RTX 2060 Super not working
Kiesbauer
Post by Kiesbauer »
My Cpu works perfectly fine, but my GPU (RTX 2060 Super) doesn't. How can I fix this? All the settings in the GPU tab are set to -1.
Re: RTX 2060 Super not working
jlmarte
Post by jlmarte »
I had the same problem.
What OS are you using? I'm using Linux Mint 19.3, if your using linux make sure you have this installed:
-- Latest Proprietary Nvidia Drivers
-- ocl-icd-opencl & ocl-icd-opencl-dev (sudo apt install ocl-icd-opencl ocl-icd-opencl-dev)
Configure your GPU slot:
-- Go to configure --> Slots --> Add --> Name it GPU
-- Leave CPU = -1
-- Set gpu-index = 0
-- Set opencl-index = 0
-- Set cuda-index = 0
--Press Ok and Save
Reboot you system.
Let me know if it works!
