FAHControl and Fedora31
drpaneas
Post by drpaneas »
First error is that by default the shebang at /usr/bin/FAHControl is using python which is by defaut pointing (to Fedora 31 system and most other systems) to python3. As a result I am getting:
$ FAHControl
File "/usr/bin/FAHControl", line 57
if sock.recv(1024).strip() == 'OK': print 'Ok'
SyntaxError: invalid syntax
Manually editing the file and changing:
- #!/usr/bin/python
+ #!/usr/bin/python2
seems to be starting although I am getting this error from the command-line:
$ FAHControl
Loading theme Default
Traceback (most recent call last):
  File "/usr/lib/python2.7/site-packages/fah/Client.py", line 352, in update
    self.process_message(app, type, data)
  File "/usr/lib/python2.7/site-packages/fah/Client.py", line 336, in process_message
    elif type == 'units': self.process_units(app, data)
  File "/usr/lib/python2.7/site-packages/fah/Client.py", line 287, in process_units
    if self.selected: self.config.update_status_ui(app)
  File "/usr/lib/python2.7/site-packages/fah/ClientConfig.py", line 534, in update_status_ui
    self.update_status_slots(app)
  File "/usr/lib/python2.7/site-packages/fah/ClientConfig.py", line 435, in update_status_slots
    app.slot_status_tree.get_selection().select_iter(selected_row)
TypeError: iter should be a GtkTreeIter
^CTraceback (most recent call last):
  File "/usr/bin/FAHControl", line 79, in <module>
    app.run()
  File "/usr/lib/python2.7/site-packages/fah/FAHControl.py", line 542, in run
    gtk.main()
KeyboardInterrupt
Another problem I have is that the GUI opens, when I go to the System Info tab, at the System Section I see:
GPUs:1
GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GPI104 [GeForce GTX 1070] 6463
CUDA Device 0 Platform: 0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
OpenCL: Not detected: clGetDeviceIDs() return -1
From the Logs tab I see:
13:39:11:ERROR:WU00:FS00:Failed to start core: OpenCL device matching slot 0 not found, try setting 'opencl-index' manually
I have installed:
sudo dnf install mesa-libOpenCL clinfo ocl-icd-devel
Please help :)
Re: FAHControl and Fedora31
Post by foldy »
To get OpenCL ready for FAH try:
sudo apt-get install ocl-icd-libopencl1
sudo apt-get install ocl-icd-opencl-dev
coredump4
Post by coredump4 »
Hi,
I just setup a GTX 1070 system on Fedora 31 with NVIDIA driver 440.64 and it's working fine.
Your 2nd error looks to simply be that the client selected the wrong GPU. Your log shows that GPU 0 is the GTX 1070, so edit /etc/fahclient/config.xml and look for the GPU slot and change the index to 0. Should look something like:
  <slot id='0' type='GPU'>
    <client-type v='advanced'/>
    <gpu-index v='0'/>
    <verbosity v='5'/>
  </slot>
Then, restart the client.
good luck!
Just leave the verbosity at the default value of 3, higher values do not currently provide any useful information in the log file.
