Viewer not working
LOlitsnico
Viewer not working
Post by LOlitsnico »
So uh. yeah. Im actually involved with a process right now. Screenshots below. But I right-click on the device that F@H is using on my computer (ie: CPU) And click View, and it just says Demo, and doesn't tell me my name, my team, the project, or any statistical information. Any Idea on why? Here is my log.
01:01:16:Saving configuration to config.xml
01:01:16:<config>
01:01:16:  <!-- Network -->
01:01:16:  <proxy v=':8080'/>
01:01:16:
01:01:16:  <!-- User Information -->
01:01:16:  <team v='225605'/>
01:01:16:  <user v='Lolitsnico'/>
01:01:16:
01:01:16:  <!-- Folding Slots -->
01:01:16:  <slot id='0' type='CPU'/>
01:01:16:  <slot id='2' type='GPU'/>
01:01:16:</config>
01:01:16:FS00:Shutting core down
01:01:16:WARNING:WU01:FS01:Slot ID 1 no longer exists and there are no other matching slots, dumping
01:01:16:WU01:FS01:Sending unit results: id:01 state:SEND error:DUMPED project:11743 run:0 clone:4437 gen:1 core:0x22 unit:0x000000048ca304f15e69de603b414d05
01:01:16:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 416
01:01:16:WU00:FS00:0xa7:Exiting, please wait. . .
01:01:16:WU01:FS01:Connecting to 140.163.4.241:8080
01:01:16:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
01:01:16:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:01:17:WU00:FS00:Starting
01:01:17:WARNING:WU00:FS00:Changed SMP threads from 5 to 6 this can cause some work units to fail
01:01:17:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
01:01:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Nico\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 12568 -checkpoint 15 -np 5
01:01:17:WU00:FS00:Started FahCore on PID 12024
01:01:17:WU00:FS00:Core PID:14144
01:01:17:WU00:FS00:FahCore 0xa7 started
01:01:17:WU00:FS00:0xa7:*********************** Log Started 2020-03-17T01:01:17Z ***********************
01:01:17:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:01:17:WU00:FS00:0xa7:       Type: 0xa7
01:01:17:WU00:FS00:0xa7:       Core: Gromacs
01:01:17:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 12024 -checkpoint 15 -np
01:01:17:WU00:FS00:0xa7:             5
01:01:17:WU00:FS00:0xa7:************************************ CBang *************************************
01:01:17:WU00:FS00:0xa7:       Date: Oct 26 2019
01:01:17:WU00:FS00:0xa7:       Time: 01:38:25
01:01:17:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
01:01:17:WU00:FS00:0xa7:     Branch: master
01:01:17:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
01:01:17:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:01:17:WU00:FS00:0xa7:   Platform: win32 10
01:01:17:WU00:FS00:0xa7:       Bits: 64
01:01:17:WU00:FS00:0xa7:       Mode: Release
01:01:17:WU00:FS00:0xa7:************************************ System ************************************
01:01:17:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 2400G with Radeon Vega Graphics
01:01:17:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
01:01:17:WU00:FS00:0xa7:       CPUs: 8
01:01:17:WU00:FS00:0xa7:     Memory: 14.93GiB
01:01:17:WU00:FS00:0xa7:Free Memory: 8.12GiB
01:01:17:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
01:01:17:WU00:FS00:0xa7: OS Version: 6.2
01:01:17:WU00:FS00:0xa7:Has Battery: false
01:01:17:WU00:FS00:0xa7: On Battery: false
01:01:17:WU00:FS00:0xa7: UTC Offset: -5
01:01:17:WU00:FS00:0xa7:        PID: 14144
01:01:17:WU00:FS00:0xa7:        CWD: C:\Users\Nico\AppData\Roaming\FAHClient\work
01:01:17:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
01:01:17:WU00:FS00:0xa7:    Version: 0.0.18
01:01:17:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:01:17:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
01:01:17:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
01:01:17:WU00:FS00:0xa7:       Time: 01:52:30
01:01:17:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
01:01:17:WU00:FS00:0xa7:************************************ Build *************************************
01:01:17:WU00:FS00:0xa7:       SIMD: avx_256
01:01:17:WU00:FS00:0xa7:********************************************************************************
01:01:17:WU00:FS00:0xa7:Project: 14304 (Run 4, Clone 224, Gen 14)
01:01:17:WU00:FS00:0xa7:Unit: 0x0000000f9bf7a4d55e66ca83f6612a71
01:01:17:WU00:FS00:0xa7:Digital signatures verified
01:01:17:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
01:01:17:WU00:FS00:0xa7:Calling: mdrun -s frame14.tpr -o frame14.trr -cpi state.cpt -cpt 15 -nt 4
01:01:17:WU00:FS00:0xa7:Steps: first=7000000 total=500000
01:01:18:WU00:FS00:0xa7:Completed 10562 out of 500000 steps (2%)
01:01:20:WU02:FS02:Download 11.48%
01:01:26:WU02:FS02:Download 35.48%
01:01:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:01:33:WU02:FS02:Download 39.66%
01:01:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:01:39:WU02:FS02:Download 55.83%
01:01:46:WU02:FS02:Download 75.14%
01:01:53:WU02:FS02:Download 96.53%
01:01:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:01:56:WU02:FS02:Download complete
01:01:56:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11741 run:0 clone:7900 gen:1 core:0x22 unit:0x000000038ca304f15e6bc56999ae78b3
01:01:56:WU02:FS02:Starting
01:01:56:ERROR:WU02:FS02:Failed to start core: OpenCL device matching slot 2 not found, try setting 'opencl-index' manually
01:02:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:02:13:Saving configuration to config.xml
01:02:13:<config>
01:02:13:  <!-- Network -->
01:02:13:  <proxy v=':8080'/>
01:02:13:
01:02:13:  <!-- User Information -->
01:02:13:  <team v='225605'/>
01:02:13:  <user v='Lolitsnico'/>
01:02:13:
01:02:13:  <!-- Folding Slots -->
01:02:13:  <slot id='0' type='CPU'/>
01:02:13:  <slot id='2' type='GPU'/>
01:02:13:</config>
01:02:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:02:39:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
01:02:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:02:56:WU02:FS02:Starting
01:02:56:ERROR:WU02:FS02:Failed to start core: OpenCL device matching slot 2 not found, try setting 'opencl-index' manually
01:02:57:WU01:FS01:Server responded WORK_ACK (400)
01:02:57:WU01:FS01:Cleaning up
01:02:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:03:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:03:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:03:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:04:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:04:10:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
01:04:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:04:33:WU02:FS02:Starting
01:04:33:ERROR:WU02:FS02:Failed to start core: OpenCL device matching slot 2 not found, try setting 'opencl-index' manually
01:04:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:04:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:05:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:05:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:05:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:05:42:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
01:05:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:06:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:06:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:06:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:06:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:07:10:WU02:FS02:Starting
01:07:10:ERROR:WU02:FS02:Failed to start core: OpenCL device matching slot 2 not found, try setting 'opencl-index' manually
01:07:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:07:15:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
01:07:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:07:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:08:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:08:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:08:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:08:49:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
01:09:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:09:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:09:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:09:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:10:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:10:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:10:26:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
01:10:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:10:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:11:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:11:25:WU02:FS02:Starting
01:11:25:ERROR:WU02:FS02:Failed to start core: OpenCL device matching slot 2 not found, try setting 'opencl-index' manually
01:11:25:WU02:FS02:Sending unit results: id:02 state:SEND error:FAILED project:11741 run:0 clone:7900 gen:1 core:0x22 unit:0x000000038ca304f15e6bc56999ae78b3
01:11:25:WU02:FS02:Connecting to 140.163.4.241:8080
01:11:25:WU01:FS02:Connecting to 65.254.110.245:8080
01:11:26:WARNING:WU01:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
01:11:26:WU01:FS02:Connecting to 18.218.241.186:80
01:11:26:WARNING:WU01:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:11:26:ERROR:WU01:FS02:Exception: Could not get an assignment
01:11:26:WU01:FS02:Connecting to 65.254.110.245:8080
01:11:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:11:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:11:46:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
01:11:46:WU02:FS02:Connecting to 140.163.4.241:80
01:12:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:12:02:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
01:12:07:WARNING:WU02:FS02:Exception: Failed to send results to work server: Failed to connect to 140.163.4.241:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:12:07:WU02:FS02:Trying to send results to collection server
01:12:07:WU02:FS02:Connecting to 140.163.4.231:8080
01:12:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:12:26:WU01:FS02:Connecting to 65.254.110.245:8080
01:12:26:WARNING:WU01:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
01:12:26:WU01:FS02:Connecting to 18.218.241.186:80
01:12:27:WARNING:WU01:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:12:27:ERROR:WU01:FS02:Exception: Could not get an assignment
01:12:28:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
01:12:28:WU02:FS02:Connecting to 140.163.4.231:80
01:12:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:12:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:12:49:ERROR:WU02:FS02:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:12:49:WU02:FS02:Sending unit results: id:02 state:SEND error:FAILED project:11741 run:0 clone:7900 gen:1 core:0x22 unit:0x000000038ca304f15e6bc56999ae78b3
01:12:49:WU02:FS02:Connecting to 140.163.4.241:8080
01:13:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:13:10:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
01:13:10:WU02:FS02:Connecting to 140.163.4.241:80
01:13:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:13:31:WARNING:WU02:FS02:Exception: Failed to send results to work server: Failed to connect to 140.163.4.241:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:13:31:WU02:FS02:Trying to send results to collection server
01:13:31:WU02:FS02:Connecting to 140.163.4.231:8080
01:13:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:13:39:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
01:13:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:13:52:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
01:13:52:WU02:FS02:Connecting to 140.163.4.231:80
01:14:03:WU01:FS02:Connecting to 65.254.110.245:8080
01:14:03:WARNING:WU01:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
01:14:03:WU01:FS02:Connecting to 18.218.241.186:80
01:14:04:WU01:FS02:Assigned to work server 140.163.4.241
01:14:04:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:GP106 [GeForce GTX 1060 6GB] 4372 from 140.163.4.241
01:14:04:WU01:FS02:Connecting to 140.163.4.241:8080
01:14:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:14:14:ERROR:WU02:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
01:14:14:WU02:FS02:Sending unit results: id:02 state:SEND error:FAILED project:11741 run:0 clone:7900 gen:1 core:0x22 unit:0x000000038ca304f15e6bc56999ae78b3
01:14:14:WU02:FS02:Connecting to 140.163.4.241:8080
01:14:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:14:25:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
01:14:25:WU01:FS02:Connecting to 140.163.4.241:80
01:14:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:14:46:ERROR:WU01:FS02:Exception: Failed to connect to 140.163.4.241:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:14:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:15:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:15:18:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
01:15:25:WARNING:WU02:FS02:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
01:15:25:WU02:FS02:Trying to send results to collection server
01:15:25:WU02:FS02:Connecting to 140.163.4.231:8080
01:15:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:15:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:16:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:16:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:16:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:16:40:WU01:FS02:Connecting to 65.254.110.245:8080
01:16:41:WARNING:WU01:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
01:16:41:WU01:FS02:Connecting to 18.218.241.186:80
01:16:41:WARNING:WU01:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:16:41:ERROR:WU01:FS02:Exception: Could not get an assignment
01:16:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:17:01:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
01:17:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:17:15:WU02:FS02:Server responded WORK_ACK (400)
01:17:15:WU02:FS02:Cleaning up
01:17:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:17:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:17:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:17:57:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:18:13:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:18:29:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:18:39:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
01:18:45:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:19:01:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:19:17:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:19:33:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:19:49:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:20:05:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:20:15:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
01:20:21:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:20:37:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:20:53:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:20:55:WU01:FS02:Connecting to 65.254.110.245:8080
01:20:55:WARNING:WU01:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
01:20:55:WU01:FS02:Connecting to 18.218.241.186:80
01:20:55:WARNING:WU01:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:20:55:ERROR:WU01:FS02:Exception: Could not get an assignment
01:21:09:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:21:25:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:21:41:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:21:52:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
01:21:57:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:22:13:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:22:29:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:22:45:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:23:01:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:23:17:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:23:33:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:23:37:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
01:23:49:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:24:05:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:24:21:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:24:37:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:24:53:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:25:09:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:25:23:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
01:25:25:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:25:41:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:25:57:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:26:13:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:26:29:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:26:45:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:27:01:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:27:05:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
01:27:17:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:27:33:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:27:46:WU01:FS02:Connecting to 65.254.110.245:8080
01:27:46:WU01:FS02:Assigned to work server 128.252.203.10
01:27:46:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:GP106 [GeForce GTX 1060 6GB] 4372 from 128.252.203.10
01:27:46:WU01:FS02:Connecting to 128.252.203.10:8080
01:27:49:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:28:05:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:28:15:WU01:FS02:Downloading 79.12MiB
01:28:21:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:28:21:WU01:FS02:Download 12.09%
01:28:27:WU01:FS02:Download 32.78%
01:28:33:WU01:FS02:Download 51.58%
01:28:37:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:28:39:WU01:FS02:Download 72.36%
01:28:45:WU01:FS02:Download 86.73%
01:28:45:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
01:28:48:WU01:FS02:Download complete
01:28:48:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11759 run:0 clone:7275 gen:2 core:0x22 unit:0x0000000380fccb0a5e6e9cb042d2462c
01:28:48:WU01:FS02:Starting
01:28:48:ERROR:WU01:FS02:Failed to start core: OpenCL device matching slot 2 not found, try setting 'opencl-index' manually
01:28:49:WU01:FS02:Starting
01:28:49:ERROR:WU01:FS02:Failed to start core: OpenCL device matching slot 2 not found, try setting 'opencl-index' manually
01:28:53:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:29:09:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
https://ibb.co/wB9MGJT
https://ibb.co/0rnTRmQ
Re: Viewer not working
Known issue with using the viewer on Windows, it broke in the latest revision of the client.
LOlitsnico
How absolutely dreadful, I was most excited about the Viewer. Are we doing to expect a software update for this? Is there a a previous version we can downgrade to that will still function?
Some have reported success with using the 7.4.4 version of FAHViewer. From their posts it can be a bit complicated to get installed and keep the rest of 7.5.1.
Blue_Collar
Post by Blue_Collar »
I successfully used the 7.4.4 FAHViewer with 7.5.1, but with mixed success. It does connect, and it sees the Work Unit I am processing, however the model is messed up. I don't really know how to explain what it looks like super well, but it is essentially buried in thousands of purple circles that are in a cube formation. Are we allowed to post links? I am new here...if yes, here is a picture for reference. If not, I apologize and I will remove it if you ask.
https://imgur.com/n1SJlDX
The link to a picture is fine.
There are some options in the viewer to change the type of view, clicking on the life preserver icon will display them. What the picture shows is a very large protein in its bounding box, due to the large number of atoms a lot of detail is obscured. The viewer is a bit more useful when it is showing a smaller protein system, then you can see more of the detail.
All proteins are folded in box of solvent ... typically that's Water. The polar properties of H2O molecules have a significant effect on the atoms in the protein. :eugeek: Reference: "bag of mostly water" :P
The viewer is supposed to make the water transparent but I think the purple is, in fact, the solvent.
Turbolego
Post by Turbolego »
Posting here so that more people can see this solution i found on reddit:
foldinger:
OLD version of FAH 7.4.4 where you can extract the FAHViewer.exe
https://download.foldingathome.org/rele ... .4_x86.exe
Do not install this package but open it using a ZIP program like https://www.7-zip.org/ and only extract the FAHViewer.exe to your current FAHclient 7.5.1 installation folder.
Source thread on reddit: https://www.reddit.com/r/Folding/commen ... /2_issues/
I also had to copy the "freetype6.dll" file (same location as FAHViewer.exe in the 7.4.4 installer).
petnek
Hardware configuration: Asus 990FX Sabertooth, CPU Vishera FX-8350 not OC (Gelid Solution Tranquillo ), 2x4 GB DDR3 RAM 1600MHz (Kingston Blu), GPU Gigabyte HD6770, HDD Seagate Barracuda 7200.14 - 500GB + Samsung Spinpoint F1 320GB, FSP Raider 550W
Post by petnek »
Viewer also consumes PC resources, so its nice to see it, but try to avoid that for maximizing the performance of machine.
