client 751 W10 64bit (1909) links don't work
massimo2
Post by massimo2 »
WIth the client 751 on W10 64bit ita (1909 production) U_R_L links in the advanced view don't work
even if you choose copy u_r_l (the clipboard is empty)
thanks
massimo
MarkyMark7
Re: client 751 W10 64bit (1909) links don't work
Post by MarkyMark7 »
Just an educated guess; but I had an older client on one of my PCs, and the link for the current project pointed at a Stanford.edu link; but the Identity links for my Name and Team point to the foldingathome.org domain, so likely the project links have not been set up (yet?) on the new domain.
I see there is now a lookup at the new site; hopefully the new FAHClient will have it. Example: https://apps.foldingathome.org/project?p=11746
-- Mark
https://folding.extremeoverclocking.com ... 381&t=1003
Or maybe https://folding.extremeoverclocking.com/sigs/sigimage.php/u=514381/t=1003/signimage.png
waded
Post by waded »
The issue with the project button doing nothing appears to have been around since 2018. It's fixed in 7.5.2 (as far as I can tell by looking at the code) but that version isn't readily available that I know of. (Any suggestion how I can get that build?)
More details on github under /FoldingAtHome/fah-control/issues/48 (sorry, new user, can't post link.)
That build, 7.5.2, has never been released, not even to beta testing. It is probably part of the new client that was being worked on. Currently on hold until they get through the current rush to handle COVID-19 research.
waded
Post by waded »
Joe_H wrote:That build, 7.5.2, has never been released, not even to beta testing. It is probably part of the new client that was being worked on. Currently on hold until they get through the current rush to handle COVID-19 research.
Thanks Joe. I understand the priorities. I'll try to run FAHClient from source as a workaround, and since that's not terribly straight forward will submit PR about how to do it if I figure it out. It'd be nice to see client/viewer builds come out on a more regular basis, here in the forum I'm sure that'd reduce duplicate reports and effort.
