FAH Not uploading WU
SomeCamel
Post by SomeCamel »
*********************** Log Started 2020-03-17T14:16:52Z ***********************
14:16:52:************************* Folding@home Client *************************
14:16:52:        Website: https://foldingathome.org/
14:16:52:      Copyright: (c) 2009-2018 foldingathome.org
14:16:52:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:16:52:           Args:
14:16:52:         Config: C:\Users\Logan\AppData\Roaming\FAHClient\config.xml
14:16:52:******************************** Build ********************************
14:16:52:        Version: 7.5.1
14:16:52:           Date: May 11 2018
14:16:52:           Time: 13:06:32
14:16:52:     Repository: Git
14:16:52:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:16:52:         Branch: master
14:16:52:       Compiler: Visual C++ 2008
14:16:52:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:16:52:       Platform: win32 10
14:16:52:           Bits: 32
14:16:52:           Mode: Release
14:16:52:******************************* System ********************************
14:16:52:            CPU: AMD FX(tm)-9590 Eight-Core Processor
14:16:52:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
14:16:52:           CPUs: 8
14:16:52:         Memory: 15.97GiB
14:16:52:    Free Memory: 13.84GiB
14:16:52:        Threads: WINDOWS_THREADS
14:16:52:     OS Version: 6.1
14:16:52:    Has Battery: false
14:16:52:     On Battery: false
14:16:52:     UTC Offset: -7
14:16:52:            PID: 3456
14:16:52:            CWD: C:\Users\COVID-19\AppData\Roaming\FAHClient
14:16:52:             OS: Windows 7 Home Premium
14:16:52:        OS Arch: AMD64
14:16:52:           GPUs: 1
14:16:52:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
14:16:52:                 470/480/570/580]
14:16:52:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
14:16:52:                 specified module could not be found.
14:16:52:
14:16:52:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
14:16:52:  Win32 Service: false
14:16:52:***********************************************************************
14:16:52:<config>
14:16:52:  <!-- Network -->
14:16:52:  <proxy v=':8080'/>
14:16:52:
14:16:52:  <!-- Slot Control -->
14:16:52:  <power v='full'/>
14:16:52:
14:16:52:  <!-- User Information -->
14:16:52:  <team v='225605'/>
14:16:52:  <user v='PCMR-Logan-M'/>
14:16:52:
14:16:52:  <!-- Folding Slots -->
14:16:52:  <slot id='0' type='CPU'/>
14:16:52:  <slot id='1' type='GPU'/>
14:16:52:</config>
14:16:52:Trying to access database...
14:16:53:Successfully acquired database lock
14:16:53:Enabled folding slot 00: READY cpu:7
14:16:53:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580]
14:16:53:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11756 run:0 clone:1010 gen:2 core:0x22 unit:0x000000039bf7a4d55e6d76f2c5514418
14:16:54:WU01:FS01:Uploading 75.87MiB to 155.247.164.213
14:16:54:WU01:FS01:Connecting to 155.247.164.213:8080
14:16:54:WU00:FS00:Connecting to 65.254.110.245:8080
14:16:54:WU02:FS01:Connecting to 65.254.110.245:8080
14:16:55:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:16:55:WU00:FS00:Connecting to 18.218.241.186:80
14:16:55:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:16:55:WU02:FS01:Connecting to 18.218.241.186:80
14:16:55:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:16:55:ERROR:WU00:FS00:Exception: Could not get an assignment
14:16:55:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:16:55:ERROR:WU02:FS01:Exception: Could not get an assignment
14:16:55:WU00:FS00:Connecting to 65.254.110.245:8080
14:16:55:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
14:16:55:WU01:FS01:Trying to send results to collection server
14:16:56:WU01:FS01:Uploading 75.87MiB to 155.247.164.214
14:16:56:WU01:FS01:Connecting to 155.247.164.214:8080
14:16:56:WU02:FS01:Connecting to 65.254.110.245:8080
14:16:57:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:16:57:WU00:FS00:Connecting to 18.218.241.186:80
14:16:57:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:16:57:WU02:FS01:Connecting to 18.218.241.186:80
14:16:57:ERROR:WU01:FS01:Exception: Transfer failed
14:16:57:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11756 run:0 clone:1010 gen:2 core:0x22 unit:0x000000039bf7a4d55e6d76f2c5514418
14:16:58:WU01:FS01:Uploading 75.87MiB to 155.247.164.213
14:16:58:WU01:FS01:Connecting to 155.247.164.213:8080
14:16:58:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:16:58:ERROR:WU00:FS00:Exception: Could not get an assignment
14:16:59:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:16:59:ERROR:WU02:FS01:Exception: Could not get an assignment
14:16:59:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
14:16:59:WU01:FS01:Trying to send results to collection server
14:17:00:WU01:FS01:Uploading 75.87MiB to 155.247.164.214
14:17:00:WU01:FS01:Connecting to 155.247.164.214:8080
14:17:01:ERROR:WU01:FS01:Exception: Transfer failed
14:17:55:WU00:FS00:Connecting to 65.254.110.245:8080
14:17:56:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:17:56:WU00:FS00:Connecting to 18.218.241.186:80
14:17:56:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:17:56:ERROR:WU00:FS00:Exception: Could not get an assignment
14:17:56:WU02:FS01:Connecting to 65.254.110.245:8080
14:17:57:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:17:57:WU02:FS01:Connecting to 18.218.241.186:80
14:17:57:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:17:57:ERROR:WU02:FS01:Exception: Could not get an assignment
14:17:57:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11756 run:0 clone:1010 gen:2 core:0x22 unit:0x000000039bf7a4d55e6d76f2c5514418
14:17:57:WU01:FS01:Uploading 75.87MiB to 155.247.164.213
14:17:57:WU01:FS01:Connecting to 155.247.164.213:8080
14:17:58:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
14:17:58:WU01:FS01:Trying to send results to collection server
14:17:58:WU01:FS01:Uploading 75.87MiB to 155.247.164.214
14:17:58:WU01:FS01:Connecting to 155.247.164.214:8080
14:17:59:ERROR:WU01:FS01:Exception: Transfer failed
14:18:31:17:127.0.0.1:New Web connection
14:19:33:WU00:FS00:Connecting to 65.254.110.245:8080
14:19:33:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:19:33:WU00:FS00:Connecting to 18.218.241.186:80
14:19:33:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:19:33:ERROR:WU00:FS00:Exception: Could not get an assignment
14:19:34:WU02:FS01:Connecting to 65.254.110.245:8080
14:19:34:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:19:34:WU02:FS01:Connecting to 18.218.241.186:80
14:19:34:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:19:34:ERROR:WU02:FS01:Exception: Could not get an assignment
14:19:35:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11756 run:0 clone:1010 gen:2 core:0x22 unit:0x000000039bf7a4d55e6d76f2c5514418
14:19:35:WU01:FS01:Uploading 75.87MiB to 155.247.164.213
14:19:35:WU01:FS01:Connecting to 155.247.164.213:8080
14:19:35:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
14:19:35:WU01:FS01:Trying to send results to collection server
14:19:35:WU01:FS01:Uploading 75.87MiB to 155.247.164.214
14:19:35:WU01:FS01:Connecting to 155.247.164.214:8080
14:19:35:ERROR:WU01:FS01:Exception: Transfer failed
14:22:10:WU00:FS00:Connecting to 65.254.110.245:8080
14:22:10:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:22:10:WU00:FS00:Connecting to 18.218.241.186:80
14:22:10:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:22:10:ERROR:WU00:FS00:Exception: Could not get an assignment
14:22:11:WU02:FS01:Connecting to 65.254.110.245:8080
14:22:11:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:22:11:WU02:FS01:Connecting to 18.218.241.186:80
14:22:11:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:22:11:ERROR:WU02:FS01:Exception: Could not get an assignment
14:22:12:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11756 run:0 clone:1010 gen:2 core:0x22 unit:0x000000039bf7a4d55e6d76f2c5514418
14:22:12:WU01:FS01:Uploading 75.87MiB to 155.247.164.213
14:22:12:WU01:FS01:Connecting to 155.247.164.213:8080
14:22:12:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
14:22:12:WU01:FS01:Trying to send results to collection server
14:22:12:WU01:FS01:Uploading 75.87MiB to 155.247.164.214
14:22:12:WU01:FS01:Connecting to 155.247.164.214:8080
14:22:13:ERROR:WU01:FS01:Exception: Transfer failed
14:26:24:WU00:FS00:Connecting to 65.254.110.245:8080
14:26:24:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:26:24:WU00:FS00:Connecting to 18.218.241.186:80
14:26:25:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:26:25:ERROR:WU00:FS00:Exception: Could not get an assignment
14:26:25:WU02:FS01:Connecting to 65.254.110.245:8080
14:26:25:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:26:25:WU02:FS01:Connecting to 18.218.241.186:80
14:26:26:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:26:26:ERROR:WU02:FS01:Exception: Could not get an assignment
14:26:26:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11756 run:0 clone:1010 gen:2 core:0x22 unit:0x000000039bf7a4d55e6d76f2c5514418
14:26:26:WU01:FS01:Uploading 75.87MiB to 155.247.164.213
14:26:26:WU01:FS01:Connecting to 155.247.164.213:8080
14:26:26:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
14:26:26:WU01:FS01:Trying to send results to collection server
14:26:26:WU01:FS01:Uploading 75.87MiB to 155.247.164.214
14:26:26:WU01:FS01:Connecting to 155.247.164.214:8080
14:26:28:ERROR:WU01:FS01:Exception: Transfer failed
14:33:15:WU00:FS00:Connecting to 65.254.110.245:8080
14:33:15:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:33:15:WU00:FS00:Connecting to 18.218.241.186:80
14:33:16:WU00:FS00:Assigned to work server 155.247.164.213
14:33:16:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.164.213
14:33:16:WU00:FS00:Connecting to 155.247.164.213:8080
14:33:16:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
14:33:16:WU02:FS01:Connecting to 65.254.110.245:8080
14:33:17:WU02:FS01:Assigned to work server 128.252.203.10
14:33:17:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 128.252.203.10
14:33:17:WU02:FS01:Connecting to 128.252.203.10:8080
14:33:17:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11756 run:0 clone:1010 gen:2 core:0x22 unit:0x000000039bf7a4d55e6d76f2c5514418
14:33:18:WU01:FS01:Uploading 75.87MiB to 155.247.164.213
14:33:18:WU01:FS01:Connecting to 155.247.164.213:8080
14:33:18:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
14:33:18:WU01:FS01:Trying to send results to collection server
14:33:18:WU01:FS01:Uploading 75.87MiB to 155.247.164.214
14:33:18:WU01:FS01:Connecting to 155.247.164.214:8080
14:33:18:ERROR:WU01:FS01:Exception: Transfer failed
14:33:38:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
14:33:38:WU02:FS01:Connecting to 128.252.203.10:80
14:33:59:ERROR:WU02:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:44:21:WU00:FS00:Connecting to 65.254.110.245:8080
14:44:21:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:44:21:WU00:FS00:Connecting to 18.218.241.186:80
14:44:21:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:44:21:ERROR:WU00:FS00:Exception: Could not get an assignment
14:44:22:WU02:FS01:Connecting to 65.254.110.245:8080
14:44:22:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:44:22:WU02:FS01:Connecting to 18.218.241.186:80
14:44:22:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:44:22:ERROR:WU02:FS01:Exception: Could not get an assignment
14:44:23:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11756 run:0 clone:1010 gen:2 core:0x22 unit:0x000000039bf7a4d55e6d76f2c5514418
14:44:23:WU01:FS01:Uploading 75.87MiB to 155.247.164.213
14:44:23:WU01:FS01:Connecting to 155.247.164.213:8080
14:44:23:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
14:44:23:WU01:FS01:Trying to send results to collection server
14:44:24:WU01:FS01:Uploading 75.87MiB to 155.247.164.214
14:44:24:WU01:FS01:Connecting to 155.247.164.214:8080
14:44:25:ERROR:WU01:FS01:Exception: Transfer failed
15:02:18:WU00:FS00:Connecting to 65.254.110.245:8080
15:02:18:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:02:18:WU00:FS00:Connecting to 18.218.241.186:80
15:02:18:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:02:18:ERROR:WU00:FS00:Exception: Could not get an assignment
15:02:19:WU02:FS01:Connecting to 65.254.110.245:8080
15:02:19:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:02:19:WU02:FS01:Connecting to 18.218.241.186:80
15:02:19:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:02:19:ERROR:WU02:FS01:Exception: Could not get an assignment
15:02:20:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11756 run:0 clone:1010 gen:2 core:0x22 unit:0x000000039bf7a4d55e6d76f2c5514418
15:02:20:WU01:FS01:Uploading 75.87MiB to 155.247.164.213
15:02:20:WU01:FS01:Connecting to 155.247.164.213:8080
15:02:20:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
15:02:20:WU01:FS01:Trying to send results to collection server
15:02:20:WU01:FS01:Uploading 75.87MiB to 155.247.164.214
15:02:20:WU01:FS01:Connecting to 155.247.164.214:8080
15:02:21:ERROR:WU01:FS01:Exception: Transfer failed
This is only on the GPU and it's on a COVID-19 project. My previous CPU project uploaded fine, but the CPU and GPU aren't even downloading projects now
davidcoton
Re: FAH Not uploading WU
Post by davidcoton »
Parts of F@H are overloaded with the enormous response to several social media references. The team are working on adding additional resources, please be patient. Just consider what it's like for the researchers who are generating many times more work than a week ago. A Pause/Fold cycle or a restart may help (but don't do it too often as it defeats the system for reducing load under fault conditions). The system should not lose the work you have done.
