Please add AMD Radeon RX Vega 10 Mobile
CyTeK1978
Post by CyTeK1978 »
Name: AMD Radeon RX Vega 10 Mobile
Device ID: 1002 15D8 - 17AA 3802
*********************** Log Started 2020-03-16T18:32:36Z ***********************
18:32:36:************************* Folding@home Client *************************
18:32:36:        Website: https://foldingathome.org/
18:32:36:      Copyright: (c) 2009-2018 foldingathome.org
18:32:36:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:32:36:           Args: --open-web-control
18:32:36:         Config: C:\Users\simon\AppData\Roaming\FAHClient\config.xml
18:32:36:******************************** Build ********************************
18:32:36:        Version: 7.5.1
18:32:36:           Date: May 11 2018
18:32:36:           Time: 13:06:32
18:32:36:     Repository: Git
18:32:36:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:32:36:         Branch: master
18:32:36:       Compiler: Visual C++ 2008
18:32:36:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:32:36:       Platform: win32 10
18:32:36:           Bits: 32
18:32:36:           Mode: Release
18:32:36:******************************* System ********************************
18:32:36:            CPU: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx
18:32:36:         CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
18:32:36:           CPUs: 8
18:32:36:         Memory: 5.94GiB
18:32:36:    Free Memory: 2.56GiB
18:32:36:        Threads: WINDOWS_THREADS
18:32:36:     OS Version: 6.2
18:32:36:    Has Battery: true
18:32:36:     On Battery: false
18:32:36:     UTC Offset: 1
18:32:36:            PID: 1244
18:32:36:            CWD: C:\Users\simon\AppData\Roaming\FAHClient
18:32:36:             OS: Windows 10 Home
18:32:36:        OS Arch: AMD64
18:32:36:           GPUs: 0
18:32:36:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
18:32:36:                 angegebene Modul wurde nicht gefunden.
18:32:36:
18:32:36:OpenCL Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:1.2 Driver:3004.8
18:32:36:  Win32 Service: false
18:32:36:***********************************************************************
Re: Please add AMD Radeon RX Vega 10 Mobile
While many AMD mobile Graphics lack the hardware to fold, your AMD Radeon RX Vega 10 Mobile has the needed features to fold. It supports OpenCL 2.0 and has Double Precision Floating Point math.
https://www.techpowerup.com/gpu-specs/r ... bile.c3053
In your log, I do not see OpenCL support listed, are you sure you have downloaded the latest driver directly from AMD?
https://www.amd.com/en/support/apu/amd- ... md-ryzen-7
CyTeK1978
Post by CyTeK1978 »
hmm, sure, testet the last actual and the driver before.
actual from installer 20.2.2
from 26.02.2020
whats with this?
from 26.02.2020
whats this?
Let us know its performance.
CyTeK1978
Post by CyTeK1978 »
bruce wrote:Let us know its performance.
sorry my english isnt tha tgood sometimes?
what should i do?
i am right that openCL is installed (see log) ?
but i actual cant use my gpu (not detected, right)?
ahh, its updated (GPU.TXT).
ok i try it now
*********************** Log Started 2020-03-17T07:20:47Z ***********************
07:20:47:************************* Folding@home Client *************************
07:20:47:        Website: https://foldingathome.org/
07:20:47:      Copyright: (c) 2009-2018 foldingathome.org
07:20:47:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:20:47:           Args: --open-web-control
07:20:47:         Config: C:\Users\simon\AppData\Roaming\FAHClient\config.xml
07:20:47:******************************** Build ********************************
07:20:47:        Version: 7.5.1
07:20:47:           Date: May 11 2018
07:20:47:           Time: 13:06:32
07:20:47:     Repository: Git
07:20:47:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
07:20:47:         Branch: master
07:20:47:       Compiler: Visual C++ 2008
07:20:47:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:20:47:       Platform: win32 10
07:20:47:           Bits: 32
07:20:47:           Mode: Release
07:20:47:******************************* System ********************************
07:20:47:            CPU: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx
07:20:47:         CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
07:20:47:           CPUs: 8
07:20:47:         Memory: 5.94GiB
07:20:47:    Free Memory: 2.32GiB
07:20:47:        Threads: WINDOWS_THREADS
07:20:47:     OS Version: 6.2
07:20:47:    Has Battery: true
07:20:47:     On Battery: false
07:20:47:     UTC Offset: 1
07:20:47:            PID: 5824
07:20:47:            CWD: C:\Users\simon\AppData\Roaming\FAHClient
07:20:47:             OS: Windows 10 Home
07:20:47:        OS Arch: AMD64
[b]07:20:47:           GPUs: 1
07:20:47:          GPU 0: Bus:4 Slot:0 Func:0 AMD:5 Radeon RX Vega 10 Mobile[/b]
07:20:47:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
07:20:47:                 angegebene Modul wurde nicht gefunden.
07:20:47:
[b]07:20:47:OpenCL Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:1.2 Driver:3004.8[/b]
07:20:47:  Win32 Service: false
07:20:47:***********************************************************************
OK, detected, no i have the Yellow "waiting for Idle".
Now i let the Machine stay a while an check if it goes into idle and start the work.
CyTeK1978
Post by CyTeK1978 »
hmm ok now it runs, but only with 2-10% , even in idle (Checked with Taskmanager Log).
Thats ok ?
CPU actualy doint nothing, no wus
Task manager is reporting CPU use, not GPU.
to monitor GPU use, I like the sensor tab in GPU-Z
CyTeK1978
Post by CyTeK1978 »
JimboPalmer wrote:Task manager is reporting CPU use, not GPU.
hmm, for me (Windows 10 Home) Taskmanager Shows my GPU use
but GPU-Z shows also only 2-10% when active or in dile
CyTeK1978
Post by CyTeK1978 »
so, nothing change, i only have 2-10% GPU Load.
One WU takes +- a Day, on CPU only Hours.
Only want to know if this is noral that i only get 2-10% usage on this GPU and such a slow working speed.
When it is normal, ok it is normal.
CyTeK1978 wrote:so, nothing change, i only have 2-10% GPU Load.
Does FAH's log show that the GPU is detected?
A common mistake is to use a program that reports the CPU activity when you're looking for GPU activity. Did you try GPU-Z or a monitoring program from the GPU manufacturer?
I don't have a GPU like yours so I don't know if it's performing the way it should. Tell us what that utility reports.
Traditionally, mobile GPUs are not considered sufficiently power for serious gaming and/or for stream computing.
GPU projects are much more complex than CPU projects since most GPUs are many times as powerful as CPUs. That may or may not be true for your hardware. If the APU is unable to keep up, we can remove support for it, but you'll have to provide us with enough information to make a good decision.
If you insist on using Task Manager, you have to select Compute and possibly something else to monitor the GPU activity. For a nVidia card you would have to select CUDA, but this is an AMD card.
CyTeK1978
Post by CyTeK1978 »
sure sure, as i told, now it works with the cpu and the gpu.
and i used taskmanager and gpu-z and it is 2-10%
Does your client say it has a WU processing on the GPU?
CyTeK1978
Post by CyTeK1978 »
Joe_H wrote:Does your client say it has a WU processing on the GPU?
is my english so bad?
yes both slots are working on WUs
CPU - Working: take some hours
GPU - Working: take a day
work is goin on, i only wonder why all tools say only 2-10% usage of gpu and ..is it normal for the Ryzen 7 3700U with Vega RX 10 Mobile to take such a long time (a day for WU)
I am at the limit of the help I can give without the first 200 lines of your log.
viewtopic.php?f=24&t=26036
It sounds as if everything is configured correctly, but without reading the log, I can't say it is perfect.
