How do I join a team
BillAnderson
Hardware configuration: Ryzen 5-2600X + GTX950 + 32GB GSKILL F4-3000C16D-16GTZR + 1TB:M.2 +4TB:WD-7200 + VPN
Post by BillAnderson »
Noobie here. I saw in another thread that TOM'S HARDWARE TEAM is 40051 so I joined that.
In the olden days (back after SETI@Home circa 2002 or so) there was a list of teams to join.
Cannot find anything similar: when I search forum for TEAM no results come back because the search is not specific enough. When I search for "join a team" I see all threads with join or all threads with "a" = YIKES!
Question: If I wanted to join a team from Canada or Nova Scotia or Yamaha motorcycles... how would I do that?
Thanks
[url=http://folding.extremeoverclocking.com/ ... p?u=866210][img]http://folding.extremeoverclocking.com/ ... p?u=866210[/img][/url]
kiore
Re: How do I join a team
Post by kiore »
BillAnderson wrote:Noobie here. I saw in another thread that TOM'S HARDWARE TEAM is 40051 so I joined that.
Thanks
Extreme Overclockers have a stats site, look here: https://folding.extremeoverclocking.com ... ist.php?s=
BTW this is where I get my stats in my signature from.
BillAnderson
Thanks
Thanks your reply helped a lot
QUESTION: do you post the stats in your signature manually or is there some wizard code you add that does it all automagically?
Nathan_P
Not currently folding
Post by Nathan_P »
the instructions for adding signatures are on this page:- https://folding.extremeoverclocking.com/?nav=IMAGES
BillAnderson
Nathan_P wrote:the instructions for adding signatures are on this page:- https://folding.extremeoverclocking.com/?nav=IMAGES
Thanks Nathan I will give that a try
Roadpower
Post by Roadpower »
From that extremeoverclocking link (thanks BTW!)
"Default (Team 0)"
That made me lol.
BillAnderson
Well Nathan my first and second attempts were failures
When I tried adding "Image" To my signature RED text appeared at the top of the signature page saying <<It was not possible to determine the dimensions of the image.>> and the new signature would not save.
BillAnderson
Interesting when I added the text ""Image"" to the forum post it translated it into the stats box
Nathan_P
Post by Nathan_P »
hmm, its been years since I added my signature so the details have long since been lost to the sands of time, having just looked in user control panel my text looks like this
BillAnderson
When I just type this string into my signature line:
https:(no blank here)//folding.extremeoverclocking.com/sigs/sigimage.php?un=BillAnderson&t=223518
and notice that no signature gets added at all even the text that is supposed to be above this line
Nathan_P
Post by Nathan_P »
I've taken out the [/img][/url] at the end of the link so you can see the text, add the[/img][/url] at the end of the below and edit to match your EOC user id
[url=http://folding.extremeoverclocking.com/ ... p?u=510459][img]http://folding.extremeoverclocking.com/ ... p?u=510459
BillAnderson
Nathan_P wrote:hmm, its been years since I added my signature so the details have long since been lost to the sands of time, having just looked in user control panel my text looks like this
I was making the classic programming error of typing in the Image codes instead of using the token buttons above the chatbox.
so I copied url that displayed the stats box:
text with spaces added = https : // folding . extremeoverclocking . com /sigs /sigimage . php? u = 866210
text only: https://folding.extremeoverclocking.com ... p?u=866210
text with img typed in: Image
text with token: Image
So based on the preview in the body of the message it doesn't matter if I type in [img] or use the token buttons the stats box appears but when editing the signature in the profile, if I type in [img] I get the image size cannot be determined error and cannot save the signature, but if I use the tokens I can save it but the signature does not include the stats box
My next step: When I quoted your message your stats box in the body of the message resolved into the text that you had pasted there. So because it resolved in your message and it resolves in your signature to both show your stats box I am going to try copy/paste/edit to see if your text works in my signature.
Nathan_P
Post by Nathan_P »
It should work, see how you get on and if you have any problems report back
jonault
Post by jonault »
The "It was not possible to determine the dimensions of the image" error is a known problem that's been around for a while. One of the forum mods said recently that they're looking into upgrading the forum software, so I suspect they'll do that first - maybe the upgrade will fix the problem.
nshorts_nhs
Hardware configuration: Multiple servers, laptops, and desktops.
Post by nshorts_nhs »
Dumb question, how often does this crawl? My team (created 2 days ago) isn't showing... I get a homer :-p
Nick Shorts
nick(a)nickandhillary(dot)com
Director, Information Technology
Nexus Health Systems
https://www.nexuscontinuum.com
