Startup problems
Startup problems
hi,
Im new to this, have installed the software, Status for Folding slots are Ready.
But nothing happens, can someone please guide me?
My computer use Win10 and is behinde a ASA firewall
petnek
- Hardware configuration: Asus 990FX Sabertooth, CPU Vishera FX-8350 not OC (Gelid Solution Tranquillo ), 2x4 GB DDR3 RAM 1600MHz (Kingston Blu), GPU Gigabyte HD6770, HDD Seagate Barracuda 7200.14 - 500GB + Samsung Spinpoint F1 320GB, FSP Raider 550W
Re: Startup problems
Welcome here,
It seems like your client is waiting for downloading work unit which should be caused because of enormous amount of new users, see here.
Only other thing to mention, if your ASA firewall blocks HTTP or HTTPS traffic if it is not from a "known" browser like Firefox, IE, Chrome, etc., then you will need to add an exception for the FAHClient part of the folding install. FAHClient uses HTTP(S) for downloading and uploading over ports 8080 (preferred) or 80. Some blocking software already has exceptions for FAHClient, but most do not.
Above the status in the FAHControl app it says: Client: local Online Inactive.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Any error messages in the Log tab? I suspect that you'll see a lot of "Cannot find WU for this configuration", which is a common error due to the very high demand at the moment. It should clear up in the next several days once more servers are online and more work gets added into the queue.Larrod wrote:Above the status in the FAHControl app it says: Client: local Online Inactive.
DarkVelocity
- Hardware configuration: Mint 19.2 Tina base: Ubuntu 18.04 bionic
Machine: Type: Desktop Mobo: ASRock model: Z390M Pro4
CPU: Topology: 8-Core model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Kaby Lake rev: D L2 cache: 16.0 MiB
Graphics: Device-1: Intel UHD Graphics 630
Memory: CORSAIR Dominator Platinum 64GB (4 x 16GB) 288-Pin DDR4 SDRAM DDR4 2666 (PC421300) Desktop Memory - Location: California
I have the following message in my logs that have repeated more than 30 times...Jesse_V wrote:Any error messages in the Log tab? I suspect that you'll see a lot of "Cannot find WU for this configuration", which is a common error due to the very high demand at the moment. It should clear up in the next several days once more servers are online and more work gets added into the queue.Larrod wrote:Above the status in the FAHControl app it says: Client: local Online Inactive.
WUs available for this configuration
21:05:37:WU00:FS00:Connecting to 18.218.241.186:80
21:05:37:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:05:37:ERROR:WU00:FS00:Exception: Could not get an assignment
Is there something wrong locally or is this due to the high demand on the servers?
Jesse_V
CPU: i7-6700k
That's it, that's due to the high demand on the servers. So many new volunteers that we are all consuming the available work faster than it can be generated. They're expanding the servers and adding more work, so keep everything running and it should pick up work when it can.
Good problem to have, but don't want to miss the opportunity/attention here. Anything us newbies can help with otherwise?
Jesse_V
CPU: i7-6700k
Just keep volunteering CPUs and GPUs! Soon we'll have some new servers online to keep up with the demand. If you'd like to help out, lurk the forums and help out when you can!loosleef wrote:Good problem to have, but don't want to miss the opportunity/attention here. Anything us newbies can help with otherwise?
DarkVelocity
Just a heads up, I have 1090 Attempts. Is there something I need to do to remedy the issue?
Logs here:
01:26:25:WU01:FS00:Starting
01:26:25:WARNING:WU01:FS00:AS lowered CPUs from 15 to 12
01:26:25:WU01:FS00:Removing old file './work/01/logfile_01-20200320-003934.txt'
01:26:25:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 16772 -checkpoint 15 -np 12
01:26:25:WU01:FS00:Started FahCore on PID 2975
01:26:25:Started thread 1105 on PID 16772
01:26:25:WU01:FS00:Core PID:2979
01:26:25:WU01:FS00:FahCore 0xa7 started
01:26:25:WU01:FS00:0xa7:*********************** Log Started 2020-03-20T01:26:25Z ***********************
01:26:25:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:26:25:WU01:FS00:0xa7: Type: 0xa7
01:26:25:WU01:FS00:0xa7: Core: Gromacs
01:26:25:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 2975 -checkpoint 15 -np
01:26:25:WU01:FS00:0xa7: 12
01:26:25:WU01:FS00:0xa7:************************************ CBang *************************************
01:26:25:WU01:FS00:0xa7: Date: Nov 5 2019
01:26:25:WU01:FS00:0xa7: Time: 06:06:57
01:26:25:WU01:FS00:0xa7: Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
01:26:25:WU01:FS00:0xa7: Branch: master
01:26:25:WU01:FS00:0xa7: Compiler: GNU 8.3.0
01:26:25:WU01:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
01:26:25:WU01:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
01:26:25:WU01:FS00:0xa7: Bits: 64
01:26:25:WU01:FS00:0xa7: Mode: Release
01:26:25:WU01:FS00:0xa7:************************************ System ************************************
01:26:25:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
01:26:25:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
01:26:25:WU01:FS00:0xa7: CPUs: 16
01:26:25:WU01:FS00:0xa7: Memory: 62.58GiB
01:26:25:WU01:FS00:0xa7:Free Memory: 2.49GiB
01:26:25:WU01:FS00:0xa7: Threads: POSIX_THREADS
01:26:25:WU01:FS00:0xa7: OS Version: 4.15
01:26:25:WU01:FS00:0xa7:Has Battery: false
01:26:25:WU01:FS00:0xa7: On Battery: false
01:26:25:WU01:FS00:0xa7: UTC Offset: -7
01:26:25:WU01:FS00:0xa7: PID: 2979
01:26:25:WU01:FS00:0xa7: CWD: /var/lib/fahclient/work
01:26:25:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
01:26:25:WU01:FS00:0xa7: Version: 0.0.18
01:26:25:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:26:25:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
01:26:25:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
01:26:25:WU01:FS00:0xa7: Time: 06:13:26
01:26:25:WU01:FS00:0xa7: Revision: 490c9aa2957b725af319379424d5c5cb36efb656
01:26:25:WU01:FS00:0xa7:************************************ Build *************************************
01:26:25:WU01:FS00:0xa7: SIMD: avx_256
01:26:25:WU01:FS00:0xa7:********************************************************************************
01:26:25:WU01:FS00:0xa7:Project: 13860 (Run 0, Clone 1540, Gen 0)
01:26:25:WU01:FS00:0xa7:Unit: 0x000000030d5a98395e725dffa35e9875
01:26:25:WU01:FS00:0xa7:Reading tar file core.xml
01:26:25:WU01:FS00:0xa7:Reading tar file frame0.tpr
01:26:25:WU01:FS00:0xa7:Digital signatures verified
01:26:25:WU01:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -e frame0.edr -cpt 15 -nt 12
01:26:25:WU01:FS00:0xa7:ERROR:
01:26:25:WU01:FS00:0xa7:ERROR:-------------------------------------------------------
01:26:25:WU01:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
01:26:25:WU01:FS00:0xa7:ERROR:Source code file: /host/debian-stable-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/fileio/gmxfio_xdr.c, line: 283
01:26:25:WU01:FS00:0xa7:ERROR:Fatal error:
01:26:25:WU01:FS00:0xa7:ERROR:wrong string length 0 for string buf (source /host/debian-stable-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/fileio/tpxio.c, line 3206)
01:26:25:WU01:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
01:26:25:WU01:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
01:26:30:WU01:FS00:0xa7:ERROR:
01:26:30:WU01:FS00:0xa7:ERROR:-------------------------------------------------------
01:26:30:WU01:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
01:26:30:WU01:FS00:0xa7:ERROR:Source code file: /host/debian-stable-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/fileio/tpxio.c, line: 3209
01:26:30:WU01:FS00:0xa7:ERROR:Fatal error:
01:26:30:WU01:FS00:0xa7:ERROR:Can not read file frame0.tpr,
01:26:30:WU01:FS00:0xa7:ERROR: this file is from a Gromacs version which is older than 2.0
01:26:30:WU01:FS00:0xa7:ERROR: Make a new one with grompp or use a gro or pdb file, if possible
01:26:30:WU01:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
01:26:30:WU01:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
01:26:35:WU01:FS00:0xa7:ERROR:
01:26:35:WU01:FS00:0xa7:ERROR:-------------------------------------------------------
01:26:35:WU01:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
01:26:35:WU01:FS00:0xa7:ERROR:Source code file: /host/debian-stable-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/fileio/tpxio.c, line: 3218
01:26:35:WU01:FS00:0xa7:ERROR:Fatal error:
01:26:35:WU01:FS00:0xa7:ERROR:Unknown precision in file frame0.tpr: real is 567986280 bytes instead of 4 or 8
01:26:35:WU01:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
01:26:35:WU01:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
01:26:40:WU01:FS00:0xa7:ERROR:
01:26:40:WU01:FS00:0xa7:ERROR:-------------------------------------------------------
01:26:40:WU01:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
01:26:40:WU01:FS00:0xa7:ERROR:Source code file: /host/debian-stable-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/fileio/gmxfio_xdr.c, line: 283
01:26:40:WU01:FS00:0xa7:ERROR:Fatal error:
01:26:40:WU01:FS00:0xa7:ERROR:wrong string length 0 for string file_tag (source /host/debian-stable-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/fileio/tpxio.c, line 3261)
01:26:40:WU01:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
01:26:40:WU01:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
01:26:45:WU01:FS00:0xa7:ERROR:
01:26:45:WU01:FS00:0xa7:ERROR:-------------------------------------------------------
01:26:45:WU01:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
01:26:45:WU01:FS00:0xa7:ERROR:Source code file: /host/debian-stable-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/fileio/tpxio.c, line: 3303
01:26:45:WU01:FS00:0xa7:ERROR:Fatal error:
01:26:45:WU01:FS00:0xa7:ERROR:reading tpx file (frame0.tpr) version 567986656 with version 100 program
01:26:45:WU01:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
01:26:45:WU01:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
01:26:50:WU01:FS00:0xa7:WARNING:Unexpected exit() call
01:26:50:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
01:26:50:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
01:26:50:WU01:FS00:0xa7:Saving result file md.log
01:26:50:WU01:FS00:0xa7:Saving result file science.log
01:26:50:WU01:FS00:0xa7:Folding@home Core Shutdown: BAD_WORK_UNIT
01:26:52:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:26:54:Removing old file 'configs/config-20200317-194707.xml'
01:26:54:Saving configuration to /etc/fahclient/config.xml
01:26:54:<config>
01:26:54: <!-- Client Control -->
01:26:54: <fold-anon v='true'/>
01:26:54:
01:26:54: <!-- Folding Slot Configuration -->
01:26:54: <gpu v='false'/>
01:26:54:
01:26:54: <!-- Logging -->
01:26:54: <verbosity v='5'/>
01:26:54:
01:26:54: <!-- Network -->
01:26:54: <proxy v=':8080'/>
01:26:54:
01:26:54: <!-- User Information -->
01:26:54: <passkey v='********************************'/>
01:26:54: <team v='225605'/>
01:26:54: <user v='DarkVelocity'/>
01:26:54:
01:26:54: <!-- Folding Slots -->
01:26:54: <slot id='0' type='CPU'/>
01:26:54:</config>
01:26:57:FS00:Paused
01:27:55:Removing old file 'configs/config-20200317-194808.xml'
01:27:55:Saving configuration to /etc/fahclient/config.xml
01:27:55:<config>
01:27:55: <!-- Client Control -->
01:27:55: <fold-anon v='true'/>
01:27:55:
01:27:55: <!-- Folding Slot Configuration -->
01:27:55: <gpu v='false'/>
01:27:55:
01:27:55: <!-- Logging -->
01:27:55: <verbosity v='5'/>
01:27:55:
01:27:55: <!-- Network -->
01:27:55: <proxy v=':8080'/>
01:27:55:
01:27:55: <!-- User Information -->
01:27:55: <passkey v='********************************'/>
01:27:55: <team v='225605'/>
01:27:55: <user v='DarkVelocity'/>
01:27:55:
01:27:55: <!-- Folding Slots -->
01:27:55: <slot id='0' type='CPU'>
01:27:55: <paused v='true'/>
01:27:55: </slot>
01:27:55:</config>
Logs here:
01:26:54:<config>
01:26:54:
01:26:54:
01:26:54:
01:26:54:
01:26:54:
01:26:54:</config>
01:27:55:<config>
01:27:55:
01:27:55:
01:27:55:
01:27:55:
01:27:55:
01:27:55: </slot>
01:27:55:</config>
