FAH starts immediately on login on my Windows 10 machine. I'd prefer if it didn't do this, but I don't see it in the Startup Apps control panel, and there is no switch to turn it off in the FAH panel itself. How do I turn off autostart?
Thanks!
Andacar
FAH Starting Right Up on Login
Re: FAH Starting Right Up on Login
Using Configure in FAHControl, select the Expert tab. Under Extra Client Options add the option pause-on-start and set the value to true. Save the setting, after this you will need to manually start all folding afterwards.
