OpenCL: Not detected: clGetDeviceIDs() returned -1FULL LOG:
*********************** Log Started 2020-03-17T03:02:26Z ***********************
03:02:26:************************* Folding@home Client *************************
03:02:26: Website: https://foldingathome.org/
03:02:26: Copyright: (c) 2009-2018 foldingathome.org
03:02:26: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:02:26: Args: --child --lifeline 1366 /etc/fahclient/config.xml --run-as
03:02:26: fahclient --pid-file=/var/run/fahclient.pid --daemon
03:02:26: Config: /etc/fahclient/config.xml
03:02:26:******************************** Build ********************************
03:02:26: Version: 7.5.1
03:02:26: Date: May 11 2018
03:02:26: Time: 19:59:04
03:02:26: Repository: Git
03:02:26: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
03:02:26: Branch: master
03:02:26: Compiler: GNU 6.3.0 20170516
03:02:26: Options: -std=gnu++98 -O3 -funroll-loops
03:02:26: Platform: linux2 4.14.0-3-amd64
03:02:26: Bits: 64
03:02:26: Mode: Release
03:02:26:******************************* System ********************************
03:02:26: CPU: AMD Ryzen 7 3700X 8-Core Processor
03:02:26: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
03:02:26: CPUs: 16
03:02:26: Memory: 15.67GiB
03:02:26:Free Memory: 14.65GiB
03:02:26: Threads: POSIX_THREADS
03:02:26: OS Version: 4.15
03:02:26:Has Battery: false
03:02:26: On Battery: false
03:02:26: UTC Offset: -5
03:02:26: PID: 1368
03:02:26: CWD: /var/lib/fahclient
03:02:26: OS: Linux 4.15.0-91-generic x86_64
03:02:26: OS Arch: AMD64
03:02:26: GPUs: 0
03:02:26: CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
03:02:26: libcuda.so: cannot open shared object file: No such file or
03:02:26: directory
03:02:26: OpenCL: Not detected: clGetDeviceIDs() returned -1
03:02:26:***********************************************************************
03:02:26:<config>
03:02:26: <!-- Client Control -->
03:02:26: <fold-anon v='true'/>
03:02:26:
03:02:26: <!-- Folding Slot Configuration -->
03:02:26: <gpu v='false'/>
03:02:26:
03:02:26: <!-- Network -->
03:02:26: <proxy v=':8080'/>
03:02:26:
03:02:26: <!-- Slot Control -->
03:02:26: <power v='full'/>
03:02:26:
03:02:26: <!-- User Information -->
03:02:26: <team v='236962'/>
03:02:26: <user v='Phobos001'/>
03:02:26:
03:02:26: <!-- Folding Slots -->
03:02:26: <slot id='0' type='CPU'>
03:02:26: <paused v='true'/>
03:02:26: </slot>
03:02:26:</config>
03:02:26:Switching to user fahclient
03:02:26:Trying to access database...
03:02:26:Successfully acquired database lock
03:02:26:Enabled folding slot 00: PAUSED cpu:16 (by user)
03:04:30:Saving configuration to /etc/fahclient/config.xml
03:04:30:<config>
03:04:30: <!-- Client Control -->
03:04:30: <fold-anon v='true'/>
03:04:30:
03:04:30: <!-- Folding Slot Configuration -->
03:04:30: <gpu v='false'/>
03:04:30:
03:04:30: <!-- Network -->
03:04:30: <proxy v=':8080'/>
03:04:30:
03:04:30: <!-- Slot Control -->
03:04:30: <power v='full'/>
03:04:30:
03:04:30: <!-- User Information -->
03:04:30: <team v='236962'/>
03:04:30: <user v='Phobos001'/>
03:04:30:
03:04:30: <!-- Folding Slots -->
03:04:30: <slot id='0' type='CPU'>
03:04:30: <paused v='true'/>
03:04:30: </slot>
03:04:30:</config>
03:05:03:Saving configuration to /etc/fahclient/config.xml
03:05:03:<config>
03:05:03: <!-- Client Control -->
03:05:03: <fold-anon v='true'/>
03:05:03:
03:05:03: <!-- Folding Slot Configuration -->
03:05:03: <gpu v='false'/>
03:05:03:
03:05:03: <!-- Network -->
03:05:03: <proxy v=':8080'/>
03:05:03:
03:05:03: <!-- Slot Control -->
03:05:03: <power v='full'/>
03:05:03:
03:05:03: <!-- User Information -->
03:05:03: <team v='236962'/>
03:05:03: <user v='Phobos001'/>
03:05:03:
03:05:03: <!-- Folding Slots -->
03:05:03: <slot id='0' type='CPU'>
03:05:03: <paused v='true'/>
03:05:03: </slot>
03:05:03:</config>
03:19:04:Saving configuration to /etc/fahclient/config.xml
03:19:04:<config>
03:19:04: <!-- Client Control -->
03:19:04: <fold-anon v='true'/>
03:19:04:
03:19:04: <!-- Folding Slot Configuration -->
03:19:04: <gpu v='false'/>
03:19:04:
03:19:04: <!-- Network -->
03:19:04: <proxy v=':8080'/>
03:19:04:
03:19:04: <!-- Slot Control -->
03:19:04: <power v='full'/>
03:19:04:
03:19:04: <!-- User Information -->
03:19:04: <team v='236962'/>
03:19:04: <user v='Phobos001'/>
03:19:04:
03:19:04: <!-- Folding Slots -->
03:19:04: <slot id='0' type='CPU'>
03:19:04: <paused v='true'/>
03:19:04: </slot>
03:19:04:</config>
03:19:15:FS00:Unpaused
03:19:15:WU00:FS00:Starting
03:19:15:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 1368 -checkpoint 15 -np 16
03:19:15:WU00:FS00:Started FahCore on PID 12850
03:19:15:WU00:FS00:Core PID:12854
03:19:15:WU00:FS00:FahCore 0xa7 started
03:19:16:WU00:FS00:0xa7:*********************** Log Started 2020-03-17T03:19:15Z ***********************
03:19:16:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:19:16:WU00:FS00:0xa7: Type: 0xa7
03:19:16:WU00:FS00:0xa7: Core: Gromacs
03:19:16:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 12850 -checkpoint 15 -np
03:19:16:WU00:FS00:0xa7: 16
03:19:16:WU00:FS00:0xa7:************************************ CBang *************************************
03:19:16:WU00:FS00:0xa7: Date: Nov 5 2019
03:19:16:WU00:FS00:0xa7: Time: 06:06:57
03:19:16:WU00:FS00:0xa7: Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
03:19:16:WU00:FS00:0xa7: Branch: master
03:19:16:WU00:FS00:0xa7: Compiler: GNU 8.3.0
03:19:16:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
03:19:16:WU00:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
03:19:16:WU00:FS00:0xa7: Bits: 64
03:19:16:WU00:FS00:0xa7: Mode: Release
03:19:16:WU00:FS00:0xa7:************************************ System ************************************
03:19:16:WU00:FS00:0xa7: CPU: AMD Ryzen 7 3700X 8-Core Processor
03:19:16:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
03:19:16:WU00:FS00:0xa7: CPUs: 16
03:19:16:WU00:FS00:0xa7: Memory: 15.67GiB
03:19:16:WU00:FS00:0xa7:Free Memory: 9.20GiB
03:19:16:WU00:FS00:0xa7: Threads: POSIX_THREADS
03:19:16:WU00:FS00:0xa7: OS Version: 4.15
03:19:16:WU00:FS00:0xa7:Has Battery: false
03:19:16:WU00:FS00:0xa7: On Battery: false
03:19:16:WU00:FS00:0xa7: UTC Offset: -5
03:19:16:WU00:FS00:0xa7: PID: 12854
03:19:16:WU00:FS00:0xa7: CWD: /var/lib/fahclient/work
03:19:16:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:19:16:WU00:FS00:0xa7: Version: 0.0.18
03:19:16:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:19:16:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:19:16:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:19:16:WU00:FS00:0xa7: Time: 06:13:26
03:19:16:WU00:FS00:0xa7: Revision: 490c9aa2957b725af319379424d5c5cb36efb656
03:19:16:WU00:FS00:0xa7:************************************ Build *************************************
03:19:16:WU00:FS00:0xa7: SIMD: avx_256
03:19:16:WU00:FS00:0xa7:********************************************************************************
03:19:16:WU00:FS00:0xa7:Project: 13833 (Run 0, Clone 3633, Gen 1)
03:19:16:WU00:FS00:0xa7:Unit: 0x0000000180fccb095e6e55bb67095533
03:19:16:WU00:FS00:0xa7:Digital signatures verified
03:19:16:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -x frame1.xtc -cpi state.cpt -cpt 15 -nt 16
03:19:16:WU00:FS00:0xa7:Steps: first=250000 total=250000
03:19:17:WU00:FS00:0xa7:Completed 136342 out of 250000 steps (54%)
03:19:26:Saving configuration to /etc/fahclient/config.xml
03:19:26:<config>
03:19:26: <!-- Client Control -->
03:19:26: <fold-anon v='true'/>
03:19:26:
03:19:26: <!-- Folding Slot Configuration -->
03:19:26: <gpu v='false'/>
03:19:26:
03:19:26: <!-- Network -->
03:19:26: <proxy v=':8080'/>
03:19:26:
03:19:26: <!-- Slot Control -->
03:19:26: <power v='full'/>
03:19:26:
03:19:26: <!-- User Information -->
03:19:26: <team v='236962'/>
03:19:26: <user v='Phobos001'/>
03:19:26:
03:19:26: <!-- Folding Slots -->
03:19:26: <slot id='0' type='CPU'/>
03:19:26:</config>
03:19:27:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
03:19:43:Saving configuration to /etc/fahclient/config.xml
03:19:43:<config>
03:19:43: <!-- Client Control -->
03:19:43: <fold-anon v='true'/>
03:19:43:
03:19:43: <!-- Folding Slot Configuration -->
03:19:43: <gpu v='false'/>
03:19:43:
03:19:43: <!-- Network -->
03:19:43: <proxy v=':8080'/>
03:19:43:
03:19:43: <!-- Slot Control -->
03:19:43: <power v='full'/>
03:19:43:
03:19:43: <!-- User Information -->
03:19:43: <team v='236962'/>
03:19:43: <user v='Phobos001'/>
03:19:43:
03:19:43: <!-- Folding Slots -->
03:19:43: <slot id='0' type='CPU'/>
03:19:43:</config>
03:19:51:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
03:20:17:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
03:20:39:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
03:21:04:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
03:21:30:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
03:21:55:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
03:22:20:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
03:22:45:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
03:23:11:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
03:23:38:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
03:24:01:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
03:24:23:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
03:24:45:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
03:25:07:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
03:25:29:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
03:25:51:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
03:26:13:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
03:26:35:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
03:26:58:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
03:27:20:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
03:27:42:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
03:28:04:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
03:28:27:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
03:28:52:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
03:29:15:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
03:29:38:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
03:29:44:Saving configuration to /etc/fahclient/config.xml
03:29:44:<config>
03:29:44: <!-- Client Control -->
03:29:44: <fold-anon v='true'/>
03:29:44:
03:29:44: <!-- Network -->
03:29:44: <proxy v=':8080'/>
03:29:44:
03:29:44: <!-- Slot Control -->
03:29:44: <power v='full'/>
03:29:44:
03:29:44: <!-- User Information -->
03:29:44: <team v='236962'/>
03:29:44: <user v='Phobos001'/>
03:29:44:
03:29:44: <!-- Folding Slots -->
03:29:44: <slot id='0' type='CPU'/>
03:29:44:</config>
03:29:44:Connecting to assign1.foldingathome.org:8080
03:29:44:Updated GPUs.txt
03:29:53:Saving configuration to /etc/fahclient/config.xml
03:29:53:<config>
03:29:53: <!-- Client Control -->
03:29:53: <fold-anon v='true'/>
03:29:53:
03:29:53: <!-- Network -->
03:29:53: <proxy v=':8080'/>
03:29:53:
03:29:53: <!-- Slot Control -->
03:29:53: <power v='full'/>
03:29:53:
03:29:53: <!-- User Information -->
03:29:53: <team v='236962'/>
03:29:53: <user v='Phobos001'/>
03:29:53:
03:29:53: <!-- Folding Slots -->
03:29:53: <slot id='0' type='CPU'/>
03:29:53:</config>
03:29:55:Saving configuration to /etc/fahclient/config.xml
03:29:55:<config>
03:29:55: <!-- Client Control -->
03:29:55: <fold-anon v='true'/>
03:29:55:
03:29:55: <!-- Network -->
03:29:55: <proxy v=':8080'/>
03:29:55:
03:29:55: <!-- Slot Control -->
03:29:55: <power v='full'/>
03:29:55:
03:29:55: <!-- User Information -->
03:29:55: <team v='236962'/>
03:29:55: <user v='Phobos001'/>
03:29:55:
03:29:55: <!-- Folding Slots -->
03:29:55: <slot id='0' type='CPU'/>
03:29:55:</config>
03:30:03:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
03:30:25:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
03:30:48:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
03:31:10:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
03:31:33:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
03:31:57:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
03:32:04:Removing old file 'configs/config-20200315-144312.xml'
03:32:04:Saving configuration to /etc/fahclient/config.xml
03:32:04:<config>
03:32:04: <!-- Client Control -->
03:32:04: <fold-anon v='true'/>
03:32:04:
03:32:04: <!-- Folding Slot Configuration -->
03:32:04: <extra-core-args v='-forcegpu'/>
03:32:04:
03:32:04: <!-- Network -->
03:32:04: <proxy v=':8080'/>
03:32:04:
03:32:04: <!-- Slot Control -->
03:32:04: <power v='full'/>
03:32:04:
03:32:04: <!-- User Information -->
03:32:04: <team v='236962'/>
03:32:04: <user v='Phobos001'/>
03:32:04:
03:32:04: <!-- Folding Slots -->
03:32:04: <slot id='0' type='CPU'/>
03:32:04:</config>
03:32:12:Removing old file 'configs/config-20200315-203436.xml'
03:32:12:Saving configuration to /etc/fahclient/config.xml
03:32:12:<config>
03:32:12: <!-- Client Control -->
03:32:12: <fold-anon v='true'/>
03:32:12:
03:32:12: <!-- Folding Slot Configuration -->
03:32:12: <extra-core-args v='-forcegpu'/>
03:32:12:
03:32:12: <!-- Network -->
03:32:12: <proxy v=':8080'/>
03:32:12:
03:32:12: <!-- Slot Control -->
03:32:12: <power v='full'/>
03:32:12:
03:32:12: <!-- User Information -->
03:32:12: <team v='236962'/>
03:32:12: <user v='Phobos001'/>
03:32:12:
03:32:12: <!-- Folding Slots -->
03:32:12: <slot id='0' type='CPU'/>
03:32:12:</config>
03:32:21:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
03:32:46:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
03:32:56:Removing old file 'configs/config-20200315-203457.xml'
03:32:56:Saving configuration to /etc/fahclient/config.xml
03:32:56:<config>
03:32:56: <!-- Client Control -->
03:32:56: <fold-anon v='true'/>
03:32:56:
03:32:56: <!-- Folding Slot Configuration -->
03:32:56: <extra-core-args v='-forcegpu'/>
03:32:56:
03:32:56: <!-- Network -->
03:32:56: <proxy v=':8080'/>
03:32:56:
03:32:56: <!-- Slot Control -->
03:32:56: <power v='full'/>
03:32:56:
03:32:56: <!-- User Information -->
03:32:56: <team v='236962'/>
03:32:56: <user v='Phobos001'/>
03:32:56:
03:32:56: <!-- Folding Slots -->
03:32:56: <slot id='0' type='CPU'/>
03:32:56:</config>
03:33:09:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
03:33:32:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
03:33:57:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
03:34:23:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
03:34:48:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
03:35:13:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
03:35:37:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
03:36:01:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
