Can I transfer my points?
TheawesomeMCB
Post by TheawesomeMCB »
So recently there was a issue with the website sending out passkeys. However now that I have a passkey when I put it in I lose all my points unless I remove it. Is there a way to transfer the points I had before that didn't have any passkey to one that has a passkey? Or should I just start over?
Re: Can I transfer my points?
No, you cannot transfer your points. FAH has always had a strict rule about modifying the database. Once a credit is recorded, it's permanent.
avatusxan
Post by avatusxan »
i have similar problem,Just installed the passkey as soon as the mail server came back to life, and restarted from scratch .
helloWorld : )
Not really. There's still a tabulation under {Name, (with no passkey)} as well as a new tabulation under {Name, Passkey} Unfortunaely there's really now way to separate what you contributed to {Name, ""} and what somebody else contributed to {Name, ""} except by using the passkey ... which is unique to you.
avatusxan
Post by avatusxan »
bruce wrote:Not really. There's still a tabulation under {Name, (with no passkey)} as well as a new tabulation under {Name, Passkey} Unfortunaely there's really now way to separate what you contributed to {Name, ""} and what somebody else contributed to {Name, ""} except by using the passkey ... which is unique to you.
I switched back to the [name,""] mode and found my earlier enrned points there :D
helloWorld : )
