GPU whitelist request
thomasgc
Post by thomasgc »
My graphics card (GeForce RTX 2080 with Max-Q Design) doesn't seem to be supported on Linux (Ubuntu 19.04)
It is supported on Windows.
"nvidia-smi -L" output:
GPU 0: GeForce RTX 2080 with Max-Q Design (UUID: GPU-fb4772f3-42bd-30a7-d1c7-40e6d807dfed)
Here is the FAHClient log:
*********************** Log Started 2020-03-16T17:34:22Z ***********************
17:34:22:************************* Folding@home Client *************************
17:34:22:        Website: https://foldingathome.org/
17:34:22:      Copyright: (c) 2009-2018 foldingathome.org
17:34:22:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:34:22:           Args: --child --lifeline 7413 /etc/fahclient/config.xml --run-as
17:34:22:                 fahclient --pid-file=/var/run/fahclient.pid --daemon
17:34:22:         Config: /etc/fahclient/config.xml
17:34:22:******************************** Build ********************************
17:34:22:        Version: 7.5.1
17:34:22:           Date: May 11 2018
17:34:22:           Time: 19:59:04
17:34:22:     Repository: Git
17:34:22:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
17:34:22:         Branch: master
17:34:22:       Compiler: GNU 6.3.0 20170516
17:34:22:        Options: -std=gnu++98 -O3 -funroll-loops
17:34:22:       Platform: linux2 4.14.0-3-amd64
17:34:22:           Bits: 64
17:34:22:           Mode: Release
17:34:22:******************************* System ********************************
17:34:22:            CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
17:34:22:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
17:34:22:           CPUs: 12
17:34:22:         Memory: 15.48GiB
17:34:22:    Free Memory: 9.57GiB
17:34:22:        Threads: POSIX_THREADS
17:34:22:     OS Version: 5.0
17:34:22:    Has Battery: true
17:34:22:     On Battery: false
17:34:22:     UTC Offset: -4
17:34:22:            PID: 7415
17:34:22:            CWD: /var/lib/fahclient
17:34:22:             OS: Linux 5.0.0-38-generic x86_64
17:34:22:        OS Arch: AMD64
17:34:22:           GPUs: 0
17:34:22:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
17:34:22:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:440.33
17:34:22:***********************************************************************
"FAHClient --lspci" output:
0x10de:0x1e90:1:0:0:NVIDIA Corporation:
0x10de:0x10f8:1:0:1:NVIDIA Corporation:
0x10de:0x1ad8:1:0:2:NVIDIA Corporation:
0x10de:0x1ad9:1:0:3:NVIDIA Corporation:
Thank you
Re: GPU whitelist request
If supported on Windows, then the card is also supported on Linux and does not need additional whitelisting.
There is a timing issue with the Linux installer for F@h. It needs to run after the hardware, drivers and OpenCL/CUDA support packages are in place. If the installer does not detect the GPU, it sets an option for the GPU to false, and then you can not get a GPU slot to setup.
To check for this, open FAHControl's Configure and look under the Expert tab and see if an Extra option for 'cpu' is set to 'false'. If it is, change that to 'true' and Save. Then restart FAHClient. After the restart the client should be able to add a GPU folding slot.
joeysfah
Post by joeysfah »
Relatively new to F@H, have been running it a few weeks on VMware appliances and a gaming laptop.
Just attempted to load on a new Alienware M15 R2 Windows 10 host, install fails to auto-config the RTX 2080 Max-Q NVIDIA and unable able to manually add. Didn't find it specifically referenced in the GPUs.tx file, wondering if it's white-listed and supported? The system also has an Intel GPU as ID 0, RTX is ID 1. Could this be a problem related to multiple GPUs? Not quite sure where to begin since not much expertise with FAH configuration... :/
Welcome to the F@H Forum joeysfah,
Please not that Max-Q seems to be a branding term for laptop designs and performance: https://blogs.nvidia.com/blog/2018/12/14/what-is-max-q/
Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file: viewtopic.php?f=38&t=26036 :)
Also, for your GPU, can you please post pictures of GPU-Z so we can identify if the Device ID is whitelisted or not.
joeysfah
Post by joeysfah »
Hey PantherX, thanks for speedy turnaround, how awesome of you!
Beginning of client log:
*********************** Log Started 2020-04-18T23:10:59Z ***********************
23:10:59:****************************** FAHClient ******************************
23:10:59:        Version: 7.6.9
23:10:59:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:10:59:      Copyright: 2020 foldingathome.org
23:10:59:       Homepage: https://foldingathome.org/
23:10:59:           Date: Apr 17 2020
23:10:59:           Time: 11:13:06
23:10:59:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
23:10:59:         Branch: master
23:10:59:       Compiler: Visual C++ 2008
23:10:59:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:10:59:       Platform: win32 10
23:10:59:           Bits: 32
23:10:59:           Mode: Release
23:10:59:           Args: --open-web-control
23:10:59:         Config: C:\Users\jpwil\AppData\Roaming\FAHClient\config.xml
23:10:59:******************************** CBang ********************************
23:10:59:           Time: 11:10:09
23:10:59:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
23:10:59:           Bits: 32
23:10:59:******************************* System ********************************
23:10:59:            CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
23:10:59:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
23:10:59:           CPUs: 16
23:10:59:         Memory: 15.76GiB
23:10:59:    Free Memory: 10.44GiB
23:10:59:        Threads: WINDOWS_THREADS
23:10:59:     OS Version: 6.2
23:10:59:    Has Battery: true
23:10:59:     On Battery: false
23:10:59:     UTC Offset: -5
23:10:59:            PID: 1448
23:10:59:            CWD: C:\Users\jpwil\AppData\Roaming\FAHClient
23:10:59:             OS: Windows 10 Enterprise
23:10:59:        OS Arch: AMD64
23:10:59:           GPUs: 2
23:10:59:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 [xxx]
23:10:59:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:7 TU104M [GeForce RTX 2080 Mobile]
23:10:59:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
23:10:59:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.14
23:10:59:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
23:10:59:  Win32 Service: false
23:10:59:******************************* libFAH ********************************
23:10:59:           Date: Apr 15 2020
23:10:59:           Time: 14:53:14
23:10:59:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
23:10:59:           Bits: 32
23:10:59:***********************************************************************
GPU-Z screen snip... ok, now I need to figure out how to drop an image in, forum usage in short. Gimme a little time to work on that; meanwhile, GPU-Z shows a Device ID of 10DE 1E90 - 1028 093B.
Thanx again, PantherX, GPU-Z screen shot coming up as soon as I figure out how to push up to a post.
Good news is that the client has detected your GPU:
23:10:59: GPUs: 2
Could you please try to add a GPU slot from FAHControl -> Configure -> Slots tab -> Add -> GPU -> OK -> Save
joeysfah
Post by joeysfah »
Thank you, PantherX, noticed that in the log... previously added a GPU slot but it didn't stick so then I posted here. After your suggestion I reviewed that addition and found also needed to change the default GPU ID to 1 and voilà! Another client in the fold. :-)
Installer mustn't know this system variant to automagically configure, only a million to track, right? The manual slot add is where I went wrong, thanks for pointing me in that direction, learned a few new things today (posting images to this forum wasn't one of them...).
Okay, so it seems that with iGPUs, Windows 10 is installing Intel Drivers which is now causing an issue with the automatic GPU detection :( Nonetheless, I am glad that it was an easy fix and you didn't have to fiddle with the OpenCL and CUDA values :)
To post the image here in the forum, you have to host it externally (https://imgur.com/) and then copy the URL which ends in .jpg and paste it within the image tags.
