Option 'gpu-index' has not set.
Samuele
Post by Samuele »
MAC USER.
I tried tu reinstall the client, but the situation its the same. All the configuration menù are disabled.
davidcoton
Re: Option 'gpu-index' has not set.
Post by davidcoton »
https://foldingathome.org/support/faq/i ... uirements/
GPU folding is not currently supported in OSX
Sorry.
If you tried to setup a GPU and now can not reset things, here is a post I wrote for someone else:
viewtopic.php?f=61&t=32538&hilit=+Trash#p313289
Samuele
Post by Samuele »
Thanks both.
Joe_H i've already tried that and i tried again now but when i re-install and launch control i see the same situation: always error and all config menù disabled
Can you post the first 200 lines of the log file located in /Library/Application Support/FAHClient? The log file can be opened in TextEdit, just copy and paste that section to a post here between Code tags selectable from the Full Editor on the forum.
Samuele
Post by Samuele »
SQLite format 3@  -˝r
¯Ö[ÀÖ,Å$ÇtableclientsclientsCREATE TABLE "clients" ("name" text NOT NULL,"address" text NOT NULL,"port" integer NOT NULL,"password" text NOT NULL,PRIMARY KEY (name))-Aindexsqlite_autoindex_clients_1clientsnÅ7tableconfigconfigCREATE TABLE "config" ("name" text NOT NULL,"value" text NOT NULL,PRIMARY KEY (name))+?indexsqlite_autoindex_config_1config
€Ì€!main_width800#main_height520
‚““Ò#main_height!main_width
ËË
local127.0.0.1çÍ
˜˜	local
I should have specified the log is named log.txt, by default the most recent older logs are moved to a folder named logs. Let us know if it is not even creating a log.txt file.
Samuele
Post by Samuele »
in /Library/Application Support/logs i don't have any log.txt
Did you mean /Library/Application Support/FAHClient when you wrote "/Library/Application Support/logs"?
What version of the OS do you have installed on your Mac?
Samuele
Post by Samuele »
yes in Library/Application Support/FAHClient i only have FAHControl.db
Mojave 10.14.6
Sorry for the delay in getting back to this, had to spend some time on the work remotely for my regular job.
I am not certain how to proceed further with this problem, and don't have a Mojave system to check this out on. I will try and see if the person who assisted in the port to OS X is available to help out.
Post by calxalot »
I suggest you run the uninstall package, delete config.xml in the FAHClient directory, then reinstall.
Samuele
Post by Samuele »
I don’t have any config.xml
Or delete the entire FAHClient directory.
Samuele
Post by Samuele »
Already done and it didn’t work
