Quadro K620 on Ubuntu 18.04
ScreechXIIV
Post by ScreechXIIV »
Hi all
I have an older machine that im am trying to put to work that has 2 Quardro K620s in it but FAH will not recognize them no what drivers I select. I am running Ubuntu 18.04.
Every time I try to add a gpu I get a "On client "local" 127.0.0.1:36330: No available GPUs"
The system info tab shows that i have 0 GPUs but 2 cuda devices and 2 opencl devices. But I am unable to get either of my cards added.
Please help
Paragon
Hardware configuration: Rig1 (Dedicated SMP): AMD Phenom II X6 1100T, Gigabyte GA-880GMA-USB3 board, 8 GB Kingston 1333 DDR3 Ram, Seasonic S12 II 380 Watt PSU, Noctua CPU Cooler
Rig2 (Part-Time GPU): Intel Q6600, Gigabyte 965P-S3 Board, EVGA 460 GTX Graphics, 8 GB Kingston 800 DDR2 Ram, Seasonic Gold X-650 PSU, Artic Cooling Freezer 7 CPU Cooler
Re: Quadro K620 on Ubuntu 18.04
Post by Paragon »
In the client, if you click on config and go to the expert tab, do you see a variable that says something like"GPU=false"? If so, set it to true and reboot.
Welcome to Folding@home!
Your card should be supported as It runs OpenCL 1.2 and does Double Precision floating point math.
It was introduced in 2014 so I would be surprised if it was not in the whitelist. On the other hand it is a workstation card not a gamer card so it may have a small audience.
For me to help more I would need the first 200 lines of your log so I could see what the software thinks your PC looks like.
viewtopic.php?f=24&t=26036
0x10de:0x13bb:2:4:GM107 [Quadro K620]
so yes it is in the file and whitelisted.
ScreechXIIV
Paragon wrote:In the client, if you click on config and go to the expert tab, do you see a variable that says something like"GPU=false"? If so, set it to true and reboot.
That did the trick. I set gpu to true and restarted my machine. After the restart I was able to add both of my gpus and everything is now working.
Thank you everybody for your help
