Hi, I'm new to F@H,
I just installed it, but it doesn't seem to be working. I'm not sure if there's any program blocking it, if its configuration has some issue or if its the servers fault (since i read somewhere they were temporarily disabled).
Cans someone help me understand if I have everything setup as it should?
Thanks
Falconair
Not sure If working
rixon
- Hardware configuration: Linux / Xeon / Tesla / HPC
Re: Not sure If working
Falconair, it always helps if you post a log. See viewtopic.php?f=24&t=26036 particularly 4-7 for info on how to do this.
have a look at the server troubles notes
viewtopic.php?f=61&t=32424
at the moment they are struggling to create enough work units for all the new users to work on.
they dumped a whole bunch about 4 hours ago, and they are all gone.
Check back later, or perhaps also run BOINC or Science United.
