Getting FAH running on Manjaro
FAH provides a V7 client installer for Debian / Mint / Ubuntu / RedHat / CentOS / Fedora. Installation on other distros may or may not be easy but if you can offer help to others, they would appreciate it.
ashtons
Post by ashtons »
I installed the client, control, and viewer packages from the AUR. The FAHControl package works, but I can't figure out how to start FAHClient. I would have thought typing in
fahclient
into my terminal would start it, but it was an unrecognized command, even after I restarted my computer.
Any tips?
v00d00
Hardware configuration: FX8320e (6 cores enabled) @ stock,
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Ran Seti@Home prior to that.
Re: Getting FAH running on Manjaro
Post by v00d00 »
As I remember, you need to configure it from FAHControl, then start it from there. While you can start it directly, it isnt beginner level and it requires some console knowledge, not to mention some knowledge of scripts and nowadays systemd.
So as taken from here: https://foldingathome.org/support/faq/i ... -advanced/
Open FAHControl, enter user information, then unpause the client. Manage, monitor and update settings as needed.
try that and report back.
Asgaroth
Post by Asgaroth »
Have a look here, this is to configure it on Arch linux (Manjaro is a spin off of arch, so it should work for you)
There are two major products that came out of Berkeley: LSD and UNIX. We don't believe this to be a coincidence.
-- Jeremy S. Anderson
voqelfrei
Post by voqelfrei »
If you installed fahclient from the aur, you need to start fahclient with systemd ( sudo systemctl start fahclient ).
stdcerr
Post by stdcerr »
see https://wiki.archlinux.org/index.php/Folding@home.
AFter I installed it from https://aur.archlinux.org/packages/foldingathome/, I was able to start it using
FAHClient
- see if that helps
pcwolf
Hardware configuration: Manjaro Linux - AsRock B550 Taichi - Ryzen 5950X - NVidia RTX 4070ti
FAH v8-4.3
Post by pcwolf »
The key is to *enable* the foldingathome.service with systemd to start Folding at boot.
FAHClient is nice to have, but you can also use the URL http://localhost:7396/ in any browser to do everything the Client can do
