GPU index, two GTX 1070
GPU index, two same GTX 1070 in the pc, error when starting FAH (gpu-index has no default):
Microsoft Windows [Version 10.0.18363.720]
(c) 2019 Microsoft Corporation. All rights reserved.
C:\Users\lee_l> fahclient --lspci
N/A
N/A
Re: GPU index, two GTX 1070
That's not the information we need.
Show us FAH's log. (See below)
Did you install the proprietary drivers from NVidia.com?
*********************** Log Started 2020-03-15T09:13:49Z ***********************
09:13:49:************************* Folding@home Client *************************
09:13:49: Website: https://foldingathome.org/
09:13:49: Copyright: (c) 2009-2018 foldingathome.org
09:13:49: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:13:49: Args:
09:13:49: Config: C:\Users\lee_l\AppData\Roaming\FAHClient\config.xml
09:13:49:******************************** Build ********************************
09:13:49: Version: 7.5.1
09:13:49: Date: May 11 2018
09:13:49: Time: 13:06:32
09:13:49: Repository: Git
09:13:49: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
09:13:49: Branch: master
09:13:49: Compiler: Visual C++ 2008
09:13:49: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:13:49: Platform: win32 10
09:13:49: Bits: 32
09:13:49: Mode: Release
09:13:49:******************************* System ********************************
09:13:49: CPU: AMD Ryzen Threadripper 1950X 16-Core Processor
09:13:49: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
09:13:49: CPUs: 16
09:13:49: Memory: 15.88GiB
09:13:49: Free Memory: 12.89GiB
09:13:49: Threads: WINDOWS_THREADS
09:13:49: OS Version: 6.2
09:13:49: Has Battery: false
09:13:49: On Battery: false
09:13:49: UTC Offset: 1
09:13:49: PID: 12636
09:13:49: CWD: C:\Users\lee_l\AppData\Roaming\FAHClient
09:13:49: OS: Windows 10 Home
09:13:49: OS Arch: AMD64
09:13:49: GPUs: 2
09:13:49: GPU 0: Bus:66 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
09:13:49: GPU 1: Bus:8 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
09:13:49: CUDA Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:6.1 Driver:10.2
09:13:49: CUDA Device 1: Platform:0 Device:1 Bus:66 Slot:0 Compute:6.1 Driver:10.2
09:13:49:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:1.2 Driver:442.50
09:13:49:OpenCL Device 1: Platform:0 Device:1 Bus:66 Slot:0 Compute:1.2 Driver:442.50
09:13:49: Win32 Service: false
09:13:49:***********************************************************************
09:13:49:<config>
09:13:49: <!-- User Information -->
09:13:49: <user v='xixou'/>
09:13:49:
09:13:49: <!-- Folding Slots -->
09:13:49: <slot id='0' type='CPU'>
09:13:49: <paused v='true'/>
09:13:49: </slot>
09:13:49: <slot id='1' type='GPU'>
09:13:49: </slot>
09:13:49: <slot id='2' type='GPU'>
09:13:49: </slot>
09:13:49: <slot id='3' type='GPU'>
09:13:49: </slot>
09:13:49: <slot id='4' type='GPU'>
09:13:49: </slot>
09:13:49:</config>
09:13:49:Trying to access database...
09:13:49:Successfully acquired database lock
09:13:49:Enabled folding slot 00: PAUSED cpu:11 (by user)
09:13:49:Enabled folding slot 01: PAUSED gpu:0:GP104 [GeForce GTX 1070] 6463 (by user)
09:13:49:Enabled folding slot 02: PAUSED gpu:1:GP104 [GeForce GTX 1070] 6463 (by user)
09:13:49:ERROR:Exception: No available GPUs
09:13:49:ERROR:Exception: Option 'gpu-index' has no default and is not set.
09:13:49:WU00:FS03:Connecting to 65.254.110.245:8080
09:13:49:WU01:FS04:Connecting to 65.254.110.245:8080
09:13:50:WARNING:WU01:FS04:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:13:50:WU01:FS04:Connecting to 18.218.241.186:80
09:13:50:WARNING:WU00:FS03:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:13:50:WU00:FS03:Connecting to 18.218.241.186:80
09:13:50:WARNING:WU01:FS04:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:13:50:ERROR:WU01:FS04:Exception: Could not get an assignment
09:13:51:WARNING:WU00:FS03:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:13:51:ERROR:WU00:FS03:Exception: Could not get an assignment
09:13:51:WU01:FS04:Connecting to 65.254.110.245:8080
09:13:51:WU00:FS03:Connecting to 65.254.110.245:8080
09:13:51:WARNING:WU01:FS04:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:13:51:WU01:FS04:Connecting to 18.218.241.186:80
09:13:51:WARNING:WU00:FS03:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:13:51:WU00:FS03:Connecting to 18.218.241.186:80
09:13:52:WARNING:WU01:FS04:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:13:52:ERROR:WU01:FS04:Exception: Could not get an assignment
09:13:52:WARNING:WU00:FS03:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:13:52:ERROR:WU00:FS03:Exception: Could not get an assignment
09:14:51:WU00:FS03:Connecting to 65.254.110.245:8080
09:14:51:WU01:FS04:Connecting to 65.254.110.245:8080
09:14:51:WARNING:WU00:FS03:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:14:51:WU00:FS03:Connecting to 18.218.241.186:80
09:14:52:WARNING:WU01:FS04:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:14:52:WU01:FS04:Connecting to 18.218.241.186:80
09:14:52:WARNING:WU00:FS03:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:14:52:ERROR:WU00:FS03:Exception: Could not get an assignment
09:14:52:WARNING:WU01:FS04:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:14:52:ERROR:WU01:FS04:Exception: Could not get an assignment
drivers: 442.50 DCH
The machine works fine with nicehash BTW.
Not currently folding
If you only have 2 1070's in the machine delete slots 3 and 4, unpause slots 1 & 2 and you should start seeing work units being downloaded. The servers are very heavily overloaded though so it may take a while for the gpu's to start folding
Try to go to the FAH Advanced Client then go to Configure->Slots, then remove your cpu/gpu's that you have there, then try to manually add your gpu's back in, keep the gpu-index, opencl-index, cusa-index values at -1 initially and see if that sorts it. Add 1 gpu at a time first to see it you can get one working, once that's done add the second one,
There are two major products that came out of Berkeley: LSD and UNIX. We don't believe this to be a coincidence.
-- Jeremy S. Anderson
There is no Slots settings under Configure menu.Asgaroth wrote:Try to go to the FAH Advanced Client then go to Configure->Slots, then remove your cpu/gpu's that you have there, then try to manually add your gpu's back in, keep the gpu-index, opencl-index, cusa-index values at -1 initially and see if that sorts it. Add 1 gpu at a time first to see it you can get one working, once that's done add the second one,
My 4 other machines works fine with FAH.
- Hardware configuration: Intel Core i7 3770K
Intel Core i5 M480
Something wrong with Folding@home client. There are FAHControl and Folding@home items in the windows start. You should launch both. May by restarting the app ( Folding@home client ) help.
FAHclient.exe is running in the process list of task manager.Denisok wrote:Something wrong with Folding@home client. There are FAHControl and Folding@home items in the windows start. You should launch both. May by restarting the app ( Folding@home client ) help.
Let me try to un-install and re-install FAH.
If that still fails, I will remove one GPU to see if that helps.
If that does not help, that means that those GPU are not part of the GPU list yet.
Ok, this is working now.
I think it was failing because I had an old version installed year ago (for curecoin).
When installing a new version, best to un-install the old , included the data.
This time it was asking me to crunch as anonymous or not, it did not ask this Morning (probably re-using old out dated settings).
mmm, it can't get WU, a bit weird because other machines got the WU's.
Internet connection is fine.
Edit: It just got a WU ^^
