My folding COVID 19 wont start
marcuskvist
Post by marcuskvist »
Hi I got this message when trying to run COVID 19 setup with GPU.
I'm new here and want to help.
Any idea what is wrong?
09:06:35: <!-- Folding Slots -->
09:06:35: <slot id='1' type='GPU'/>
09:06:35:</config>
09:12:11:WU01:FS01:Connecting to 65.254.110.245:8080
09:12:11:WU01:FS01:Assigned to work server 192.0.2.1
09:12:11:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GT216 [Quadro FX 880M] from 192.0.2.1
09:12:11:WU01:FS01:Connecting to 192.0.2.1:8080
09:12:32:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:12:32:WU01:FS01:Connecting to 192.0.2.1:80
09:12:53:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Cheers
/M
Re: My folding COVID 19 wont start
Your GT216 or Quadro is too old to be used for GPU folding using the current software. At a minimum a GPU needs to be based on nVidia's Fermi or newer chips, Kepler is better.
Rudra_from_ua
Post by Rudra_from_ua »
Have the same problem. The CPU is working but not GPU. Video card is in a whitelist.
23:07:22:WU00:FS00:Connecting to 65.254.110.245:8080
23:07:22:WU01:FS01:Connecting to 65.254.110.245:8080
23:07:22:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:07:22:WU00:FS00:Connecting to 18.218.241.186:80
23:07:23:WU01:FS01:Assigned to work server 192.0.2.1
23:07:23:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Whistler XT [Radeon HD 6770M Series] from 192.0.2.1
23:07:23:WU01:FS01:Connecting to 192.0.2.1:8080
23:07:23:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:07:23:ERROR:WU00:FS00:Exception: Could not get an assignment
23:07:23:WU00:FS00:Connecting to 65.254.110.245:8080
23:07:23:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:07:23:WU00:FS00:Connecting to 18.218.241.186:80
23:07:24:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:07:24:ERROR:WU00:FS00:Exception: Could not get an assignment
23:07:43:Removing old file 'configs/config-20200324-002516.xml'
23:07:43:Saving configuration to config.xml
The 6770M is in the whitelist, and used to be able to be used for folding. However it does not support double precision calculations which current projects need. Most calculations are done in single precision, but some critical ones are done in double to maintain enough accuracy.
The last projects for GPU that used just SP ended just last year, a decision was pending on whether any future projects would might use just SP. So a number of cards have remained on the whitelist at this point that can not be used. They may be removing them in the near future, and marking them unsupported.
