nothing works after setup, please help
Radaengel
Post by Radaengel »
can someone help me? i'm really bad at setting up things manually :-/
*********************** Log Started 2020-03-16T22:12:03Z ***********************
22:12:03:************************* Folding@home Client *************************
22:12:03:        Website: https://foldingathome.org/
22:12:03:      Copyright: (c) 2009-2018 foldingathome.org
22:12:03:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:12:03:           Args: --open-web-control
22:12:03:         Config: C:\Users\King\AppData\Roaming\FAHClient\config.xml
22:12:03:******************************** Build ********************************
22:12:03:        Version: 7.5.1
22:12:03:           Date: May 11 2018
22:12:03:           Time: 13:06:32
22:12:03:     Repository: Git
22:12:03:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:12:03:         Branch: master
22:12:03:       Compiler: Visual C++ 2008
22:12:03:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:12:03:       Platform: win32 10
22:12:03:           Bits: 32
22:12:03:           Mode: Release
22:12:03:******************************* System ********************************
22:12:03:            CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
22:12:03:         CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
22:12:03:           CPUs: 4
22:12:03:         Memory: 15.98GiB
22:12:03:    Free Memory: 12.78GiB
22:12:03:        Threads: WINDOWS_THREADS
22:12:03:     OS Version: 6.2
22:12:03:    Has Battery: false
22:12:03:     On Battery: false
22:12:03:     UTC Offset: 1
22:12:03:            PID: 1624
22:12:03:            CWD: C:\Users\King\AppData\Roaming\FAHClient
22:12:03:             OS: Windows 10 Home
22:12:03:        OS Arch: AMD64
22:12:03:           GPUs: 1
22:12:03:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
22:12:03:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
22:12:03:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.66
22:12:03:  Win32 Service: false
22:12:03:***********************************************************************
22:12:03:<config>
22:12:03:  <!-- Slot Control -->
22:12:03:  <power v='FULL'/>
22:12:03:
22:12:03:  <!-- User Information -->
22:12:03:  <team v='239199'/>
22:12:03:  <user v='Radaengel'/>
22:12:03:
22:12:03:  <!-- Folding Slots -->
22:12:03:  <slot id='0' type='CPU'/>
22:12:03:</config>
22:12:03:Trying to access database...
22:12:03:Successfully acquired database lock
22:12:03:Enabled folding slot 00: READY cpu:4
22:12:04:WU00:FS00:Connecting to 65.254.110.245:8080
22:12:05:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:12:05:WU00:FS00:Connecting to 18.218.241.186:80
22:12:05:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:12:05:ERROR:WU00:FS00:Exception: Could not get an assignment
22:12:06:WU00:FS00:Connecting to 65.254.110.245:8080
22:12:06:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:12:06:WU00:FS00:Connecting to 18.218.241.186:80
22:12:06:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:12:06:ERROR:WU00:FS00:Exception: Could not get an assignment
22:12:08:19:127.0.0.1:New Web connection
22:12:51:ERROR:Receive error: 10053: Eine bestehende Verbindung wurde softwaregesteuert
22:12:51:ERROR:durch den Hostcomputer abgebrochen.
22:13:06:WU00:FS00:Connecting to 65.254.110.245:8080
22:13:06:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:13:06:WU00:FS00:Connecting to 18.218.241.186:80
22:13:06:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:13:06:ERROR:WU00:FS00:Exception: Could not get an assignment
22:14:43:WU00:FS00:Connecting to 65.254.110.245:8080
22:14:43:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:14:43:WU00:FS00:Connecting to 18.218.241.186:80
22:14:44:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:14:44:ERROR:WU00:FS00:Exception: Could not get an assignment
22:17:20:WU00:FS00:Connecting to 65.254.110.245:8080
22:17:20:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:17:20:WU00:FS00:Connecting to 18.218.241.186:80
22:17:21:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:17:21:ERROR:WU00:FS00:Exception: Could not get an assignment
22:21:34:WU00:FS00:Connecting to 65.254.110.245:8080
22:21:35:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:21:35:WU00:FS00:Connecting to 18.218.241.186:80
22:21:35:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:21:35:ERROR:WU00:FS00:Exception: Could not get an assignment
Re: nothing works after setup, please help
Setup looks okay, you may be running into this - Subject: Temporary server outages
