PS: To make this clear in advance; FAH is not detecting my GPU.
I wasn't able to find a means to text copy FAHControl System Info so I took a screen shot instead, also keep in mind that I'm a novice *nix user so I probably won't understand complicated instructions that assume prior knowledge. I'm aware the Folding project is over loaded with new volunteers at this time but my question isn't related to those issues. I'm just trying to fix my configuration so that I am properly setup going forward for when WU's are made available.
I have video drivers installed and can play contemporary 3D games that are able to be run on a *nix platform such as Doom and Shadow of the Tomb Raider via Steam launcher.
The following is from System Reports:
System: Host: OMITTED Kernel: 5.3.0-40-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
Desktop: Cinnamon 4.4.8 wm: muffin dm: LightDM Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Machine: Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <filter> UEFI: American Megatrends v: 3.50 date: 11/07/2019
CPU: Topology: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen
L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 115205
Speed: 2142 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 2144 2: 4276 3: 2145
4: 2435 5: 2200 6: 2200 7: 2200 8: 2200 9: 2141 10: 2425 11: 2200 12: 2199 13: 2203
14: 2198 15: 2140 16: 4282
Graphics: Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X] vendor: Micro-Star MSI
driver: amdgpu v: kernel bus ID: 26:00.0 chip ID: 1002:67df
Display: x11 server: X.Org 1.19.6 driver: amdgpu,ati
unloaded: fbdev,modesetting,radeon,vesa resolution: 2560x1080~60Hz
OpenGL:
renderer: AMD Radeon RX 480 Graphics (POLARIS10 DRM 3.33.0 5.3.0-40-generic LLVM 9.0.0)
v: 4.6 Mesa 20.1.0-devel (git-b93a195 2020-03-14 bionic-oibaf-ppa) direct render: Yes
Audio: Device-1: AMD Ellesmere [Radeon RX 580] vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 26:00.1 chip ID: 1002:aaf0
Device-2: AMD vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 28:00.4
chip ID: 1022:1487
Sound Server: ALSA v: k5.3.0-40-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: f000 bus ID: 22:00.0 chip ID: 10ec:8168
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 1.84 TiB used: 394.66 GiB (20.9%)
ID-1: /dev/nvme0n1 model: Sabrent size: 953.87 GiB speed: 31.6 Gb/s lanes: 4
serial: <filter>
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-00BN5A0 size: 931.51 GiB
speed: 6.0 Gb/s serial: <filter>
Partition: ID-1: / size: 937.40 GiB used: 144.31 GiB (15.4%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-0
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 chip ID: 1d6b:0002
Device-1: 1-8:2 info: Kensington Expert Mouse Trackball type: Mouse
driver: hid-generic,usbhid rev: 1.1 chip ID: 047d:1020
Device-2: 1-9:3 info: Logitech Keyboard K120 type: Keyboard,HID
driver: hid-generic,usbhid rev: 1.1 chip ID: 046d:c31c
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 chip ID: 1d6b:0002
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 56.5 C mobo: N/A
Fan Speeds (RPM): N/A gpu: fan: 1302
Repos: No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb http: //mirrors.evowise.com/linuxmint/packages tricia main upstream import backport
2: deb http: //ubuntu.osuosl.org/ubuntu bionic main restricted universe multiverse
3: deb http: //ubuntu.osuosl.org/ubuntu bionic-updates main restricted universe multiverse
4: deb http: //ubuntu.osuosl.org/ubuntu bionic-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
6: deb http: //archive.canonical.com/ubuntu/ bionic partner
Active apt repos in: /etc/apt/sources.list.d/official-source-repositories.list
1: deb-src http: //mirrors.evowise.com/linuxmint/packages tricia main upstream import backport
2: deb-src http: //ubuntu.osuosl.org/ubuntu bionic main restricted universe multiverse
3: deb-src http: //ubuntu.osuosl.org/ubuntu bionic-updates main restricted universe multiverse
4: deb-src http: //ubuntu.osuosl.org/ubuntu bionic-backports main restricted universe multiverse
5: deb-src http: //security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
6: deb-src http: //archive.canonical.com/ubuntu/ bionic partner
Active apt repos in: /etc/apt/sources.list.d/oibaf-graphics-drivers-bionic.list
1: deb http: //ppa.launchpad.net/oibaf/graphics-drivers/ubuntu bionic main
Info: Processes: 365 Uptime: 3d 3h 40m Memory: 15.65 GiB used: 4.32 GiB (27.6%) Init: systemd
v: 237 runlevel: 5 Compilers: gcc: 7.5.0 alt: 7 Client: Unknown python3.6 client
inxi: 3.0.32 Thanks in advance for assistance.
