Incorrect COVID19 Project Description
ryannathans
Post by ryannathans »
viewtopic.php?f=74&t=32463
This post mentions that 11760 is a GPU project (that I'm currently working on with my GPU)
GPU : 11741 to 11764
However, this
https://apps.foldingathome.org/project?p=11760
page states
These are high-priority **CPU** projects to simulate the main protease of the COVID-19.
Re: Incorrect COVID19 Project Description
Post by muziqaz »
I'm not sure what you mean, but description does not contradict what's in the forum post.
11760 is COVID project, and forum post mentions that if you are folding any GPU project between 11741 and 11764 (which includes 11760), you are contributing to COVID research.
Thank you for your contribution
FAH Omega tester
kiore
Post by kiore »
Yes that should read GPU not CPU unit series. To confirm on your log the CPU units will always use core A7 while the GPU will say core 22.
Post by muziqaz »
kiore wrote:Yes that should read GPU not CPU unit series. To confirm on your log the CPU units will always use core A7 while the GPU will say core 22.
Ah, yes, I'm blind or not paying attention :)
FAH Omega tester
moritzgedig
Re: Incorrect Project 11761 Description
Post by moritzgedig »
I can second that.
11761 is a Core 0x22 Project.
https://apps.foldingathome.org/project.py?p=11761 is wrong
donating since 2001
vnicolici
Post by vnicolici »
I have GPU unit from a 0x22 project, that currently doesn't even seem to have a description:
https://apps.foldingathome.org/project?p=11776
Trying to see the description there gives me "Project unspecified". There is also no description displayed in the local web control, instead of description it's saying "Loading...".
I assume this is also a COVID project.
kiore
Post by kiore »
vnicolici wrote:I have GPU unit from a 0x22 project, that currently doesn't even seem to have a description:
It looks like one, especially as it has popped up without a description and starts with 117xxx These units are coming quickly into testing as previous series are complete or give new leads.
