Concerned about my RTX 2060 KO
NolanSyKinsley
Post by NolanSyKinsley »
Running into a little bit of an issue with the RTX 2060 KO. It is technically a 2080/2070 TU104 chip repackaged as upgraded 2060. It shows up in lspci as VGA compatible controller: NVIDIA Corporation TU104 [GeForce RTX 2060], but when I run the FAH client it loads it as gpu:0:TU106-200A [GeForce RTX 2060]. I just wanted to make sure this wouldn't cause any issues.
Re: Concerned about my RTX 2060 KO
That should be fine, it looks like your card shares a device ID with another from nVidia.
