problem with sending finished work
avatusxan
Post by avatusxan »
i think i am having trouble with sending the work which i have finished computing from my computer to the server. it has been stacked up to 3 pieces of work on my laptop, which need to be sent to the server, Anyone else having similar problems?
helloWorld : )
Re: problem with sending finished work
Yes, it is part of the server overload problem we have been seeing for the last few days. There has been a particular set of servers and projects displaying this problem that they are looking into and seeing what the cause is.
Which projects are these, what is the address of the WS and CS for each?
avatusxan
Post by avatusxan »
PRCG 14328 (3, 2995, 1) work server 155.247.164.214 collection server 155.247.166.219
PRCG 14310 (36, 99, 3) work server 155.247.166.220 collection server 155.247.166.219
PRCG 11757 (0, 2175, 5) work server 155.247.164.213 collection server 155.247.164.214
PRCG 14328 (5, 1730, 11) work server 155.247.164.214 collection server 155.247.166.220
stacked jobs witch need to be sent.
helloWorld : )
mrzorn
Post by mrzorn »
same problem
11758 (0,2107,0) - work 155.247.164.213 - collection .214
metrognome
Post by metrognome »
Same here, stuck trying to upload results.
It's been trying to upload for days so the attempts etc. are only since last re-start.
*********************** Log Started 2020-03-18T13:10:21Z ***********************
13:10:21:************************* Folding@home Client *************************
13:10:21:        Website: https://foldingathome.org/
13:10:21:      Copyright: (c) 2009-2018 foldingathome.org
13:10:21:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:10:21:           Args: --open-web-control
13:10:21:         Config: F:\Games\FoldingAtHome\config.xml
13:10:21:******************************** Build ********************************
13:10:21:        Version: 7.5.1
13:10:21:           Date: May 11 2018
13:10:21:           Time: 13:06:32
13:10:21:     Repository: Git
13:10:21:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
13:10:21:         Branch: master
13:10:21:       Compiler: Visual C++ 2008
13:10:21:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:10:21:       Platform: win32 10
13:10:21:           Bits: 32
13:10:21:           Mode: Release
13:10:21:******************************* System ********************************
13:10:21:            CPU: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
13:10:21:         CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
13:10:21:           CPUs: 12
13:10:21:         Memory: 31.83GiB
13:10:21:    Free Memory: 18.82GiB
13:10:21:        Threads: WINDOWS_THREADS
13:10:21:     OS Version: 6.2
13:10:21:    Has Battery: false
13:10:21:     On Battery: false
13:10:21:     UTC Offset: 1
13:10:21:            PID: 14616
13:10:21:            CWD: F:\Games\FoldingAtHome
13:10:21:             OS: Windows 10 Enterprise
13:10:21:        OS Arch: AMD64
13:10:21:           GPUs: 1
13:10:21:          GPU 0: Bus:3 Slot:0 Func:0 NVIDIA:8 TU104 [GeForce RTX 2080]
13:10:21:  CUDA Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:7.5 Driver:10.1
13:10:21:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:432.0
13:10:21:  Win32 Service: false
13:10:21:***********************************************************************
13:10:21:<config>
13:10:21:  <!-- Network -->
13:10:21:  <proxy v=':8080'/>
13:10:21:
13:10:21:  <!-- Slot Control -->
13:10:21:  <power v='full'/>
13:10:21:
13:10:21:  <!-- User Information -->
13:10:21:  <passkey v='********************************'/>
13:10:21:  <user v='****************'/>
13:10:21:
13:10:21:  <!-- Folding Slots -->
13:10:21:  <slot id='0' type='CPU'/>
13:10:21:  <slot id='1' type='GPU'/>
13:10:21:</config>
13:10:21:Trying to access database...
13:10:21:Successfully acquired database lock
13:10:21:Enabled folding slot 00: READY cpu:11
13:10:21:Enabled folding slot 01: READY gpu:0:TU104 [GeForce RTX 2080]
13:10:21:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:11741 run:0 clone:339 gen:4 core:0x22 unit:0x0000000e8ca304f15e67d7609c88ea2e
13:10:21:WU03:FS01:Uploading 21.92MiB to 140.163.4.241
13:10:21:WU03:FS01:Connecting to 140.163.4.241:8080
13:10:21:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11753 run:0 clone:3381 gen:0 core:0x22 unit:0x000000009bf7a4d55e6d76cab65037c1
13:10:22:WU01:FS01:Uploading 49.92MiB to 155.247.164.213
13:10:22:WU01:FS01:Connecting to 155.247.164.213:8080
13:10:22:WU00:FS00:Connecting to 65.254.110.245:8080
13:10:22:WU02:FS01:Connecting to 65.254.110.245:8080
13:10:22:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
13:10:22:WU01:FS01:Trying to send results to collection server
13:10:22:WU01:FS01:Uploading 49.92MiB to 155.247.164.214
13:10:22:WU01:FS01:Connecting to 155.247.164.214:8080
13:10:22:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:10:22:WU00:FS00:Connecting to 18.218.241.186:80
13:10:22:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:10:22:WU02:FS01:Connecting to 18.218.241.186:80
13:10:22:ERROR:WU01:FS01:Exception: Transfer failed
13:10:22:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11753 run:0 clone:3381 gen:0 core:0x22 unit:0x000000009bf7a4d55e6d76cab65037c1
13:10:22:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:10:22:ERROR:WU00:FS00:Exception: Could not get an assignment
13:10:23:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:10:23:ERROR:WU02:FS01:Exception: Could not get an assignment
13:10:23:WU00:FS00:Connecting to 65.254.110.245:8080
13:10:23:WU02:FS01:Connecting to 65.254.110.245:8080
13:10:23:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:10:23:WU00:FS00:Connecting to 18.218.241.186:80
13:10:23:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:10:23:WU02:FS01:Connecting to 18.218.241.186:80
13:10:23:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:10:23:ERROR:WU00:FS00:Exception: Could not get an assignment
13:10:24:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
13:10:24:WU01:FS01:Trying to send results to collection server
13:10:24:WU01:FS01:Uploading 49.92MiB to 155.247.164.214
13:10:24:WU01:FS01:Connecting to 155.247.164.214:8080
13:10:24:ERROR:WU01:FS01:Exception: Transfer failed
13:10:27:WU03:FS01:Upload 5.70%
13:10:33:WU03:FS01:Upload 23.09%
13:10:39:WU03:FS01:Upload 40.48%
13:10:45:WU03:FS01:Upload 58.45%
13:10:45:40:127.0.0.1:New Web connection
13:10:51:WU03:FS01:Upload 76.69%
13:10:57:WU03:FS01:Upload 94.08%
13:11:15:WU03:FS01:Upload complete
13:11:15:WU03:FS01:Server responded WORK_ACK (400)
13:11:15:WU03:FS01:Final credit estimate, 70678.00 points
13:11:15:WU03:FS01:Cleaning up
13:11:22:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11753 run:0 clone:3381 gen:0 core:0x22 unit:0x000000009bf7a4d55e6d76cab65037c1
13:11:23:WU01:FS01:Uploading 49.92MiB to 155.247.164.213
13:11:23:WU01:FS01:Connecting to 155.247.164.213:8080
13:11:23:WU00:FS00:Connecting to 65.254.110.245:8080
13:11:23:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
13:11:23:WU01:FS01:Trying to send results to collection server
13:11:23:WU01:FS01:Uploading 49.92MiB to 155.247.164.214
13:11:23:WU01:FS01:Connecting to 155.247.164.214:8080
13:11:23:WU02:FS01:Connecting to 65.254.110.245:8080
13:11:23:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:11:23:WU00:FS00:Connecting to 18.218.241.186:80
13:11:23:ERROR:WU01:FS01:Exception: Transfer failed
13:11:23:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:11:23:WU02:FS01:Connecting to 18.218.241.186:80
13:11:23:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:11:23:ERROR:WU00:FS00:Exception: Could not get an assignment
13:11:24:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:11:24:ERROR:WU02:FS01:Exception: Could not get an assignment
13:13:00:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11753 run:0 clone:3381 gen:0 core:0x22 unit:0x000000009bf7a4d55e6d76cab65037c1
13:13:00:WU01:FS01:Uploading 49.92MiB to 155.247.164.213
13:13:00:WU01:FS01:Connecting to 155.247.164.213:8080
13:13:00:WU00:FS00:Connecting to 65.254.110.245:8080
13:13:00:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
13:13:00:WU01:FS01:Trying to send results to collection server
13:13:00:WU01:FS01:Uploading 49.92MiB to 155.247.164.214
13:13:00:WU01:FS01:Connecting to 155.247.164.214:8080
13:13:00:WU02:FS01:Connecting to 65.254.110.245:8080
13:13:00:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:13:00:WU00:FS00:Connecting to 18.218.241.186:80
13:13:00:ERROR:WU01:FS01:Exception: Transfer failed
13:13:01:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:13:01:WU02:FS01:Connecting to 18.218.241.186:80
13:13:01:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:13:01:ERROR:WU00:FS00:Exception: Could not get an assignment
13:13:01:WU02:FS01:Assigned to work server 155.247.164.213
13:13:01:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104 [GeForce RTX 2080] from 155.247.164.213
13:13:01:WU02:FS01:Connecting to 155.247.164.213:8080
13:13:03:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
13:15:37:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11753 run:0 clone:3381 gen:0 core:0x22 unit:0x000000009bf7a4d55e6d76cab65037c1
13:15:37:WU01:FS01:Uploading 49.92MiB to 155.247.164.213
13:15:37:WU01:FS01:Connecting to 155.247.164.213:8080
13:15:37:WU00:FS00:Connecting to 65.254.110.245:8080
13:15:37:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
13:15:37:WU01:FS01:Trying to send results to collection server
13:15:37:WU01:FS01:Uploading 49.92MiB to 155.247.164.214
13:15:37:WU01:FS01:Connecting to 155.247.164.214:8080
13:15:37:WU02:FS01:Connecting to 65.254.110.245:8080
13:15:37:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:15:37:WU00:FS00:Connecting to 18.218.241.186:80
13:15:37:ERROR:WU01:FS01:Exception: Transfer failed
13:15:38:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:15:38:WU02:FS01:Connecting to 18.218.241.186:80
13:15:38:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:15:38:ERROR:WU00:FS00:Exception: Could not get an assignment
13:15:38:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:15:38:ERROR:WU02:FS01:Exception: Could not get an assignment
13:19:51:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11753 run:0 clone:3381 gen:0 core:0x22 unit:0x000000009bf7a4d55e6d76cab65037c1
13:19:51:WU01:FS01:Uploading 49.92MiB to 155.247.164.213
13:19:51:WU01:FS01:Connecting to 155.247.164.213:8080
13:19:51:WU00:FS00:Connecting to 65.254.110.245:8080
13:19:52:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
13:19:52:WU01:FS01:Trying to send results to collection server
13:19:52:WU01:FS01:Uploading 49.92MiB to 155.247.164.214
13:19:52:WU02:FS01:Connecting to 65.254.110.245:8080
13:19:52:WU01:FS01:Connecting to 155.247.164.214:8080
13:19:52:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:19:52:WU00:FS00:Connecting to 18.218.241.186:80
13:19:52:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:19:52:ERROR:WU00:FS00:Exception: Could not get an assignment
13:19:52:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:19:52:WU02:FS01:Connecting to 18.218.241.186:80
13:19:52:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:19:52:ERROR:WU02:FS01:Exception: Could not get an assignment
13:19:53:ERROR:WU01:FS01:Exception: Transfer failed
