So I have a few questions with this program
1. Is there a way to cancel your current project without waiting to have the time to expire?
2. Is the mail system down because I didn't get a email for my passphase?
3. Are you able to combine multiple systems to do the same project to speed up the progress?
Is there a way?
Re: Is there a way?
1. Yes, but since cherrypicking is not allowed on the project, I won't explain how to do so without a good technical reason.
2. Maybe, with all the new members arriving on the project ... there are also some issue with certain domains. Which one did you use ?
3. This is already how FAH works. Each WUs you get are part of bigger problem. If you meant combining multiple system into a single account, yes, you can use the same account (User ID, Team Number, passkey) on as much system as you want.
TheawesomeMCB
Re: Is there a way?
1. The reason I want to stop it is because I just want to stop doing it so it doesn't have to wait for me to just not finish it. I'm going to be doing this on another computer and I just don't want it sitting there not getting any progress done when someone else could be doing the simulation sooner without my computer having to wait for the time to expire. I don't want to cherry pick I just want to help get the simulation done sooner to help with research.
2. https://apps.foldingathome.org/getpasskey
3. Ah okay thanks!
3. Ah okay thanks!
