997: Overlapped I/O operation is in progress.
John_Alan
Post by John_Alan »
I am receiving a bunch of "997: Overlapped I/O operation is in progress." error entries in the log file and FAHControl is constantly cycling between "connecting" "online" "updating" every couple of seconds, which makes it nearly impossible to make changes to the config file or view any specifics in the log file, since everything is constantly reloading. I'm not sure if the 997: Overlap I/O error is related, but wanted to mention it if anyone has seen something similar.
*********************** Log Started 2020-03-15T22:46:41Z ***********************
22:46:41:************************* Folding@home Client *************************
22:46:41:        Website: https://foldingathome.org/
22:46:41:      Copyright: (c) 2009-2018 foldingathome.org
22:46:41:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:46:41:           Args:
22:46:41:         Config: C:\FAH\DATA\config.xml
22:46:41:******************************** Build ********************************
22:46:41:        Version: 7.5.1
22:46:41:           Date: May 11 2018
22:46:41:           Time: 13:06:32
22:46:41:     Repository: Git
22:46:41:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:46:41:         Branch: master
22:46:41:       Compiler: Visual C++ 2008
22:46:41:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:46:41:       Platform: win32 10
22:46:41:           Bits: 32
22:46:41:           Mode: Release
22:46:41:******************************* System ********************************
22:46:41:            CPU: AMD EPYC 7302P 16-Core Processor
22:46:41:         CPU ID: AuthenticAMD Family 23 Model 49 Stepping 0
22:46:41:           CPUs: 32
22:46:41:         Memory: 127.87GiB
22:46:41:    Free Memory: 124.38GiB
22:46:41:        Threads: WINDOWS_THREADS
22:46:41:     OS Version: 6.2
22:46:41:    Has Battery: false
22:46:41:     On Battery: false
22:46:41:     UTC Offset: -5
22:46:41:            PID: 10252
22:46:41:            CWD: C:\FAH\DATA
22:46:41:             OS: Windows 10 Enterprise
22:46:41:        OS Arch: AMD64
22:46:41:           GPUs: 1
22:46:41:          GPU 0: Bus:129 Slot:0 Func:0 NVIDIA:7 TU116 [GeForce GTX 1660 SUPER]
22:46:41:  CUDA Device 0: Platform:0 Device:0 Bus:129 Slot:0 Compute:7.5 Driver:10.2
22:46:41:OpenCL Device 0: Platform:0 Device:0 Bus:129 Slot:0 Compute:1.2 Driver:442.19
22:46:41:  Win32 Service: false
22:46:41:***********************************************************************
22:46:41:<config>
22:46:41:  <!-- Folding Slots -->
22:46:41:  <slot id='0' type='CPU'/>
22:46:41:  <slot id='1' type='GPU'/>
22:46:41:</config>
22:46:41:Trying to access database...
22:46:41:Successfully acquired database lock
22:46:41:Enabled folding slot 00: READY cpu:30
22:46:41:Enabled folding slot 01: READY gpu:0:TU116 [GeForce GTX 1660 SUPER]
22:46:41:WU00:FS00:Connecting to 65.254.110.245:8080
22:46:41:WU01:FS01:Connecting to 65.254.110.245:8080
22:46:42:WU00:FS00:Assigned to work server 128.252.203.10
22:46:42:WU00:FS00:Requesting new work unit for slot 00: READY cpu:30 from 128.252.203.10
22:46:42:WU01:FS01:Assigned to work server 140.163.4.231
22:46:42:WU00:FS00:Connecting to 128.252.203.10:8080
22:46:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660 SUPER] from 140.163.4.231
22:46:42:WU01:FS01:Connecting to 140.163.4.231:8080
[b]22:47:00:ERROR:Receive error: 997: Overlapped I/O operation is in progress.[/b]
22:47:03:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
22:47:03:WU01:FS01:Connecting to 140.163.4.231:80
22:47:04:WU00:FS00:Downloading 2.82MiB
[b]22:47:05:ERROR:Receive error: 997: Overlapped I/O operation is in progress.[/b]
22:47:05:WU00:FS00:Download complete
22:47:05:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14248 run:0 clone:69 gen:326 core:0xa7 unit:0x0000017180fccb0a5d93c659271b8cc7
22:47:06:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
22:47:06:WU00:FS00:Connecting to cores.foldingathome.org:80
22:47:06:WU00:FS00:FahCore a7: Downloading 6.71MiB
22:47:07:WU00:FS00:FahCore a7: Download complete
22:47:07:WU00:FS00:Valid core signature
22:47:07:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
22:47:07:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
22:47:07:WU00:FS00:Starting
22:47:07:WU00:FS00:Running FahCore: C:\FAH\FAHClient/FAHCoreWrapper.exe C:\FAH\DATA\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 10252 -checkpoint 15 -np 30
22:47:07:WU00:FS00:Started FahCore on PID 8520
22:47:08:WU00:FS00:Core PID:8360
22:47:08:WU00:FS00:FahCore 0xa7 started
22:47:08:WU00:FS00:0xa7:*********************** Log Started 2020-03-15T22:47:08Z ***********************
22:47:08:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:47:08:WU00:FS00:0xa7:       Type: 0xa7
22:47:08:WU00:FS00:0xa7:       Core: Gromacs
22:47:08:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 8520 -checkpoint 15 -np
22:47:08:WU00:FS00:0xa7:             30
22:47:08:WU00:FS00:0xa7:************************************ CBang *************************************
22:47:08:WU00:FS00:0xa7:       Date: Oct 26 2019
22:47:08:WU00:FS00:0xa7:       Time: 01:38:25
22:47:08:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:47:08:WU00:FS00:0xa7:     Branch: master
22:47:08:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:47:08:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:47:08:WU00:FS00:0xa7:   Platform: win32 10
22:47:08:WU00:FS00:0xa7:       Bits: 64
22:47:08:WU00:FS00:0xa7:       Mode: Release
22:47:08:WU00:FS00:0xa7:************************************ System ************************************
22:47:08:WU00:FS00:0xa7:        CPU: AMD EPYC 7302P 16-Core Processor
22:47:08:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 49 Stepping 0
22:47:08:WU00:FS00:0xa7:       CPUs: 32
22:47:08:WU00:FS00:0xa7:     Memory: 127.87GiB
22:47:08:WU00:FS00:0xa7:Free Memory: 123.69GiB
22:47:08:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:47:08:WU00:FS00:0xa7: OS Version: 6.2
22:47:08:WU00:FS00:0xa7:Has Battery: false
22:47:08:WU00:FS00:0xa7: On Battery: false
22:47:08:WU00:FS00:0xa7: UTC Offset: -5
22:47:08:WU00:FS00:0xa7:        PID: 8360
22:47:08:WU00:FS00:0xa7:        CWD: C:\FAH\DATA\work
22:47:08:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:47:08:WU00:FS00:0xa7:    Version: 0.0.18
22:47:08:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:47:08:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:47:08:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:47:08:WU00:FS00:0xa7:       Time: 01:52:30
22:47:08:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:47:08:WU00:FS00:0xa7:************************************ Build *************************************
22:47:08:WU00:FS00:0xa7:       SIMD: avx_256
22:47:08:WU00:FS00:0xa7:********************************************************************************
22:47:08:WU00:FS00:0xa7:Project: 14248 (Run 0, Clone 69, Gen 326)
22:47:08:WU00:FS00:0xa7:Unit: 0x0000017180fccb0a5d93c659271b8cc7
22:47:08:WU00:FS00:0xa7:Reading tar file core.xml
22:47:08:WU00:FS00:0xa7:Reading tar file frame326.tpr
22:47:08:WU00:FS00:0xa7:Digital signatures verified
22:47:08:WU00:FS00:0xa7:Calling: mdrun -s frame326.tpr -o frame326.trr -x frame326.xtc -cpt 15 -nt 30
22:47:08:WU00:FS00:0xa7:Steps: first=81500000 total=250000
22:47:10:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
[b]22:47:17:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
22:47:17:ERROR:Receive error: 997: Overlapped I/O operation is in progress.[/b]
23:53:00:WU00:FS00:Connecting to 65.254.110.245:8080
23:53:00:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:53:00:WU00:FS00:Connecting to 18.218.241.186:80
23:53:00:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:53:00:ERROR:WU00:FS00:Exception: Could not get an assignment
23:53:19:WU01:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
23:54:29:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
23:54:37:WU00:FS00:Connecting to 65.254.110.245:8080
23:54:37:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:54:37:WU00:FS00:Connecting to 18.218.241.186:80
23:54:37:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:54:37:ERROR:WU00:FS00:Exception: Could not get an assignment
[b]23:54:44:ERROR:Receive error: 997: Overlapped I/O operation is in progress.[/b]
23:54:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
[b]23:54:51:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
23:54:58:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
23:55:00:ERROR:Receive error: 997: Overlapped I/O operation is in progress.[/b]
23:55:01:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
[b]23:55:04:ERROR:Receive error: 997: Overlapped I/O operation is in progress.[/b]
23:55:17:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
[b]23:55:17:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
23:55:24:ERROR:Receive error: 997: Overlapped I/O operation is in progress.[/b]
23:55:24:WU01:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
[b]23:55:24:ERROR:Receive error: 997: Overlapped I/O operation is in progress.[/b]
23:55:33:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
[b]23:55:36:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
23:55:42:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
23:55:42:ERROR:Receive error: 997: Overlapped I/O operation is in progress.[/b]
23:55:49:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
[b]23:55:53:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
23:56:02:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
23:56:03:ERROR:Receive error: 997: Overlapped I/O operation is in progress.[/b]
23:56:05:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
[b]23:56:08:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
23:56:14:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
23:56:18:ERROR:Receive error: 997: Overlapped I/O operation is in progress.[/b]
23:56:21:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
[b]23:56:23:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
23:56:28:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
23:56:33:ERROR:Receive error: 997: Overlapped I/O operation is in progress.[/b]
Re: 997: Overlapped I/O operation is in progress.
Congratulation. You've reporte an error that I've never seen before. :D ;)
1) is Google Chrome running? If so close it. Does that change anything.
2) is more than one copy of any of FAH's programs running?
I too have never seen that, I wonder if he has more than one Web Control running at once.
John_Alan
Post by John_Alan »
No, Google Chrome is not running. I've tried uninstalling, setting default browser to Internet Explore, reinstalling, etc. and it keeps behaving this way. I have two other remote machines running Intel Xeon E5 & E3 CPU's and they do not exhibit this constant refreshing behavior.
My machine that is experiencing this error is an AMD Epyc 7302P 16-Core CPU w/128GB DDR4 running Windows 10 Pro with a GeForce GTX 1660 Super 6GB.
I have also added the .exe processes and FAH folder to the exceptions for Windows antivirus and have all of the firewall exceptions added as well. This is quite the head scratcher :?
John_Alan
Post by John_Alan »
How can I confirm that no more than one Web Control is running? I've even tried deleting the extra text that launches the web browser window from the FAHClient.exe launch shortcut.
Web Control can simply be closed without limiting FAH's processing. If you want to run it in another browser, you can do that, too.
scerbera
Post by scerbera »
me too, I have just shut browser down and restarted browser and seems to have stopped. Microsoft edge, win 10.
19:22:18:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:22:25:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:22:28:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:22:33:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:22:39:WU03:FS02:0x22:Completed 1340000 out of 2000000 steps (67%)
19:22:44:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:22:48:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:22:51:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:23:40:WU03:FS02:0x22:Completed 1360000 out of 2000000 steps (68%)
19:23:47:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:23:50:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:24:38:WU03:FS02:0x22:Completed 1380000 out of 2000000 steps (69%)
19:24:50:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:25:19:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:25:36:WU03:FS02:0x22:Completed 1400000 out of 2000000 steps (70%)
19:26:05:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:26:35:WU03:FS02:0x22:Completed 1420000 out of 2000000 steps (71%)
19:27:33:WU03:FS02:0x22:Completed 1440000 out of 2000000 steps (72%)
19:28:34:WU03:FS02:0x22:Completed 1460000 out of 2000000 steps (73%)
19:29:31:WU03:FS02:0x22:Completed 1480000 out of 2000000 steps (74%)
spoke too soon
19:30:29:WU03:FS02:0x22:Completed 1500000 out of 2000000 steps (75%)
19:31:13:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:31:29:WU03:FS02:0x22:Completed 1520000 out of 2000000 steps (76%)
19:31:37:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:32:10:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:32:16:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:32:20:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:32:25:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:32:26:WU03:FS02:0x22:Completed 1540000 out of 2000000 steps (77%)
19:33:10:WU01:FS00:Connecting to 65.254.110.245:8080
19:33:10:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:33:10:WU01:FS00:Connecting to 18.218.241.186:80
19:33:11:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:33:11:ERROR:WU01:FS00:Exception: Could not get an assignment
19:33:25:WU03:FS02:0x22:Completed 1560000 out of 2000000 steps (78%)
19:33:58:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:34:07:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:34:10:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:34:13:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:34:19:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:34:22:WU03:FS02:0x22:Completed 1580000 out of 2000000 steps (79%)
19:34:44:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:34:46:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:34:57:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:35:06:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:35:09:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:35:12:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:35:19:WU03:FS02:0x22:Completed 1600000 out of 2000000 steps (80%)
19:35:23:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:35:36:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:35:44:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:36:01:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:36:05:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:36:10:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:36:17:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:36:19:WU03:FS02:0x22:Completed 1620000 out of 2000000 steps (81%)
19:36:24:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:36:37:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:36:38:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:37:00:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:37:16:WU03:FS02:0x22:Completed 1640000 out of 2000000 steps (82%)
19:37:33:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:37:39:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:37:40:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:37:56:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:38:04:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:38:11:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:38:14:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:38:15:WU03:FS02:0x22:Completed 1660000 out of 2000000 steps (83%)
19:38:25:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:38:27:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:38:35:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:38:45:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:38:47:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:38:54:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:39:13:WU03:FS02:0x22:Completed 1680000 out of 2000000 steps (84%)
19:39:56:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:40:00:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:40:02:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:40:07:ERROR:Receive error: 997: Overlapped I/O operation is in progress.
19:40:10:WU03:FS02:0x22:Completed 1700000 out of 2000000 steps (85%)
ModsEdit: Added Code Tags - PantherX
TooLs_GaminG
Post by TooLs_GaminG »
i have the same issue on my end. it is slowly processing but disconnecting every few seconds. i am running AMD Ryzen 5 3600 6-core and a RTX 2060 Super.
John_Alan
Post by John_Alan »
@scerbera Are you on an AMD system as well?
jonault
Post by jonault »
A google search didn't turn up anything specific to Folding@Home, but it appears other programs have had this same 997 error message in the past. So far, I haven't seen any explanation of the underlying cause that might suggest a solution for F@H.
Edit: A lot of the web sites discussing this all seem to repeat the same steps to solve it. This thread over at StackExchange is fairly concise, and also suggests that antivirus software may be part of the problem.
scerbera
Post by scerbera »
yes AMD system, its really annoying. only standard win 10 firewall is on as brand new installation.
John_Alan
Post by John_Alan »
Same here. I’ve been trying to find out more info about running a command line only client on Win10, but haven’t found much information. I guess I just need to wait and see if this is resolved in future releases as my two Intel boxes do not exhibit the same behavior.
tulanebarandgrill
Post by tulanebarandgrill »
Have you tried running FAHControl instead of Web Control ?
- TulaneBaG
rcervantes88
Post by rcervantes88 »
I am having this same issue on my system with AMD Ryzen 7 3700X and a 1050 Ti.
I have another Ryzen 7 1700X with an AMD RX 580 and another i7-4790K with 980 Ti working just fine. All running Windows 10.
excelblue
Hardware configuration: Windows 10 Pro
AMD Threadripper 3960X (24C/48T)
2x nVIDIA RTX 2080 Ti
Post by excelblue »
I have the same issue on my machine.
Windows 10 64-bit (English)
64 GB DDR4-RAM
2x nVIDIA RTX 2080Ti
1TB PCIe 4.0 NVMe SSD
I am running FAHClient 7.5.1.
