WARNING:WU05:FS04:FahCore returned: CORE_RESTART (98 = 0x62)
jonfen801
Post by jonfen801 »
How should I troubleshoot this? each time I restart the process (ubuntu 18.04) a different set (or only one) of the GPUs keeps throwing this error...
05:40:40:WU04:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
05:40:51:WU00:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
05:40:56:WU05:FS04:Starting
05:40:56:WU05:FS04:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_21.fah/FahCore_21 -dir 05 -suffix 01 -version 705 -lifeline 7258 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 3 -gpu 3
05:40:56:WU05:FS04:Started FahCore on PID 7478
05:40:56:WU05:FS04:Core PID:7482
05:40:56:WU05:FS04:FahCore 0x21 started
05:40:56:WU03:FS03:Starting
05:40:56:WU03:FS03:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_21.fah/FahCore_21 -dir 03 -suffix 01 -version 705 -lifeline 7258 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 2 -gpu 2
05:40:56:WU03:FS03:Started FahCore on PID 7485
05:40:56:WU03:FS03:Core PID:7489
05:40:56:WU03:FS03:FahCore 0x21 started
05:41:11:WARNING:WU05:FS04:FahCore returned: CORE_RESTART (98 = 0x62)
05:41:11:WARNING:WU03:FS03:FahCore returned: CORE_RESTART (98 = 0x62)
05:41:25:7:192.168.0.5:New Web connection
05:41:56:WU05:FS04:Starting
05:41:56:WU05:FS04:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_21.fah/FahCore_21 -dir 05 -suffix 01 -version 705 -lifeline 7258 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 3 -gpu 3
05:41:56:WU05:FS04:Started FahCore on PID 7492
05:41:56:WU05:FS04:Core PID:7496
05:41:56:WU05:FS04:FahCore 0x21 started
05:41:56:WU03:FS03:Starting
05:41:56:WU03:FS03:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_21.fah/FahCore_21 -dir 03 -suffix 01 -version 705 -lifeline 7258 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 2 -gpu 2
05:41:56:WU03:FS03:Started FahCore on PID 7499
05:41:56:WU03:FS03:Core PID:7503
05:41:56:WU03:FS03:FahCore 0x21 started
05:42:11:WARNING:WU05:FS04:FahCore returned: CORE_RESTART (98 = 0x62)
05:42:11:WARNING:WU03:FS03:FahCore returned: CORE_RESTART (98 = 0x62)
05:42:31:WU04:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
05:42:56:WU05:FS04:Starting
05:42:56:WU05:FS04:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_21.fah/FahCore_21 -dir 05 -suffix 01 -version 705 -lifeline 7258 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 3 -gpu 3
05:42:56:WU05:FS04:Started FahCore on PID 7506
05:42:56:WU05:FS04:Core PID:7510
05:42:56:WU05:FS04:FahCore 0x21 started
05:42:56:WU03:FS03:Starting
05:42:56:WU03:FS03:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_21.fah/FahCore_21 -dir 03 -suffix 01 -version 705 -lifeline 7258 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 2 -gpu 2
05:42:56:WU03:FS03:Started FahCore on PID 7513
05:42:56:WU03:FS03:Core PID:7517
05:42:56:WU03:FS03:FahCore 0x21 started
05:43:11:WARNING:WU05:FS04:FahCore returned: CORE_RESTART (98 = 0x62)
05:43:11:WARNING:WU03:FS03:FahCore returned: CORE_RESTART (98 = 0x62)
05:43:56:WU05:FS04:Starting
05:43:56:WU05:FS04:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_21.fah/FahCore_21 -dir 05 -suffix 01 -version 705 -lifeline 7258 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 3 -gpu 3
05:43:56:WU05:FS04:Started FahCore on PID 7521
05:43:56:WU05:FS04:Core PID:7525
05:43:56:WU05:FS04:FahCore 0x21 started
05:43:56:WU03:FS03:Starting
05:43:56:WU03:FS03:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_21.fah/FahCore_21 -dir 03 -suffix 01 -version 705 -lifeline 7258 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 2 -gpu 2
05:43:56:WU03:FS03:Started FahCore on PID 7528
05:43:56:WU03:FS03:Core PID:7532
05:43:56:WU03:FS03:FahCore 0x21 started
05:43:58:WU01:FS02:0x21:Completed 250000 out of 25000000 steps (1%)
05:44:11:WARNING:WU05:FS04:FahCore returned: CORE_RESTART (98 = 0x62)
05:44:11:WARNING:WU03:FS03:FahCore returned: CORE_RESTART (98 = 0x62)
05:44:23:WU04:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
05:44:56:WU05:FS04:Starting
05:44:56:WU05:FS04:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_21.fah/FahCore_21 -dir 05 -suffix 01 -version 705 -lifeline 7258 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 3 -gpu 3
05:44:56:WU05:FS04:Started FahCore on PID 7535
05:44:56:WU05:FS04:Core PID:7539
05:44:56:WU05:FS04:FahCore 0x21 started
05:44:56:WU03:FS03:Starting
05:44:56:WU03:FS03:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_21.fah/FahCore_21 -dir 03 -suffix 01 -version 705 -lifeline 7258 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 2 -gpu 2
05:44:56:WU03:FS03:Started FahCore on PID 7542
05:44:56:WU03:FS03:Core PID:7546
05:44:56:WU03:FS03:FahCore 0x21 started
05:45:11:WARNING:WU05:FS04:FahCore returned: CORE_RESTART (98 = 0x62)
05:45:11:WARNING:WU03:FS03:FahCore returned: CORE_RESTART (98 = 0x62)
Re: WARNING:WU05:FS04:FahCore returned: CORE_RESTART (98 = 0
What process are you restarting and why?
The FAHClient process should be running (forever) as a Daemon whether your folding or not. As a background task, it downloads new assignments (WUs) and starts other processes like FAHCore_* which perform the computations to process the WU to completion. Result files are then passed to FAHClient for uploading. FAHClient should be started automatically at boot time.
You shou;d manage all these processes using WebControl or FAHControl which allows you monitor what is happening in the background as well as to interactively PAUSE active WUs or reconfigure other settings.
I don't know what you're doing, but this is the first time I see such messages ...
Post by foldy »
@jonfen801: How many GPUs do you have? Can you post the first part of the FAH log.txt?
jonfen801
Post by jonfen801 »
@bruce: The daemon doesn't work on 18.04, it just fails. It gives no info just "FAIL" with an exit code of 1
@foldy: This is the config.xml file I am using:
viewtopic.php?f=16&t=32427&e=0
As a work around I have been running the following: $ cd /var/lib/fabclient && sudo FABClient
That works, but the same config in /etc/fabclient does not.
bruce wrote:What process are you restarting and why?
