Failed to get assignment
mrquokka
Post by mrquokka »
Hello!
I just started folding today and for a few hours it worked only on the cpu. Now it wont work even there, it just says that it failed to get an assignment. The log is here:
 *********************** Log Started 2020-03-14T17:33:29Z ***********************
17:33:29:************************* Folding@home Client *************************
17:33:29:        Website: https://foldingathome.org/
17:33:29:      Copyright: (c) 2009-2018 foldingathome.org
17:33:29:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:33:29:           Args: --open-web-control
17:33:29:         Config: C:\Users\armin\AppData\Roaming\FAHClient\config.xml
17:33:29:******************************** Build ********************************
17:33:29:        Version: 7.5.1
17:33:29:           Date: May 11 2018
17:33:29:           Time: 13:06:32
17:33:29:     Repository: Git
17:33:29:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
17:33:29:         Branch: master
17:33:29:       Compiler: Visual C++ 2008
17:33:29:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:33:29:       Platform: win32 10
17:33:29:           Bits: 32
17:33:29:           Mode: Release
17:33:29:******************************* System ********************************
17:33:29:            CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
17:33:29:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
17:33:29:           CPUs: 4
17:33:29:         Memory: 15.93GiB
17:33:29:    Free Memory: 9.94GiB
17:33:29:        Threads: WINDOWS_THREADS
17:33:29:     OS Version: 6.2
17:33:29:    Has Battery: false
17:33:29:     On Battery: false
17:33:29:     UTC Offset: 2
17:33:29:            PID: 9400
17:33:29:            CWD: C:\Users\armin\AppData\Roaming\FAHClient
17:33:29:             OS: Windows 10 Enterprise
17:33:29:        OS Arch: AMD64
17:33:29:           GPUs: 2
17:33:29:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
17:33:29:          GPU 1: Bus:7 Slot:0 Func:0 NVIDIA:3 GK104 [GeForce GTX 760] 2258
17:33:29:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.1
17:33:29:  CUDA Device 1: Platform:0 Device:1 Bus:7 Slot:0 Compute:3.0 Driver:10.1
17:33:29:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:432.0
17:33:29:OpenCL Device 1: Platform:0 Device:1 Bus:7 Slot:0 Compute:1.2 Driver:432.0
17:33:29:  Win32 Service: false
17:33:29:***********************************************************************
17:33:29:<config>
17:33:29:  <!-- Slot Control -->
17:33:29:  <power v='FULL'/>
17:33:29:
17:33:29:  <!-- User Information -->
17:33:29:  <user v='mrquokka'/>
17:33:29:
17:33:29:  <!-- Folding Slots -->
17:33:29:  <slot id='0' type='CPU'/>
17:33:29:  <slot id='1' type='GPU'/>
17:33:29:  <slot id='2' type='GPU'/>
17:33:29:</config>
17:33:29:Trying to access database...
17:33:29:Successfully acquired database lock
17:33:29:Enabled folding slot 00: READY cpu:2
17:33:29:Enabled folding slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463
17:33:29:Enabled folding slot 02: READY gpu:1:GK104 [GeForce GTX 760] 2258
17:33:29:ERROR:Exception: Failed to register systray icon: Unspecified error
17:33:29:WU00:FS00:Starting
17:33:29:WARNING:WU00:FS00:AS lowered CPUs from 2 to 1
17:33:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\armin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9400 -checkpoint 15 -np 1
17:33:29:WU00:FS00:Started FahCore on PID 11412
17:33:29:WU00:FS00:Core PID:14248
17:33:29:WU00:FS00:FahCore 0xa7 started
17:33:29:WU01:FS01:Connecting to 65.254.110.245:8080
17:33:29:WU02:FS02:Connecting to 65.254.110.245:8080
17:33:29:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T17:33:29Z ***********************
17:33:29:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:33:29:WU00:FS00:0xa7:       Type: 0xa7
17:33:29:WU00:FS00:0xa7:       Core: Gromacs
17:33:29:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 11412 -checkpoint 15 -np
17:33:29:WU00:FS00:0xa7:             1
17:33:29:WU00:FS00:0xa7:************************************ CBang *************************************
17:33:29:WU00:FS00:0xa7:       Date: Oct 26 2019
17:33:29:WU00:FS00:0xa7:       Time: 01:38:25
17:33:29:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:33:29:WU00:FS00:0xa7:     Branch: master
17:33:29:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:33:30:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:33:30:WU00:FS00:0xa7:   Platform: win32 10
17:33:30:WU00:FS00:0xa7:       Bits: 64
17:33:30:WU00:FS00:0xa7:       Mode: Release
17:33:30:WU00:FS00:0xa7:************************************ System ************************************
17:33:30:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
17:33:30:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
17:33:30:WU00:FS00:0xa7:       CPUs: 4
17:33:30:WU00:FS00:0xa7:     Memory: 15.93GiB
17:33:30:WU00:FS00:0xa7:Free Memory: 9.92GiB
17:33:30:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
17:33:30:WU00:FS00:0xa7: OS Version: 6.2
17:33:30:WU00:FS00:0xa7:Has Battery: false
17:33:30:WU00:FS00:0xa7: On Battery: false
17:33:30:WU00:FS00:0xa7: UTC Offset: 2
17:33:30:WU00:FS00:0xa7:        PID: 14248
17:33:30:WU00:FS00:0xa7:        CWD: C:\Users\armin\AppData\Roaming\FAHClient\work
17:33:30:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:33:30:WU00:FS00:0xa7:    Version: 0.0.18
17:33:30:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:33:30:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:33:30:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:33:30:WU00:FS00:0xa7:       Date: Oct 26 2019
17:33:30:WU00:FS00:0xa7:       Time: 01:52:30
17:33:30:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:33:30:WU00:FS00:0xa7:     Branch: master
17:33:30:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:33:30:WU00:FS00:0xa7:************************************ Build *************************************
17:33:30:WU00:FS00:0xa7:       SIMD: avx_256
17:33:30:WU00:FS00:0xa7:********************************************************************************
17:33:30:WU00:FS00:0xa7:Project: 14307 (Run 5, Clone 418, Gen 1)
17:33:30:WU00:FS00:0xa7:Unit: 0x000000019bf7a4d55e66c524808f1de5
17:33:30:WU00:FS00:0xa7:Digital signatures verified
17:33:30:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpi state.cpt -cpt 15 -nt 1
17:33:30:WU00:FS00:0xa7:ERROR:Guru Meditation #67ad47b8c78be1eb.778dc2536c066fb4 (1512.1550) '00/01/pullx.xvg'
17:33:30:WU00:FS00:0xa7:WARNING:Unexpected exit() call
17:33:30:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
17:33:30:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
17:33:30:WU00:FS00:0xa7:Saving result file frame1.trr
17:33:30:WU00:FS00:0xa7:Saving result file md.log
17:33:30:WU00:FS00:0xa7:Saving result file pullf.xvg
17:33:30:WU00:FS00:0xa7:ERROR:Guru Meditation #13bde74ae9fd81.a554734419d686b3 (796.814) '00/01/pullf.xvg'
17:33:30:WU02:FS02:Assigned to work server 155.247.166.220
17:33:30:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GK104 [GeForce GTX 760] 2258 from 155.247.166.220
17:33:30:WU01:FS01:Assigned to work server 155.247.166.220
17:33:30:WU02:FS02:Connecting to 155.247.166.220:8080
17:33:30:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 155.247.166.220
17:33:30:WU01:FS01:Connecting to 155.247.166.220:8080
17:33:31:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:33:31:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:33:31:WU02:FS02:Connecting to 65.254.110.245:8080
17:33:31:WU01:FS01:Connecting to 65.254.110.245:8080
17:33:31:WU02:FS02:Assigned to work server 155.247.166.220
17:33:31:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GK104 [GeForce GTX 760] 2258 from 155.247.166.220
17:33:31:WU02:FS02:Connecting to 155.247.166.220:8080
17:33:31:WU01:FS01:Assigned to work server 155.247.166.220
17:33:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 155.247.166.220
17:33:31:WU01:FS01:Connecting to 155.247.166.220:8080
17:33:32:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:33:32:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:33:32:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:33:32:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
17:33:32:WU00:FS00:Starting
17:33:32:WARNING:WU00:FS00:AS lowered CPUs from 2 to 1
17:33:32:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\armin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9400 -checkpoint 15 -np 1
17:33:32:WU00:FS00:Started FahCore on PID 6400
17:33:32:WU00:FS00:Core PID:9076
17:33:32:WU00:FS00:FahCore 0xa7 started
17:33:33:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T17:33:32Z ***********************
17:33:33:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:33:33:WU00:FS00:0xa7:       Type: 0xa7
17:33:33:WU00:FS00:0xa7:       Core: Gromacs
17:33:33:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 6400 -checkpoint 15 -np 1
17:33:33:WU00:FS00:0xa7:************************************ CBang *************************************
17:33:33:WU00:FS00:0xa7:       Date: Oct 26 2019
17:33:33:WU00:FS00:0xa7:       Time: 01:38:25
17:33:33:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:33:33:WU00:FS00:0xa7:     Branch: master
17:33:33:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:33:33:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:33:33:WU00:FS00:0xa7:   Platform: win32 10
17:33:33:WU00:FS00:0xa7:       Bits: 64
17:33:33:WU00:FS00:0xa7:       Mode: Release
17:33:33:WU00:FS00:0xa7:************************************ System ************************************
17:33:33:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
17:33:33:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
17:33:33:WU00:FS00:0xa7:       CPUs: 4
17:33:33:WU00:FS00:0xa7:     Memory: 15.93GiB
17:33:33:WU00:FS00:0xa7:Free Memory: 9.73GiB
17:33:33:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
17:33:33:WU00:FS00:0xa7: OS Version: 6.2
17:33:33:WU00:FS00:0xa7:Has Battery: false
17:33:33:WU00:FS00:0xa7: On Battery: false
17:33:33:WU00:FS00:0xa7: UTC Offset: 2
17:33:33:WU00:FS00:0xa7:        PID: 9076
17:33:33:WU00:FS00:0xa7:        CWD: C:\Users\armin\AppData\Roaming\FAHClient\work
17:33:33:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:33:33:WU00:FS00:0xa7:    Version: 0.0.18
17:33:33:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:33:33:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:33:33:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:33:33:WU00:FS00:0xa7:       Time: 01:52:30
17:33:33:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:33:33:WU00:FS00:0xa7:************************************ Build *************************************
17:33:33:WU00:FS00:0xa7:       SIMD: avx_256
17:33:33:WU00:FS00:0xa7:********************************************************************************
17:33:33:WU00:FS00:0xa7:Project: 14307 (Run 5, Clone 418, Gen 1)
17:33:33:WU00:FS00:0xa7:Unit: 0x000000019bf7a4d55e66c524808f1de5
17:33:33:WU00:FS00:0xa7:Digital signatures verified
17:33:33:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpi state.cpt -cpt 15 -nt 1
17:33:33:WU00:FS00:0xa7:ERROR:Guru Meditation #67ad47b8c78be1eb.778dc2536c066fb4 (1512.1550) '00/01/pullx.xvg'
17:33:33:WU00:FS00:0xa7:WARNING:Unexpected exit() call
17:33:33:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
17:33:33:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
17:33:33:WU00:FS00:0xa7:Saving result file frame1.trr
17:33:33:WU00:FS00:0xa7:Saving result file md.log
17:33:33:WU00:FS00:0xa7:Saving result file pullf.xvg
17:33:33:WU00:FS00:0xa7:ERROR:Guru Meditation #13bde74ae9fd81.a554734419d686b3 (796.814) '00/01/pullf.xvg'
17:33:34:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:33:34:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
17:34:31:WU01:FS01:Connecting to 65.254.110.245:8080
17:34:31:WU02:FS02:Connecting to 65.254.110.245:8080
17:34:31:WU01:FS01:Assigned to work server 155.247.166.220
17:34:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 155.247.166.220
17:34:31:WU01:FS01:Connecting to 155.247.166.220:8080
17:34:32:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:34:32:WU02:FS02:Assigned to work server 155.247.166.220
17:34:32:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GK104 [GeForce GTX 760] 2258 from 155.247.166.220
17:34:32:WU02:FS02:Connecting to 155.247.166.220:8080
17:34:32:WU00:FS00:Starting
17:34:32:WARNING:WU00:FS00:AS lowered CPUs from 2 to 1
17:34:32:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\armin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9400 -checkpoint 15 -np 1
17:34:32:WU00:FS00:Started FahCore on PID 10980
17:34:32:WU00:FS00:Core PID:9428
17:34:32:WU00:FS00:FahCore 0xa7 started
17:34:32:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:34:33:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T17:34:32Z ***********************
17:34:33:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:34:33:WU00:FS00:0xa7:       Type: 0xa7
17:34:33:WU00:FS00:0xa7:       Core: Gromacs
17:34:33:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 10980 -checkpoint 15 -np
17:34:33:WU00:FS00:0xa7:             1
17:34:33:WU00:FS00:0xa7:************************************ CBang *************************************
17:34:33:WU00:FS00:0xa7:       Date: Oct 26 2019
17:34:33:WU00:FS00:0xa7:       Time: 01:38:25
17:34:33:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:34:33:WU00:FS00:0xa7:     Branch: master
17:34:33:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:34:33:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:34:33:WU00:FS00:0xa7:   Platform: win32 10
17:34:33:WU00:FS00:0xa7:       Bits: 64
17:34:33:WU00:FS00:0xa7:       Mode: Release
17:34:33:WU00:FS00:0xa7:************************************ System ************************************
17:34:33:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
17:34:33:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
17:34:33:WU00:FS00:0xa7:       CPUs: 4
17:34:33:WU00:FS00:0xa7:     Memory: 15.93GiB
17:34:33:WU00:FS00:0xa7:Free Memory: 9.79GiB
17:34:33:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
17:34:33:WU00:FS00:0xa7: OS Version: 6.2
17:34:33:WU00:FS00:0xa7:Has Battery: false
17:34:33:WU00:FS00:0xa7: On Battery: false
17:34:33:WU00:FS00:0xa7: UTC Offset: 2
17:34:33:WU00:FS00:0xa7:        PID: 9428
17:34:33:WU00:FS00:0xa7:        CWD: C:\Users\armin\AppData\Roaming\FAHClient\work
17:34:33:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:34:33:WU00:FS00:0xa7:    Version: 0.0.18
17:34:33:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:34:33:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:34:33:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:34:33:WU00:FS00:0xa7:       Time: 01:52:30
17:34:33:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:34:33:WU00:FS00:0xa7:************************************ Build *************************************
17:34:33:WU00:FS00:0xa7:       SIMD: avx_256
17:34:33:WU00:FS00:0xa7:********************************************************************************
17:34:33:WU00:FS00:0xa7:Project: 14307 (Run 5, Clone 418, Gen 1)
17:34:33:WU00:FS00:0xa7:Unit: 0x000000019bf7a4d55e66c524808f1de5
17:34:33:WU00:FS00:0xa7:Digital signatures verified
17:34:33:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpi state.cpt -cpt 15 -nt 1
17:34:33:WU00:FS00:0xa7:ERROR:Guru Meditation #67ad47b8c78be1eb.778dc2536c066fb4 (1512.1550) '00/01/pullx.xvg'
17:34:33:WU00:FS00:0xa7:WARNING:Unexpected exit() call
17:34:33:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
17:34:33:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
17:34:33:WU00:FS00:0xa7:Saving result file frame1.trr
17:34:33:WU00:FS00:0xa7:Saving result file md.log
17:34:33:WU00:FS00:0xa7:Saving result file pullf.xvg
17:34:33:WU00:FS00:0xa7:ERROR:Guru Meditation #13bde74ae9fd81.a554734419d686b3 (796.814) '00/01/pullf.xvg'
17:34:34:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:34:34:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
17:35:32:WU00:FS00:Starting
17:35:32:WARNING:WU00:FS00:AS lowered CPUs from 2 to 1
17:35:32:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\armin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9400 -checkpoint 15 -np 1
17:35:32:WU00:FS00:Started FahCore on PID 7324
17:35:32:WU00:FS00:Core PID:7376
17:35:32:WU00:FS00:FahCore 0xa7 started
17:35:33:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T17:35:32Z ***********************
17:35:33:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:35:33:WU00:FS00:0xa7:       Type: 0xa7
17:35:33:WU00:FS00:0xa7:       Core: Gromacs
17:35:33:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 7324 -checkpoint 15 -np 1
17:35:33:WU00:FS00:0xa7:************************************ CBang *************************************
17:35:33:WU00:FS00:0xa7:       Date: Oct 26 2019
17:35:33:WU00:FS00:0xa7:       Time: 01:38:25
17:35:33:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:35:33:WU00:FS00:0xa7:     Branch: master
17:35:33:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:35:33:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:35:33:WU00:FS00:0xa7:   Platform: win32 10
17:35:33:WU00:FS00:0xa7:       Bits: 64
17:35:33:WU00:FS00:0xa7:       Mode: Release
17:35:33:WU00:FS00:0xa7:************************************ System ************************************
17:35:33:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
17:35:33:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
17:35:33:WU00:FS00:0xa7:       CPUs: 4
17:35:33:WU00:FS00:0xa7:     Memory: 15.93GiB
17:35:33:WU00:FS00:0xa7:Free Memory: 9.70GiB
17:35:33:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
17:35:33:WU00:FS00:0xa7: OS Version: 6.2
17:35:33:WU00:FS00:0xa7:Has Battery: false
17:35:33:WU00:FS00:0xa7: On Battery: false
17:35:33:WU00:FS00:0xa7: UTC Offset: 2
17:35:33:WU00:FS00:0xa7:        PID: 7376
17:35:33:WU00:FS00:0xa7:        CWD: C:\Users\armin\AppData\Roaming\FAHClient\work
17:35:33:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:35:33:WU00:FS00:0xa7:    Version: 0.0.18
17:35:33:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:35:33:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:35:33:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:35:33:WU00:FS00:0xa7:       Time: 01:52:30
17:35:33:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:35:33:WU00:FS00:0xa7:************************************ Build *************************************
17:35:33:WU00:FS00:0xa7:       SIMD: avx_256
17:35:33:WU00:FS00:0xa7:********************************************************************************
17:35:33:WU00:FS00:0xa7:Project: 14307 (Run 5, Clone 418, Gen 1)
17:35:33:WU00:FS00:0xa7:Unit: 0x000000019bf7a4d55e66c524808f1de5
17:35:33:WU00:FS00:0xa7:Digital signatures verified
17:35:33:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpi state.cpt -cpt 15 -nt 1
17:35:33:WU00:FS00:0xa7:ERROR:Guru Meditation #67ad47b8c78be1eb.778dc2536c066fb4 (1512.1550) '00/01/pullx.xvg'
17:35:33:WU00:FS00:0xa7:WARNING:Unexpected exit() call
17:35:33:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
17:35:33:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
17:35:33:WU00:FS00:0xa7:Saving result file frame1.trr
17:35:33:WU00:FS00:0xa7:Saving result file md.log
17:35:33:WU00:FS00:0xa7:Saving result file pullf.xvg
17:35:33:WU00:FS00:0xa7:ERROR:Guru Meditation #13bde74ae9fd81.a554734419d686b3 (796.814) '00/01/pullf.xvg'
17:35:34:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:35:34:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
17:36:08:WU01:FS01:Connecting to 65.254.110.245:8080
17:36:08:WU02:FS02:Connecting to 65.254.110.245:8080
17:36:08:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:36:08:WU01:FS01:Connecting to 18.218.241.186:80
17:36:09:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:36:09:WU02:FS02:Connecting to 18.218.241.186:80
17:36:09:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:36:09:ERROR:WU01:FS01:Exception: Could not get an assignment
17:36:09:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:36:09:ERROR:WU02:FS02:Exception: Could not get an assignment
17:36:33:WU00:FS00:Starting
17:36:33:WARNING:WU00:FS00:AS lowered CPUs from 2 to 1
17:36:33:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\armin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9400 -checkpoint 15 -np 1
17:36:33:WU00:FS00:Started FahCore on PID 11328
17:36:33:WU00:FS00:Core PID:14988
17:36:33:WU00:FS00:FahCore 0xa7 started
17:36:33:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T17:36:33Z ***********************
17:36:33:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:36:33:WU00:FS00:0xa7:       Type: 0xa7
17:36:33:WU00:FS00:0xa7:       Core: Gromacs
17:36:33:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 11328 -checkpoint 15 -np
17:36:33:WU00:FS00:0xa7:             1
17:36:33:WU00:FS00:0xa7:************************************ CBang *************************************
17:36:33:WU00:FS00:0xa7:       Date: Oct 26 2019
17:36:33:WU00:FS00:0xa7:       Time: 01:38:25
17:36:33:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:36:33:WU00:FS00:0xa7:     Branch: master
17:36:33:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:36:33:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:36:33:WU00:FS00:0xa7:   Platform: win32 10
17:36:33:WU00:FS00:0xa7:       Bits: 64
17:36:33:WU00:FS00:0xa7:       Mode: Release
17:36:33:WU00:FS00:0xa7:************************************ System ************************************
17:36:33:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
17:36:33:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
17:36:33:WU00:FS00:0xa7:       CPUs: 4
17:36:33:WU00:FS00:0xa7:     Memory: 15.93GiB
17:36:33:WU00:FS00:0xa7:Free Memory: 9.60GiB
17:36:33:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
17:36:33:WU00:FS00:0xa7: OS Version: 6.2
17:36:33:WU00:FS00:0xa7:Has Battery: false
17:36:33:WU00:FS00:0xa7: On Battery: false
17:36:33:WU00:FS00:0xa7: UTC Offset: 2
17:36:33:WU00:FS00:0xa7:        PID: 14988
17:36:33:WU00:FS00:0xa7:        CWD: C:\Users\armin\AppData\Roaming\FAHClient\work
17:36:33:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:36:33:WU00:FS00:0xa7:    Version: 0.0.18
17:36:33:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:36:33:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:36:33:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:36:33:WU00:FS00:0xa7:       Time: 01:52:30
17:36:33:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:36:33:WU00:FS00:0xa7:************************************ Build *************************************
17:36:33:WU00:FS00:0xa7:       SIMD: avx_256
17:36:33:WU00:FS00:0xa7:********************************************************************************
17:36:33:WU00:FS00:0xa7:Project: 14307 (Run 5, Clone 418, Gen 1)
17:36:33:WU00:FS00:0xa7:Unit: 0x000000019bf7a4d55e66c524808f1de5
17:36:33:WU00:FS00:0xa7:Digital signatures verified
17:36:33:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpi state.cpt -cpt 15 -nt 1
17:36:33:WU00:FS00:0xa7:ERROR:Guru Meditation #67ad47b8c78be1eb.778dc2536c066fb4 (1512.1550) '00/01/pullx.xvg'
17:36:33:WU00:FS00:0xa7:WARNING:Unexpected exit() call
17:36:33:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
17:36:33:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
17:36:33:WU00:FS00:0xa7:Saving result file frame1.trr
17:36:33:WU00:FS00:0xa7:Saving result file md.log
17:36:33:WU00:FS00:0xa7:Saving result file pullf.xvg
17:36:33:WU00:FS00:0xa7:ERROR:Guru Meditation #13bde74ae9fd81.a554734419d686b3 (796.814) '00/01/pullf.xvg'
17:36:34:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:36:34:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
17:36:34:WARNING:WU00:FS00:Too many errors, failing
17:36:34:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:14307 run:5 clone:418 gen:1 core:0xa7 unit:0x000000019bf7a4d55e66c524808f1de5
17:36:34:WU00:FS00:Uploading 1.18MiB to 155.247.164.213
17:36:34:WU00:FS00:Connecting to 155.247.164.213:8080
17:36:35:WU03:FS00:Connecting to 65.254.110.245:8080
17:36:35:WU00:FS00:Upload complete
17:36:35:WU00:FS00:Server responded WORK_QUIT (404)
17:36:35:WARNING:WU00:FS00:Server did not like results, dumping
17:36:35:WU00:FS00:Cleaning up
17:36:36:WARNING:WU03:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:36:36:WU03:FS00:Connecting to 18.218.241.186:80
17:36:36:WU03:FS00:Assigned to work server 155.247.164.213
17:36:36:WU03:FS00:Requesting new work unit for slot 00: READY cpu:2 from 155.247.164.213
17:36:36:WU03:FS00:Connecting to 155.247.164.213:8080
17:36:36:ERROR:WU03:FS00:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:36:36:WU03:FS00:Connecting to 65.254.110.245:8080
17:36:37:WARNING:WU03:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:36:37:WU03:FS00:Connecting to 18.218.241.186:80
17:36:37:WU03:FS00:Assigned to work server 155.247.164.213
17:36:37:WU03:FS00:Requesting new work unit for slot 00: READY cpu:2 from 155.247.164.213
17:36:37:WU03:FS00:Connecting to 155.247.164.213:8080
17:36:38:WU03:FS00:Downloading 1.24MiB
17:36:39:WU03:FS00:Download complete
17:36:39:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:14303 run:3 clone:312 gen:6 core:0xa7 unit:0x000000079bf7a4d55e66cc664b933feb
17:36:39:WU03:FS00:Starting
17:36:39:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\armin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 705 -lifeline 9400 -checkpoint 15 -np 2
17:36:39:WU03:FS00:Started FahCore on PID 14460
17:36:39:WU03:FS00:Core PID:14716
17:36:39:WU03:FS00:FahCore 0xa7 started
17:36:39:WU03:FS00:0xa7:*********************** Log Started 2020-03-14T17:36:39Z ***********************
17:36:39:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:36:39:WU03:FS00:0xa7:       Type: 0xa7
17:36:39:WU03:FS00:0xa7:       Core: Gromacs
17:36:39:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 705 -lifeline 14460 -checkpoint 15 -np
17:36:39:WU03:FS00:0xa7:             2
17:36:39:WU03:FS00:0xa7:************************************ CBang *************************************
17:36:39:WU03:FS00:0xa7:       Date: Oct 26 2019
17:36:39:WU03:FS00:0xa7:       Time: 01:38:25
17:36:39:WU03:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:36:39:WU03:FS00:0xa7:     Branch: master
17:36:39:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
17:36:39:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:36:39:WU03:FS00:0xa7:   Platform: win32 10
17:36:39:WU03:FS00:0xa7:       Bits: 64
17:36:39:WU03:FS00:0xa7:       Mode: Release
17:36:39:WU03:FS00:0xa7:************************************ System ************************************
17:36:39:WU03:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
17:36:39:WU03:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
17:36:39:WU03:FS00:0xa7:       CPUs: 4
17:36:39:WU03:FS00:0xa7:     Memory: 15.93GiB
17:36:39:WU03:FS00:0xa7:Free Memory: 9.78GiB
17:36:39:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
17:36:39:WU03:FS00:0xa7: OS Version: 6.2
17:36:39:WU03:FS00:0xa7:Has Battery: false
17:36:39:WU03:FS00:0xa7: On Battery: false
17:36:39:WU03:FS00:0xa7: UTC Offset: 2
17:36:39:WU03:FS00:0xa7:        PID: 14716
17:36:39:WU03:FS00:0xa7:        CWD: C:\Users\armin\AppData\Roaming\FAHClient\work
17:36:39:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
17:36:39:WU03:FS00:0xa7:    Version: 0.0.18
17:36:39:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:36:39:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:36:39:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
17:36:39:WU03:FS00:0xa7:       Time: 01:52:30
17:36:39:WU03:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:36:39:WU03:FS00:0xa7:************************************ Build *************************************
17:36:39:WU03:FS00:0xa7:       SIMD: avx_256
17:36:39:WU03:FS00:0xa7:********************************************************************************
17:36:39:WU03:FS00:0xa7:Project: 14303 (Run 3, Clone 312, Gen 6)
17:36:39:WU03:FS00:0xa7:Unit: 0x000000079bf7a4d55e66cc664b933feb
17:36:39:WU03:FS00:0xa7:Reading tar file core.xml
17:36:39:WU03:FS00:0xa7:Reading tar file frame6.tpr
17:36:39:WU03:FS00:0xa7:Digital signatures verified
17:36:39:WU03:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpt 15 -nt 2
17:36:40:WU03:FS00:0xa7:Steps: first=3000000 total=500000
17:36:40:WU03:FS00:0xa7:Completed 1 out of 500000 steps (0%)
17:38:41:WU03:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
17:38:45:WU01:FS01:Connecting to 65.254.110.245:8080
17:38:45:WU02:FS02:Connecting to 65.254.110.245:8080
17:38:46:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:38:46:WU01:FS01:Connecting to 18.218.241.186:80
17:38:46:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:38:46:WU02:FS02:Connecting to 18.218.241.186:80
17:38:46:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:38:46:ERROR:WU01:FS01:Exception: Could not get an assignment
17:38:46:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:38:46:ERROR:WU02:FS02:Exception: Could not get an assignment
17:40:53:WU03:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
17:42:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:42:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:42:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:42:59:WU01:FS01:Connecting to 65.254.110.245:8080
17:43:00:WU02:FS02:Connecting to 65.254.110.245:8080
17:43:00:WU01:FS01:Assigned to work server 155.247.166.220
17:43:00:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 155.247.166.220
17:43:00:WU01:FS01:Connecting to 155.247.166.220:8080
17:43:00:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:43:00:WU02:FS02:Assigned to work server 155.247.166.220
17:43:00:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GK104 [GeForce GTX 760] 2258 from 155.247.166.220
17:43:00:WU02:FS02:Connecting to 155.247.166.220:8080
17:43:00:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:43:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:43:12:WU03:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
17:45:24:WU03:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
17:47:36:WU03:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
17:49:50:WU03:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
17:49:51:WU01:FS01:Connecting to 65.254.110.245:8080
17:49:51:WU02:FS02:Connecting to 65.254.110.245:8080
17:49:51:WU01:FS01:Assigned to work server 155.247.166.220
17:49:51:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 155.247.166.220
17:49:51:WU01:FS01:Connecting to 155.247.166.220:8080
17:49:51:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:49:52:WU02:FS02:Assigned to work server 155.247.166.220
17:49:52:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GK104 [GeForce GTX 760] 2258 from 155.247.166.220
17:49:52:WU02:FS02:Connecting to 155.247.166.220:8080
17:49:52:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:52:05:WU03:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
17:54:19:WU03:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
17:56:26:WU03:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
17:58:35:WU03:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
18:00:46:WU03:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
18:00:56:WU01:FS01:Connecting to 65.254.110.245:8080
18:00:56:WU02:FS02:Connecting to 65.254.110.245:8080
18:00:57:WU01:FS01:Assigned to work server 155.247.166.220
18:00:57:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 155.247.166.220
18:00:57:WU01:FS01:Connecting to 155.247.166.220:8080
18:00:57:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
18:00:58:WU02:FS02:Assigned to work server 155.247.166.220
18:00:58:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GK104 [GeForce GTX 760] 2258 from 155.247.166.220
18:00:58:WU02:FS02:Connecting to 155.247.166.220:8080
18:00:58:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
18:02:58:WU03:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
18:05:11:WU03:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
18:07:24:WU03:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
18:09:35:WU03:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
18:11:56:WU03:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
18:14:17:WU03:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
18:16:36:WU03:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
18:18:53:WU01:FS01:Connecting to 65.254.110.245:8080
18:18:53:WU02:FS02:Connecting to 65.254.110.245:8080
18:18:53:WU01:FS01:Assigned to work server 155.247.166.220
18:18:53:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 155.247.166.220
18:18:53:WU01:FS01:Connecting to 155.247.166.220:8080
18:18:54:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
18:18:54:WU02:FS02:Assigned to work server 155.247.166.220
18:18:54:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GK104 [GeForce GTX 760] 2258 from 155.247.166.220
18:18:54:WU02:FS02:Connecting to 155.247.166.220:8080
18:18:54:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
18:18:54:WU03:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
18:21:12:WU03:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
18:23:30:WU03:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
18:25:47:WU03:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
18:28:03:WU03:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
18:30:13:WU03:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
18:32:23:WU03:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
18:34:33:WU03:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
18:36:44:WU03:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
18:38:55:WU03:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
18:41:06:WU03:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
18:43:18:WU03:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
18:45:29:WU03:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
18:47:40:WU03:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
18:47:55:WU01:FS01:Connecting to 65.254.110.245:8080
18:47:55:WU02:FS02:Connecting to 65.254.110.245:8080
18:47:56:WU01:FS01:Assigned to work server 155.247.166.220
18:47:56:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 155.247.166.220
18:47:56:WU01:FS01:Connecting to 155.247.166.220:8080
18:47:56:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
18:47:56:WU02:FS02:Assigned to work server 155.247.166.220
18:47:56:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GK104 [GeForce GTX 760] 2258 from 155.247.166.220
18:47:56:WU02:FS02:Connecting to 155.247.166.220:8080
18:47:57:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
18:49:51:WU03:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
18:52:01:WU03:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
18:54:11:WU03:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
18:56:20:WU03:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
18:58:29:WU03:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
19:00:40:WU03:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
19:02:49:WU03:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
19:04:59:WU03:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
19:07:08:WU03:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
19:09:17:WU03:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
19:11:26:WU03:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
19:13:35:WU03:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
19:15:44:WU03:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
19:17:53:WU03:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
19:20:02:WU03:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
19:22:12:WU03:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
19:24:21:WU03:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
19:26:29:WU03:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
19:28:38:WU03:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
19:30:47:WU03:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
19:32:56:WU03:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
19:34:54:WU01:FS01:Connecting to 65.254.110.245:8080
19:34:54:WU02:FS02:Connecting to 65.254.110.245:8080
19:34:55:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:34:55:WU01:FS01:Connecting to 18.218.241.186:80
19:34:55:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:34:55:WU02:FS02:Connecting to 18.218.241.186:80
19:34:55:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:34:55:ERROR:WU01:FS01:Exception: Could not get an assignment
19:34:55:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:34:55:ERROR:WU02:FS02:Exception: Could not get an assignment
19:35:04:WU03:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
19:37:13:WU03:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
19:39:22:WU03:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
19:41:30:WU03:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
19:43:38:WU03:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
19:45:46:WU03:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
19:47:55:WU03:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
19:50:02:WU03:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
19:52:11:WU03:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
19:54:20:WU03:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
19:56:28:WU03:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
19:58:36:WU03:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
20:00:45:WU03:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
20:02:54:WU03:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
20:05:03:WU03:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
20:07:13:WU03:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
20:09:21:WU03:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
20:11:30:WU03:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
20:13:39:WU03:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
20:15:48:WU03:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
20:17:58:WU03:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
20:20:08:WU03:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
20:22:19:WU03:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
20:24:28:WU03:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
20:26:37:WU03:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
20:28:46:WU03:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
20:30:56:WU03:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
20:33:05:WU03:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
20:35:15:WU03:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
20:37:24:WU03:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
20:39:35:WU03:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
20:41:45:WU03:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
20:43:55:WU03:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
20:46:04:WU03:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
20:48:13:WU03:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
20:50:22:WU03:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
20:50:55:WU01:FS01:Connecting to 65.254.110.245:8080
20:50:55:WU02:FS02:Connecting to 65.254.110.245:8080
20:50:56:WU01:FS01:Assigned to work server 155.247.166.220
20:50:56:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 155.247.166.220
20:50:56:WU01:FS01:Connecting to 155.247.166.220:8080
20:50:56:WU02:FS02:Assigned to work server 155.247.166.220
20:50:56:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GK104 [GeForce GTX 760] 2258 from 155.247.166.220
20:50:56:WU02:FS02:Connecting to 155.247.166.220:8080
20:50:56:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
20:50:56:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
20:52:31:WU03:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
20:54:41:WU03:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
20:56:50:WU03:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
20:59:00:WU03:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
21:01:09:WU03:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
21:03:18:WU03:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
21:05:28:WU03:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
21:07:38:WU03:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
21:09:48:WU03:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
21:11:57:WU03:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
21:11:58:WU00:FS00:Connecting to 65.254.110.245:8080
21:11:58:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:11:58:WU00:FS00:Connecting to 18.218.241.186:80
21:11:59:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:11:59:ERROR:WU00:FS00:Exception: Could not get an assignment
21:11:59:WU00:FS00:Connecting to 65.254.110.245:8080
21:11:59:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:11:59:WU00:FS00:Connecting to 18.218.241.186:80
21:12:00:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:12:00:ERROR:WU00:FS00:Exception: Could not get an assignment
21:12:59:WU00:FS00:Connecting to 65.254.110.245:8080
21:13:00:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:13:00:WU00:FS00:Connecting to 18.218.241.186:80
21:13:00:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:13:00:ERROR:WU00:FS00:Exception: Could not get an assignment
21:14:08:WU03:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
21:14:08:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
21:14:09:WU03:FS00:0xa7:Saving result file frame6.trr
21:14:09:WU03:FS00:0xa7:Saving result file md.log
21:14:09:WU03:FS00:0xa7:Saving result file pullf.xvg
21:14:09:WU03:FS00:0xa7:Saving result file pullx.xvg
21:14:09:WU03:FS00:0xa7:Saving result file science.log
21:14:09:WU03:FS00:0xa7:Saving result file traj_comp.xtc
21:14:09:WU03:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
21:14:09:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:14:09:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:14303 run:3 clone:312 gen:6 core:0xa7 unit:0x000000079bf7a4d55e66cc664b933feb
21:14:09:WU03:FS00:Uploading 3.20MiB to 155.247.164.213
21:14:09:WU03:FS00:Connecting to 155.247.164.213:8080
21:14:10:WU03:FS00:Upload complete
21:14:10:WU03:FS00:Server responded WORK_ACK (400)
21:14:10:WU03:FS00:Final credit estimate, 1133.00 points
21:14:10:WU03:FS00:Cleaning up
21:14:36:WU00:FS00:Connecting to 65.254.110.245:8080
21:14:37:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:14:37:WU00:FS00:Connecting to 18.218.241.186:80
21:14:37:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:14:37:ERROR:WU00:FS00:Exception: Could not get an assignment
21:17:14:WU00:FS00:Connecting to 65.254.110.245:8080
21:17:14:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:17:14:WU00:FS00:Connecting to 18.218.241.186:80
21:17:14:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:17:14:ERROR:WU00:FS00:Exception: Could not get an assignment
21:21:28:WU00:FS00:Connecting to 65.254.110.245:8080
21:21:29:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:21:29:WU00:FS00:Connecting to 18.218.241.186:80
21:21:29:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:21:29:ERROR:WU00:FS00:Exception: Could not get an assignment
21:28:19:WU00:FS00:Connecting to 65.254.110.245:8080
21:28:20:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:28:20:WU00:FS00:Connecting to 18.218.241.186:80
21:28:20:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:28:20:ERROR:WU00:FS00:Exception: Could not get an assignment
21:39:25:WU00:FS00:Connecting to 65.254.110.245:8080
21:39:25:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:39:25:WU00:FS00:Connecting to 18.218.241.186:80
21:39:26:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:39:26:ERROR:WU00:FS00:Exception: Could not get an assignment
21:57:21:WU00:FS00:Connecting to 65.254.110.245:8080
21:57:22:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:57:22:WU00:FS00:Connecting to 18.218.241.186:80
21:57:22:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:57:22:ERROR:WU00:FS00:Exception: Could not get an assignment
22:12:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
22:12:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
Im currently managing it through teamviewer so i hope the solution will be easy...
Thank you!
...mrquokka...
Re: Failed to get assignment
See announcement : Temporary server outages
KjartanD
Post by KjartanD »
Is this lack of WU on the servers the cuase for this? Haven't got a WU for hours now for the CPU, but the GPU get's WU right away.
00:15:57:WU01:FS00:Connecting to 65.254.110.245:8080
00:15:58:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
00:15:58:WU01:FS00:Connecting to 18.218.241.186:80
00:15:58:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:15:58:ERROR:WU01:FS00:Exception: Could not get an assignment
HyggeJJ
Post by HyggeJJ »
I have the same issue.
My GPU gets WU's, but my CPU is just waiting and waiting and waiting.. It has been like that for more than 4 hours, and I saw the same issue yesterday?!
16:25:51:WU00:FS00:Connecting to 65.254.110.245:8080
16:25:51:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:25:51:WU00:FS00:Connecting to 18.218.241.186:80
16:25:52:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:25:52:ERROR:WU00:FS00:Exception: Could not get an assignment16:32:42:WU00:FS00:Connecting to 65.254.110.245:8080
16:32:42:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:32:42:WU00:FS00:Connecting to 18.218.241.186:80
16:32:43:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:32:43:ERROR:WU00:FS00:Exception: Could not get an assignment16:43:47:WU00:FS00:Connecting to 65.254.110.245:8080
16:43:48:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:43:48:WU00:FS00:Connecting to 18.218.241.186:80
16:43:48:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:43:48:ERROR:WU00:FS00:Exception: Could not get an assignment
HyggeJJ
Post by HyggeJJ »
And, now my CPU suddenly got a nice little assignment.. Strange behaviour :-)
As Bruce posted recently, Things are getting better! And with the large number of requests still versus the number that can be assigned at once, it is still a bit of the luck of the draw when ou connect with a request.
HyggeJJ
Post by HyggeJJ »
Hmm.. Yes, well... I have not gotten any WS assignments for neither my CPU (3950x) nor GPU (1080ti) today (9 hours of online time).
Instead of mining I wanted to dedicate my power to the COVID-19 projects, but having my system just idling an entire day does not make sense.
RelicZombie
Post by RelicZombie »
Are there any News about this Topic? I've set up 4 Servers for folding, none of them is recieving any WUs. The CPUs try to vonnext to WU Server 18.218.241.186 and 65.254.110.245. The first one is not in the Server Stats oft the Folding team
(https://apps.foldingathome.org/serverstats)
, the second one has zero Public Jobs available. But according to the Stats, other servers do. Is there Any way to request WUs from a different Server?
My GPUs recieve WUs just fine.
The first IP number is the "real" one for the AWS hosting of the AS listed as assign2. Both AS handle requests to get your system connected to one of the WS machines which have the actual jos to download to you. The number lied for available jobs on an AS are dynamic, and based on status reports the various WS machines send them. The number can be zero right after a restart until the AS collects status reports and starts making assignments.
More CPU WUs are in progress and should be showing up soon. But you getting GPU work and not CPU work is just opposite of some reporting getting CPU work and waiting to get GPU work. Everyone is waiting at some point.
saad3000
Post by saad3000 »
same here:
13:20:43:WU00:FS00:Connecting to 65.254.110.245:8080
13:20:43:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': Empty work server assignment
13:20:43:WU00:FS00:Connecting to 18.218.241.186:80
13:20:44:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': Empty work server assignment
13:20:44:ERROR:WU00:FS00:Exception: Could not get an assignment
