GPU unsupported
NIAUcz
GPU unsupported
Post by NIAUcz »
*********************** Log Started 2020-03-15T20:35:49Z ***********************
20:35:49:************************* Folding@home Client *************************
20:35:49:        Website: https://foldingathome.org/
20:35:49:      Copyright: (c) 2009-2018 foldingathome.org
20:35:49:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:35:49:           Args: --open-web-control
20:35:49:         Config: <none>
20:35:49:******************************** Build ********************************
20:35:49:        Version: 7.5.1
20:35:49:           Date: May 11 2018
20:35:49:           Time: 13:06:32
20:35:49:     Repository: Git
20:35:49:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:35:49:         Branch: master
20:35:49:       Compiler: Visual C++ 2008
20:35:49:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:35:49:       Platform: win32 10
20:35:49:           Bits: 32
20:35:49:           Mode: Release
20:35:49:******************************* System ********************************
20:35:49:            CPU: Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz
20:35:49:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
20:35:49:           CPUs: 4
20:35:49:         Memory: 15.94GiB
20:35:49:    Free Memory: 13.13GiB
20:35:49:        Threads: WINDOWS_THREADS
20:35:49:     OS Version: 6.2
20:35:49:    Has Battery: false
20:35:49:     On Battery: false
20:35:49:     UTC Offset: 1
20:35:49:            PID: 9696
20:35:49:            CWD: C:\Users\pccc\AppData\Roaming\FAHClient
20:35:49:             OS: Windows 10 Enterprise
20:35:49:        OS Arch: AMD64
20:35:49:           GPUs: 1
20:35:49:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Hawaii [Radeon R9 200X Series]
20:35:49:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
20:35:49:                 Uvedený modul nebyl nalezen.
20:35:49:
20:35:49:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
20:35:49:  Win32 Service: false
20:35:49:***********************************************************************
20:35:49:<config>
20:35:49:  <!-- Folding Slots -->
20:35:49:</config>
20:35:49:Connecting to assign1.foldingathome.org:8080
20:35:49:Updated GPUs.txt
20:35:49:Read GPUs.txt
20:35:49:Trying to access database...
20:35:49:Successfully acquired database lock
20:35:49:Enabled folding slot 00: PAUSED cpu:2 (not configured)
20:35:49:Enabled folding slot 01: PAUSED gpu:0:Hawaii [Radeon R9 200/300X Series] (not configured)
20:35:54:4:127.0.0.1:New Web connection
20:35:56:23:127.0.0.1:New Web connection
20:36:26:60:127.0.0.1:New Web connection
20:36:50:Saving configuration to config.xml
20:36:50:<config>
20:36:50:  <!-- Folding Slots -->
20:36:50:  <slot id='0' type='CPU'/>
20:36:50:  <slot id='1' type='GPU'/>
20:36:50:</config>
20:36:50:Set client configured
20:36:50:WU00:FS00:Connecting to 65.254.110.245:8080
20:36:50:WU01:FS01:Connecting to 65.254.110.245:8080
20:36:51:WU01:FS01:Connecting to 65.254.110.245:8080
20:36:51:WU01:FS01:Assigned to work server 140.163.4.241
20:36:51:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.241
20:36:51:WU01:FS01:Connecting to 140.163.4.241:8080
20:36:53:WU00:FS00:Connecting to 65.254.110.245:8080
20:36:54:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:36:54:WU00:FS00:Connecting to 18.218.241.186:80
20:36:54:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:36:54:ERROR:WU00:FS00:Exception: Could not get an assignment
20:36:55:WU00:FS00:Connecting to 65.254.110.245:8080
20:36:55:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:36:55:WU00:FS00:Connecting to 18.218.241.186:80
20:36:56:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:36:56:ERROR:WU00:FS00:Exception: Could not get an assignment
20:37:12:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:37:12:WU01:FS01:Connecting to 140.163.4.241:80
20:37:33:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.241:80: Pokus o připojení selhal, protože připojená strana v časovém intervalu řádně neodpověděla, nebo vytvořené připojení selhalo, protože neodpověděl připojený hostitel.
20:37:34:WU01:FS01:Connecting to 65.254.110.245:8080
20:37:34:WU01:FS01:Assigned to work server 140.163.4.231
20:37:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.231
20:37:34:WU01:FS01:Connecting to 140.163.4.231:8080
20:37:51:Saving configuration to config.xml
20:37:51:<config>
20:37:51:  <!-- User Information -->
20:37:51:  <team v='239558'/>
20:37:51:  <user v='NAIU'/>
20:37:51:
20:37:51:  <!-- Folding Slots -->
20:37:51:  <slot id='0' type='CPU'/>
20:37:51:  <slot id='1' type='GPU'/>
20:37:51:</config>
20:37:55:WU00:FS00:Connecting to 65.254.110.245:8080
20:37:55:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:37:55:WU01:FS01:Connecting to 140.163.4.231:80
20:37:55:WU00:FS00:Assigned to work server 155.247.164.213
20:37:55:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 155.247.164.213
20:37:55:WU00:FS00:Connecting to 155.247.164.213:8080
20:38:16:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: Pokus o připojení selhal, protože připojená strana v časovém intervalu řádně neodpověděla, nebo vytvořené připojení selhalo, protože neodpověděl připojený hostitel.
20:38:34:WU01:FS01:Connecting to 65.254.110.245:8080
20:38:34:WU01:FS01:Assigned to work server 140.163.4.231
20:38:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.231
20:38:34:WU01:FS01:Connecting to 140.163.4.231:8080
20:38:55:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:38:55:WU01:FS01:Connecting to 140.163.4.231:80
20:39:16:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: Pokus o připojení selhal, protože připojená strana v časovém intervalu řádně neodpověděla, nebo vytvořené připojení selhalo, protože neodpověděl připojený hostitel.
20:40:11:WU01:FS01:Connecting to 65.254.110.245:8080
20:40:12:WU01:FS01:Assigned to work server 140.163.4.231
20:40:12:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.231
20:40:12:WU01:FS01:Connecting to 140.163.4.231:8080
20:40:33:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:40:33:WU01:FS01:Connecting to 140.163.4.231:80
20:40:54:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: Pokus o připojení selhal, protože připojená strana v časovém intervalu řádně neodpověděla, nebo vytvořené připojení selhalo, protože neodpověděl připojený hostitel.
20:41:11:WU01:FS01:Connecting to 65.254.110.245:8080
20:41:11:WU01:FS01:Assigned to work server 140.163.4.231
20:41:12:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.231
20:41:12:WU01:FS01:Connecting to 140.163.4.231:8080
20:42:34:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:42:48:WU01:FS01:Connecting to 65.254.110.245:8080
20:42:49:WU01:FS01:Assigned to work server 140.163.4.231
20:42:49:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.231
20:42:49:WU01:FS01:Connecting to 140.163.4.231:8080
20:43:10:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:43:10:WU01:FS01:Connecting to 140.163.4.231:80
20:43:31:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: Pokus o připojení selhal, protože připojená strana v časovém intervalu řádně neodpověděla, nebo vytvořené připojení selhalo, protože neodpověděl připojený hostitel.
20:43:40:Saving configuration to config.xml
20:43:40:<config>
20:43:40:  <!-- Network -->
20:43:40:  <proxy v=':8080'/>
20:43:40:
20:43:40:  <!-- User Information -->
20:43:40:  <team v='239558'/>
20:43:40:  <user v='NAIU'/>
20:43:40:
20:43:40:  <!-- Folding Slots -->
20:43:40:  <slot id='0' type='CPU'/>
20:43:40:  <slot id='1' type='GPU'/>
20:43:40:</config>
20:43:57:Saving configuration to config.xml
20:43:57:<config>
20:43:57:  <!-- Network -->
20:43:57:  <proxy v=':8080'/>
20:43:57:
20:43:57:  <!-- User Information -->
20:43:57:  <team v='239558'/>
20:43:57:  <user v='NAIU'/>
20:43:57:
20:43:57:  <!-- Folding Slots -->
20:43:57:  <slot id='0' type='CPU'/>
20:43:57:  <slot id='1' type='GPU'/>
20:43:57:</config>
20:45:25:WU01:FS01:Connecting to 65.254.110.245:8080
20:45:27:WU01:FS01:Assigned to work server 140.163.4.231
20:45:27:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.231
20:45:27:WU01:FS01:Connecting to 140.163.4.231:8080
20:45:48:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:45:48:WU01:FS01:Connecting to 140.163.4.231:80
20:46:09:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: Pokus o připojení selhal, protože připojená strana v časovém intervalu řádně neodpověděla, nebo vytvořené připojení selhalo, protože neodpověděl připojený hostitel.
20:49:21:ERROR:Receive error: 10053: Software v hostitelském počítači ukončil vytvořené připojení.
20:49:37:ERROR:Receive error: 10053: Software v hostitelském počítači ukončil vytvořené připojení.
20:49:40:WU01:FS01:Connecting to 65.254.110.245:8080
20:49:40:WU01:FS01:Assigned to work server 140.163.4.231
20:49:41:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.231
20:49:41:WU01:FS01:Connecting to 140.163.4.231:8080
20:50:02:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:50:02:WU01:FS01:Connecting to 140.163.4.231:80
20:50:24:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: Pokus o připojení selhal, protože připojená strana v časovém intervalu řádně neodpověděla, nebo vytvořené připojení selhalo, protože neodpověděl připojený hostitel.
20:56:31:WU01:FS01:Connecting to 65.254.110.245:8080
20:56:32:WU01:FS01:Assigned to work server 140.163.4.231
20:56:33:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.231
20:56:33:WU01:FS01:Connecting to 140.163.4.231:8080
20:56:54:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:56:54:WU01:FS01:Connecting to 140.163.4.231:80
20:57:15:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: Pokus o připojení selhal, protože připojená strana v časovém intervalu řádně neodpověděla, nebo vytvořené připojení selhalo, protože neodpověděl připojený hostitel.
21:07:37:WU01:FS01:Connecting to 65.254.110.245:8080
21:07:37:WU01:FS01:Assigned to work server 140.163.4.241
21:07:38:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.241
21:07:38:WU01:FS01:Connecting to 140.163.4.241:8080
21:07:59:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
21:07:59:WU01:FS01:Connecting to 140.163.4.241:80
21:08:20:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.241:80: Pokus o připojení selhal, protože připojená strana v časovém intervalu řádně neodpověděla, nebo vytvořené připojení selhalo, protože neodpověděl připojený hostitel.
21:09:04:WU01:FS01:Connecting to 65.254.110.245:8080
21:09:05:WU01:FS01:Assigned to work server 128.252.203.10
21:09:05:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 128.252.203.10
21:09:05:WU01:FS01:Connecting to 128.252.203.10:8080
21:09:22:Saving configuration to config.xml
21:09:22:<config>
21:09:22:  <!-- Network -->
21:09:22:  <proxy v=':8080'/>
21:09:22:
21:09:22:  <!-- Slot Control -->
21:09:22:  <power v='LIGHT'/>
21:09:22:
21:09:22:  <!-- User Information -->
21:09:22:  <team v='239558'/>
21:09:22:  <user v='NAIU'/>
21:09:22:
21:09:22:  <!-- Folding Slots -->
21:09:22:  <slot id='0' type='CPU'/>
21:09:22:  <slot id='1' type='GPU'/>
21:09:22:</config>
21:09:23:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:09:54:ERROR:Receive error: 10053: Software v hostitelském počítači ukončil vytvořené připojení.
21:10:04:WU01:FS01:Connecting to 65.254.110.245:8080
21:10:05:WU01:FS01:Assigned to work server 140.163.4.241
21:10:05:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.241
21:10:05:WU01:FS01:Connecting to 140.163.4.241:8080
21:10:10:ERROR:Receive error: 10053: Software v hostitelském počítači ukončil vytvořené připojení.
21:10:23:Saving configuration to config.xml
21:10:23:<config>
21:10:23:  <!-- Network -->
21:10:23:  <proxy v=':8080'/>
21:10:23:
21:10:23:  <!-- Slot Control -->
21:10:23:  <power v='MEDIUM'/>
21:10:23:
21:10:23:  <!-- User Information -->
21:10:23:  <team v='239558'/>
21:10:23:  <user v='NAIU'/>
21:10:23:
21:10:23:  <!-- Folding Slots -->
21:10:23:  <slot id='0' type='CPU'/>
21:10:23:  <slot id='1' type='GPU'/>
21:10:23:</config>
21:10:26:ERROR:Receive error: 10053: Software v hostitelském počítači ukončil vytvořené připojení.
21:10:26:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
21:10:26:WU01:FS01:Connecting to 140.163.4.241:80
21:10:52:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:11:42:WU01:FS01:Connecting to 65.254.110.245:8080
21:11:42:WU01:FS01:Assigned to work server 140.163.4.231
21:11:43:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.231
21:11:43:WU01:FS01:Connecting to 140.163.4.231:8080
21:12:55:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:14:19:WU01:FS01:Connecting to 65.254.110.245:8080
21:14:20:WU01:FS01:Assigned to work server 140.163.4.241
21:14:20:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.241
21:14:20:WU01:FS01:Connecting to 140.163.4.241:8080
Re: GPU unsupported
I see no hint your GPU is unsupported. (some of the log is in a language I do not read, so i may have missed it)
I do see signs F@H servers are over loaded
I think that when the F@H server catches up, you will get work
NIAUcz
Re: GPU unsupported
Post by NIAUcz »
Yes, thank you, everything already works.
