Is my GPU supported? (MacPro 2019)
Lassejulius
Post by Lassejulius »
Hello,
I am Running MacOS Catalina and have MacPro 2019 (Cheese Grinder).
My Graphic Card is a: AMD Radeon Pro 580X 8 GB
When I start Folding@home I only see one Slot (0 = CPU).
That's it, nothing more.
So, does't my Mac support GPU Support at all? :-/
Many greetings,
Lasse
Denisok
Hardware configuration: Intel Core i7 3770K
Intel Core i5 M480
Re: Is my GPU supportet? (MacPro 2019)
Post by Denisok »
Hello
Unfortunately, F@H on Mac doesn't support GPU
The GPU is supported, the OS is not supported by the F@h software. There is a long history behind that , but it started with a buggy implementation of OpenCL a number of OS versions ago. Apple eventually fixed the bug a few years later.
It should work if you set up to boot into Linux or Windows. There are also CPU projects related to COVID-19, but they are still ramping up the projects.
If you use Bootcamp to run Windows or Linux then yes, the AMD Radeon Pro 580X is a supported piece of hardware. It needs OpenCL 1.2 or newer and the card has that, and needs Double Precision math and the card does that.
https://www.techpowerup.com/gpu-specs/r ... 580x.c3398
Lassejulius
Thank you for the really (!) quick answers, guys :-)
So I will wait for some CPU Workunits.
