GPU has project but is not running
tenthousandthousand
Post by tenthousandthousand »
Hello,
Sorry if I am new to all this and don't know exactly how it works... I have two projects running, one on my CPU and one on my GPU. But Task Manager says that my GPU is barely being used at all. The GPU project seems to be only using about 25% of my CPU capacity and 1% of my GPU capacity, and it says that project will take another 9 hours to complete. I was able to do a GPU project in only a few hours last night so I am not sure what has changed. I have attached my logs. Thank you for your help.
*********************** Log Started 2020-03-14T20:38:11Z ***********************
20:38:11:************************* Folding@home Client *************************
20:38:11:        Website: https://foldingathome.org/
20:38:11:      Copyright: (c) 2009-2018 foldingathome.org
20:38:11:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:38:11:           Args:
20:38:11:         Config: C:\Users\Benjamin\AppData\Roaming\FAHClient\config.xml
20:38:11:******************************** Build ********************************
20:38:11:        Version: 7.5.1
20:38:11:           Date: May 11 2018
20:38:11:           Time: 13:06:32
20:38:11:     Repository: Git
20:38:11:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:38:11:         Branch: master
20:38:11:       Compiler: Visual C++ 2008
20:38:11:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:38:11:       Platform: win32 10
20:38:11:           Bits: 32
20:38:11:           Mode: Release
20:38:11:******************************* System ********************************
20:38:11:            CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
20:38:11:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
20:38:11:           CPUs: 4
20:38:11:         Memory: 7.96GiB
20:38:11:    Free Memory: 5.68GiB
20:38:11:        Threads: WINDOWS_THREADS
20:38:11:     OS Version: 6.2
20:38:11:    Has Battery: false
20:38:11:     On Battery: false
20:38:11:     UTC Offset: -7
20:38:11:            PID: 9404
20:38:11:            CWD: C:\Users\Benjamin\AppData\Roaming\FAHClient
20:38:11:             OS: Windows 10 Home
20:38:11:        OS Arch: AMD64
20:38:11:           GPUs: 1
20:38:11:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 3GB] 3935
20:38:11:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
20:38:11:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.59
20:38:11:  Win32 Service: false
20:38:11:***********************************************************************
20:38:11:<config>
20:38:11:  <!-- Slot Control -->
20:38:11:  <power v='full'/>
20:38:11:
20:38:11:  <!-- User Information -->
20:38:11:  <team v='225605'/>
20:38:11:  <user v='tenthousandthousand'/>
20:38:11:
20:38:11:  <!-- Folding Slots -->
20:38:11:  <slot id='0' type='CPU'/>
20:38:11:  <slot id='1' type='GPU'/>
20:38:11:</config>
20:38:11:Trying to access database...
20:38:11:Successfully acquired database lock
20:38:11:Enabled folding slot 00: READY cpu:3
20:38:11:Enabled folding slot 01: READY gpu:0:GP106 [GeForce GTX 1060 3GB] 3935
20:38:11:WU00:FS00:Connecting to 65.254.110.245:8080
20:38:11:WU01:FS01:Connecting to 65.254.110.245:8080
20:38:12:WU00:FS00:Assigned to work server 155.247.164.213
20:38:12:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.164.213
20:38:12:WU00:FS00:Connecting to 155.247.164.213:8080
20:38:12:WU01:FS01:Assigned to work server 155.247.166.220
20:38:12:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP106 [GeForce GTX 1060 3GB] 3935 from 155.247.166.220
20:38:12:WU01:FS01:Connecting to 155.247.166.220:8080
20:38:12:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
20:38:13:ERROR:WU00:FS00:Exception: Server did not assign work unit
20:38:13:WU01:FS01:Connecting to 65.254.110.245:8080
20:38:13:WU00:FS00:Connecting to 65.254.110.245:8080
20:38:13:WU01:FS01:Assigned to work server 155.247.166.220
20:38:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP106 [GeForce GTX 1060 3GB] 3935 from 155.247.166.220
20:38:13:WU01:FS01:Connecting to 155.247.166.220:8080
20:38:13:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:38:13:WU00:FS00:Connecting to 18.218.241.186:80
20:38:14:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:38:14:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:38:14:ERROR:WU00:FS00:Exception: Could not get an assignment
20:39:13:WU00:FS00:Connecting to 65.254.110.245:8080
20:39:13:WU00:FS00:Assigned to work server 128.252.203.9
20:39:13:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 128.252.203.9
20:39:13:WU00:FS00:Connecting to 128.252.203.9:8080
20:39:13:WU01:FS01:Connecting to 65.254.110.245:8080
20:39:14:WU01:FS01:Assigned to work server 155.247.166.220
20:39:14:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP106 [GeForce GTX 1060 3GB] 3935 from 155.247.166.220
20:39:14:WU01:FS01:Connecting to 155.247.166.220:8080
20:39:14:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
20:39:14:WU00:FS00:Downloading 7.72MiB
20:39:16:WU00:FS00:Download complete
20:39:16:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14401 run:0 clone:3526 gen:76 core:0xa7 unit:0x0000005480fccb095dcb2ea3a405cb6f
20:39:16:WU00:FS00:Starting
20:39:16:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Benjamin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9404 -checkpoint 15 -np 3
20:39:16:WU00:FS00:Started FahCore on PID 5248
20:39:16:WU00:FS00:Core PID:6792
20:39:16:WU00:FS00:FahCore 0xa7 started
20:39:16:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T20:39:16Z ***********************
20:39:16:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:39:16:WU00:FS00:0xa7:       Type: 0xa7
20:39:16:WU00:FS00:0xa7:       Core: Gromacs
20:39:16:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 5248 -checkpoint 15 -np 3
20:39:16:WU00:FS00:0xa7:************************************ CBang *************************************
20:39:16:WU00:FS00:0xa7:       Date: Oct 26 2019
20:39:16:WU00:FS00:0xa7:       Time: 01:38:25
20:39:16:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:39:16:WU00:FS00:0xa7:     Branch: master
20:39:16:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:39:16:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:39:16:WU00:FS00:0xa7:   Platform: win32 10
20:39:16:WU00:FS00:0xa7:       Bits: 64
20:39:16:WU00:FS00:0xa7:       Mode: Release
20:39:16:WU00:FS00:0xa7:************************************ System ************************************
20:39:16:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
20:39:16:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
20:39:16:WU00:FS00:0xa7:       CPUs: 4
20:39:16:WU00:FS00:0xa7:     Memory: 7.96GiB
20:39:16:WU00:FS00:0xa7:Free Memory: 4.91GiB
20:39:16:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
20:39:16:WU00:FS00:0xa7: OS Version: 6.2
20:39:16:WU00:FS00:0xa7:Has Battery: false
20:39:16:WU00:FS00:0xa7: On Battery: false
20:39:16:WU00:FS00:0xa7: UTC Offset: -7
20:39:16:WU00:FS00:0xa7:        PID: 6792
20:39:16:WU00:FS00:0xa7:        CWD: C:\Users\Benjamin\AppData\Roaming\FAHClient\work
20:39:16:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:39:16:WU00:FS00:0xa7:    Version: 0.0.18
20:39:16:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:39:16:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:39:16:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:39:16:WU00:FS00:0xa7:       Time: 01:52:30
20:39:16:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:39:16:WU00:FS00:0xa7:************************************ Build *************************************
20:39:16:WU00:FS00:0xa7:       SIMD: avx_256
20:39:16:WU00:FS00:0xa7:********************************************************************************
20:39:16:WU00:FS00:0xa7:Project: 14401 (Run 0, Clone 3526, Gen 76)
20:39:16:WU00:FS00:0xa7:Unit: 0x0000005480fccb095dcb2ea3a405cb6f
20:39:16:WU00:FS00:0xa7:Reading tar file core.xml
20:39:16:WU00:FS00:0xa7:Reading tar file frame76.tpr
20:39:16:WU00:FS00:0xa7:Digital signatures verified
20:39:16:WU00:FS00:0xa7:Calling: mdrun -s frame76.tpr -o frame76.trr -x frame76.xtc -cpt 15 -nt 3
20:39:16:WU00:FS00:0xa7:Steps: first=9500000 total=125000
20:39:20:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
20:40:50:WU01:FS01:Connecting to 65.254.110.245:8080
20:40:50:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:40:50:WU01:FS01:Connecting to 18.218.241.186:80
20:40:51:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:40:51:ERROR:WU01:FS01:Exception: Could not get an assignment
20:42:15:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
20:43:21:FS00:Shutting core down
20:43:21:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 6792
20:43:21:WU00:FS00:0xa7:Exiting, please wait. . .
20:43:25:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
20:43:25:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:43:25:WU00:FS00:Starting
20:43:25:WARNING:WU00:FS00:Changed SMP threads from 3 to 1 this can cause some work units to fail
20:43:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Benjamin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9404 -checkpoint 15 -np 1
20:43:25:WU00:FS00:Started FahCore on PID 9764
20:43:26:WU00:FS00:Core PID:11100
20:43:26:WU00:FS00:FahCore 0xa7 started
20:43:26:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T20:43:26Z ***********************
20:43:26:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:43:26:WU00:FS00:0xa7:       Type: 0xa7
20:43:26:WU00:FS00:0xa7:       Core: Gromacs
20:43:26:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 9764 -checkpoint 15 -np 1
20:43:26:WU00:FS00:0xa7:************************************ CBang *************************************
20:43:26:WU00:FS00:0xa7:       Date: Oct 26 2019
20:43:26:WU00:FS00:0xa7:       Time: 01:38:25
20:43:26:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:43:26:WU00:FS00:0xa7:     Branch: master
20:43:26:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:43:26:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:43:26:WU00:FS00:0xa7:   Platform: win32 10
20:43:26:WU00:FS00:0xa7:       Bits: 64
20:43:26:WU00:FS00:0xa7:       Mode: Release
20:43:26:WU00:FS00:0xa7:************************************ System ************************************
20:43:26:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
20:43:26:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
20:43:26:WU00:FS00:0xa7:       CPUs: 4
20:43:26:WU00:FS00:0xa7:     Memory: 7.96GiB
20:43:26:WU00:FS00:0xa7:Free Memory: 5.35GiB
20:43:26:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
20:43:26:WU00:FS00:0xa7: OS Version: 6.2
20:43:26:WU00:FS00:0xa7:Has Battery: false
20:43:26:WU00:FS00:0xa7: On Battery: false
20:43:26:WU00:FS00:0xa7: UTC Offset: -7
20:43:26:WU00:FS00:0xa7:        PID: 11100
20:43:26:WU00:FS00:0xa7:        CWD: C:\Users\Benjamin\AppData\Roaming\FAHClient\work
20:43:26:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:43:26:WU00:FS00:0xa7:    Version: 0.0.18
20:43:26:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:43:26:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:43:26:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:43:26:WU00:FS00:0xa7:       Time: 01:52:30
20:43:26:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:43:26:WU00:FS00:0xa7:************************************ Build *************************************
20:43:26:WU00:FS00:0xa7:       SIMD: avx_256
20:43:26:WU00:FS00:0xa7:********************************************************************************
20:43:26:WU00:FS00:0xa7:Project: 14401 (Run 0, Clone 3526, Gen 76)
20:43:26:WU00:FS00:0xa7:Unit: 0x0000005480fccb095dcb2ea3a405cb6f
20:43:26:WU00:FS00:0xa7:Digital signatures verified
20:43:26:WU00:FS00:0xa7:Calling: mdrun -s frame76.tpr -o frame76.trr -x frame76.xtc -cpi state.cpt -cpt 15 -nt 1
20:43:26:WU00:FS00:0xa7:Steps: first=9500000 total=125000
20:43:28:WU00:FS00:0xa7:Completed 1732 out of 125000 steps (1%)
20:44:17:Saving configuration to config.xml
20:44:17:<config>
20:44:17:  <!-- Slot Control -->
20:44:17:  <power v='light'/>
20:44:17:
20:44:17:  <!-- User Information -->
20:44:17:  <team v='225605'/>
20:44:17:  <user v='tenthousandthousand'/>
20:44:17:
20:44:17:  <!-- Folding Slots -->
20:44:17:  <slot id='0' type='CPU'/>
20:44:17:  <slot id='1' type='GPU'/>
20:44:17:</config>
20:48:44:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
20:57:52:WU00:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
21:08:09:WU00:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
21:16:54:WU00:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
21:26:25:WU00:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
21:35:39:WU00:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
21:45:50:WU00:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
21:56:23:WU00:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
22:06:18:WU00:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
22:15:09:WU00:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
22:18:49:FS00:Shutting core down
22:18:49:WU01:FS01:Connecting to 65.254.110.245:8080
22:18:49:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 11100
22:18:49:WU00:FS00:0xa7:Exiting, please wait. . .
22:18:50:Saving configuration to config.xml
22:18:50:<config>
22:18:50:  <!-- Slot Control -->
22:18:50:  <power v='full'/>
22:18:50:
22:18:50:  <!-- User Information -->
22:18:50:  <team v='225605'/>
22:18:50:  <user v='tenthousandthousand'/>
22:18:50:
22:18:50:  <!-- Folding Slots -->
22:18:50:  <slot id='0' type='CPU'/>
22:18:50:  <slot id='1' type='GPU'/>
22:18:50:</config>
22:18:50:WU01:FS01:Assigned to work server 155.247.166.220
22:18:50:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP106 [GeForce GTX 1060 3GB] 3935 from 155.247.166.220
22:18:50:WU01:FS01:Connecting to 155.247.166.220:8080
22:18:50:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
22:18:52:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
22:18:52:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:18:53:WU00:FS00:Starting
22:18:53:WARNING:WU00:FS00:Changed SMP threads from 1 to 3 this can cause some work units to fail
22:18:53:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Benjamin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9404 -checkpoint 15 -np 3
22:18:53:WU00:FS00:Started FahCore on PID 3628
22:18:53:WU00:FS00:Core PID:6828
22:18:53:WU00:FS00:FahCore 0xa7 started
22:18:53:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T22:18:53Z ***********************
22:18:53:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:18:53:WU00:FS00:0xa7:       Type: 0xa7
22:18:53:WU00:FS00:0xa7:       Core: Gromacs
22:18:53:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 3628 -checkpoint 15 -np 3
22:18:53:WU00:FS00:0xa7:************************************ CBang *************************************
22:18:53:WU00:FS00:0xa7:       Date: Oct 26 2019
22:18:53:WU00:FS00:0xa7:       Time: 01:38:25
22:18:53:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:18:53:WU00:FS00:0xa7:     Branch: master
22:18:53:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:18:53:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:18:53:WU00:FS00:0xa7:   Platform: win32 10
22:18:53:WU00:FS00:0xa7:       Bits: 64
22:18:53:WU00:FS00:0xa7:       Mode: Release
22:18:53:WU00:FS00:0xa7:************************************ System ************************************
22:18:53:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
22:18:53:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
22:18:53:WU00:FS00:0xa7:       CPUs: 4
22:18:53:WU00:FS00:0xa7:     Memory: 7.96GiB
22:18:53:WU00:FS00:0xa7:Free Memory: 4.57GiB
22:18:53:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:18:53:WU00:FS00:0xa7: OS Version: 6.2
22:18:53:WU00:FS00:0xa7:Has Battery: false
22:18:53:WU00:FS00:0xa7: On Battery: false
22:18:53:WU00:FS00:0xa7: UTC Offset: -7
22:18:53:WU00:FS00:0xa7:        PID: 6828
22:18:53:WU00:FS00:0xa7:        CWD: C:\Users\Benjamin\AppData\Roaming\FAHClient\work
22:18:53:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:18:53:WU00:FS00:0xa7:    Version: 0.0.18
22:18:53:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:18:53:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:18:53:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:18:53:WU00:FS00:0xa7:       Time: 01:52:30
22:18:53:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:18:53:WU00:FS00:0xa7:************************************ Build *************************************
22:18:53:WU00:FS00:0xa7:       SIMD: avx_256
22:18:53:WU00:FS00:0xa7:********************************************************************************
22:18:53:WU00:FS00:0xa7:Project: 14401 (Run 0, Clone 3526, Gen 76)
22:18:53:WU00:FS00:0xa7:Unit: 0x0000005480fccb095dcb2ea3a405cb6f
22:18:53:WU00:FS00:0xa7:Digital signatures verified
22:18:53:WU00:FS00:0xa7:Calling: mdrun -s frame76.tpr -o frame76.trr -x frame76.xtc -cpi state.cpt -cpt 15 -nt 3
22:18:53:WU00:FS00:0xa7:Steps: first=9500000 total=125000
22:18:56:WU00:FS00:0xa7:Completed 14222 out of 125000 steps (11%)
22:20:45:WU00:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
22:23:04:WU01:FS01:Connecting to 65.254.110.245:8080
22:23:04:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:23:04:WU01:FS01:Connecting to 18.218.241.186:80
22:23:04:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:23:04:ERROR:WU01:FS01:Exception: Could not get an assignment
22:23:38:WU00:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
22:26:27:WU00:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
22:29:12:WU00:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
22:29:55:WU01:FS01:Connecting to 65.254.110.245:8080
22:29:55:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:29:55:WU01:FS01:Connecting to 18.218.241.186:80
22:29:55:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:29:55:ERROR:WU01:FS01:Exception: Could not get an assignment
22:32:03:WU00:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
22:34:46:WU00:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
22:37:36:WU00:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
22:40:26:WU00:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
22:41:00:WU01:FS01:Connecting to 65.254.110.245:8080
22:41:00:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:41:00:WU01:FS01:Connecting to 18.218.241.186:80
22:41:01:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:41:01:ERROR:WU01:FS01:Exception: Could not get an assignment
22:43:18:WU00:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
22:46:10:WU00:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
22:49:05:WU00:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
22:51:52:WU00:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
22:54:49:WU00:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
22:57:52:WU00:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
22:58:57:WU01:FS01:Connecting to 65.254.110.245:8080
22:58:57:WU01:FS01:Assigned to work server 155.247.166.220
22:58:57:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP106 [GeForce GTX 1060 3GB] 3935 from 155.247.166.220
22:58:57:WU01:FS01:Connecting to 155.247.166.220:8080
22:58:58:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
23:00:50:WU00:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
23:03:46:WU00:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
23:06:28:WU00:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
23:09:13:WU00:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
23:12:04:WU00:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
23:14:48:WU00:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
23:17:35:WU00:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
23:20:24:WU00:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
23:23:27:WU00:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
23:26:20:WU00:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
23:27:59:WU01:FS01:Connecting to 65.254.110.245:8080
23:27:59:WU01:FS01:Assigned to work server 155.247.166.220
23:27:59:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP106 [GeForce GTX 1060 3GB] 3935 from 155.247.166.220
23:27:59:WU01:FS01:Connecting to 155.247.166.220:8080
23:28:00:WU01:FS01:Downloading 5.79MiB
23:28:04:WU01:FS01:Download complete
23:28:04:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14310 run:293 clone:67 gen:0 core:0x21 unit:0x000000000002894c5e6cf8bf1fb8a2c6
23:28:04:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah
23:28:04:WU01:FS01:Connecting to cores.foldingathome.org:80
23:28:04:WU01:FS01:FahCore 21: Downloading 3.47MiB
23:28:05:WU01:FS01:FahCore 21: Download complete
23:28:05:WU01:FS01:Valid core signature
23:28:05:WU01:FS01:Unpacked 11.80MiB to cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe
23:28:05:WU01:FS01:Starting
23:28:05:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Benjamin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 9404 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
23:28:05:WU01:FS01:Started FahCore on PID 8904
23:28:06:WU01:FS01:Core PID:5616
23:28:06:WU01:FS01:FahCore 0x21 started
23:28:06:WU01:FS01:0x21:*********************** Log Started 2020-03-14T23:28:06Z ***********************
23:28:06:WU01:FS01:0x21:Project: 14310 (Run 293, Clone 67, Gen 0)
23:28:06:WU01:FS01:0x21:Unit: 0x000000000002894c5e6cf8bf1fb8a2c6
23:28:06:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
23:28:06:WU01:FS01:0x21:Machine: 1
23:28:06:WU01:FS01:0x21:Reading tar file core.xml
23:28:06:WU01:FS01:0x21:Reading tar file integrator.xml
23:28:06:WU01:FS01:0x21:Reading tar file state.xml
23:28:06:WU01:FS01:0x21:Reading tar file system.xml
23:28:06:WU01:FS01:0x21:Digital signatures verified
23:28:06:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
23:28:06:WU01:FS01:0x21:Version 0.0.20
23:28:15:WU01:FS01:0x21:Completed 0 out of 25000000 steps (0%)
23:28:15:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:29:27:WU00:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
23:30:16:FS00:Paused
23:30:16:FS01:Paused
23:30:16:FS00:Shutting core down
23:30:16:FS01:Shutting core down
23:30:16:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 6828
23:30:16:WU00:FS00:0xa7:Exiting, please wait. . .
23:30:17:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
23:30:20:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
23:30:20:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:30:25:FS00:Unpaused
23:30:25:FS01:Unpaused
23:30:25:WU00:FS00:Starting
23:30:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Benjamin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9404 -checkpoint 15 -np 3
23:30:25:WU00:FS00:Started FahCore on PID 2164
23:30:25:WU00:FS00:Core PID:2556
23:30:25:WU00:FS00:FahCore 0xa7 started
23:30:26:WU01:FS01:Starting
23:30:26:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Benjamin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 9404 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
23:30:26:WU01:FS01:Started FahCore on PID 5864
23:30:26:WU01:FS01:Core PID:11048
23:30:26:WU01:FS01:FahCore 0x21 started
23:30:26:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T23:30:25Z ***********************
23:30:26:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:30:26:WU00:FS00:0xa7:       Type: 0xa7
23:30:26:WU00:FS00:0xa7:       Core: Gromacs
23:30:26:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 2164 -checkpoint 15 -np 3
23:30:26:WU00:FS00:0xa7:************************************ CBang *************************************
23:30:26:WU00:FS00:0xa7:       Date: Oct 26 2019
23:30:26:WU00:FS00:0xa7:       Time: 01:38:25
23:30:26:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:30:26:WU00:FS00:0xa7:     Branch: master
23:30:26:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:30:26:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:30:26:WU00:FS00:0xa7:   Platform: win32 10
23:30:26:WU00:FS00:0xa7:       Bits: 64
23:30:26:WU00:FS00:0xa7:       Mode: Release
23:30:26:WU00:FS00:0xa7:************************************ System ************************************
23:30:26:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
23:30:26:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
23:30:26:WU00:FS00:0xa7:       CPUs: 4
23:30:26:WU00:FS00:0xa7:     Memory: 7.96GiB
23:30:26:WU00:FS00:0xa7:Free Memory: 5.32GiB
23:30:26:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:30:26:WU00:FS00:0xa7: OS Version: 6.2
23:30:26:WU00:FS00:0xa7:Has Battery: false
23:30:26:WU00:FS00:0xa7: On Battery: false
23:30:26:WU00:FS00:0xa7: UTC Offset: -7
23:30:26:WU00:FS00:0xa7:        PID: 2556
23:30:26:WU00:FS00:0xa7:        CWD: C:\Users\Benjamin\AppData\Roaming\FAHClient\work
23:30:26:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:30:26:WU00:FS00:0xa7:    Version: 0.0.18
23:30:26:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:30:26:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:30:26:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:30:26:WU00:FS00:0xa7:       Time: 01:52:30
23:30:26:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:30:26:WU00:FS00:0xa7:************************************ Build *************************************
23:30:26:WU00:FS00:0xa7:       SIMD: avx_256
23:30:26:WU00:FS00:0xa7:********************************************************************************
23:30:26:WU00:FS00:0xa7:Project: 14401 (Run 0, Clone 3526, Gen 76)
23:30:26:WU00:FS00:0xa7:Unit: 0x0000005480fccb095dcb2ea3a405cb6f
23:30:26:WU00:FS00:0xa7:Digital signatures verified
23:30:26:WU00:FS00:0xa7:Calling: mdrun -s frame76.tpr -o frame76.trr -x frame76.xtc -cpi state.cpt -cpt 15 -nt 3
23:30:26:WU01:FS01:0x21:*********************** Log Started 2020-03-14T23:30:26Z ***********************
23:30:26:WU01:FS01:0x21:Project: 14310 (Run 293, Clone 67, Gen 0)
23:30:26:WU01:FS01:0x21:Unit: 0x000000000002894c5e6cf8bf1fb8a2c6
23:30:26:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
23:30:26:WU01:FS01:0x21:Machine: 1
23:30:26:WU01:FS01:0x21:Digital signatures verified
23:30:26:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
23:30:26:WU01:FS01:0x21:Version 0.0.20
23:30:26:WU00:FS00:0xa7:Steps: first=9500000 total=125000
23:30:27:WU01:FS01:0x21:Completed 0 out of 25000000 steps (0%)
23:30:27:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:30:29:WU00:FS00:0xa7:Completed 45312 out of 125000 steps (36%)
23:30:38:FS00:Paused
23:30:38:FS00:Shutting core down
23:30:38:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 2556
23:30:38:WU00:FS00:0xa7:Exiting, please wait. . .
23:30:41:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
23:30:42:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:31:01:Saving configuration to config.xml
23:31:01:<config>
23:31:01:  <!-- Slot Control -->
23:31:01:  <power v='full'/>
23:31:01:
23:31:01:  <!-- User Information -->
23:31:01:  <team v='225605'/>
23:31:01:  <user v='tenthousandthousand'/>
23:31:01:
23:31:01:  <!-- Folding Slots -->
23:31:01:  <slot id='0' type='CPU'>
23:31:01:    <paused v='true'/>
23:31:01:  </slot>
23:31:01:  <slot id='1' type='GPU'/>
23:31:01:</config>
23:36:01:WU01:FS01:0x21:Completed 250000 out of 25000000 steps (1%)
23:36:03:FS00:Unpaused
23:36:03:WU00:FS00:Starting
23:36:03:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Benjamin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9404 -checkpoint 15 -np 3
23:36:03:WU00:FS00:Started FahCore on PID 10532
23:36:03:WU00:FS00:Core PID:7772
23:36:03:WU00:FS00:FahCore 0xa7 started
23:36:03:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T23:36:03Z ***********************
23:36:03:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:36:03:WU00:FS00:0xa7:       Type: 0xa7
23:36:03:WU00:FS00:0xa7:       Core: Gromacs
23:36:03:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 10532 -checkpoint 15 -np
23:36:03:WU00:FS00:0xa7:             3
23:36:03:WU00:FS00:0xa7:************************************ CBang *************************************
23:36:03:WU00:FS00:0xa7:       Date: Oct 26 2019
23:36:03:WU00:FS00:0xa7:       Time: 01:38:25
23:36:03:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:36:03:WU00:FS00:0xa7:     Branch: master
23:36:03:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:36:03:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:36:03:WU00:FS00:0xa7:   Platform: win32 10
23:36:03:WU00:FS00:0xa7:       Bits: 64
23:36:03:WU00:FS00:0xa7:       Mode: Release
23:36:03:WU00:FS00:0xa7:************************************ System ************************************
23:36:03:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
23:36:03:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
23:36:03:WU00:FS00:0xa7:       CPUs: 4
23:36:03:WU00:FS00:0xa7:     Memory: 7.96GiB
23:36:03:WU00:FS00:0xa7:Free Memory: 4.94GiB
23:36:03:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:36:03:WU00:FS00:0xa7: OS Version: 6.2
23:36:03:WU00:FS00:0xa7:Has Battery: false
23:36:03:WU00:FS00:0xa7: On Battery: false
23:36:03:WU00:FS00:0xa7: UTC Offset: -7
23:36:03:WU00:FS00:0xa7:        PID: 7772
23:36:03:WU00:FS00:0xa7:        CWD: C:\Users\Benjamin\AppData\Roaming\FAHClient\work
23:36:03:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:36:03:WU00:FS00:0xa7:    Version: 0.0.18
23:36:03:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:36:03:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:36:03:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:36:03:WU00:FS00:0xa7:       Time: 01:52:30
23:36:03:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:36:03:WU00:FS00:0xa7:************************************ Build *************************************
23:36:03:WU00:FS00:0xa7:       SIMD: avx_256
23:36:03:WU00:FS00:0xa7:********************************************************************************
23:36:03:WU00:FS00:0xa7:Project: 14401 (Run 0, Clone 3526, Gen 76)
23:36:03:WU00:FS00:0xa7:Unit: 0x0000005480fccb095dcb2ea3a405cb6f
23:36:03:WU00:FS00:0xa7:Digital signatures verified
23:36:03:WU00:FS00:0xa7:Calling: mdrun -s frame76.tpr -o frame76.trr -x frame76.xtc -cpi state.cpt -cpt 15 -nt 3
23:36:03:WU00:FS00:0xa7:Steps: first=9500000 total=125000
23:36:06:Saving configuration to config.xml
23:36:06:<config>
23:36:06:  <!-- Slot Control -->
23:36:06:  <power v='full'/>
23:36:06:
23:36:06:  <!-- User Information -->
23:36:06:  <team v='225605'/>
23:36:06:  <user v='tenthousandthousand'/>
23:36:06:
23:36:06:  <!-- Folding Slots -->
23:36:06:  <slot id='0' type='CPU'/>
23:36:06:  <slot id='1' type='GPU'/>
23:36:06:</config>
23:36:06:WU00:FS00:0xa7:Completed 45382 out of 125000 steps (36%)
23:38:17:WU00:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
23:41:46:WU01:FS01:0x21:Completed 500000 out of 25000000 steps (2%)
23:42:03:WU00:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
23:45:19:WU00:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
23:47:23:WU01:FS01:0x21:Completed 750000 out of 25000000 steps (3%)
23:48:32:WU00:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
23:51:48:WU00:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
23:53:02:WU01:FS01:0x21:Completed 1000000 out of 25000000 steps (4%)
jonault
Re: GPU has project but is not running
Post by jonault »
The windows task manager doesn't accurately reflect how hard the GPU is working on F@H. Both of my GPUs are running full throttle, but my Task Manager also shows only a few % usage.
I don't have a GTX 1060 to compare, but based on the cards I do have, your GPU folding times seem reasonable, so I think you're doing fine.You should keep in mind that folding performance can vary somewhat from one project to the next, so you may see faster or slower performance in the future.
BlueRotkev
Hardware configuration: Zotac Twin Fan 1660Ti (442.59GRD)
240GB WD Green M2
2TB WD Black 7200
i5 7400
16GB Loki of Asgard 2400MHz RAM
Post by BlueRotkev »
Change one of the graphs in Task manager to CUDA, you'll soon see what its up to
i5-7400
Nvidia 1660Ti
AVG PPD 572000
Here to fight COVID-19
GPU-z has excellent monitors.
