Please add differrent Vega 8(Ryzen3500U) variant
L4kritz
Post by L4kritz »
I hope you can Whitelist this gpu also as you already have an different Vega8 in there.
thank you very much!
0x1002:0x15d8:4:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:AMD Radeon(TM) Vega 8 Graphics
20:43:51:WU00:FS00:0xa7:*********************** Log Started 2020-03-15T20:43:50Z ***********************
20:43:51:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:43:51:WU00:FS00:0xa7:       Type: 0xa7
20:43:51:WU00:FS00:0xa7:       Core: Gromacs
20:43:51:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 4556 -checkpoint 15 -np 7
20:43:51:WU00:FS00:0xa7:************************************ CBang *************************************
20:43:52:WU00:FS00:0xa7:       Date: Oct 26 2019
20:43:52:WU00:FS00:0xa7:       Time: 01:38:25
20:43:52:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:43:52:WU00:FS00:0xa7:     Branch: master
20:43:52:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:43:52:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:43:52:WU00:FS00:0xa7:   Platform: win32 10
20:43:52:WU00:FS00:0xa7:       Bits: 64
20:43:52:WU00:FS00:0xa7:       Mode: Release
20:43:52:WU00:FS00:0xa7:************************************ System ************************************
20:43:52:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
20:43:52:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
20:43:52:WU00:FS00:0xa7:       CPUs: 8
20:43:52:WU00:FS00:0xa7:     Memory: 17.94GiB
20:43:52:WU00:FS00:0xa7:Free Memory: 15.07GiB
20:43:52:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
20:43:52:WU00:FS00:0xa7: OS Version: 6.2
20:43:52:WU00:FS00:0xa7:Has Battery: true
20:43:52:WU00:FS00:0xa7: On Battery: false
20:43:52:WU00:FS00:0xa7: UTC Offset: 1
20:43:52:WU00:FS00:0xa7:        PID: 10828
20:43:52:WU00:FS00:0xa7:        CWD: C:\Users\leonb\AppData\Roaming\FAHClient\work
20:43:52:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:43:52:WU00:FS00:0xa7:    Version: 0.0.18
20:43:52:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:43:52:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:43:52:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:43:52:WU00:FS00:0xa7:       Time: 01:52:30
20:43:52:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:43:52:WU00:FS00:0xa7:************************************ Build *************************************
20:43:52:WU00:FS00:0xa7:       SIMD: avx_256
20:43:52:WU00:FS00:0xa7:********************************************************************************
20:43:52:WU00:FS00:0xa7:Project: 14328 (Run 0, Clone 2357, Gen 0)
20:43:52:WU00:FS00:0xa7:Unit: 0x000000019bf7a4d65e694d8135aa819b
20:43:52:WU00:FS00:0xa7:Digital signatures verified
20:43:52:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
20:43:52:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpi state.cpt -cpt 15 -nt 6
20:43:52:WU00:FS00:0xa7:Steps: first=0 total=250000
20:43:55:WU00:FS00:0xa7:Completed 150941 out of 250000 steps (60%)
20:45:09:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
20:46:42:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
20:48:11:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
20:49:51:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
20:51:20:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
20:52:48:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
20:54:17:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
20:55:48:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
20:57:18:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
Re: Add Vega 8(picasso) Ryzen5300U
OK we need the first 200 lines of the log, the portion you posted tells us nothing about the PCs configuration.
viewtopic.php?f=24&t=26036
I could guess why it is not folding, but I would feel more useful if I had facts.
L4kritz
Re: Add Vega 8(picasso) Ryzen 3500U
Post by L4kritz »
This is everything in the log.txt file
*********************** Log Started 2020-03-15T20:43:49Z ***********************
20:43:49:************************* Folding@home Client *************************
20:43:49:      Website: https://foldingathome.org/
20:43:49:    Copyright: (c) 2009-2018 foldingathome.org
20:43:49:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:43:49:         Args:
20:43:49:       Config: C:\Users\leonb\AppData\Roaming\FAHClient\config.xml
20:43:49:******************************** Build ********************************
20:43:49:      Version: 7.5.1
20:43:49:         Date: May 11 2018
20:43:49:         Time: 13:06:32
20:43:49:   Repository: Git
20:43:49:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:43:49:       Branch: master
20:43:49:     Compiler: Visual C++ 2008
20:43:49:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:43:49:     Platform: win32 10
20:43:49:         Bits: 32
20:43:49:         Mode: Release
20:43:49:******************************* System ********************************
20:43:49:          CPU: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
20:43:49:       CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
20:43:49:         CPUs: 8
20:43:49:       Memory: 17.94GiB
20:43:49:  Free Memory: 15.16GiB
20:43:49:      Threads: WINDOWS_THREADS
20:43:49:   OS Version: 6.2
20:43:49:  Has Battery: true
20:43:49:   On Battery: false
20:43:49:   UTC Offset: 1
20:43:49:          PID: 9968
20:43:49:          CWD: C:\Users\leonb\AppData\Roaming\FAHClient
20:43:49:           OS: Windows 10 Home
20:43:49:      OS Arch: AMD64
20:43:49:         GPUs: 0
20:43:49:         CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
20:43:49:               angegebene Modul wurde nicht gefunden.
20:43:49:
20:43:49:       OpenCL: Not detected: Failed to open dynamic library 'OpenCL.dll': Das
20:43:49:
20:43:49:Win32 Service: false
20:43:49:***********************************************************************
20:43:49:<config>
20:43:49:  <!-- Network -->
20:43:49:  <proxy v=':8080'/>
20:43:49:
20:43:49:  <!-- Slot Control -->
20:43:49:  <power v='medium'/>
20:43:49:
20:43:49:  <!-- User Information -->
20:43:49:  <team v='223518'/>
20:43:49:  <user v='L4kritz'/>
20:43:49:
20:43:49:  <!-- Folding Slots -->
20:43:49:  <slot id='0' type='CPU'/>
20:43:49:</config>
20:43:49:Trying to access database...
20:43:49:Successfully acquired database lock
20:43:49:Enabled folding slot 00: READY cpu:7
20:43:50:WU00:FS00:Starting
20:43:50:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\leonb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9968 -checkpoint 15 -np 7
20:43:50:WU00:FS00:Started FahCore on PID 4556
20:43:50:WU00:FS00:Core PID:10828
20:43:50:WU00:FS00:FahCore 0xa7 started
20:58:48:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
21:00:20:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
21:01:51:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
21:03:21:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
21:04:51:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
21:05:21:FS00:Shutting core down
21:05:22:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 10828
21:05:22:WU00:FS00:0xa7:Exiting, please wait. . .
21:05:22:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
21:05:23:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:05:23:WU00:FS00:Starting
21:05:23:WARNING:WU00:FS00:Changed SMP threads from 7 to 8 this can cause some work units to fail
21:05:23:WARNING:WU00:FS00:AS lowered CPUs from 8 to 7
21:05:23:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\leonb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9968 -checkpoint 15 -np 7
21:05:23:WU00:FS00:Started FahCore on PID 8172
21:05:23:WU00:FS00:Core PID:9952
21:05:23:WU00:FS00:FahCore 0xa7 started
21:05:24:WU00:FS00:0xa7:*********************** Log Started 2020-03-15T21:05:23Z ***********************
21:05:24:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:05:24:WU00:FS00:0xa7:       Type: 0xa7
21:05:24:WU00:FS00:0xa7:       Core: Gromacs
21:05:24:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 8172 -checkpoint 15 -np 7
21:05:24:WU00:FS00:0xa7:************************************ CBang *************************************
21:05:24:WU00:FS00:0xa7:       Date: Oct 26 2019
21:05:24:WU00:FS00:0xa7:       Time: 01:38:25
21:05:24:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:05:24:WU00:FS00:0xa7:     Branch: master
21:05:24:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
21:05:24:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:05:24:WU00:FS00:0xa7:   Platform: win32 10
21:05:24:WU00:FS00:0xa7:       Bits: 64
21:05:24:WU00:FS00:0xa7:       Mode: Release
21:05:24:WU00:FS00:0xa7:************************************ System ************************************
21:05:24:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
21:05:24:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
21:05:24:WU00:FS00:0xa7:       CPUs: 8
21:05:24:WU00:FS00:0xa7:     Memory: 17.94GiB
21:05:24:WU00:FS00:0xa7:Free Memory: 13.45GiB
21:05:24:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
21:05:24:WU00:FS00:0xa7: OS Version: 6.2
21:05:24:WU00:FS00:0xa7:Has Battery: true
21:05:24:WU00:FS00:0xa7: On Battery: false
21:05:24:WU00:FS00:0xa7: UTC Offset: 1
21:05:24:WU00:FS00:0xa7:        PID: 9952
21:05:24:WU00:FS00:0xa7:        CWD: C:\Users\leonb\AppData\Roaming\FAHClient\work
21:05:24:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
21:05:24:WU00:FS00:0xa7:    Version: 0.0.18
21:05:24:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:05:24:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:05:24:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
21:05:24:WU00:FS00:0xa7:       Time: 01:52:30
21:05:24:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:05:24:WU00:FS00:0xa7:************************************ Build *************************************
21:05:24:WU00:FS00:0xa7:       SIMD: avx_256
21:05:24:WU00:FS00:0xa7:********************************************************************************
21:05:24:WU00:FS00:0xa7:Project: 14328 (Run 0, Clone 2357, Gen 0)
21:05:24:WU00:FS00:0xa7:Unit: 0x000000019bf7a4d65e694d8135aa819b
21:05:24:WU00:FS00:0xa7:Digital signatures verified
21:05:24:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
21:05:24:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpi state.cpt -cpt 15 -nt 6
21:05:24:WU00:FS00:0xa7:Steps: first=0 total=250000
21:05:25:WU00:FS00:0xa7:Completed 185882 out of 250000 steps (74%)
21:06:11:Saving configuration to config.xml
21:06:11:<config>
21:06:11:  <!-- Network -->
21:06:11:  <proxy v=':8080'/>
21:06:11:
21:06:11:  <!-- Slot Control -->
21:06:11:  <power v='full'/>
21:06:11:
21:06:11:  <!-- User Information -->
21:06:11:  <team v='223518'/>
21:06:11:  <user v='L4kritz'/>
21:06:11:
21:06:11:  <!-- Folding Slots -->
21:06:11:  <slot id='0' type='CPU'/>
21:06:11:</config>
21:06:23:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
21:07:51:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
21:09:20:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
21:10:53:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
21:12:23:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
21:13:54:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
21:15:24:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
21:16:54:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
21:18:24:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
21:19:54:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
21:21:25:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
21:22:55:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
21:24:25:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
21:25:55:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
21:27:24:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
21:28:59:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
21:30:30:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
21:32:00:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
21:33:31:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
21:35:02:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
21:36:35:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
21:38:08:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
Your configuration seemsto look like the GPU portion has never been used by any other user. As all my gear is old castoffs, this is not my specialty!
You need to get a unique Device ID for your card, which may look like 0x10de:0x1294 (Actually some older Nvidia card) There are several ways to get this ID but the one I know is GPU-Z .
As you can see, in the example Device ID is about 1/3 of the way down on the right. Post your actual Device ID. When some actual expert comes by, they can add your ID to the whitelist on the server and when your client downloads it, you can fold!
This APU does support OpenCL 2.0 and does Double Precision math so meets the minimum hardware specs.
L4kritz
Re: Please add differrent Vega 8(picasso/ Ryzen 3500U) varia
Post by L4kritz »
Thank you i hope this is the right thing:
Looks good to me, we will see if the experts agree!
L4kritz
Re: Please add differrent Vega 8(Ryzen3500U) variant
Post by L4kritz »
It is now beeing detected as a Radeon RX Vega 10 Mobile.
