Server did not like results, dumping
Ettanin
Post by Ettanin »
Hello,
Does this mean my system wastes time?
05:20:58:WU00:FS02:0xa7:Completed 250000 out of 250000 steps (100%)
05:21:00:WU00:FS02:0xa7:Saving result file ..\logfile_01.txt
05:21:00:WU00:FS02:0xa7:Saving result file frame3.trr
05:21:01:WU00:FS02:0xa7:Saving result file md.log
05:21:01:WU00:FS02:0xa7:Saving result file science.log
05:21:01:WU00:FS02:0xa7:Saving result file traj_comp.xtc
05:21:01:WU00:FS02:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
05:21:01:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:21:01:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:14328 run:9 clone:755 gen:3 core:0xa7 unit:0x000000049bf7a4d65e6d0ba0227d62d8
05:21:01:WU00:FS02:Uploading 4.96MiB to 155.247.164.214
05:21:01:WU00:FS02:Connecting to 155.247.164.214:8080
05:21:02:WARNING:WU00:FS02:Exception: Failed to send results to work server: Transfer failed
05:21:02:WU00:FS02:Trying to send results to collection server
05:21:03:WU00:FS02:Uploading 4.96MiB to 155.247.166.220
05:21:03:WU00:FS02:Connecting to 155.247.166.220:8080
05:21:09:WU00:FS02:Upload 74.40%
05:21:10:WU00:FS02:Upload complete
05:21:10:WU00:FS02:Server responded WORK_QUIT (404)
05:21:10:WARNING:WU00:FS02:Server did not like results, dumping
05:21:10:WU00:FS02:Cleaning up
Re: Server did not like results, dumping
If the WU was corrupted for any reason, it is of no scientific value and will not be accepted. It's not always easy to determine when or where it was corrupted. Does this happen to every WU or just this one?
Ettanin
Post by Ettanin »
Happened three times so far, twice on CPU, once on GPU. System however is fine, last two successful results were on 16th march...
alxbelu
Post by alxbelu »
I only experienced this once on my laptop CPU, but same project, same error and same server:
01:40:03:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:14328 run:1 clone:162 gen:4 core:0xa7 unit:0x000000059bf7a4d65e6d13cb386fdc9c
01:40:03:WU03:FS00:Uploading 4.96MiB to 155.247.164.214
01:40:03:WU03:FS00:Connecting to 155.247.164.214:8080
01:40:04:WARNING:WU03:FS00:Exception: Failed to send results to work server: Transfer failed
01:40:04:WU03:FS00:Trying to send results to collection server
01:40:04:WU03:FS00:Uploading 4.96MiB to 155.247.166.220
01:40:04:WU03:FS00:Connecting to 155.247.166.220:8080
01:40:10:WU03:FS00:Upload 15.12%
01:40:10:WU04:FS00:Connecting to 65.254.110.245:8080
01:40:11:WARNING:WU04:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
01:40:11:WU04:FS00:Connecting to 18.218.241.186:80
01:40:11:WARNING:WU04:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:40:11:ERROR:WU04:FS00:Exception: Could not get an assignment
01:40:16:WU03:FS00:Upload 26.46%
01:40:22:WU03:FS00:Upload 39.07%
01:40:28:WU03:FS00:Upload 50.41%
01:40:34:WU03:FS00:Upload 63.01%
01:40:40:WU03:FS00:Upload 76.87%
01:40:46:WU03:FS00:Upload 90.73%
01:40:51:WU03:FS00:Upload complete
01:40:51:WU03:FS00:Server responded WORK_QUIT (404)
01:40:51:WARNING:WU03:FS00:Server did not like results, dumping
In my case it's a ~1y old laptop with an i7-8750h, not overclocked, thermal throttling working as expected (at the time I also had it by an open window which definitely kept the thermals in check). And as mentioned, no other WUs have failed.
Official F@H Twitter (frequently updated): https://twitter.com/foldingathome
Official F@H Facebook: https://www.facebook.com/Foldinghome-136059519794607/
(I'm not affiliated with the F@H Team, just promoting these channels for official updates)
Do you have any antivirus scanner active on your system? Depending on which is used, the random binary data in the F@h work files may be misidentified as being from malware and either modified or quarantined. That can also corrupt a WU. If you are running such scans, we recommend excluding the F@h data directory from scans.
alxbelu
Post by alxbelu »
Not sure about OP, but I do have Avira installed, but I have also still only experienced the issue once, and have since (today/March 17) completed and submitted another instance of 14328 (as well as other WUs). I'll wait and see if it happens again before changing anything.
16:33:55:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14328 run:0 clone:3919 gen:12 core:0xa7 unit:0x0000000d9bf7a4d65e6c0bb8bc78dfff
16:33:55:WU01:FS00:Uploading 4.96MiB to 155.247.164.214
16:33:55:WU01:FS00:Connecting to 155.247.164.214:8080
16:34:01:WU01:FS00:Upload complete
16:34:01:WU01:FS00:Server responded WORK_ACK (400)
16:34:01:WU01:FS00:Final credit estimate, 2428.00 points
Ettanin
Post by Ettanin »
Joe_H wrote:Do you have any antivirus scanner active on your system? Depending on which is used, the random binary data in the F@h work files may be misidentified as being from malware and either modified or quarantined. That can also corrupt a WU. If you are running such scans, we recommend excluding the F@h data directory from scans.
None besides what comes with Windows 10 (Defender). I don't think it's the reason for any of the issues or else several people would have that as well.
EDIT: System seems fine, the recent GPU unit was completed with WORK_ACK. I assume I just had back luck and got three bad WUs in a row.
Scraig
Post by Scraig »
The same problem here. WU started at 05:16:16 and ended at 09:57:34 = 04:40:48 GPU time wasted.
*********************** Log Started 2020-03-18T19:01:35Z ***********************
******************************* Date: 2020-03-19 *******************************
05:09:58:WU02:FS01:Connecting to 65.254.110.245:8080
05:09:58:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:09:58:WU02:FS01:Connecting to 18.218.241.186:80
05:09:59:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:09:59:ERROR:WU02:FS01:Exception: Could not get an assignment
05:09:59:WU02:FS01:Connecting to 65.254.110.245:8080
05:10:00:WU02:FS01:Assigned to work server 128.252.203.2
05:10:00:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP106 [GeForce GTX 1060 6GB] 4372 from 128.252.203.2
05:10:00:WU02:FS01:Connecting to 128.252.203.2:8080
05:10:55:WU02:FS01:Downloading 79.27MiB
05:11:01:WU02:FS01:Download 16.24%
05:11:07:WU02:FS01:Download 36.74%
05:11:13:WU02:FS01:Download 50.38%
05:11:19:WU02:FS01:Download 59.61%
05:11:25:WU02:FS01:Download 65.76%
05:11:31:WU02:FS01:Download 75.53%
05:11:37:WU02:FS01:Download 83.42%
05:11:43:WU02:FS01:Download 91.85%
05:11:48:WU02:FS01:Download complete
05:11:48:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14533 run:0 clone:2816 gen:0 core:0x22 unit:0x0000000080fccb025e72f20d11e271a4
05:13:18:WU02:FS01:Starting
05:13:18:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\siegf\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 808 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
05:13:18:WU02:FS01:Started FahCore on PID 21312
05:13:18:WU02:FS01:Core PID:8720
05:13:18:WU02:FS01:FahCore 0x22 started
05:13:18:WU02:FS01:0x22:*********************** Log Started 2020-03-19T05:13:18Z ***********************
05:13:18:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
05:13:18:WU02:FS01:0x22:       Type: 0x22
05:13:18:WU02:FS01:0x22:       Core: Core22
05:13:18:WU02:FS01:0x22:    Website: https://foldingathome.org/
05:13:18:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
05:13:18:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
05:13:18:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
05:13:18:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 21312 -checkpoint 15
05:13:18:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
05:13:18:WU02:FS01:0x22:             0 -gpu 0
05:13:18:WU02:FS01:0x22:     Config: <none>
05:13:18:WU02:FS01:0x22:************************************ Build *************************************
05:13:18:WU02:FS01:0x22:    Version: 0.0.2
05:13:18:WU02:FS01:0x22:       Date: Dec 6 2019
05:13:18:WU02:FS01:0x22:       Time: 21:30:31
05:13:18:WU02:FS01:0x22: Repository: Git
05:13:18:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
05:13:18:WU02:FS01:0x22:     Branch: HEAD
05:13:18:WU02:FS01:0x22:   Compiler: Visual C++ 2008
05:13:18:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:13:18:WU02:FS01:0x22:   Platform: win32 10
05:13:18:WU02:FS01:0x22:       Bits: 64
05:13:18:WU02:FS01:0x22:       Mode: Release
05:13:18:WU02:FS01:0x22:************************************ System ************************************
05:13:18:WU02:FS01:0x22:        CPU: AMD Ryzen 9 3900X 12-Core Processor
05:13:18:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
05:13:18:WU02:FS01:0x22:       CPUs: 24
05:13:18:WU02:FS01:0x22:     Memory: 31.93GiB
05:13:18:WU02:FS01:0x22:Free Memory: 25.39GiB
05:13:18:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
05:13:18:WU02:FS01:0x22: OS Version: 6.2
05:13:18:WU02:FS01:0x22:Has Battery: false
05:13:18:WU02:FS01:0x22: On Battery: false
05:13:18:WU02:FS01:0x22: UTC Offset: 1
05:13:18:WU02:FS01:0x22:        PID: 8720
05:13:18:WU02:FS01:0x22:        CWD: C:\Users\siegf\AppData\Roaming\FAHClient\work
05:13:18:WU02:FS01:0x22:         OS: Windows 10 Home
05:13:18:WU02:FS01:0x22:    OS Arch: AMD64
05:13:18:WU02:FS01:0x22:********************************************************************************
05:13:18:WU02:FS01:0x22:Project: 14533 (Run 0, Clone 2816, Gen 0)
05:13:18:WU02:FS01:0x22:Unit: 0x0000000080fccb025e72f20d11e271a4
05:13:18:WU02:FS01:0x22:Reading tar file core.xml
05:13:18:WU02:FS01:0x22:Reading tar file integrator.xml
05:13:18:WU02:FS01:0x22:Reading tar file state.xml
05:13:18:WU02:FS01:0x22:Reading tar file system.xml
05:13:18:WU02:FS01:0x22:Digital signatures verified
05:13:18:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
05:13:18:WU02:FS01:0x22:Version 0.0.2
05:13:31:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
05:13:31:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:16:18:WU02:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
05:19:05:WU02:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
05:21:53:WU02:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
05:24:39:WU02:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
05:27:27:WU02:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
05:30:17:WU02:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
05:33:04:WU02:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
05:35:51:WU02:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
05:38:38:WU02:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
05:41:25:WU02:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
05:44:17:WU02:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
05:47:04:WU02:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
05:49:51:WU02:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
05:52:38:WU02:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
05:55:25:WU02:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
05:58:16:WU02:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
06:01:03:WU02:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
06:03:51:WU02:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
06:06:38:WU02:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
06:09:25:WU02:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
06:12:16:WU02:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
06:15:04:WU02:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
06:17:51:WU02:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
06:20:39:WU02:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
06:23:26:WU02:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
06:26:17:WU02:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
06:29:04:WU02:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
06:31:52:WU02:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
06:34:39:WU02:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
06:37:26:WU02:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
06:40:18:WU02:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
06:43:05:WU02:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
06:45:52:WU02:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
06:48:39:WU02:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
06:51:27:WU02:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
06:54:18:WU02:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
06:57:05:WU02:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
06:59:53:WU02:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
07:02:40:WU02:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
07:05:27:WU02:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
07:08:18:WU02:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
07:11:06:WU02:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
07:13:53:WU02:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
07:16:40:WU02:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
07:19:28:WU02:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
07:22:19:WU02:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
07:25:06:WU02:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
07:27:54:WU02:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
07:30:46:WU02:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
07:33:38:WU02:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
07:36:36:WU02:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
07:39:30:WU02:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
07:42:23:WU02:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
07:45:17:WU02:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
07:48:11:WU02:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
07:51:09:WU02:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
07:54:01:WU02:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
07:56:53:WU02:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
07:59:45:WU02:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
08:02:37:WU02:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
08:05:34:WU02:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
08:08:26:WU02:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
08:11:18:WU02:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
08:14:09:WU02:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
08:17:02:WU02:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
08:20:00:WU02:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
08:22:55:WU02:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
08:25:49:WU02:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
08:28:41:WU02:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
08:31:33:WU02:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
08:34:30:WU02:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
08:37:23:WU02:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
08:40:16:WU02:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
08:43:09:WU02:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
08:46:01:WU02:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
08:48:55:WU02:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
08:51:45:WU02:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
08:54:36:WU02:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
08:57:26:WU02:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
09:00:16:WU02:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
09:03:10:WU02:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
09:06:00:WU02:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
09:08:51:WU02:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
09:11:41:WU02:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
09:14:31:WU02:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
09:17:26:WU02:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
09:20:16:WU02:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
09:23:06:WU02:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
09:25:56:WU02:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
09:28:47:WU02:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
09:31:41:WU02:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
09:34:32:WU02:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
09:37:22:WU02:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
09:40:12:WU02:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
09:43:02:WU02:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
09:45:57:WU02:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
09:48:49:WU02:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
09:51:45:WU02:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
09:54:40:WU02:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
09:57:34:WU02:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
09:57:39:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
09:57:39:WU02:FS01:0x22:Saving result file checkpointState.xml
09:57:39:WU02:FS01:0x22:Saving result file checkpt.crc
09:57:39:WU02:FS01:0x22:Saving result file positions.xtc
09:57:39:WU02:FS01:0x22:Saving result file science.log
09:57:39:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
09:57:40:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:57:40:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:14533 run:0 clone:2816 gen:0 core:0x22 unit:0x0000000080fccb025e72f20d11e271a4
09:57:40:WU02:FS01:Uploading 49.92MiB to 128.252.203.2
09:57:40:WU02:FS01:Connecting to 128.252.203.2:8080
09:57:46:WU02:FS01:Upload 5.26%
09:57:52:WU02:FS01:Upload 9.14%
09:57:58:WU02:FS01:Upload 15.27%
09:58:04:WU02:FS01:Upload 21.91%
09:58:10:WU02:FS01:Upload 27.92%
09:58:16:WU02:FS01:Upload 33.30%
09:58:22:WU02:FS01:Upload 43.94%
09:58:28:WU02:FS01:Upload 50.33%
09:58:34:WU02:FS01:Upload 59.22%
09:58:40:WU02:FS01:Upload 65.10%
09:58:46:WU02:FS01:Upload 74.24%
09:58:52:WU02:FS01:Upload 83.13%
09:58:58:WU02:FS01:Upload 89.39%
09:59:04:WU02:FS01:Upload 94.77%
09:59:10:WU02:FS01:Upload complete
09:59:10:WU02:FS01:Server responded WORK_QUIT (404)
09:59:10:WARNING:WU02:FS01:Server did not like results, dumping
09:59:10:WU02:FS01:Cleaning up
