Due to server overload my clients get stuck on ready mode. Even after new work units are available it doesn’t go on untill I restart my pc.
There are several issues with this version. Maybe its time for a newer version. Wth the help of supponsors we can get better clients maybe a little more cosmetic to attract more users.
Can’t get new work units untill reboot
Whittle
- Hardware configuration: Intel i7-4790K @ stock 4.00Ghz, 24GB RAM, NVIDIA GeForce GTX 1080
Re: Can’t get new work units untill reboot
If it has had trouble downloading a WU (e.g. none available) then it has a timer after which it will try again to download. The timer seems to increase after each failed attempt, so if I want to "reset" it I just pause the relevant folding slot and then tell it to fold again.
AnimeCwboy
I'm noticing that if the servers run out, the next attempt to download becomes progressively longer. (3min > 5m > 10m > 30m > 1hr > 3hrs < etc.) Usually this happens with I go to bed. Usually I just close and restart FAH and it resets the timers and I get a new WU much faster. But like mentioned above, they're running out because so many people are running FAH now, which is a good thing.
