:           Time: 13:06:32
16:40:24:     Repository: Git
16:40:24:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
16:40:24:         Branch: master
16:40:24:       Compiler: Visual C++ 2008
16:40:24:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:40:24:       Platform: win32 10
16:40:24:           Bits: 32
16:40:24:           Mode: Release
16:40:24:******************************* System ********************************
16:40:24:            CPU: Intel(R) Core(TM) i5-9600K CPU @ 3.70GHz
16:40:24:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
16:40:24:           CPUs: 6
16:40:24:         Memory: 15.93GiB
16:40:24:    Free Memory: 10.30GiB
16:40:24:        Threads: WINDOWS_THREADS
16:40:24:     OS Version: 6.2
16:40:24:    Has Battery: false
16:40:24:     On Battery: false
16:40:24:     UTC Offset: 1
16:40:24:            PID: 17964
16:40:24:            CWD: C:\Users\DESKTOP\AppData\Roaming\FAHClient
16:40:24:             OS: Windows 10 Enterprise
16:40:24:        OS Arch: AMD64
16:40:24:           GPUs: 1
16:40:24:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106 [GeForce RTX 2070] M 6497
16:40:24:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
16:40:24:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.50
16:40:24:  Win32 Service: false
16:40:24:***********************************************************************
16:40:24:<config>
16:40:24:  <!-- Folding Core -->
16:40:24:  <checkpoint v='16'/>
16:40:24:
16:40:24:  <!-- Network -->
16:40:24:  <proxy v=':8080'/>
16:40:24:
16:40:24:  <!-- Slot Control -->
16:40:24:  <pause-on-battery v='false'/>
16:40:24:
16:40:24:  <!-- User Information -->
16:40:24:  <user v='joenegevman'/>
16:40:24:
16:40:24:  <!-- Folding Slots -->
16:40:24:  <slot id='1' type='GPU'/>
16:40:24:</config>
16:40:24:Trying to access database...
16:40:24:Successfully acquired database lock
16:40:24:Enabled folding slot 01: READY gpu:0:TU106 [GeForce RTX 2070] M 6497
16:40:24:WU01:FS01:Starting
16:40:24:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\DESKTOP\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 17964 -checkpoint 16 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:40:25:WU01:FS01:Started FahCore on PID 988
16:40:25:WU01:FS01:Core PID:9076
16:40:25:WU01:FS01:FahCore 0x21 started
16:40:25:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11758 run:0 clone:2910 gen:0 core:0x22 unit:0x000000039bf7a4d55e6d7717f351bd6a
16:40:25:WU00:FS01:Uploading 55.25MiB to 155.247.164.213
16:40:25:WU00:FS01:Connecting to 155.247.164.213:8080
16:40:25:WU01:FS01:0x21:*********************** Log Started 2020-03-18T16:40:25Z ***********************
16:40:25:WU01:FS01:0x21:Project: 14310 (Run 289, Clone 43, Gen 4)
16:40:25:WU01:FS01:0x21:Unit: 0x000000060002894c5e6cf8b5241b84d2
16:40:25:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
16:40:25:WU01:FS01:0x21:Machine: 1
16:40:25:WU01:FS01:0x21:Digital signatures verified
16:40:25:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
16:40:25:WU01:FS01:0x21:Version 0.0.20
16:40:25:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
16:40:25:WU00:FS01:Trying to send results to collection server
16:40:25:WU00:FS01:Uploading 55.25MiB to 155.247.164.214
16:40:25:WU00:FS01:Connecting to 155.247.164.214:8080
16:40:25:WU01:FS01:0x21:  Found a checkpoint file
16:40:26:ERROR:WU00:FS01:Exception: Transfer failed
16:40:26:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11758 run:0 clone:2910 gen:0 core:0x22 unit:0x000000039bf7a4d55e6d7717f351bd6a
16:40:26:WU00:FS01:Uploading 55.25MiB to 155.247.164.213
16:40:26:WU00:FS01:Connecting to 155.247.164.213:8080
16:40:27:10:127.0.0.1:New Web connection
16:40:27:WU01:FS01:0x21:Completed 500000 out of 25000000 steps (2%)
16:40:27:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:40:28:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
16:40:28:WU00:FS01:Trying to send results to collection server
16:40:28:WU00:FS01:Uploading 55.25MiB to 155.247.164.214
16:40:28:WU00:FS01:Connecting to 155.247.164.214:8080
16:40:28:ERROR:WU00:FS01:Exception: Transfer failed
16:41:26:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11758 run:0 clone:2910 gen:0 core:0x22 unit:0x000000039bf7a4d55e6d7717f351bd6a
16:41:26:WU00:FS01:Uploading 55.25MiB to 155.247.164.213
16:41:26:WU00:FS01:Connecting to 155.247.164.213:8080
16:41:26:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
16:41:26:WU00:FS01:Trying to send results to collection server
16:41:26:WU00:FS01:Uploading 55.25MiB to 155.247.164.214
16:41:26:WU00:FS01:Connecting to 155.247.164.214:8080
16:41:27:ERROR:WU00:FS01:Exception: Transfer failed
16:43:01:WU01:FS01:0x21:Completed 750000 out of 25000000 steps (3%)
16:43:03:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11758 run:0 clone:2910 gen:0 core:0x22 unit:0x000000039bf7a4d55e6d7717f351bd6a
16:43:03:WU00:FS01:Uploading 55.25MiB to 155.247.164.213
16:43:03:WU00:FS01:Connecting to 155.247.164.213:8080
16:43:03:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
16:43:03:WU00:FS01:Trying to send results to collection server
16:43:03:WU00:FS01:Uploading 55.25MiB to 155.247.164.214
16:43:03:WU00:FS01:Connecting to 155.247.164.214:8080
16:43:04:ERROR:WU00:FS01:Exception: Transfer failed
16:45:35:WU01:FS01:0x21:Completed 1000000 out of 25000000 steps (4%)
16:45:40:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11758 run:0 clone:2910 gen:0 core:0x22 unit:0x000000039bf7a4d55e6d7717f351bd6a
16:45:40:WU00:FS01:Uploading 55.25MiB to 155.247.164.213
16:45:40:WU00:FS01:Connecting to 155.247.164.213:8080
16:45:41:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
16:45:41:WU00:FS01:Trying to send results to collection server
16:45:41:WU00:FS01:Uploading 55.25MiB to 155.247.164.214
16:45:41:WU00:FS01:Connecting to 155.247.164.214:8080
16:45:41:ERROR:WU00:FS01:Exception: Transfer failed
16:48:09:WU01:FS01:0x21:Completed 1250000 out of 25000000 steps (5%)
16:49:55:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11758 run:0 clone:2910 gen:0 core:0x22 unit:0x000000039bf7a4d55e6d7717f351bd6a
16:49:55:WU00:FS01:Uploading 55.25MiB to 155.247.164.213
16:49:55:WU00:FS01:Connecting to 155.247.164.213:8080
16:49:55:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
16:49:55:WU00:FS01:Trying to send results to collection server
16:49:55:WU00:FS01:Uploading 55.25MiB to 155.247.164.214
16:49:55:WU00:FS01:Connecting to 155.247.164.214:8080
16:49:56:ERROR:WU00:FS01:Exception: Transfer failed
16:50:44:WU01:FS01:0x21:Completed 1500000 out of 25000000 steps (6%)
16:52:13:FS01:Shutting core down
16:52:13:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 9076
16:52:13:WU01:FS01:0x21:Exiting, please wait. . .
16:52:13:WU01:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
16:52:13:Clean exit
bmwbmw2
Re: program dont working
Post by bmwbmw2 »
https://imgur.com/p5ZUjCN
We are aware of a specific problem for the server used by project:11758
bmwbmw2
Post by bmwbmw2 »
reinstall help anyway?? or waiting?
The failed transfer is not stopping your system from working on the GPU WU it also has. The log shows it had reached 5% at the time you paused folding.
