Whitelist request GP100GL - Tesla P100 PCIe 12GB
reyemai
Post by reyemai »
Hello, first day at F@H.
I have been trying exploiting at maximum my resources... but this quite valuable card looks not to be in whitelist. I'm not an expert but I believe to be similar to the 16GB variant.
Hope to bring my support!
Thank you!
GPUZ:
NVIDIA Tesla P100-PCIE-12GB
Device ID: 10DE 15F7 - 10DE 11DA
relevant in fahclient --lspci
0x10de:0x15f7:130:0:0:NVIDIA Corporation:NVIDIA Tesla P100-PCIE-12GB
*********************** Log Started 2020-03-16T00:07:49Z ***********************
00:07:49:************************* Folding@home Client *************************
00:07:49:        Website: https://foldingathome.org/
00:07:49:      Copyright: (c) 2009-2018 foldingathome.org
00:07:49:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:07:49:           Args: --open-web-control
00:07:49:         Config: C:\Users\reyemai\AppData\Roaming\FAHClient\config.xml
00:07:49:******************************** Build ********************************
00:07:49:        Version: 7.5.1
00:07:49:           Date: May 11 2018
00:07:49:           Time: 13:06:32
00:07:49:     Repository: Git
00:07:49:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:07:49:         Branch: master
00:07:49:       Compiler: Visual C++ 2008
00:07:49:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:07:49:       Platform: win32 10
00:07:49:           Bits: 32
00:07:49:           Mode: Release
00:07:49:******************************* System ********************************
00:07:49:            CPU: Intel(R) Xeon(R) CPU E5-2643 v3 @ 3.40GHz
00:07:49:         CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
00:07:49:           CPUs: 24
00:07:49:         Memory: 255.91GiB
00:07:49:    Free Memory: 204.06GiB
00:07:49:        Threads: WINDOWS_THREADS
00:07:49:     OS Version: 6.2
00:07:49:    Has Battery: false
00:07:49:     On Battery: false
00:07:49:     UTC Offset: 1
00:07:49:            PID: 73068
00:07:49:            CWD: C:\Users\reyemai\AppData\Roaming\FAHClient
00:07:49:             OS: Windows Server 2016 Standard
00:07:49:        OS Arch: AMD64
00:07:49:           GPUs: 0
00:07:49:  CUDA Device 0: Platform:0 Device:0 Bus:130 Slot:0 Compute:6.0 Driver:10.1
00:07:49:OpenCL Device 0: Platform:0 Device:0 Bus:130 Slot:0 Compute:1.2 Driver:426.50
00:07:49:  Win32 Service: false
00:07:49:***********************************************************************
00:07:49:<config>
00:07:49:  <!-- Network -->
00:07:49:  <proxy v=':8080'/>
00:07:49:
00:07:49:  <!-- Slot Control -->
00:07:49:  <pause-on-start v='true'/>
00:07:49:  <power v='FULL'/>
00:07:49:
00:07:49:  <!-- User Information -->
00:07:49:  <user v='reyemai'/>
00:07:49:
00:07:49:  <!-- Folding Slots -->
00:07:49:  <slot id='0' type='CPU'>
00:07:49:    <paused v='true'/>
00:07:49:  </slot>
00:07:49:</config>
00:07:49:Trying to access database...
00:07:49:Successfully acquired database lock
00:07:49:Enabled folding slot 00: PAUSED cpu:24 (by user)
Re: Whitelist request GP100GL - Tesla P100 PCIe 12GB
It was indeed missing, thank you for your request. I added it to the list so you should now be able to fold with your GPU.
Sorry for the delay, we're all quite busy those days.
reyemai
Post by reyemai »
toTOW wrote:It was indeed missing, thank you for your request. I added it to the list so you should now be able to fold with your GPU.
Thank you toTOW, no problem at all, your job is very appreciated!
